  3. A compendium of hardware boards to support MySensor nodes
9 Posts 7 Posters 9.3k Views 6 Watching
  • Z Offline
    Z Offline
    Zeph
    wrote on last edited by Zeph
    warning: will continue to be edited
    Please see also: http://forum.mysensors.org/topic/595/pcb-boards-for-mysensors
    (I ran out of steam for now, will return over time. Glad to have help in filling in details, fixing errors, and suggested additional options)
    There are a number of very interesting designs here, and I thought it would be worthwhile to list them, because I start getting confused and others might as well.
    The following are Arduino ATMega compatible using the Nordic nRF24L01+
    In the following , APM = Arduino Pro Mini, Nano = Arduino Nano, nRF = nRF24L01+ module
    First, let's mention the approach documented in the how-to here, combining cheap standard Arduino family boards with the radios.
    • 3.3v APM @ 8Mhz (150ma 3.3v) directly connected to nRF
    • 5V APM @ 16MHz (150ma 5v) with adapter board and reg to connect to nRF
    • 5v/3.3v Nano @ 16 Mhz (150ma 5v, ?? ma 3.3v) directly connected to nRF
    In this case, you add whatever sensors you want externally. The APMs use a ceramic resonator, not sure about the Nano.
    @axilent http://forum.mysensors.org/topic/179/mysensors-battey-board-revision-1-0
    3.3v MySensors Battery Board Rev 1.0 ATMega328p @ 8 Mhz
    Power::
    • 0.7-x.xV boosted to 3.3V @ xx mA by TPS61222DCKT
    • Onboard single AAA holder, externally use 1-2 AA or AAA or whatever
    • solar input connector 0.8-5.5V and solar will be the main power while solar voltage is higher than battery
    Radio: onboard nRF24L01+ chip and antenna
    • CE/CSN/IRQ: @ D8/D9/D7
    Sensors/Actuators:
    • Temp: TMP102AIDRLT accuracy ± 0.5 ° C range -25 ° C +85 ° C with MCU wake up function on alert @ I2C
    • Red LED @ D4
    Connectors:
    • 3 GROVE connectors (D3+D4, A0+A1, I2C=A4+A5) each w power/ground
    • ICSP (MOSI,MISO,CLK,Reset) w power/ground
    Highly optimized for low power. Uses internal 8 MHz RC oscillator. This differs from the rest in that it has the nRF24L01+ chip directly on board (including "?" style antenna) rather than having a socket for nRF module.
    "it can run until discharge to 0.7V regardless of frequency'
    Price likely $15-22 populated, not yet available.
    SeeedStudio DevDuinos http://www.seeedstudio.com/depot/s/devduino.html?search_in_description=0
    3.3v ATMega328p @ 16Mhz
    Power:
    • CR2032 (v1.3) or
    • 2xAAA (v2.0) onboard holders
    Radio: 2x4 socket for nRF module
    • CE/CSN/IRQ:
    Sensors/Actuators:
    • Vin voltage divider @A2
    • Temp: analog MCP9700 (-40 ° C +125 ° C, accuracy of ± 2 ° C) @ A3
    Connectors:
    • 3 GROVE connectors (D2+D3, A0+A1, I2C=A4+A5) each with power/ground
    • ICSP (MOSI,MISO,CLK,Reset) with power/ground
    Size: 30x40mm (V1.3), 30.5x67mm (V2.0)
    nRF modules hang over the PCB (may interfere with GROVE connectors on V1.3)
    "it will work until discharge of a cell to 0.9-1.65V (supplying 1.8-3.3 V) depending on the frequency used"
    Price $17 populated, including nRF module
    ITead mini_rboard http://imall.iteadstudio.com/im140704001.html
    http://forum.mysensors.org/topic/232/rboard-cheap-relay-radio-arduino-board-10
    http://wiki.iteadstudio.com/Mini_Rboard
    Power::
    External 5V
    • CE/CSN/IRQ: D9/D10/D2
    Sensors/Actuators:
    Relay on D4
    Connectors:
    1x6 pin for a 433 Mhz radio
    Size:
    37mm x 49mm
    Price $9.50 plus shipping
    @Bandra http://forum.mysensors.org/topic/205/my-ideal-sensor-node-pcb/3
    piggyback APM 5v or 3.3v
    Power: depends on APM, typ 150ma
    • space for 3.3v boost
    • CE/CSN/IRQ:
    Sensors/Actuators:
    • Temp & humidity: digital DHT-11 @D?
