  3. Home Assistant
  4. Raspberry Pi gateway + hass.io + MQTT + MySensors
38 Posts 4 Posters 5.0k Views 5 Watching
  • SebexS
    SebexS
    Sebex
    Thanks @monte, I'm gonna try that first
    • monteM monte
      To use RPi as a gateway you need install Home Assistant on a Raspbian install and compile a Mysensors binary on it. Hass.io won't work with this scenario. I suggest you follow the docker install guide.
      SebexS
      SebexS
      Sebex
      @monte does docker allow complete functionality of hass.io? Here it's mentioned that docker will limit functionality, is that correct? For clarification, how would docker relate to a manual installation of hass.io
      monteM 1 Reply Last reply
      • SebexS Sebex
        monteM
        monteM
        monte
        @sebex well, it appears that you can install hass.io manually on your raspbian installation via this script
        Also you can install plain Home Assistant docker image if you don't need any addons and additional functionality of hassio. That's the way I went.
        You need to understand that either way you can achieve the same things but a little different ways.
        The main point is that you need Raspbian setup in the first place if you want to use the same RPi as a gateway. You can't compile Mysensors gateway on a hassio image.
        • Dave MyersD
          Dave MyersD
          Dave Myers
          Unless there has been a recent change I’m unaware of - I don’t think you can have RPi function as gateway when it is running Hass.IO (via HassOS). There is not a way to load and run the mysensors executable.
          I’d suggest building a serial gateway with a nano (with NRF radio connected to nano). If you connect that via USB to your Pi, you should be able to use the homeassistant config for serial gateways to get everything working.
            Michał Szura
            I think that you have concept problem. First I don't think that raspbian install have any sense at this stage. There's so much more you can do with hassos ( docker). And second why you doesn't connect gateway via USB an use serial connection. I use Arduino mega directly via USB and it is very stable. You have to add in configuration mysensors with path to USB (I recommend serial number identification).
            SebexS 1 Reply Last reply
            • M Michał Szura
              SebexS
              SebexS
              Sebex
              @michał-szura here and there I do read the possibility of a Pi acting as a gateway and controller. But you mention that it is not possible whatsoever? Why not?
              @Dave-Myers I agree that it is not possible via HassOS, but it should be possible when run via a virtual enivroment as monte suggested.
              @monte hassio now shows up in docker as a container. But I am struggling to run it, what's the command to run hassio_supervisor? attach hassio_supervisor causes it to become unresponsive.
                Michał Szura
                In this case I have question why? I Know that why not and because I can is good enough answer but...
                You can have best from home assistant (install Hass os) and mysensors (make gateway on separate Arduino). And this way when you want to upgrade to something more than RPi you can do it with minimal damage ( I did it this way and it was quite nice upgrade). But this is only myn2 cents
                • M Michał Szura
                  monteM
                  monteM
                  monte
                  @michał-szura some may say that one integrated device is better than two. Also you can restart and debug mysensors gateway via ssh, try to achieve this with arduino. Anyway, even after you decide to move your controller installation to lets say dedicated server, NUC or VM you can still use your RPi as a network gateway without rebuilding anything.
                  @Sebex what exactly did you do? Did you use install script, or followed some guide on mentioned forum thread.
                  To see if supervisor is running execute sudo systemctl status hassio-supervisor.service
                  Also you can use sudo docker ps command to list running docker containers, sudo docker ps -a will show every container even if it is stopped.
                  • monteM monte
                    SebexS
                    SebexS
                    Sebex
                    wrote on last edited by Sebex
                    @monte said in Raspberry Pi gateway + hass.io + MQTT + MySensors:
                    I followed your github link, and used the cmd below to instal hassio.
