  3. Getting started with Wemos d1 mini & RFM69HW
20 Posts 5 Posters 2.4k Views 6 Watching
  • L
    L
    Les
    Using a very simple sketch (trying to test after all)
    // Enable debug prints
    #define MY_RADIO_RFM69
    #define MY_RFM69_FREQUENCY  RFM69_915MHZ
    #define MY_IS_RFM69HW // Omit if your RFM is not "H"
    #define MY_RFM69_IRQ_PIN D1
    #define MY_RFM69_IRQ_NUM MY_RFM69_IRQ_PIN
    #define MY_RFM69_CS_PIN D8 // NSS. Use MY_RFM69_SPI_CS for older versions (before 2.2.0)
    #define MY_RFM69_NETWORKID  99
    #define MY_BAUD_RATE  115200
    int counter =0;
    // Initialize motion message
    MyMessage msg(CHILD_ID, V_TEMP);
      Serial.println("Setup completed");
    	sendSketchInfo("Test Sensor", "1.0");
    	present(CHILD_ID, S_TEMP);
      Serial.println("Looped");
    //	send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
    	send(msg.set(counter, 1));
    	counter=counter+1;
      sleep(2000);
    If I disconnect the 3v, it doesn't crash just gives the fail message since it can't communicate with the rfm69. As soon as reconnect it crashes :(
    E 1 Reply Last reply
    • L Les
      int counter =0;
      	counter=counter+1;
        sleep(2000);
      E
      E
      evb
      You could try the new RFM69 driver?
      Add to your simple sketch
      #define MY_RFM69_NEW_DRIVER
      Add also some extra debug info
      #define MY_DEBUG_VERBOSE_RFM69
      #define MY_DEBUG_VERBOSE_RFM69_REGISTERS
      Maybe it will reveal something...
      • mfalkviddM
        Be aware that all nodes need to use the same driver. So if you switch to the new driver on the node, you need to switch to the new driver on the gateway as well.
        • L
          L
          Les
          wrote on last edited by Les
          Got some good news. Adding the #define MY_RFM69_NEW_DRIVER and now it doesn't crash! Thanks evb and mfalkvidd for the tips.
          So, now that the wemos with radio is has the above sketch, just a simple send of a number running.
          On the pi I download the main branch, ran:
          ./configure --my-transport=rfm69 --my-rfm69-irq-pin=22 --my-rfm69-cs-pin=24 --my-rfm69-frequency=915 --my-is-rfm69hw
          --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out
          --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mysgw1  --my-mqtt-user=UID
          --my-mqtt-password=password
          then
          make
          sudo ./bin/mysgw
          The output is the same as post 1. They both say they are sending, but neither receive anything. Did I miss some settings? I know in the sketch I specified a network id which I didn't see the option for in the gateway on pi.
          • L Les
            then
            make
            sudo ./bin/mysgw
            @les if the sketch uses a different network id, it will be on a different network. Different networks are, well, different - as in not the same. So there will be no communication between them.
            If you need to set network id, set the define as described on https://www.mysensors.org/build/raspberry#advanced If you don't need to set network id, don't set network id.
            L 1 Reply Last reply
            • K
              K
              kimot
              Why you are using Wemos like normal node with RFM radio?
              I assume you are building ethernet gateway with Wemos and RFM69.
              Simply use my sketch fot gateway and your uno like node and try.
                L
                L
                Les
                @mfalkvidd I figured it had something to do with the network ID, but from what I understand there is no way to specify it on the PI. However in my case I don't need an ID I was just under the impression it was required. So I've removed it. And 1/2 success.
                The Pi when starting mysgw still produces the same startup and sends 1 msg out.
                On the wemos serial output I see it gets 1 msg from the pi but doesn't progress.
                32566 TSM:INIT
                32568 TSM:INIT:TSP OK
                32570 TSM:FPAR
                33075 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                33814 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                35082 !TSM:FPAR:NO REPLY
                35084 TSM:FPAR
                35589 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                37596 !TSM:FPAR:NO REPLY
                37598 TSM:FPAR
                Is there some extra steps required to pair them or get the two to communicate?
