  3. ISR not in IRAM error
12 Posts 5 Posters 2.8k Views 5 Watching
  • YveauxY Yveaux
    @adamant According to this post: https://community.blynk.cc/t/error-isr-not-in-iram/37426/15
    could you try the following:
    • For the old RFM69 driver (you seem to be using this one):
      Change the following line https://github.com/mysensors/MySensors/blob/development/hal/transport/RFM69/driver/old/RFM69_old.cpp#L464
      from
    void RFM69::isr0()
    to
    ICACHE_RAM_ATTR void RFM69::isr0()
    • For the new RFM69 driver (for reference):
      Change the following line https://github.com/mysensors/MySensors/blob/development/hal/transport/RFM69/driver/new/RFM69_new.cpp#L245
      from
    LOCAL void RFM69_interruptHandler(void)
    to
    ICACHE_RAM_ATTR void RFM69_interruptHandler(void)
    AdamAntA
    AdamAntA
    AdamAnt
    @yveaux Hello, thanks so much for your help on this!
    Changing those functions has helped me get past the error, however I now have a different issue.
    Using the the same sketch and setup, on the old driver the gateway crashes with a Soft WDT reset shortly after it initializes the radio:
    50 MCO:BGN:INIT GW,CP=RRNGE---,REL=255,VER=2.3.1
    101 TSF:LRT:OK
    117 TSM:INIT
    131 TSF:WUR:MS=0
    156 TSM:INIT:TSP OK
    177 TSM:INIT:GW MODE
    199 TSM:READY:ID=0,PAR=0,DIS=0
    231 MCO:REG:NOT NEEDED
    scandone
    259 TSM:READY:NWD REQ
    Soft WDT reset
    >>>stack>>>
    ctx: cont
    sp: 3ffffc40 end: 3fffffd0 offset: 01b0
    3ffffdf0:  000003e7 3ffee488 00000a91 402017ee
    3ffffe00:  3ffee319 00000001 00000040 40201664
    3ffffe10:  3ffee319 000000ff 3ffee488 000003e7
    3ffffe20:  3ffee319 000000ff 3ffee488 40201bd5
    3ffffe30:  00000a8a 00000007 00000001 00418937
    3ffffe40:  00000000 3ffee71c 4023d1ac 000009c2
    3ffffe50:  000000ff 3ffee488 00000002 40201428
    3ffffe60:  3ffee319 00000007 00000005 000000c8
    3ffffe70:  3a4d5354 44414552 574e3a59 000000ff
    3ffffe80:  3fffdad0 3ffee46c 3ffee319 40201ced
    3ffffe90:  6d616461 37393931 00000100 402022d7
    3ffffea0:  00000001 3ffef9fc 00000000 40207afc
    3ffffeb0:  000003fd 4023202b 00000000 40100584
    3ffffec0:  00000001 3ffee317 00000001 40202754
    3ffffed0:  e260f400 00f2597d 3fffff00 3ffffef0
    3ffffee0:  00000000 4bc6a7f0 3fffff10 3fffff00
    3ffffef0:  00000004 00000000 4bc6a7f0 00000000
    3fffff00:  6d616461 00418937 00000000 3ffee2c0
    3fffff10:  3fffdad0 3ffee319 000000ff 40202420
    3fffff20:  3fffdad0 00000103 3ffee35c 402028d4
    3fffff30:  00000000 00000000 000001f4 40201dc5
    3fffff40:  3fffdad0 00000103 000001f4 4020364d
    3fffff50:  00000000 00000103 000001f4 402039df
    3fffff60:  3fffdad0 00000103 000001f4 40203a03
    3fffff70:  3fffdad0 3ffee317 3ffee6cc 40203a62
    3fffff80:  3ffee470 3ffee317 00000000 402036a4
    3fffff90:  600002ff 00020000 3ffee470 3ffee2c0
    3fffffa0:  3fffdad0 3ffee317 3ffee6fe 40203b50
    3fffffb0:  feefeffe 00000000 3ffee2b8 40203bb4
    3fffffc0:  feefeffe feefeffe 3ffe851c 40100129
    <<<stack<<<
    However, using the new driver, I get past that point and the gateway initializes fine. But unfortunately, the sensor node never connects. It just constantly sits waiting to find a parent node:
    16 MCO:BGN:INIT NODE,CP=RPNNA---,REL=255,VER=2.3.1
    26 TSM:INIT
    27 TSF:WUR:MS=0
    29 TSM:INIT:TSP OK
    31 TSM:FPAR
    36 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2045 !TSM:FPAR:NO REPLY
    2048 TSM:FPAR
    2054 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4061 !TSM:FPAR:NO REPLY
    4063 TSM:FPAR
    4069 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6076 !TSM:FPAR:NO REPLY
    6078 TSM:FPAR
    6083 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8091 !TSM:FPAR:FAIL
    8092 TSM:FAIL:CNT=1
    8094 TSM:FAIL:DIS
    8096 TSF:TDI:TSL
    I'm pretty confident my antenna setups are correct - single core wire, each one a straight piece 82mm long.