    • Temp: digital DS1820 onewire @ D?
    • Pressure: digital BMP180 @ I2c
    • Light: analog LDR voltage divider @ A?
    Connectors:
    • 5 pin header w D7, D8, A2 and power/ground
    • 3 pin header w D3
    **Size: ** 50x30mm (same as 2xAA holder)
    The nRF module hangs over the APM
    @gregl http://forum.mysensors.org/topic/52/sensor-node-ready-to-buy
    Version 1.2 of DevDuino?
    Power::
    • CE/CSN/IRQ:
    Sensors/Actuators:
    Connectors:
    Size:
    @Mrlynx http://forum.mysensors.org/topic/207/my-sensorboard-mys-1-0beta
    APM 3.3v or 5V
    Power::
    • onboard 3.3v regulator
    Radio: 2x4 socket for nRF module, oriented over the board
    • CE/CSN/IRQ:
    Sensors/Actuators:
    Connectors:
    • 6 pin header with D2,D3,D4,D5 and Vcc/Ground (optional SMD pullup for each)
    • 6 pin header with D6, D7, D8 and Vcc/Ground/3.3v (optional SMD pullup for each)
    • 4 ADC (A0-A3?) (optional SMD voltage divider for each)
    Size:
    @rosskinard http://forum.mysensors.org/topic/56/arduino-nano-gateway-for-vera-pcb-link
    actually a gateway rather than end node but worth mentioning
    Power::
    • CE/CSN/IRQ:
    Sensors/Actuators:
    Connectors:
    Size:
    @clippermiami http://forum.mysensors.org/topic/185/battery-sensor-v-1-0-pcb
    Power::
    • CE/CSN/IRQ:
    Sensors/Actuators:
    Connectors:
    Size:
    N 1 Reply Last reply
    • B Offline
      B Offline
      Bandra
      Nice! Just want to mention that my design has two connectors. The 5 pin one you mention, as well as a 3 pin one that breaks out D3.
      • Z Offline
        Z Offline
        Zeph
        (Reserved for followup)
        • D Offline
          Dvbit
          About the;
          Has anybody tested it with the mysensors vera gateway?
          Does it work?
          For a newbie like me it is attractvive as it requires minmal soldering activities/knowledge
          Thanks for your feedback
          greglG 1 Reply Last reply
          • D Dvbit
            About the;
            Does it work?
            greglG Offline
            greglG Offline
            gregl
            @Dvbit See here: http://forum.mysensors.org/topic/251/devduino-v-2-0-board
            • Z Zeph
              Power::
              Sensors/Actuators:
              • Red LED @ D4
              Connectors:
              Power:
              • CR2032 (v1.3) or
              • CE/CSN/IRQ:
              Sensors/Actuators:
              Connectors:
              Power::
              External 5V
              Sensors/Actuators:
              Relay on D4
              Connectors:
              Size:
              37mm x 49mm
              • CE/CSN/IRQ:
              Sensors/Actuators:
              Connectors:
              • 3 pin header w D3
              Power::
              • CE/CSN/IRQ:
              Sensors/Actuators:
              Connectors:
              Size:
              APM 3.3v or 5V
              Power::
              • CE/CSN/IRQ:
              Sensors/Actuators:
              Connectors:
              Size:
              Power::
              • CE/CSN/IRQ:
              Sensors/Actuators:
              Connectors:
              Size:
              Power::
              • CE/CSN/IRQ:
              Sensors/Actuators:
              Connectors:
              Size:
              N Offline
              N Offline
              Nicola Reina
              wrote on last edited by Nicola Reina
              @Zeph
              Hi what is apm ? Referred in the posta about mrlynx mysens?
              D 1 Reply Last reply
              • N Nicola Reina
                @Zeph
                Dwalt
                @Nicola-Reina said:
                @Zeph
                APM = arduino pro mini
                • F Offline
                  F Offline
                  funky81
                  Keep this post updated...please :+1:
                  Z 1 Reply Last reply
                  • F funky81
                    Z Offline
                    Z Offline
                    Zeph
                    @funky81
                    See the link near the top of the (edited) original post, to a thread which follows up on this one. For board designs created by the community, that thread going to be more up to date (and it tracks some information about what's available).
                    This thread was earlier, but lists commercial options as well, so it's still of some value.
                    I'm thinking to let the other thread keep up with community designs, but if you know of a good commercial offering for our purposes, please leave a reply and I'll add it to the list here.
                    12.0k