                • L
                  L
                  Les
                  also worth noting I am manually running sudo bin/mysgw not as a service. As the instructions sound like it can be tested this way to make sure it is working.
                  • L Les
                    @les yes that's the best way to start the gw when testing/troubleshooting
                    • L Les
                      32566 TSM:INIT
                      32570 TSM:FPAR
                      35084 TSM:FPAR
                      37598 TSM:FPAR
                      @les network id can be specified on the pi, see my previous post for instructions. But not specifying it at all is a better solution for most use cases.
                      • mfalkviddM
                        I think the best next step is to follow @evb's recommendation to add #define MY_DEBUG_VERBOSE_RFM69 to the sketch (and preferably to the gateway as well)
                        • L
                          L
                          Les
                          I'm going to take a stab in the dark that the issue is with the pi node since the wemos received and sent and I don't see any message on the pi for anything being received.
                          With the debuging enabled on the client I get:
                           __  __       ____
                                  |___/                      2.3.1
                          12703 MCO:BGN:INIT NODE,CP=RPNNE---,REL=255,VER=2.3.1
                          12893 TSM:INIT
                          12908 TSF:WUR:MS=0
                          12928 RFM69:INIT
                          12946 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                          12988 RFM69:PTX:LEVEL=5 dBm
                          13017 RFM69:DUMP:Registers Address | HEX value
                          13067 RFM69:DUMP:REG=0x01 Value=0x04
                          13106 RFM69:DUMP:REG=0x02 Value=0x00
                          13145 RFM69:DUMP:REG=0x03 Value=0x02
                          13183 RFM69:DUMP:REG=0x04 Value=0x40
                          13222 RFM69:DUMP:REG=0x05 Value=0x03
                          13261 RFM69:DUMP:REG=0x06 Value=0x33
                          13300 RFM69:DUMP:REG=0x07 Value=0xe4
                          13338 RFM69:DUMP:REG=0x08 Value=0xc0
                          13377 RFM69:DUMP:REG=0x09 Value=0x00
                          13416 RFM69:DUMP:REG=0x0a Value=0x41
                          13454 RFM69:DUMP:REG=0x0b Value=0x00
                          13493 RFM69:DUMP:REG=0x0c Value=0x02
                          13532 RFM69:DUMP:REG=0x0d Value=0x92
                          13570 RFM69:DUMP:REG=0x0e Value=0xf5
                          13609 RFM69:DUMP:REG=0x0f Value=0x20
                          13648 RFM69:DUMP:REG=0x10 Value=0x24
                          13687 RFM69:DUMP:REG=0x11 Value=0x57
                          13725 RFM69:DUMP:REG=0x12 Value=0x09
                          13764 RFM69:DUMP:REG=0x13 Value=0x1a
                          13803 RFM69:DUMP:REG=0x14 Value=0x40
                          13841 RFM69:DUMP:REG=0x15 Value=0xb0
                          13880 RFM69:DUMP:REG=0x16 Value=0x7b
                          13919 RFM69:DUMP:REG=0x17 Value=0x9b
                          13958 RFM69:DUMP:REG=0x18 Value=0x88
                          13996 RFM69:DUMP:REG=0x19 Value=0xe2
                          14035 RFM69:DUMP:REG=0x1a Value=0xe2
                          14074 RFM69:DUMP:REG=0x1b Value=0x40
                          14112 RFM69:DUMP:REG=0x1c Value=0x80
                          14151 RFM69:DUMP:REG=0x1d Value=0x06
                          14190 RFM69:DUMP:REG=0x1e Value=0x10
                          14229 RFM69:DUMP:REG=0x1f Value=0x00
                          14267 RFM69:DUMP:REG=0x20 Value=0x00
                          14306 RFM69:DUMP:REG=0x21 Value=0x00
                          14345 RFM69:DUMP:REG=0x22 Value=0x00
                          14383 RFM69:DUMP:REG=0x23 Value=0x02
                          14422 RFM69:DUMP:REG=0x24 Value=0xff