    • AdamAntA AdamAnt
      101 TSF:LRT:OK
      117 TSM:INIT
      131 TSF:WUR:MS=0
      156 TSM:INIT:TSP OK
      scandone
      Soft WDT reset
      >>>stack>>>
      ctx: cont
      <<<stack<<<
      26 TSM:INIT
      27 TSF:WUR:MS=0
      29 TSM:INIT:TSP OK
      31 TSM:FPAR
      2048 TSM:FPAR
      4063 TSM:FPAR
      6078 TSM:FPAR
      8091 !TSM:FPAR:FAIL
      8092 TSM:FAIL:CNT=1
      8094 TSM:FAIL:DIS
      8096 TSF:TDI:TSL
      @adamant are you using the new driver on the node? Gateway and nodes must use the same driver.
      What does the gateway log say?
      AdamAntA 1 Reply Last reply
        AdamAntA
        AdamAntA
        AdamAnt
        @mfalkvidd Yeah, I reflashed the node & gateway each time to match.
        The gateway has the same sketch as in post 1, just with #define MY_RFM69_NEW_DRIVER added, and the sensor node is the simple repeater sketch:
         * Copyright (C) 2013-2018 Sensnology AB
         * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
         * Version 1.0 - Henrik Ekblad
         * Example sketch showing how to create a node that repeats messages
         * from nodes far from gateway back to gateway.
         * It is important that nodes that has enabled repeater mode calls
         * process() frequently. Repeaters should never sleep.
        #define MY_RADIO_RFM69
        #define MY_REPEATER_FEATURE
        	//Send the sensor node sketch version information to the gateway
        	sendSketchInfo("Repeater Node", "1.0");
          Stefan_NE
          i have the same problem. Using the 2.4.2 of the ESP8266 board library works fine. All later versions not.
          Ther is an other Problme with the ESP Gateway. The Wifi reconnect after a soft reboot or pushing the reset switch is not working.
          The gateway is trying to reconnect until it gets power on / off .
          a Modification of the MyGatewayTransportEthernet.cpp helps. Wifi will be always disconnected with the boot process.
          #if defined(MY_GATEWAY_ESP8266) || defined(MY_GATEWAY_ESP32)
          #if defined(MY_WIFI_SSID)
          // Turn off access point
          WiFi.mode(WIFI_STA);
          #if defined(MY_HOSTNAME)
          WiFi.hostname(MY_HOSTNAME);
          #elif defined(MY_GATEWAY_ESP32)
          WiFi.setHostname(MY_HOSTNAME);
          #ifdef MY_IP_ADDRESS
          WiFi.config(_ethernetGatewayIP, _gatewayIp, _subnetIp);
          GATEWAY_DEBUG(PSTR("GWT:TIN:Disconnect Wifi..\n")); //----------- added
          WiFi.persistent(false); // --------------------------------------------------------------------added
          WiFi.disconnect(); //-------------------------------------------------------------------------- added
          GATEWAY_DEBUG(PSTR("GWT:TIN:Delay 500 ms...\n"));
          delay(500);
          (void)WiFi.begin(MY_WIFI_SSID, MY_WIFI_PASSWORD, 0, MY_WIFI_BSSID);
          while (WiFi.status() != WL_CONNECTED) {
          wait(500);
          GATEWAY_DEBUG(PSTR("GWT:TIN:CONNECTING_wait_500ms...\n"));
          GATEWAY_DEBUG(PSTR("GWT:TIN:IP: %s\n"), WiFi.localIP().toString().c_str());
          Have a nice day
          Stefan
          • S Stefan_NE
            delay(500);
            wait(500);
            Have a nice day
            Stefan
            @stefan_ne I entered two issues for the issues described above: https://github.com/mysensors/MySensors/issues/1335 and https://github.com/mysensors/MySensors/issues/1334
            Please enter another issue for your case, or issue a pull request.
            • AdamAntA
              AdamAntA
              AdamAnt
              Just jumping in here to say that a combination of using the new driver, and downgrading to ESP8266 ver 2.5.0 has fixed this for me. The other issue I was having was total user error, a bad solder joint was giving me strange results.
              Thanks for your help!!
              • AdamAntA AdamAnt
                @adamant thanks for reporting back!
                Does this mean that https://github.com/mysensors/MySensors/issues/1335 can be closed?
                  Stefan_NE
                  I don't think so, in time we have just some workarounds
                  Have a nice day
                  Stefan
                  • S Stefan_NE
                    Have a nice day
                    Stefan
                    @stefan_ne I would like @AdamAnt to confirm if https://github.com/mysensors/MySensors/issues/1335 is still relevant or not.
                    The op of this thread had 2 issues. I entered them in GitHub, then he hinted the second issue (#1335) was solved by fixing a bad solder joint.
                    So, unless somebody confirms #1335 is still relevant, I will close it.
                    #1334 is of course still to be solved.
                    • K
                      K
                      KalleL
                      I had the same error and realized it was caused in combination with an interrupt routine . Having read the answers above I tried only to introduce
                      this directive
                      ICACHE_RAM_ATTR void Interrupt_routine()
                      { ...code...
                      ... and it was all fine :)
