  3. MySensors shield and RGBW Controller
66 Posts 16 Posters 41.8k Views 21 Watching
  • A
    activemind
    @LastSamurai Thats a bummer that there are no current limiting ressistor. They are a must with any kind of RGB flood. Hmmm!
    I understand why you did not need them because you are primarily driving strips and not RGB floods!
    Maybe you can add them to your TODO list for the next rev as optional components.
    Yeah, I installed KiCad and now need to load your files to see if I can stumble my way around :-)
    -AM
    L 1 Reply Last reply
    • A activemind
      -AM
      L
      L
      LastSamurai
      @activemind Yes, I will include that in my next version (whenever that will be^^). You could just add them "after" the board before connection the actual RGB lights though (if you use TH components).
      Ok have fun ;) If you have questions feel free to send me a message here.
      • A
        activemind
        @LastSamurai Thanks for the offer. I might take you up on it though :-P
        I think I am going to start another thread once I have something meaningful to update.
        -AM
        • L
          L
          LastSamurai
          Just a short update: I now have 5 of these controllers controlling different led strips in my apartment. They are all working without a problem (some of them for nearly half a year now).
          I did some small updates to the code (which you can get via github) and will try to update the pcb later to fix that one annoying error with the mosfets.
          • L
            L
            LastSamurai
            I will try to upload the changed pcb tomorrow. Today I added my sensor platform that I am currently using with a motion sensor to light up a room when someone enters.
            I will also try to add some pictures of my current setup soon.
            Here is the sensor platform: https://www.openhardware.io/view/261
            J 1 Reply Last reply
            • L LastSamurai
              J
              J
              Jan Gatzke
              @LastSamurai
              I tried the new version of the pcb. I think the hardware is just working fine. However I have a problem with the sketch or domoticz. I can switch the light on and off. This switches all channels. So the FETs and the Arduino seem to work fine. I can dim the light, too. What does not work is the color selection with domoticz. If I select another color nothing happens. All 4 channels seem to habe the same level all the time. Any idea?
              • L
                L
                LastSamurai
                @Jan-Gatzke Was this due to the error in my fading code? Otherwise you have to connect a serial to usb controller to the node and check what the converter method does that converts domoticz to RGBW values.
                • L LastSamurai
                  J
                  J
                  Jan Gatzke
                  @LastSamurai
                  Yes, this was the problem we already discussed in the other thread.
                  • pepsonP
                    pepsonP
                    pepson
                    Hi
                    Is anybody who can help me how add phisical button to enable from the wall leds only in color white ?
                    Button will be connect to pin in arduino but how implement it to code sketch ? I want to on/off white color without gateway... example gateway not working....
                    franz-unixF 1 Reply Last reply
                    • pepsonP pepson
                      Hi
                      franz-unixF
                      franz-unixF
                      franz-unix
                      @pepson Hi, not sure if it is exactly what you are looking for, but this firmware
                      https://github.com/d-diot/d-diot-nano-repeater
                      Can turn a RGB led strip on and off with a button press. To force white color you need to customize the code.
                      • pepsonP
                        pepsonP
                        pepson
                        But I need code in sketch to upload by Arduino IDE...
                        • K kalle
                          How many LEDs do you want drive with this controller, because the MOSFET has a limit of 4.6A.
                          A full bright white LED (like a SMD5050) can have ~60mA current - so you can drive save 70 LEDs on a strip with this controller.
                          But anyway, nice design :-)
                          P
                          P
                          pichaty
                          Banned
                          wrote on last edited by pichaty
                          #65
                          • TRS-80T
                            TRS-80T
                            TRS-80
                            wrote on last edited by TRS-80
                            #66
                            @LastSamurai,
                            Very nice project you have here! Thank you for taking the time to post/share your work!
                            At first I thought it might be exactly what I was looking for, but reading through everything now I am not so sure.
                            I have been studying various ways (Wi-Fi, 433/315 Mhz RF, MySensors) to implement controlling RGB lights and I initially thought Wi-Fi (while readily available, easy, and cheap) might be too "slow" in response time, which got me thinking to use MySensors (with NRF24) instead, which led me to this thread (among others).
                            Something concerned me though, I see in your GitHub for this project you stated:
                            Project frozen/final - This project is done from my side. It has been working for years but I switched to another solution so I won't update this anymore.
                            and on your OpenHardware page:
                            Update2: They have been running for about 2 years now mostly without problems. The only disadvantage is that my Mysensors network overall is quite "slow" (~1s reaction time). I am currently experimenting with Wifi RGBWW controllers (H801) so there wont be to many more updates to this project
                            Which made me want to ask you what you are using now?
                            It seems to me that those MagicHome type Wi-Fi (or RF) RGB controllers would be pretty hard to beat price wise, I don't think I could implement similar functionality (including packaging, etc.) for the same amount of money, and that's before even counting my time.
                            Also I am still struggling with reliability of my MySensors network in general, but I hope to be able to still solve this as it seems that many others have been able to (but that is a different subject altogether).
