  3. Eeprom access via mySensors
readmanagementeepromwritestructured
9 Posts 2 Posters 7.3k Views 1 Watching
  • klimK
    klimK
    klim
    Hi i hope you can help me finding a solution for my requirement. I want eeprom content to be fully manageable via mySensors protocol using payload.
    The previous days I've tried a few solutions but I'm unsatisfied with all of them, here are some of my unusable solutions:
    • Each eeprom value has it's own function for accessing --> stupid solution e.g. Payload: readValue1
    • Direct access eeprom addresses --> hassle solution without structured access, datatype length problem. e.g. Payload: %command%,%address%,%value% --> write,0x10,255
    Please note, the above Payload examples aren't real, they are just for better description.
    I want a generic solution to manage eeprom values with the use of structured eeprom access, optionally where the node can give information about it's structure (variables and datatypes) to the controller for easier management. Do you have any ideas who to do that, please?
    hekH 1 Reply Last reply
    • klimK klim
      @klim
      I have noted the request.
      • klimK
        klimK
        klim
        Hi, just wanted to ask about any ideas, not to make a feature request. But in general i think this could be useful for the whole mySensors project.
        What i built already:
        -Used the EEPROMAnything.h library for structured eeprom access
        -Wrote a Payload parser for: command,section,value e.g. write,value1,199
        -But then i've a problem to access the struct sections
        Here's an excerpt about my solution:
        struct store_t {
        byte version;
        int value1;
        unsigned long value2;
        char code[5];
        } configuration;
        The parser separates the Payload into:
        -command <-- e.g. write
        -section <-- e.g. value1
        -value <-- e.g. 199
        To read data from the struct i can simply use** configuration.value1** which works fine.
        But i want to use the data from the Payload like ** configuration.section** where the section holds the struct section name to access.
        The only nasty solution i figured out was, comparing the Payload section with a string.
        if (strcmp(payload,"value1") == 0) {
        Serial.println(configuration.value1);
        } else
        if (strcmp(payload,"value2") == 0) {
        Serial.println(configuration.value2);
        How could i do that better?
          It is a hard to solve it any other way if you use a string as identifier.
          • klimK
            klimK
            klim
            Thanks for reply. This means, my it is not possible do it that way, right?
            Any other ideas to generalize eeprom access?
              You could for instance use a index + length to access a certain a region in the eeprom pretty easy. But remember there are a limit on the size of payload.
              • klimK
                klimK
                klim
                I already mentioned direct access eeprom addresses. I don't like it, because of loosing all the benefits of structured eeprom access.
                  You could read-up on and get inspired of protocol buffers. Pretty neat.
                  https://developers.google.com/protocol-buffers/
                  • klimK
                    klimK
                    klim
                    thanks, i'll give it a try.
