  3. Signing fails due to NACKed messages
11 Posts 3 Posters 1.5k Views 2 Watching
  • EncryptE
    EncryptE
    Encrypt
    Hello!
    I've just noticed in the logs I provided that the node doesn't respond to network discovery requests... So I'd say there is definitely something wrong with my setup now...
    I rebooted the gateway and the node and it is working again...
    I guess the issue is temporarily resolved.
    I have a question: does the TX/RX power of the (RFM69W) radio automatically changes over time, depending on signal quality?
    I think I've read that somewhere on the MySensors forums but I may be wrong.
    If it does, maybe the radio signal was automatically set to a too low value at some point?
    Come have fun with me on IRC: #mysensors on Libera.chat :)
    • EncryptE
      EncryptE
      Encrypt
      wrote on last edited by Encrypt
      Hello!
      The issue persists finally, but network discovery seems to be working, it seems... Here are relevant logs:
      Nov 14 21:32:00 DEBUG TSM:READY:NWD REQ
      Nov 14 21:32:00 DEBUG TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
      Nov 14 21:32:00 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=21,pt=1,l=1,sg=1:0
      Nov 14 21:41:59 DEBUG TSF:SRT:OK
      Nov 14 21:42:00 DEBUG TSF:SAN:OK
      Nov 14 21:52:00 DEBUG TSM:READY:NWD REQ
      Nov 14 21:52:00 DEBUG TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
      Nov 14 21:52:00 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=21,pt=1,l=1,sg=1:0
      Nov 14 21:57:00 DEBUG TSF:SAN:OK
      Nov 14 22:00:00 DEBUG !TSF:MSG:SEND,0-0-2-2,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=NACK:
      Nov 14 22:00:00 DEBUG !TSF:MSG:SIGN FAIL
      Nov 14 22:00:00 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
      Nov 14 22:00:41 DEBUG TSF:MSG:SEND,0-0-2-2,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
      Nov 14 22:00:42 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
      Nov 14 22:00:42 DEBUG TSF:MSG:SEND,0-0-2-2,s=0,c=1,t=3,pt=0,l=1,sg=1,ft=0,st=OK:6
      Nov 14 22:00:43 DEBUG TSF:MSG:SEND,0-0-2-2,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
      Nov 14 22:00:43 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
      Nov 14 22:00:43 DEBUG TSF:MSG:SEND,0-0-2-2,s=0,c=1,t=3,pt=0,l=1,sg=1,ft=0,st=OK:3
      As you can see, the heater was supposed to go into "Eco" mode at 22:00:00 but signing failed.
      It seems that the nonce was received though, but the nonce request wasn't acknowledged...
      At 22:00:43, I changed manually the mode to "Off" and to "Eco" again (in HomeAssistant) and it finally worked...
      Do you have any clue why this is happening?
      Maybe @Anticimex -- the awesome security guy of MySensors -- has an idea? :P
      AnticimexA 1 Reply Last reply
      • EncryptE Encrypt
        Hello!
        AnticimexA
        AnticimexA
        Anticimex
        @encrypt the only things that comes to my mind is that your rf environment has shifted slightly or the noise level of the supply to the radio has increased to cause intermittent failure in the transmissions.
        You could try to switch channel for the radio and see if it helps? Or measure the stability of the power supply to the radio when the node(s) are communicating.
        • EncryptE
          EncryptE
          Encrypt
          Hello @Anticimex, thanks for your answer!
          You're right, since nothing changed on the hardware side, it may be a noise / power supply issue.
          Also, I should really finish making clean MySensors PCBs for that project and not rely on breadboards and stuff like that which is very likely to degrade the signal.
          I'll keep you updated with my progress, thanks again :)
          • EncryptE Encrypt
            AnticimexA
            AnticimexA
            Anticimex
            @encrypt for sure, going pcb will give the radio supply a better power signal (just remember to not make the trace too thin).
            But as you have had the rig operational for a long time, it might be worth checking other radio channels as well as perhaps some neighbor got some dirty rf toy or similar that mess with the rf environment.
            • EncryptE
              EncryptE
              Encrypt
              Well, I'm using RFM69W radios running on the 868MHz band.
              So, there should be a very low traffic on that band (compared to Wi-Fi).
              I'll probably add a capacitor near Vcc pin of the radio, I've just seen on the datasheet that it's recommended , although it seems there is already one on the board.
              Also, regarding the gateway, I plan to make a dipole antenna, since I don't have any space constraint.
              • EncryptE Encrypt
                AnticimexA
                AnticimexA
                Anticimex
                @encrypt 868 MHz is not unique so there could be interference. But yes, decouple the hell out of it. You cannot go overboard with decoupling so if you have the space, go for both electrolythic and ceramic caps. Perhaps even a tantal to try to catch as many frequencies as possible.
                Antenna will also help a ton if it is properly matched.
                • EncryptE
                  EncryptE
                  Encrypt
                  Hello again!
                  I restarted the node this morning, just out of curiosity...
                  I'm actually very surprised to see that presentation works without any problem (and the node sends its initial value correctly), but commands sent later failed...