                    curl -sL https://raw.githubusercontent.com/home-assistant/hassio-installer/master/hassio_install.sh | bash -s -- -m MY_MACHINE
                    When I run your suggested status cmd I indeed see that hassio is running:
                    Dec 29 23:18:24 banana hassio-supervisor[1046]: 19-12-29 22:18:24 INFO (MainThread) [__main__] Run Hass.io
                    Dec 29 23:18:24 banana hassio-supervisor[1046]: 19-12-29 22:18:24 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
                    Dec 29 23:18:24 banana hassio-supervisor[1046]: 19-12-29 22:18:24 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 add-ons
                    Dec 29 23:18:24 banana hassio-supervisor[1046]: 19-12-29 22:18:24 INFO (MainThread) [hassio.addons] Phase 'system' start 0 add-ons
                    Dec 29 23:18:24 banana hassio-supervisor[1046]: 19-12-29 22:18:24 INFO (MainThread) [hassio.addons] Phase 'services' start 0 add-ons
                    Dec 29 23:18:24 banana hassio-supervisor[1046]: 19-12-29 22:18:24 INFO (SyncWorker_1) [hassio.docker.interface] Start homeassistant/raspberrypi3-64-homeassistant
                    Dec 29 23:18:33 banana hassio-supervisor[1046]: 19-12-29 22:18:33 ERROR (MainThread) [hassio.homeassistant] Home Assistant has crashed!
                    Dec 29 23:18:33 banana hassio-supervisor[1046]: 19-12-29 22:18:33 INFO (MainThread) [hassio.addons] Phase 'application' start 0 add-ons
                    Dec 29 23:18:33 banana hassio-supervisor[1046]: 19-12-29 22:18:33 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
                    Dec 29 23:18:33 banana hassio-supervisor[1046]: 19-12-29 22:18:33 INFO (MainThread) [hassio.core] Hass.io is up and running
                    But I tried accessing hassio multiple times via <raspberrypi local ipadres>:8123, which is unresponsive. Any suggestions? The Pi is connected via wifi, ip adres is not yet static but doubt that this is the cause.
                    -- update
                    Now that I am looking into it again after setting Pi's IP to static, the bottom 4th line shows an error. Home assistant has crashed. So something is going wrong...
                    • SebexS Sebex
                      -- update
                      monteM
                      monteM
                      monte
                      wrote on last edited by monte
                      @sebex well, that indicates that homeassistant docker container has crashed for some reason. That's why you can not access it via web.
                      I assume you tried to restart RPi? No changes?
                      Try sudo docker start homeassistant and sudo docker ps -a after this to see if it crashed or not.
                      It will print something like this:
                      CONTAINER ID   NAMES                      IMAGE                                            COMMAND                  CREATED             STATUS
                      b8d101b1b04d   addon_core_configurator    homeassistant/amd64-addon-configurator:4.2       "/run.sh"                13 hours ago        Up 13 hours
                      ee63787039a5   hassio_dns                 homeassistant/amd64-hassio-dns:1                 "coredns -conf /conf…"   14 hours ago        Up 14 hours
                      18c68d86c0ae   homeassistant              homeassistant/qemux86-64-homeassistant:0.103.5   "/bin/entry.sh pytho…"   14 hours ago        Up 14 hours
                      24f80b84279d   hassio_supervisor          homeassistant/amd64-hassio-supervisor            "/bin/entry.sh pytho…"   14 hours ago        Up 14 hours
                      Status will show the status of the container. You can read the logs to see why it is crashing with command sudo docker logs homeassistant.
                      Yesterday after I wrote a reply I tried that install script on my server and it just worked. I hope we will find problem with your setup :)
                      • monteM monte
                        SebexS
                        SebexS
                        Sebex
                        @monte yes tried rebooting it several times and also reinstalled but no changes so far, it still crashes.
                        I tried your commands, after sudo docker start homeassistant it immediately crashes according to the logs below.
                        CONTAINER ID        IMAGE                                                 COMMAND                  CREATED             STATUS                     PORTS               NAMES
                        0b0ffff70832        homeassistant/armv7-hassio-dns:1                      "coredns -conf /conf…"   5 minutes ago       Up 5 minutes                                   hassio_dns
                        3b83e6f9db07        homeassistant/raspberrypi3-64-homeassistant:0.103.5   "/bin/entry.sh pytho…"   2 hours ago         Exited (1) 2 seconds ago                       homeassistant
                        9fd90364c61f        homeassistant/armv7-hassio-supervisor
                        [FATAL tini (6)] exec /bin/entry.sh failed: Exec format error
                        Thanks for the help so far @monte hope we can fix it :D
                        • SebexS Sebex
                          monteM
                          monteM
                          monte
                          @sebex okay, that seems that for some reason script pulled out wrong HA container, I mean for wrong architecture. At least [FATAL tini (6)] exec /bin/entry.sh failed: Exec format error indicates that.
                          What is your RPi version?
