  3. ESP8266 Gateway with local sensors stuck in loop
6 Posts 4 Posters 818 Views 4 Watching
    ShadeX12
    wrote on last edited by ShadeX12
    Hi Guys,
    I previously had this sketch working fine with a local sensor on Arduino Uno. I want to move to NodeMCU for the sake of simplicity.
    I have loaded the sketch that worked previosuly on the Ardunio onto the NodeMCU and it is stuck in the infinite loop. I suspect this has something to do with sleep not working?
    Here is the code:
    //Set NODE ID
    #define MY_NODE_ID 0
    #define MY_BAUD_RATE 9600
    //#define MY_RADIO_RF24
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_ESP8266
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "homeassistant-out"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "homeassistant-in"
    // Set MQTT client id
    // Enable these if your MQTT broker requires username/password
    #define MY_MQTT_USER "####"
    #define MY_MQTT_PASSWORD "#####"
    // Set WIFI SSID and password
    #define MY_WIFI_SSID "######"
    #define MY_WIFI_PASSWORD "######!"
    // passed to the DHCP server if not static.
    #define MY_HOSTNAME "KITCHEN_MQTT_GW"
    // MQTT broker ip address.
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 87, 179
    //MQTT broker if using URL instead of ip address.
    // #define MY_CONTROLLER_URL_ADDRESS "test.mosquitto.org"
    #define MY_PORT 1883
    // Enable inclusion mode
    //#define MY_INCLUSION_MODE_BUTTON_PIN D1
    // Set blinking period
    // Flash leds on rx/tx/err
    #define CHILD_ID_PH_LOCAL 1   // Id of the sensor child
    // Initialize motion message
    MyMessage msg(CHILD_ID_PH_LOCAL, V_TRIPPED);
      sendSketchInfo("Kitchen Motion Sensor", "2.0");
      present(CHILD_ID_PH_LOCAL, S_MOTION);
      // Read digital motion value
      Serial.println(tripped);
    Any help you anyone can provide would be greatly appreciated.
    Thank You!
    • S ShadeX12
      Hi Guys,
      Here is the code:
      //Set NODE ID
      Thank You!
      @ShadeX12 yyes you are correct. Esp8266 only supports sleeping by resetting the mcu, which means it would start fresh after every sleep (instead of continuing on he next line after sleep).
        ShadeX12
        Thanks for the reply.
        I removed sleep and added wait instead. Now it just seems to output a sensor as tripped regardless of what is going on. It seems like it is not reading the state from the pin.
          wait(5000);
        Here is the serial output:
        143021 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
        148086 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
        153151 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
        158216 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
        163281 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
        168346 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
        173411 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
        178476 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
        183541 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
        188606 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
        193671 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
        198736 GWT:TPS:TOPIC=homeassistant-out/0/1/1/0/16,MSG SENT
        Any ideas?
          ShadeX12
          After surfing around the web a bit I eventually came up with this:
            long state = digitalRead(DIGITAL_INPUT_SENSOR);
              if(state == HIGH) {
                Serial.println("Motion detected!");
                send(msg.set("1"));
                delay(1000);
              else {
                Serial.println("Motion absent!");
                send(msg.set("0"));
                delay(1000);
          This seems to be working fine.
          • electrikE
            electrikE
            electrik
            Now you are sending the message every second, even if the state didn't change.
            If you check to the previous state, and then send when the state changed it would be more efficient
            • K
              K
              Karl-Heinz K
              @ShadeX12
              maybe these links will provide the necessary background information to solve your problem:
              Basics about ESP8266 sleep modes:
              https://www.losant.com/blog/making-the-esp8266-low-powered-with-deep-sleep
              Extensive discussion of this topic:
              https://github.com/esp8266/Arduino/issues/1488
              Especially this citation might be interesting:
              "GPIO16 is connected to CH_DP for deepSleep.
              and pulled low during deepSleep.
              if CH_DP goes high the chip wakes up.
              for what reason the high signal comes from does not mater.
              can be the RTC timer or any other electrical stuff connected to CH_DP.
              so adding a pullup to CH_DP and a switch that is normally close to GPIO16 will work fine."
              Excellent summary, how to work with interrupts in general on the ESP8266:
              https://techtutorialsx.com/2016/12/11/esp8266-external-interrupts/
              Good luck with your project.
              Karl-Heinz
