  3. Getting started with Wemos d1 mini & RFM69HW
20 Posts 5 Posters 2.4k Views 6 Watching
  • mfalkviddM
    Be aware that all nodes need to use the same driver. So if you switch to the new driver on the node, you need to switch to the new driver on the gateway as well.
    • L
      L
      Les
      wrote on last edited by Les
      Got some good news. Adding the #define MY_RFM69_NEW_DRIVER and now it doesn't crash! Thanks evb and mfalkvidd for the tips.
      So, now that the wemos with radio is has the above sketch, just a simple send of a number running.
      On the pi I download the main branch, ran:
      ./configure --my-transport=rfm69 --my-rfm69-irq-pin=22 --my-rfm69-cs-pin=24 --my-rfm69-frequency=915 --my-is-rfm69hw
      --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out
      --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mysgw1  --my-mqtt-user=UID
      --my-mqtt-password=password
      then
      make
      sudo ./bin/mysgw
      The output is the same as post 1. They both say they are sending, but neither receive anything. Did I miss some settings? I know in the sketch I specified a network id which I didn't see the option for in the gateway on pi.
      • L Les
        then
        make
        sudo ./bin/mysgw
        @les if the sketch uses a different network id, it will be on a different network. Different networks are, well, different - as in not the same. So there will be no communication between them.
        If you need to set network id, set the define as described on https://www.mysensors.org/build/raspberry#advanced If you don't need to set network id, don't set network id.
        L 1 Reply Last reply
        • K
          K
          kimot
          Why you are using Wemos like normal node with RFM radio?
          I assume you are building ethernet gateway with Wemos and RFM69.
          Simply use my sketch fot gateway and your uno like node and try.
            L
            L
            Les
            @mfalkvidd I figured it had something to do with the network ID, but from what I understand there is no way to specify it on the PI. However in my case I don't need an ID I was just under the impression it was required. So I've removed it. And 1/2 success.
            The Pi when starting mysgw still produces the same startup and sends 1 msg out.
            On the wemos serial output I see it gets 1 msg from the pi but doesn't progress.
            32566 TSM:INIT
            32568 TSM:INIT:TSP OK
            32570 TSM:FPAR
            33075 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            33814 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
            35082 !TSM:FPAR:NO REPLY
            35084 TSM:FPAR
            35589 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            37596 !TSM:FPAR:NO REPLY
            37598 TSM:FPAR
            Is there some extra steps required to pair them or get the two to communicate?
            • L
              L
              Les
              also worth noting I am manually running sudo bin/mysgw not as a service. As the instructions sound like it can be tested this way to make sure it is working.
              • L Les
                @les yes that's the best way to start the gw when testing/troubleshooting
                • L Les
                  32566 TSM:INIT
                  32570 TSM:FPAR
                  35084 TSM:FPAR
                  37598 TSM:FPAR
                  @les network id can be specified on the pi, see my previous post for instructions. But not specifying it at all is a better solution for most use cases.
                  • mfalkviddM
                    I think the best next step is to follow @evb's recommendation to add #define MY_DEBUG_VERBOSE_RFM69 to the sketch (and preferably to the gateway as well)
                    • L
                      L
                      Les
                      I'm going to take a stab in the dark that the issue is with the pi node since the wemos received and sent and I don't see any message on the pi for anything being received.
                      With the debuging enabled on the client I get:
                       __  __       ____
                              |___/                      2.3.1
                      12703 MCO:BGN:INIT NODE,CP=RPNNE---,REL=255,VER=2.3.1
                      12893 TSM:INIT
                      12908 TSF:WUR:MS=0
                      12928 RFM69:INIT
                      12946 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                      12988 RFM69:PTX:LEVEL=5 dBm
                      13017 RFM69:DUMP:Registers Address | HEX value
                      13067 RFM69:DUMP:REG=0x01 Value=0x04
                      13106 RFM69:DUMP:REG=0x02 Value=0x00