                          14461 RFM69:DUMP:REG=0x25 Value=0x40
                          14499 RFM69:DUMP:REG=0x26 Value=0x07
                          14538 RFM69:DUMP:REG=0x27 Value=0x80
                          14577 RFM69:DUMP:REG=0x28 Value=0x00
                          14616 RFM69:DUMP:REG=0x29 Value=0xe4
                          14654 RFM69:DUMP:REG=0x2a Value=0x00
                          14693 RFM69:DUMP:REG=0x2b Value=0x00
                          14732 RFM69:DUMP:REG=0x2c Value=0x00
                          14770 RFM69:DUMP:REG=0x2d Value=0x03
                          14809 RFM69:DUMP:REG=0x2e Value=0x88
                          14848 RFM69:DUMP:REG=0x2f Value=0x2d
                          14886 RFM69:DUMP:REG=0x30 Value=0x64
                          14925 RFM69:DUMP:REG=0x31 Value=0x00
                          14964 RFM69:DUMP:REG=0x32 Value=0x00
                          15003 RFM69:DUMP:REG=0x33 Value=0x00
                          15041 RFM69:DUMP:REG=0x34 Value=0x00
                          15080 RFM69:DUMP:REG=0x35 Value=0x00
                          15119 RFM69:DUMP:REG=0x36 Value=0x00
                          15157 RFM69:DUMP:REG=0x37 Value=0xd4
                          15196 RFM69:DUMP:REG=0x38 Value=0x40
                          15235 RFM69:DUMP:REG=0x39 Value=0xff
                          15274 RFM69:DUMP:REG=0x3a Value=0xff
                          15312 RFM69:DUMP:REG=0x3b Value=0x00
                          15351 RFM69:DUMP:REG=0x3c Value=0x05
                          15390 RFM69:DUMP:REG=0x3d Value=0x10
                          15428 RFM69:DUMP:REG=0x3e Value=0x00
                          15467 RFM69:DUMP:REG=0x3f Value=0x00
                          15506 RFM69:DUMP:REG=0x40 Value=0x00
                          15544 RFM69:DUMP:REG=0x41 Value=0x00
                          15583 RFM69:DUMP:REG=0x42 Value=0x00
                          15622 RFM69:DUMP:REG=0x43 Value=0x00
                          15661 RFM69:DUMP:REG=0x44 Value=0x00
                          15699 RFM69:DUMP:REG=0x45 Value=0x00
                          15738 RFM69:DUMP:REG=0x46 Value=0x00
                          15777 RFM69:DUMP:REG=0x47 Value=0x00
                          15815 RFM69:DUMP:REG=0x48 Value=0x00
                          15854 RFM69:DUMP:REG=0x49 Value=0x00
                          15893 RFM69:DUMP:REG=0x4a Value=0x00
                          15931 RFM69:DUMP:REG=0x4b Value=0x00
                          15970 RFM69:DUMP:REG=0x4c Value=0x00
                          16009 RFM69:DUMP:REG=0x4d Value=0x00
                          16048 RFM69:DUMP:REG=0x4e Value=0x01
                          16086 RFM69:DUMP:REG=0x4f Value=0x00
                          16125 TSM:INIT:TSP OK
                          16148 TSM:FPAR
                          16164 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
                          16209 RFM69:CSMA:RSSI=-36
                          16236 RFM69:CSMA:RSSI=-36
                          16264 RFM69:CSMA:RSSI=-36
                          16291 RFM69:CSMA:RSSI=-36
                          16318 RFM69:CSMA:RSSI=-36
                          16345 RFM69:CSMA:RSSI=-36
                          16373 RFM69:CSMA:RSSI=-36
                          16400 RFM69:CSMA:RSSI=-36
                          16427 RFM69:CSMA:RSSI=-36
                          16454 RFM69:CSMA:RSSI=-36
                          16482 RFM69:CSMA:RSSI=-36
                          16509 RFM69:CSMA:RSSI=-36
                          16536 RFM69:CSMA:RSSI=-36
                          16564 RFM69:CSMA:RSSI=-36
                          16591 RFM69:CSMA:RSSI=-36
                          16618 RFM69:CSMA:RSSI=-36
                          16645 RFM69:CSMA:RSSI=-36
                          16673 RFM69:CSMA:RSSI=-36
                          16700 RFM69:CSMA:RSSI=-36
                          16730 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          18810 !TSM:FPAR:NO REPLY
                          18836 TSM:FPAR
