  3. Dallas DS18B20 temperate sensor
8 Posts 2 Posters 925 Views 2 Watching
  • J Offline
    J Offline
    Jenkins
    Hello
    This is my first project with a Ds18B20 an arduino mega as that is what I had to hand as a test as well as a nrf24l01 radio. This is all being transmitted to a raspberry pi gateway with a nrf24l01 with the eventual plan to link to hass io.
    I am unfortunately stuck with making sure the value is transmitted to the raspberry pi. I am using the code detailed here [https://www.mysensors.org/build/temp] (https://www.mysensors.org/build/temp)
    I have added the extra definitions needed for the mega and connected the radio as per [https://www.mysensors.org/build/connect_radio] (https://www.mysensors.org/build/connect_radio)
    This is the debug message from my raspberry pi, I tried using the log parser but it was not clear what the sensor output was and if this was right. Please could someone help me as to if this is right?
    TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    TSF:MSG:BC
    TSF:MSG:FPAR REQ,ID=3
    TSF:PNG:SEND,TO=0
    TSF:CKU:OK
    TSF:MSG:GWL OK
    !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    TSF:MSG:BC
    TSF:PNG:SEND,TO=0
    TSF:CKU:OK
    TSF:MSG:GWL OK
    TSF:MSG:BC
    TSF:PNG:SEND,TO=0
    TSF:CKU:OK
    TSF:MSG:GWL OK
    TSF:MSG:BC
    TSF:PNG:SEND,TO=0
    TSF:CKU:OK
    TSF:MSG:GWL OK
    TSF:SRT:OK
    TSM:READY:NWD REQ
    ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    TSF:SAN:OK
    TSF:MSG:BC
    TSF:PNG:SEND,TO=0
    TSF:CKU:OK
    TSF:MSG:GWL OK
    TSF:MSG:BC
    TSF:PNG:SEND,TO=0
    TSF:CKU:OK
    TSF:MSG:GWL OK
    TSF:MSG:BC
    TSF:PNG:SEND,TO=0
    TSF:CKU:OK
    TSF:MSG:GWL OK
    TSF:MSG:BC
    TSF:PNG:SEND,TO=0
    TSF:CKU:OK
    TSF:MSG:GWL OK
    TSF:MSG:BC
    TSF:PNG:SEND,TO=0
    TSF:CKU:OK
    TSF:MSG:GWL OK
    TSF:MSG:BC
    TSF:CKU:OK,FCTRL
    TSF:MSG:GWL OK
    Thanks in advance
    • J Jenkins
      Hello
      TSF:MSG:BC
      TSF:PNG:SEND,TO=0
      TSF:CKU:OK
      TSF:MSG:GWL OK
      TSF:MSG:BC
      TSF:PNG:SEND,TO=0
      TSF:CKU:OK
      TSF:MSG:GWL OK
      TSF:MSG:BC
      TSF:PNG:SEND,TO=0
      TSF:CKU:OK
      TSF:MSG:GWL OK
      TSF:MSG:BC
      TSF:PNG:SEND,TO=0
      TSF:CKU:OK
      TSF:MSG:GWL OK
      TSF:SRT:OK
      TSM:READY:NWD REQ
      TSF:SAN:OK
      TSF:MSG:BC
      TSF:PNG:SEND,TO=0
      TSF:CKU:OK
      TSF:MSG:GWL OK
      TSF:MSG:BC
      TSF:PNG:SEND,TO=0
      TSF:CKU:OK
      TSF:MSG:GWL OK
      TSF:MSG:BC
      TSF:PNG:SEND,TO=0
      TSF:CKU:OK
      TSF:MSG:GWL OK
      TSF:MSG:BC
      TSF:PNG:SEND,TO=0
      TSF:CKU:OK
      TSF:MSG:GWL OK
      TSF:MSG:BC
      TSF:PNG:SEND,TO=0
      TSF:CKU:OK
      TSF:MSG:GWL OK
      TSF:MSG:BC
      TSF:CKU:OK,FCTRL
      TSF:MSG:GWL OK
      Thanks in advance
      mfalkviddM Online
      mfalkviddM Online
      Welcome to the forum @Jenkins
      Are you sure this log is from the Raspberry Pi gateway? It looks like a node log.
      • J Offline
        J Offline
        Jenkins
        Hello @mfalkvidd
        Thanks for the reply, I reread the instructions https://www.mysensors.org/build/raspberry and ran the following commands.
        git clone https://github.com/mysensors/MySensors.git --branch development
        cd MySensors
        The choice of these commands was based on wanting to use the raspberry py to recive information on the nrf24l01 chip and share it on an ethernet gateway.
        ./configure --my-transport=rf24 --my-gateway=ethernet --my-port=5003
        make
        sudo ./bin/mysgw
        This was the output I got with the sensor on the arduio already on and running the code.
        Apr 03 19:23:36 ERROR Failed to open log pipe.
        Apr 03 19:23:36 INFO  Starting gateway...