                      13145 RFM69:DUMP:REG=0x03 Value=0x02
                      13183 RFM69:DUMP:REG=0x04 Value=0x40
                      13222 RFM69:DUMP:REG=0x05 Value=0x03
                      13261 RFM69:DUMP:REG=0x06 Value=0x33
                      13300 RFM69:DUMP:REG=0x07 Value=0xe4
                      13338 RFM69:DUMP:REG=0x08 Value=0xc0
                      13377 RFM69:DUMP:REG=0x09 Value=0x00
                      13416 RFM69:DUMP:REG=0x0a Value=0x41
                      13454 RFM69:DUMP:REG=0x0b Value=0x00
                      13493 RFM69:DUMP:REG=0x0c Value=0x02
                      13532 RFM69:DUMP:REG=0x0d Value=0x92
                      13570 RFM69:DUMP:REG=0x0e Value=0xf5
                      13609 RFM69:DUMP:REG=0x0f Value=0x20
                      13648 RFM69:DUMP:REG=0x10 Value=0x24
                      13687 RFM69:DUMP:REG=0x11 Value=0x57
                      13725 RFM69:DUMP:REG=0x12 Value=0x09
                      13764 RFM69:DUMP:REG=0x13 Value=0x1a
                      13803 RFM69:DUMP:REG=0x14 Value=0x40
                      13841 RFM69:DUMP:REG=0x15 Value=0xb0
                      13880 RFM69:DUMP:REG=0x16 Value=0x7b
                      13919 RFM69:DUMP:REG=0x17 Value=0x9b
                      13958 RFM69:DUMP:REG=0x18 Value=0x88
                      13996 RFM69:DUMP:REG=0x19 Value=0xe2
                      14035 RFM69:DUMP:REG=0x1a Value=0xe2
                      14074 RFM69:DUMP:REG=0x1b Value=0x40
                      14112 RFM69:DUMP:REG=0x1c Value=0x80
                      14151 RFM69:DUMP:REG=0x1d Value=0x06
                      14190 RFM69:DUMP:REG=0x1e Value=0x10
                      14229 RFM69:DUMP:REG=0x1f Value=0x00
                      14267 RFM69:DUMP:REG=0x20 Value=0x00
                      14306 RFM69:DUMP:REG=0x21 Value=0x00
                      14345 RFM69:DUMP:REG=0x22 Value=0x00
                      14383 RFM69:DUMP:REG=0x23 Value=0x02
                      14422 RFM69:DUMP:REG=0x24 Value=0xff
                      14461 RFM69:DUMP:REG=0x25 Value=0x40
                      14499 RFM69:DUMP:REG=0x26 Value=0x07
                      14538 RFM69:DUMP:REG=0x27 Value=0x80
                      14577 RFM69:DUMP:REG=0x28 Value=0x00
                      14616 RFM69:DUMP:REG=0x29 Value=0xe4
                      14654 RFM69:DUMP:REG=0x2a Value=0x00
                      14693 RFM69:DUMP:REG=0x2b Value=0x00
                      14732 RFM69:DUMP:REG=0x2c Value=0x00
                      14770 RFM69:DUMP:REG=0x2d Value=0x03
                      14809 RFM69:DUMP:REG=0x2e Value=0x88
                      14848 RFM69:DUMP:REG=0x2f Value=0x2d
                      14886 RFM69:DUMP:REG=0x30 Value=0x64
                      14925 RFM69:DUMP:REG=0x31 Value=0x00
                      14964 RFM69:DUMP:REG=0x32 Value=0x00
                      15003 RFM69:DUMP:REG=0x33 Value=0x00
                      15041 RFM69:DUMP:REG=0x34 Value=0x00
                      15080 RFM69:DUMP:REG=0x35 Value=0x00
                      15119 RFM69:DUMP:REG=0x36 Value=0x00
                      15157 RFM69:DUMP:REG=0x37 Value=0xd4
                      15196 RFM69:DUMP:REG=0x38 Value=0x40
                      15235 RFM69:DUMP:REG=0x39 Value=0xff
                      15274 RFM69:DUMP:REG=0x3a Value=0xff
                      15312 RFM69:DUMP:REG=0x3b Value=0x00
                      15351 RFM69:DUMP:REG=0x3c Value=0x05
                      15390 RFM69:DUMP:REG=0x3d Value=0x10
                      15428 RFM69:DUMP:REG=0x3e Value=0x00
                      15467 RFM69:DUMP:REG=0x3f Value=0x00
                      15506 RFM69:DUMP:REG=0x40 Value=0x00
                      15544 RFM69:DUMP:REG=0x41 Value=0x00
                      15583 RFM69:DUMP:REG=0x42 Value=0x00
                      15622 RFM69:DUMP:REG=0x43 Value=0x00
                      15661 RFM69:DUMP:REG=0x44 Value=0x00
                      15699 RFM69:DUMP:REG=0x45 Value=0x00
                      15738 RFM69:DUMP:REG=0x46 Value=0x00
                      15777 RFM69:DUMP:REG=0x47 Value=0x00
                      15815 RFM69:DUMP:REG=0x48 Value=0x00
                      15854 RFM69:DUMP:REG=0x49 Value=0x00
                      15893 RFM69:DUMP:REG=0x4a Value=0x00
                      15931 RFM69:DUMP:REG=0x4b Value=0x00
                      15970 RFM69:DUMP:REG=0x4c Value=0x00
                      16009 RFM69:DUMP:REG=0x4d Value=0x00
                      16048 RFM69:DUMP:REG=0x4e Value=0x01
                      16086 RFM69:DUMP:REG=0x4f Value=0x00
                      16125 TSM:INIT:TSP OK
                      16148 TSM:FPAR
                      16164 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
                      16209 RFM69:CSMA:RSSI=-36
