  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 106.8k Views 36 Watching
  • cashew75C
    cashew75C
    cashew75
    Hi, I'm having a hard time getting this Temperatursensor to work with Home Assistant. When i start it it doesn't register with the HA. If I use the same hardware and switch out the sensor to a DHT sensor (new sketch of course) then it works out of the box, HA sees the sensor. I've tried changing the Dallas DS18B20, but nothing. If i look at the logs the gateway have no problem with the sensor. Is there something in the code for the sensor that doesn't add up to it being presented to HA in the right way? I'm quite the newbie when it comes to programming.
      Have you tried another controller like mycontroller?
      cashew75C 1 Reply Last reply
        cashew75C
        cashew75C
        cashew75
        @gohan No I have not. I have a RF-Link also connected to the HA and it's working great. As I said, if I use the same hardware that I used to control the Dallas sensor and change the sensor to a DHT sensor the DHT sensor is accepted by HA and shows up as a sensor. That's why I was asking if there is something in the code for the Temperature sensor sketch that has to be changed to be able to present it to HA.
          pls post the code that is not working
            cashew75C
            cashew75C
            cashew75
            @gohan Thanks for the quick reply! Well I've use the standard sketch for this Temperatur sensor. This is the code i've got.
            #include <OneWire.h>
            int numSensors=0;
            bool receivedConfig = false;
            bool metric = true;
            MyMessage msg(0,V_TEMP);
            void before()
              sensors.begin();
                 present(i, S_TEMP);
              sleep(conversionTime);
                #if COMPARE_TEMP == 1
              sleep(SLEEP_TIME);
            • pepsonP
              pepsonP
              pepson
              Anybody has sketch for sensors dallas DS18b20 with identify it with ID Dallas ?
              And i can change value 16 to more sensors ? Example 20 ?
              • A
                APL2017
                Looking at code example it seems to be sufficient to set bool metric = false to get readings in Fahrenheit, but node still returns readings in C. Any idea why?
                • A APL2017
                  @apl2017 if I'm looking at the same sketch as you are looking at, the metric variable is never used. getControllerConfig() is used to fetch the controller's metric setting instead.
                  • R Rene046
                    I sofar got the sketch running and giving good data on serial and into domoticz
                    i only could use some help with how to sent my Temperature in Celsius to domoticz to
                    i tried to use:
                    send(msgTemp.set(insideThermometer ,2));
                    and
                    send(msgTemp.set(tempC,2));
                    both without luck, the first did transmit some data but wrong numbers
                    second did nothing think because with this i done i does not know what address the DS1820 is on.
                    Im learning every day something new....
                    Maybe someone could help,
                    G
                    G
                    gniazdoj
                    @Rene046
                    Hi guys
                    Hi
                    can you advice how to manage Domoticz to display 2 decimals under Temperature sensors page, when following line MsgTemp.set(temperature,2) I can see on arduino serial monitor, mysensors sent 20.75 value, the same value i can see under child item with Hardware tab but not on sensor where 20.75*C is rounded to 20.8. its fine for general log but i want to have stable temperature for heating system. I have added code to count average from last X records like 20 or 40 with 0.25 steps, this stabilize Heating system and protect it against on/off to frequently.
                    Additionally when i use JSON it will present proper value under sensor page, same with ESPEasy and 2 decimal configuration on ESP.
                    do you know how i can changed domoticz to force him to present 2 decimals?
                    Mysensors 2.3.1/2.3.2
                    Domoticz 4.10717
                    raspberry pi
                    Thank you
                    Jakub
                    K 1 Reply Last reply
                    • G gniazdoj
                      @Rene046
                      Hi guys
                      Hi
                      Domoticz 4.10717
                      raspberry pi
                      Thank you
                      Jakub
                      K
                      K
                      kimot
                      Domoticz globally or only with MySensors ?
                      My Domoticz is the same version like yours.
                      Temperatures from ESPeasy are with two decimals on Temperature sensors page, but on devices page only one decimal.
                      Exactly the opposite like you wrote.
                      G 1 Reply Last reply
                      • K kimot
                        G
                        G
                        gniazdoj
                        wrote on last edited by gniazdoj
                        #170
                        @kimot
                        Hi
                        Thank you for feedback.
                        I have this issue only with mysensors. it's exactly like you wrote. Hardware tab, present 2 decimals ( for mysensors and espeasy). Device tab, present 1 decimal ( for all sensors), Temperature tab shows 2 decimal for esp easy and JSON updates but 1 decimal for mysensor. Not sure why.
                        Temporary I managed to workaround by using script taking data from Hardware page - child and sending JSON update all started by crone updating dummy sensor.
                        like this:
                        TEMP=`curl -s "http://X.X.X.X:XX/json.htm?type=command&param=mysensorsgetchilds&idx=40&nodeid=0"| awk 'NR>1{print $5}'| sed 's/"//g;s/^.//;s/)//g; s/,//g;/^$/d;s/]//g;' | sed -n '3,2p'`
                        IDX=255
                        curl -s "http://X.X.X.X:XX/json.htm?type=command&param=udevice&idx=$IDX&nvalue=0&svalue=$TEMP"
                        but for sure this can be workaround by dzVents and JSON handling results but i'm not skilled enough for that :)
                        Thank you
                        Jakub
                        • G
                          G
                          garubi
                          The note before the example sketch states that you should use the "modified" library from MySensors examples.
                          But as of today, with MySensors 2.3.2 and Arduino 1.8.15 I used the standard DallasTemperature library (provided by the Arduino's Libraries manger) with no problems at all.
                          Using the "standard" Arduino libraries is a grate advantage, so I the custom library is no more used, it could be useful to update the guidelines in the page.
                          Stefano