                          18851 RFM69:SWR:SEND,TO=255,SEQ=1,RETRY=0
                          18897 RFM69:CSMA:RSSI=-36
                          18924 RFM69:CSMA:RSSI=-36
                          18951 RFM69:CSMA:RSSI=-36
                          18978 RFM69:CSMA:RSSI=-36
                          19006 RFM69:CSMA:RSSI=-36
                          19033 RFM69:CSMA:RSSI=-36
                          19060 RFM69:CSMA:RSSI=-36
                          19087 RFM69:CSMA:RSSI=-36
                          19115 RFM69:CSMA:RSSI=-36
                          19142 RFM69:CSMA:RSSI=-36
                          19169 RFM69:CSMA:RSSI=-36
                          19196 RFM69:CSMA:RSSI=-36
                          19224 RFM69:CSMA:RSSI=-36
                          19251 RFM69:CSMA:RSSI=-36
                          19278 RFM69:CSMA:RSSI=-36
                          19305 RFM69:CSMA:RSSI=-36
                          19333 RFM69:CSMA:RSSI=-36
                          19360 RFM69:CSMA:RSSI=-36
                          19387 RFM69:CSMA:RSSI=-36
                          19418 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          20911 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                          21497 !TSM:FPAR:NO REPLY
                          21523 TSM:FPAR
                          21538 RFM69:SWR:SEND,TO=255,SEQ=2,RETRY=0
                          21584 RFM69:CSMA:RSSI=-36
                          21611 RFM69:CSMA:RSSI=-36
                          21638 RFM69:CSMA:RSSI=-36
                          21665 RFM69:CSMA:RSSI=-36
                          21693 RFM69:CSMA:RSSI=-36
                          21720 RFM69:CSMA:RSSI=-36
                          21747 RFM69:CSMA:RSSI=-36
                          21774 RFM69:CSMA:RSSI=-36
                          21802 RFM69:CSMA:RSSI=-36
                          21829 RFM69:CSMA:RSSI=-36
                          21856 RFM69:CSMA:RSSI=-36
                          21883 RFM69:CSMA:RSSI=-36
                          21911 RFM69:CSMA:RSSI=-36
                          21938 RFM69:CSMA:RSSI=-36
                          21965 RFM69:CSMA:RSSI=-36
                          21992 RFM69:CSMA:RSSI=-36
                          22020 RFM69:CSMA:RSSI=-36
                          22047 RFM69:CSMA:RSSI=-36
                          22074 RFM69:CSMA:RSSI=-36
                          22105 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          24184 !TSM:FPAR:NO REPLY
                          24210 TSM:FPAR
                          24225 RFM69:SWR:SEND,TO=255,SEQ=3,RETRY=0
                          24271 RFM69:CSMA:RSSI=-36
                          24298 RFM69:CSMA:RSSI=-36
                          24325 RFM69:CSMA:RSSI=-36
                          24352 RFM69:CSMA:RSSI=-36
                          24380 RFM69:CSMA:RSSI=-36
                          24407 RFM69:CSMA:RSSI=-36
                          24434 RFM69:CSMA:RSSI=-36
                          24461 RFM69:CSMA:RSSI=-36
                          24489 RFM69:CSMA:RSSI=-36
                          24516 RFM69:CSMA:RSSI=-36
                          24543 RFM69:CSMA:RSSI=-36
                          24570 RFM69:CSMA:RSSI=-36
                          24598 RFM69:CSMA:RSSI=-36
                          24625 RFM69:CSMA:RSSI=-36
                          24652 RFM69:CSMA:RSSI=-36
                          24679 RFM69:CSMA:RSSI=-36
                          24707 RFM69:CSMA:RSSI=-36
                          24734 RFM69:CSMA:RSSI=-36
                          24761 RFM69:CSMA:RSSI=-36
                          24792 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          26871 !TSM:FPAR:FAIL
                          26893 TSM:FAIL:CNT=1
                          26915 TSM:FAIL:DIS
                          26934 TSF:TDI:TSL
                          26953 RFM69:RSL
                          On the pi, in /etc/mysensors.conf it has
                          verbose=debug
                          Not sure if it needs to be set elsewhere.