                  Here are the logs:
                  Nov 16 12:12:16 DEBUG TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  Nov 16 12:12:16 DEBUG TSF:MSG:BC
                  Nov 16 12:12:16 DEBUG TSF:MSG:FPAR REQ,ID=2
                  Nov 16 12:12:16 DEBUG TSF:PNG:SEND,TO=0
                  Nov 16 12:12:16 DEBUG TSF:CKU:OK
                  Nov 16 12:12:16 DEBUG TSF:MSG:GWL OK
                  Nov 16 12:12:16 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                  Nov 16 12:12:18 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                  Nov 16 12:12:18 DEBUG TSF:MSG:PINGED,ID=2,HP=1
                  Nov 16 12:12:18 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                  Nov 16 12:12:18 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                  Nov 16 12:12:18 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  Nov 16 12:12:18 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=16,pt=0,l=0,sg=0:
                  Nov 16 12:12:18 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
                  Nov 16 12:12:18 DEBUG TSF:MSG:READ,2-2-0,s=255,c=0,t=17,pt=0,l=5,sg=1:2.3.1
                  Nov 16 12:12:19 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                  Nov 16 12:12:19 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                  Nov 16 12:12:19 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=6,pt=1,l=1,sg=1:0
                  Nov 16 12:12:19 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                  Nov 16 12:12:19 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                  Nov 16 12:12:19 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=6,pt=0,l=1,sg=1,ft=0,st=OK:M
                  Nov 16 12:12:19 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=11,pt=0,l=10,sg=1:Fil pilote
                  Nov 16 12:12:20 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                  Nov 16 12:12:20 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                  Nov 16 12:12:20 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=12,pt=0,l=3,sg=1:1.0
                  Nov 16 12:12:20 DEBUG TSF:MSG:READ,2-2-0,s=0,c=3,t=16,pt=0,l=0,sg=1:
                  Nov 16 12:12:21 DEBUG TSF:MSG:READ,2-2-0,s=0,c=0,t=4,pt=0,l=0,sg=1:
                  Nov 16 12:12:21 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=26,pt=1,l=1,sg=1:2
                  Nov 16 12:12:21 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                  Nov 16 12:12:21 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                  Nov 16 12:12:21 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=27,pt=1,l=1,sg=1,ft=0,st=OK:1
                  Nov 16 12:12:21 DEBUG TSF:MSG:READ,2-2-0,s=0,c=3,t=16,pt=0,l=0,sg=1:
                  Nov 16 12:12:21 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                  Nov 16 12:12:21 DEBUG TSF:MSG:READ,2-2-0,s=0,c=1,t=2,pt=2,l=2,sg=1:1
                  Nov 16 12:12:22 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                  Nov 16 12:12:22 DEBUG TSF:MSG:READ,2-2-0,s=0,c=1,t=3,pt=2,l=2,sg=1:2
                  Nov 16 12:13:21 DEBUG TSF:MSG:SEND,0-0-2-2,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                  Nov 16 12:13:21 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                  Nov 16 12:13:21 DEBUG TSF:MSG:SEND,0-0-2-2,s=0,c=1,t=3,pt=0,l=1,sg=1,ft=0,st=OK:3
                  Nov 16 12:13:25 DEBUG !TSF:MSG:SEND,0-0-2-2,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=NACK:
                  Nov 16 12:13:25 DEBUG !TSF:MSG:SIGN FAIL
                  Nov 16 12:13:25 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                  Nov 16 12:13:30 DEBUG !TSF:MSG:SEND,0-0-2-2,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=NACK:
                  Nov 16 12:13:30 DEBUG !TSF:MSG:SIGN FAIL
                  Nov 16 12:13:30 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                  Nov 16 12:13:39 DEBUG !TSF:MSG:SEND,0-0-2-2,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=NACK:
                  Nov 16 12:13:39 DEBUG !TSF:MSG:SIGN FAIL
                  Nov 16 12:13:39 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                  Nov 16 12:13:44 DEBUG !TSF:MSG:SEND,0-0-2-2,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=NACK:
                  Nov 16 12:13:44 DEBUG !TSF:MSG:SIGN FAIL
                  Nov 16 12:13:44 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                  Nov 16 12:13:47 DEBUG TSF:MSG:SEND,0-0-2-2,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                  Nov 16 12:13:47 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                  Nov 16 12:13:47 DEBUG TSF:MSG:SEND,0-0-2-2,s=0,c=1,t=3,pt=0,l=1,sg=1,ft=0,st=OK:0
                  As you can see, the node finished starting at 12:13:25 but my first command at 12:13:25 failed.
                  If it was really a noise / power supply issue, I would expect presentation to fail, considering that it's a long process taking more than 5s and using the radio quite intensively.
                  I've read that people here got range issue with MySensors 2.3.x, isn't that linked? Here for instance:
                  • https://forum.mysensors.org/topic/9321/rpi-ethernet-gateway-with-rfm69h-c-w-very-poor-range/9
                  • https://forum.mysensors.org/topic/7912/rfm69-new-driver-delay/56
                  @tekka: It seems you were working on that, was it supposed to be fixed in version 2.3.1?
                  I can't enable radio logging easily but I suspect it could be caused by the auto-adjusting RSSI feature...
                  AnticimexA tekkaT 2 Replies Last reply
                  • EncryptE Encrypt
                    Hello again!
                    Here are the logs:
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @encrypt noise sensitivity could be temperature related if the radio runs "hot"
                    • EncryptE Encrypt
                      Hello again!
                      Here are the logs:
                      tekkaT
                      tekkaT
                      tekka
                      wrote on last edited by tekka
                      @encrypt said in Signing fails due to NACKed messages:
                      I'm afraid, but without additional debug information it's gonna stay a guessing game. If possible, enable
                      #define MY_DEBUG_VERBOSE_RFM69
                      for additional info. Also, please post the node sketch to interpret the log in the right context.