        Apr 03 19:23:36 INFO  Protocol version - 2.4.0-alpha
        Apr 03 19:23:36 DEBUG MCO:BGN:INIT GW,CP=RNNGL---,FQ=NA,REL=0,VER=2.4.0-alpha
        Apr 03 19:23:36 DEBUG TSF:LRT:OK
        Apr 03 19:23:36 DEBUG TSM:INIT
        Apr 03 19:23:36 DEBUG TSF:WUR:MS=0
        Apr 03 19:23:36 DEBUG TSM:INIT:TSP OK
        Apr 03 19:23:36 DEBUG TSM:INIT:GW MODE
        Apr 03 19:23:36 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
        Apr 03 19:23:36 DEBUG MCO:REG:NOT NEEDED
        Apr 03 19:23:36 DEBUG Listening for connections on :5003
        Apr 03 19:23:36 DEBUG MCO:BGN:STP
        Apr 03 19:23:36 DEBUG MCO:BGN:INIT OK,TSP=1
        Apr 03 19:23:36 DEBUG TSM:READY:NWD REQ
        Apr 03 19:23:36 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
        Apr 03 19:23:57 DEBUG TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        Apr 03 19:23:57 DEBUG TSF:MSG:BC
        Apr 03 19:23:57 DEBUG TSF:MSG:FPAR REQ,ID=3
        Apr 03 19:23:57 DEBUG TSF:PNG:SEND,TO=0
        Apr 03 19:23:57 DEBUG TSF:CKU:OK
        Apr 03 19:23:57 DEBUG TSF:MSG:GWL OK
        Apr 03 19:23:58 DEBUG !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
        Apr 03 19:23:59 DEBUG TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        Apr 03 19:23:59 DEBUG TSF:MSG:BC
        Apr 03 19:23:59 DEBUG TSF:MSG:FPAR REQ,ID=3
        Apr 03 19:23:59 DEBUG TSF:CKU:OK,FCTRL
        Apr 03 19:23:59 DEBUG TSF:MSG:GWL OK
        Apr 03 19:24:00 DEBUG !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
        Apr 03 19:24:53 DEBUG TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        Apr 03 19:24:53 DEBUG TSF:MSG:BC
        Apr 03 19:24:53 DEBUG TSF:MSG:FPAR REQ,ID=3
        Apr 03 19:24:53 DEBUG TSF:PNG:SEND,TO=0
        Apr 03 19:24:53 DEBUG TSF:CKU:OK
        Apr 03 19:24:53 DEBUG TSF:MSG:GWL OK
        Apr 03 19:24:53 DEBUG !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
        Apr 03 19:24:53 DEBUG TSF:CKU:OK,FCTRL
        Apr 03 19:24:54 DEBUG !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
        Apr 03 19:25:18 DEBUG TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        Apr 03 19:25:18 DEBUG TSF:MSG:BC
        Apr 03 19:25:18 DEBUG TSF:MSG:FPAR REQ,ID=3
        Apr 03 19:25:18 DEBUG TSF:PNG:SEND,TO=0
        Apr 03 19:25:18 DEBUG TSF:CKU:OK
        Apr 03 19:25:18 DEBUG TSF:MSG:GWL OK
        Apr 03 19:25:19 DEBUG !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
        Apr 03 19:25:19 DEBUG TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        Apr 03 19:25:19 DEBUG TSF:MSG:BC
        Apr 03 19:25:19 DEBUG TSF:MSG:FPAR REQ,ID=3
        Apr 03 19:25:19 DEBUG TSF:CKU:OK,FCTRL
        Apr 03 19:25:19 DEBUG TSF:MSG:GWL OK
        Apr 03 19:25:20 DEBUG !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
        Apr 03 19:25:43 DEBUG TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        Apr 03 19:25:43 DEBUG TSF:MSG:BC
        Apr 03 19:25:43 DEBUG TSF:MSG:FPAR REQ,ID=3
        Apr 03 19:25:43 DEBUG TSF:PNG:SEND,TO=0
        Apr 03 19:25:43 DEBUG TSF:CKU:OK
        Apr 03 19:25:43 DEBUG TSF:MSG:GWL OK
        Apr 03 19:25:43 DEBUG !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
        Apr 03 19:26:08 DEBUG TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        Apr 03 19:26:08 DEBUG TSF:MSG:BC
        Apr 03 19:26:08 DEBUG TSF:MSG:FPAR REQ,ID=3
        Apr 03 19:26:08 DEBUG TSF:PNG:SEND,TO=0
        Apr 03 19:26:08 DEBUG TSF:CKU:OK
        Apr 03 19:26:08 DEBUG TSF:MSG:GWL OK
        Apr 03 19:26:08 DEBUG !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
        The code on the arduino is as below
         * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
         * http://www.mysensors.org/build/temp
        #define MY_RADIO_RF24
        #include <OneWire.h>
        #define MY_RF24_CE_PIN 49
        #define MY_RF24_CS_PIN 53
        int numSensors=0;
        bool receivedConfig = false;
        bool metric = true;
        MyMessage msg(0,V_TEMP);
        void before()
          sensors.begin();
             present(i, S_TEMP);
            // start serial port
          //Serial.begin(9600);
          //Serial.println("Dallas Temperature IC Control Library Demo");
          sleep(conversionTime);
            #if COMPARE_TEMP == 1
          sleep(SLEEP_TIME);
        Does this all look ok? I feel like I missed something as the output above looks similar still. If it makes any difference I am using a raspberry PI 4 runnning buster.