                          Always produces this initialization, 1 sent message and just sits there.
                          Jul 30 16:51:25 INFO  Starting gateway...
                          Jul 30 16:51:25 INFO  Protocol version - 2.3.2-beta
                          Jul 30 16:51:25 DEBUG MCO:BGN:INIT GW,CP=RPNGL---,FQ=NA,REL=6,VER=2.3.2-beta
                          Jul 30 16:51:25 DEBUG TSF:LRT:OK
                          Jul 30 16:51:25 DEBUG TSM:INIT
                          Jul 30 16:51:25 DEBUG TSF:WUR:MS=0
                          Jul 30 16:51:25 DEBUG TSM:INIT:TSP OK
                          Jul 30 16:51:25 DEBUG TSM:INIT:GW MODE
                          Jul 30 16:51:25 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
                          Jul 30 16:51:25 DEBUG MCO:REG:NOT NEEDED
                          Jul 30 16:51:25 DEBUG MCO:BGN:STP
                          Jul 30 16:51:25 DEBUG MCO:BGN:INIT OK,TSP=1
                          Jul 30 16:51:25 DEBUG GWT:RMQ:CONNECTING...
                          Jul 30 16:51:25 DEBUG connected to 127.0.0.1
                          Jul 30 16:51:25 DEBUG GWT:RMQ:OK
                          Jul 30 16:51:25 DEBUG GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
                          Jul 30 16:51:25 DEBUG TSM:READY:NWD REQ
                          Jul 30 16:51:27 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                          • L
                            L
                            Les
                            Also I should mention I saw in the posts it says that some version of raspbian don't play with MySensors, so I've used main branch 2.3.1 and development 2.3.2 beta on Pi. Same results.
                            • E
                              E
                              evb
                              @Les, I'm still learning also :-)
                              In your first post you mentioned the wemos - rfm69hw hardware connections:
                              GND GND
                              3.3V VCC
                              D1 DIO0
                              D5 SCK
                              D6 MISO
                              D7 MOSI
                              D8 NSS
                              In previous posts, you mentioned in your sketch:
                              But in the latest debug output, I see:
                              Your CS/NSS pin is now on D15 and the IRQ pin on D5?
                              @mfalkvidd: or must I interpret these numbers different?
                              (I don't want to hijack this thread, but I've the same problem with my SAMD21 M0 board, see my thread in the same section ;-) )
                              • E evb
                                GND GND
                                3.3V VCC
                                D1 DIO0
                                D5 SCK
                                D6 MISO
                                D7 MOSI
                                D8 NSS
                                @evb D1, D8, etc are just macros or variables. They (normally) resolve to numbers. What numbers they resolve to (and which macros are available) is set by the board files in the Arduino IDE.
                                I am not familiar with the M0 boards, but here is an example of what the macros look like: https://github.com/arduino/ArduinoCore-samd/blob/master/variants/arduino_mzero/variant.h
                                Here is a big table with numbers and pins for Arduino M0.
                                Here are the macros for D1 Mini: https://github.com/esp8266/Arduino/blob/master/variants/d1_mini/pins_arduino.h
                                Excerpt from that file:
                                static const uint8_t D8   = 15;
                                The macros are replaced with their real values when compiling. So the debug output can only show the number, it can not show what macro was used. That's why the debug output shows 15 instead of D8.
                                • L
                                  L
                                  Les
                                  Yes D8 = pin 15 :)
                                  So any ideas on why the raspberry pi isn't sending parent information or "listening/responding" to the wemos?
                                  As a side sanity check I will try a different raspberry pi. Can someone confirm the pins on Pi2/3?
                                  Power - 1
                                  Mosi -19
                                  Miso -21
                                  DIO - 22
                                  Clk - 23
                                  NSS - 24
                                  GND - 25