                      16236 RFM69:CSMA:RSSI=-36
                      16264 RFM69:CSMA:RSSI=-36
                      16291 RFM69:CSMA:RSSI=-36
                      16318 RFM69:CSMA:RSSI=-36
                      16345 RFM69:CSMA:RSSI=-36
                      16373 RFM69:CSMA:RSSI=-36
                      16400 RFM69:CSMA:RSSI=-36
                      16427 RFM69:CSMA:RSSI=-36
                      16454 RFM69:CSMA:RSSI=-36
                      16482 RFM69:CSMA:RSSI=-36
                      16509 RFM69:CSMA:RSSI=-36
                      16536 RFM69:CSMA:RSSI=-36
                      16564 RFM69:CSMA:RSSI=-36
                      16591 RFM69:CSMA:RSSI=-36
                      16618 RFM69:CSMA:RSSI=-36
                      16645 RFM69:CSMA:RSSI=-36
                      16673 RFM69:CSMA:RSSI=-36
                      16700 RFM69:CSMA:RSSI=-36
                      16730 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      18810 !TSM:FPAR:NO REPLY
                      18836 TSM:FPAR
                      18851 RFM69:SWR:SEND,TO=255,SEQ=1,RETRY=0
                      18897 RFM69:CSMA:RSSI=-36
                      18924 RFM69:CSMA:RSSI=-36
                      18951 RFM69:CSMA:RSSI=-36
                      18978 RFM69:CSMA:RSSI=-36
                      19006 RFM69:CSMA:RSSI=-36
                      19033 RFM69:CSMA:RSSI=-36
                      19060 RFM69:CSMA:RSSI=-36
                      19087 RFM69:CSMA:RSSI=-36
                      19115 RFM69:CSMA:RSSI=-36
                      19142 RFM69:CSMA:RSSI=-36
                      19169 RFM69:CSMA:RSSI=-36
                      19196 RFM69:CSMA:RSSI=-36
                      19224 RFM69:CSMA:RSSI=-36
                      19251 RFM69:CSMA:RSSI=-36
                      19278 RFM69:CSMA:RSSI=-36
                      19305 RFM69:CSMA:RSSI=-36
                      19333 RFM69:CSMA:RSSI=-36
                      19360 RFM69:CSMA:RSSI=-36
                      19387 RFM69:CSMA:RSSI=-36
                      19418 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      20911 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                      21497 !TSM:FPAR:NO REPLY
                      21523 TSM:FPAR
                      21538 RFM69:SWR:SEND,TO=255,SEQ=2,RETRY=0
                      21584 RFM69:CSMA:RSSI=-36
                      21611 RFM69:CSMA:RSSI=-36
                      21638 RFM69:CSMA:RSSI=-36
                      21665 RFM69:CSMA:RSSI=-36
                      21693 RFM69:CSMA:RSSI=-36
                      21720 RFM69:CSMA:RSSI=-36
                      21747 RFM69:CSMA:RSSI=-36
                      21774 RFM69:CSMA:RSSI=-36
                      21802 RFM69:CSMA:RSSI=-36
                      21829 RFM69:CSMA:RSSI=-36
                      21856 RFM69:CSMA:RSSI=-36
                      21883 RFM69:CSMA:RSSI=-36
                      21911 RFM69:CSMA:RSSI=-36
                      21938 RFM69:CSMA:RSSI=-36
                      21965 RFM69:CSMA:RSSI=-36
                      21992 RFM69:CSMA:RSSI=-36
                      22020 RFM69:CSMA:RSSI=-36
                      22047 RFM69:CSMA:RSSI=-36
                      22074 RFM69:CSMA:RSSI=-36
                      22105 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      24184 !TSM:FPAR:NO REPLY
                      24210 TSM:FPAR
                      24225 RFM69:SWR:SEND,TO=255,SEQ=3,RETRY=0
                      24271 RFM69:CSMA:RSSI=-36
                      24298 RFM69:CSMA:RSSI=-36
                      24325 RFM69:CSMA:RSSI=-36
                      24352 RFM69:CSMA:RSSI=-36
                      24380 RFM69:CSMA:RSSI=-36
                      24407 RFM69:CSMA:RSSI=-36
                      24434 RFM69:CSMA:RSSI=-36
                      24461 RFM69:CSMA:RSSI=-36
                      24489 RFM69:CSMA:RSSI=-36
                      24516 RFM69:CSMA:RSSI=-36
                      24543 RFM69:CSMA:RSSI=-36
                      24570 RFM69:CSMA:RSSI=-36
                      24598 RFM69:CSMA:RSSI=-36
                      24625 RFM69:CSMA:RSSI=-36
                      24652 RFM69:CSMA:RSSI=-36
                      24679 RFM69:CSMA:RSSI=-36
                      24707 RFM69:CSMA:RSSI=-36
                      24734 RFM69:CSMA:RSSI=-36
                      24761 RFM69:CSMA:RSSI=-36
                      24792 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      26871 !TSM:FPAR:FAIL
                      26893 TSM:FAIL:CNT=1
                      26915 TSM:FAIL:DIS
                      26934 TSF:TDI:TSL
                      26953 RFM69:RSL
                      On the pi, in /etc/mysensors.conf it has
                      verbose=debug
                      Not sure if it needs to be set elsewhere.