        I will continue to also read other posts to see if I can find my error. Thank you for your help.
        • mfalkviddM Online
          mfalkviddM Online
          Sorry, my bad. It is clearly a gateway log.
          The first line here shows that the gateway received a message from node 3.
          The message is a Find Parent request, which means node 3 is asking for the gateway.
          The last line is the gateway sending a response. The ! before TSF and the st=NACK means that the gateway sent the message, but the gateway did not receive acknowledgement from the node that the node received the reply.
          The most common cause is unstable power supply. What capacitor(s) are you using? (On the Raspberry and on the node). How is the nrf powered on the node?
          If you haven't already, see https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for the most common problems and how to troubleshoot them efficiently.
          • J Offline
            J Offline
            Jenkins
            Hello
            Before my post was approved last night I did realise I was missing capacitors on the rf24 modules. The node has the rf24 module powered from the 3.3v pin of the arduino mega. The raspberry pi gpio 3.3v is powering the other rf24. I have ordered some capacitors so will see if that helps when they arrive sometime next week.
            Thanks for the help
            • J Offline
              J Offline
              Jenkins
              The Capacitors took a lot longer than they should due to the post being slow at the moment. But I think it now works, here is a trace do you agree?
              pi@RASPINAS:~ $ sudo /usr/local/bin/mysgw
              Apr 14 14:01:03 INFO  Starting gateway...
              Apr 14 14:01:03 INFO  Protocol version - 2.4.0-alpha
              Apr 14 14:01:03 DEBUG MCO:BGN:INIT GW,CP=RNNGL---,FQ=NA,REL=0,VER=2.4.0-alpha
              Apr 14 14:01:03 DEBUG TSF:LRT:OK
              Apr 14 14:01:03 DEBUG TSM:INIT
              Apr 14 14:01:03 DEBUG TSF:WUR:MS=0
              Apr 14 14:01:03 DEBUG TSM:INIT:TSP OK
              Apr 14 14:01:03 DEBUG TSM:INIT:GW MODE
              Apr 14 14:01:03 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
              Apr 14 14:01:03 DEBUG MCO:REG:NOT NEEDED
              Apr 14 14:01:03 DEBUG Listening for connections on ���:5003
              Apr 14 14:01:03 DEBUG MCO:BGN:STP
              Apr 14 14:01:03 DEBUG MCO:BGN:INIT OK,TSP=1
              Apr 14 14:01:03 DEBUG TSM:READY:NWD REQ
              Apr 14 14:01:03 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
              Apr 14 14:01:11 DEBUG TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
              Apr 14 14:01:11 DEBUG TSF:MSG:BC
              Apr 14 14:01:11 DEBUG TSF:MSG:FPAR REQ,ID=2
              Apr 14 14:01:11 DEBUG TSF:CKU:OK,FCTRL
              Apr 14 14:01:11 DEBUG TSF:MSG:GWL OK
              Apr 14 14:01:12 DEBUG !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
              Apr 14 14:01:13 DEBUG TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
              Apr 14 14:01:13 DEBUG TSF:MSG:BC
              Apr 14 14:01:13 DEBUG TSF:MSG:FPAR REQ,ID=2
              Apr 14 14:01:13 DEBUG TSF:CKU:OK,FCTRL
              Apr 14 14:01:13 DEBUG TSF:MSG:GWL OK
              Apr 14 14:01:14 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
              Apr 14 14:01:15 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
              Apr 14 14:01:15 DEBUG TSF:MSG:PINGED,ID=2,HP=1
              Apr 14 14:01:15 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
              Apr 14 14:01:15 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              Apr 14 14:01:15 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              Apr 14 14:01:15 DEBUG TSF:MSG:READ,2-2-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.2
              Apr 14 14:01:15 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
              Apr 14 14:01:17 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=11,pt=0,l=18,sg=0:Temperature Sensor
              Apr 14 14:01:17 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
              Apr 14 14:01:17 DEBUG TSF:MSG:READ,2-2-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
              Apr 14 14:01:17 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
              Apr 14 14:01:17 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
              Apr 14 14:01:18 DEBUG TSF:MSG:READ,2-2-0,s=0,c=1,t=0,pt=7,l=5,sg=0:25.0
              Apr 14 14:01:48 DEBUG TSF:MSG:READ,2-2-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.5
              Apr 14 14:16:03 DEBUG TSF:SAN:OK
              Apr 14 14:21:03 DEBUG TSM:READY:NWD REQ
              Apr 14 14:21:03 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
              Thank you
              • J Jenkins
                Thank you
                mfalkviddM Online
                mfalkviddM Online
                @Jenkins yes that looks good. st=OK means the next node acknowledged the message.
                J 1 Reply Last reply
                  J Offline
                  J Offline
                  Jenkins
                  @mfalkvidd thank you for all your help