                          You can try running the script without -m MY_MACHINE argument. It should autodetect the architecture and pull correct docker image.
                          What does uname -m show?
                          • SebexS
                            SebexS
                            Sebex
                            @monte yea it made me wonder as well whether I should have selected the rpi 3 64bit version for docker image.
                            I have a Raspberry pi 3 b+ (so 64bit).
                            uname -m shows armv7l, when googling I got the answer that this can also be due to that Raspbian is running in 32 mode?
                            I tried running the script without -m MY_MACHINE returns an error for setting the machine.
                            root@banana:/home/pi# sudo curl -sL https://raw.githubusercontent.com/home-assistant/hassio-installer/master/hassio_install.sh | bash -s
                            ModemManager.service enabled
                            [Warning] ModemManager service is enabled. This might cause issue when using serial devices.
                            [ERROR] Please set machine for armv7l
                            I've just completely reflashed my Pi and used a different microsd card (couldn't format the original one anymore). Reinstalled raspbian, docker and hass.io. For the latter I selected raspberrpi3 (instead of rpi3-64). After accessing localip:8123 it seems that hass.io is accessible :D It's currently preparing so looking good!!
                            • SebexS Sebex
                              SebexS
                              SebexS
                              Sebex
                              Ok so homeassistant is running and not crashing :) Now building the gateway, @monte to eventually communicate with hass.io do I need to select the gateway as --my-gateway=ethernet or mqtt?
                              • SebexS Sebex
                                monteM
                                monteM
                                monte
                                @sebex you can chose either. I prefer ethernet, so you don't rely on another piece of software - MQTT broker, no additional setup is required.
                                Read this docs especially the "Presentation" paragraph. At first I had trouble registering my nodes in HA, because it require particular way of presentation. "Send at least one initial value per V_TYPE. In version 2.x of MySensors, this has to be done in the loop function."
                                • monteM monte
                                  SebexS
                                  SebexS
                                  Sebex
                                  @monte ok thanks, will take it into account.
                                  Out of curiousity, since MQTT takes additional setup what''s the benefit of using MQTT? Do you know?
                                  • SebexS Sebex
                                    monteM
                                    monteM
                                    monte
                                    @sebex I guess if you already have other mqtt services or devices in your system, or want to use a controller that is designed specifically around mqtt, nodered for example, or the one that doesn't have support for Mysensors specifically.
                                    Also you could use Mysensors with remote mqtt server, your own, or third party. I tried this once, when I needed one sensor exposed to internet without dedicated server hardware at place, so I've built an esp8266 gateway with mqtt connected to free online mqtt broker. The nodered controller was also hosted on a free cloud :)
                                    Not that it was particularly useful, or I would recommend it to someone, but it's a flexibility Mysensors has, and I guess it's the main reason so many people are using it for their projects.
                                    • SebexS
                                      SebexS
                                      Sebex
                                      @monte ok it seems to work. Temp/humidity sensor is recognised by HA and data is getting through so looks good! Only connection isnt stable which is most likely due to that I still need to get capacitors for the NRF24L01+ on both ends, and need to solder the cables to the sensor. So still some tweaks to do but happy that it works, thanks for the support @monte :grinning:
                                      Two general questions, any advice for which capacitor to select? Apart from 4.7 or 47uF, there's different types. Tanto, elco, bipolaire etc.
                                      Furthermore I wondered why the 64bit hassio software didn't work on my Arduino, while it is a 64bit RPi 3+. Does Raspbian (or dockers?) as default run in 32?
                                      • SebexS Sebex
                                        monteM
                                        monteM
                                        monte
                                        #21
                                        @sebex 4.7uF should be enough, I've never seen any problem with this value on my nodes. As for the type of the capacitor you probably will want to use ceramic or electrolytic (polarized) capacitor, but it doesn't do much difference for this application, if any. Those are just the most common types. Ceramic SMD capacitor of a size 0805 is the best choice IMO because it could be soldered directly to the VCC and GND pins on top of NRF24 module.
                                        You can google about why raspbian is running like RPi is 32 bits, but as I understood it's better for downward compatibility and the fact that RPi3 won't get much boost (if any) from switching to 64 bit architecture.
                                        • monteM monte
                                          SebexS
                                          SebexS
                                          Sebex
                                          @monte ah smart makes sense and probably looks most neat as well. Thanks!