                      Always produces this initialization, 1 sent message and just sits there.
                      Jul 30 16:51:25 INFO  Starting gateway...
                      Jul 30 16:51:25 INFO  Protocol version - 2.3.2-beta
                      Jul 30 16:51:25 DEBUG MCO:BGN:INIT GW,CP=RPNGL---,FQ=NA,REL=6,VER=2.3.2-beta
                      Jul 30 16:51:25 DEBUG TSF:LRT:OK
                      Jul 30 16:51:25 DEBUG TSM:INIT
                      Jul 30 16:51:25 DEBUG TSF:WUR:MS=0
                      Jul 30 16:51:25 DEBUG TSM:INIT:TSP OK
                      Jul 30 16:51:25 DEBUG TSM:INIT:GW MODE
                      Jul 30 16:51:25 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
                      Jul 30 16:51:25 DEBUG MCO:REG:NOT NEEDED
                      Jul 30 16:51:25 DEBUG MCO:BGN:STP
                      Jul 30 16:51:25 DEBUG MCO:BGN:INIT OK,TSP=1
                      Jul 30 16:51:25 DEBUG GWT:RMQ:CONNECTING...
                      Jul 30 16:51:25 DEBUG connected to 127.0.0.1
                      Jul 30 16:51:25 DEBUG GWT:RMQ:OK
                      Jul 30 16:51:25 DEBUG GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
                      Jul 30 16:51:25 DEBUG TSM:READY:NWD REQ
                      Jul 30 16:51:27 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                      • L
                        L
                        Les
                        Also I should mention I saw in the posts it says that some version of raspbian don't play with MySensors, so I've used main branch 2.3.1 and development 2.3.2 beta on Pi. Same results.
                        • E
                          E
                          evb
                          @Les, I'm still learning also :-)
                          In your first post you mentioned the wemos - rfm69hw hardware connections:
                          GND GND
                          3.3V VCC
                          D1 DIO0
                          D5 SCK
                          D6 MISO
                          D7 MOSI
                          D8 NSS
                          In previous posts, you mentioned in your sketch:
                          #define MY_RFM69_IRQ_PIN D1
                          #define MY_RFM69_IRQ_NUM MY_RFM69_IRQ_PIN
                          #define MY_RFM69_CS_PIN D8
                          But in the latest debug output, I see:
                          Your CS/NSS pin is now on D15 and the IRQ pin on D5?
                          @mfalkvidd: or must I interpret these numbers different?
                          (I don't want to hijack this thread, but I've the same problem with my SAMD21 M0 board, see my thread in the same section ;-) )
                          • E evb
                            GND GND
                            3.3V VCC
                            D1 DIO0
                            D5 SCK
                            D6 MISO
                            D7 MOSI
                            D8 NSS
                            @evb D1, D8, etc are just macros or variables. They (normally) resolve to numbers. What numbers they resolve to (and which macros are available) is set by the board files in the Arduino IDE.
                            I am not familiar with the M0 boards, but here is an example of what the macros look like: https://github.com/arduino/ArduinoCore-samd/blob/master/variants/arduino_mzero/variant.h
                            Here is a big table with numbers and pins for Arduino M0.
                            Here are the macros for D1 Mini: https://github.com/esp8266/Arduino/blob/master/variants/d1_mini/pins_arduino.h
                            Excerpt from that file:
                            static const uint8_t D8   = 15;
                            The macros are replaced with their real values when compiling. So the debug output can only show the number, it can not show what macro was used. That's why the debug output shows 15 instead of D8.
                            • L
                              L
                              Les
                              Yes D8 = pin 15 :)
                              So any ideas on why the raspberry pi isn't sending parent information or "listening/responding" to the wemos?
                              As a side sanity check I will try a different raspberry pi. Can someone confirm the pins on Pi2/3?
                              Power - 1
                              Mosi -19
                              Miso -21
                              DIO - 22
                              Clk - 23
                              NSS - 24
                              GND - 25
