  3. Encryption with RFM69 [solved]
13 Posts 3 Posters 2.0k Views 3 Watching
  • AnticimexA Anticimex
    @les here are all the security related flags documentation.
    L
    L
    Les
    @anticimex Thanks for the tips. I did review those pages and based on that it seems that #define MY_SECURITY_SIMPLE_PASSWD "yourpassword" is all that would be required unless you would like to personalize. I would like to keep it simple though.
    AnticimexA 1 Reply Last reply
    • L Les
      AnticimexA
      AnticimexA
      Anticimex
      @les right, but you also write that you were interested in encryption and not signing, so it is not the correct flag in that case. And also, note that you need the same flag on all nodes and gw if you use one that enable encryption.
      L 1 Reply Last reply
        L
        L
        Les
        @anticimex according to the documentation
        MY_SECURITY_SIMPLE_PASSWD Enables security (signing and encryption) without the need for personalization
        So the connection should be encrypted and signed without anything else (other than putting the same define statement on all nodes with the same password).
        • L Les
          AnticimexA
          AnticimexA
          Anticimex
          @les correct.
          Have you checked the troubleshooting section in the docs regarding signibg issues? There is also a more verbose debug flag available.
          • L
            L
            Les
            @anticimex said in Encryption with RFM69:
            I see that now, will give it a shot.
            • K
              K
              kimot
              #define MY_RFM69_ENABLE_ENCRYPTION
              All nodes and gateway must have this enabled, and all must be personalized with the same AES key.
              You need a helper-sketch specifically for this purpose
              • SecurityPersonalizer.ino
              • K kimot
                L
                L
                Les
                @kimot Ok, thanks for that info, I thought with MY_SECURITY_SIMPLE_PASSWD you didn't need to personalize. If I'm reading the instruction properly flash securitypersonal.ino to device, copy out the key and then paste to all nodes. Which sounds simple. Have I missed anything?
                • L Les
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @les correct, no personalization needed. But with that flag, all nodes in your network need to share it. And memory requirements increase significantly so pay attention to the compiler log regarding warnings on memory use.
                  • L
                    L
                    Les
                    I added the following to the top of my code:
                    #define MY_SECURITY_SIMPLE_PASSWD "testpass"
                    And it works now....not sure if having the Security above the radio information helped, but it does work now :)
                    • L Les
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @les great! We'll, the debug flags should not help getting things to work, only provide additional information if it doesn't.
                      All configuration flags need to be placed prior to any header include directives. Else they will have no effect.
                      Anyway, glad it worked out in the end.
