  3. Home Assistant
  4. mysensors integration freezes when it triggers switch.toggle
8 Posts 2 Posters 687 Views 2 Watching
  • K Offline
    K Offline
    kiesel
    I have an IR-sensor attached to one of my nodes. The goal is to be able to trigger various automations with my TV remote. So far most seem to be working fine, except for switches.
    I am using this automation:
    alias: 'Infrared Debug'
    trigger:
      platform: state
      entity_id: sensor.mysensors_wohnzimmer_main_3_3
    condition:
      condition: template
      value_template: "{{ trigger.to_state.state != '0' }}"
    action:
      - service: system_log.write
        data_template:
          message: >
                  "Automation IR Debug: {{trigger.to_state.state}}"
          level: warning
      - service: switch.toggle
        entity_id: switch.kleine_lampe
    When I press the same button a view times the switch gets toggled but at some point the whole integration stops working. Here is an annotated logfile. My comments are {written like this}:
    2020-04-18 22:52:02 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:334151 TSF:MSG:READ,3-3-0,s=3,c=1,t=33,pt=5,l=4,sg=0:551505585 {Button pressed}
    [homeassistant.components.mysensors.gateway] Node update: node 3 child 3
    2020-04-18 22:52:02 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: mysensors_wohnzimmer_main 3 3: value_type 33, value = 551505585
    2020-04-18 22:52:02 WARNING (MainThread) [homeassistant.components.system_log.external] "Automation IR Debug: 551505585"
    2020-04-18 22:52:03 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:334311 TSF:MSG:READ,3-3-0,s=3,c=1,t=33,pt=2,l=2,sg=0:0 {second message to workaround another issue, ignored by the automation}
    2020-04-18 22:52:03 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 3 child 3
    2020-04-18 22:52:03 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: mysensors_wohnzimmer_main 3 3: value_type 33, value = 0
    2020-04-18 22:52:04 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:336228 TSF:MSG:READ,3-3-0,s=3,c=1,t=33,pt=5,l=4,sg=0:551505585 {Button pressed}
    2020-04-18 22:52:04 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 3 child 3
    2020-04-18 22:52:05 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: mysensors_wohnzimmer_main 3 3: value_type 33, value = 551505585
    2020-04-18 22:52:05 WARNING (MainThread) [homeassistant.components.system_log.external] "Automation IR Debug: 551505585"
    2020-04-18 22:52:05 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:336388 TSF:MSG:READ,3-3-0,s=3,c=1,t=33,pt=2,l=2,sg=0:0 {second message to workaround another issue, ignored by the automation}
    2020-04-18 22:52:05 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 3 child 3
    2020-04-18 22:52:05 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: mysensors_wohnzimmer_main 3 3: value_type 33, value = 0
    2020-04-18 22:52:06 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:337334 TSF:MSG:READ,3-3-0,s=3,c=1,t=33,pt=5,l=4,sg=0:34469099 {Button pressed}
    2020-04-18 22:52:06 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 3 child 3
    2020-04-18 22:52:06 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: mysensors_wohnzimmer_main 3 3: value_type 33, value = 34469099 {Button pressed}
    2020-04-18 22:52:06 WARNING (MainThread) [homeassistant.components.system_log.external] "Automation IR Debug: 34469099"
    2020-04-18 22:52:06 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:337491 TSF:MSG:READ,3-3-0,s=3,c=1,t=33,pt=2,l=2,sg=0:0 {second message to workaround another issue, ignored by the automation}
    2020-04-18 22:52:06 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: mysensors_wohnzimmer_main 3 3: value_type 33, value = 0{second message to workaround another issue, ignored by the automation}
    2020-04-18 22:52:06 DEBUG (SyncWorker_9) [mysensors.persistence] Saving sensors to persistence file /config/mysensors1.pickle
    2020-04-18 22:52:06 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:338235 TSF:MSG:READ,3-3-0,s=3,c=1,t=33,pt=5,l=4,sg=0:551505585 {Button pressed}
    2020-04-18 22:52:07 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: mysensors_wohnzimmer_main 3 3: value_type 33, value = 551505585
    2020-04-18 22:52:07 WARNING (MainThread) [homeassistant.components.system_log.external] "Automation IR Debug: 551505585"
    2020-04-18 22:52:07 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:338395 TSF:MSG:READ,3-3-0,s=3,c=1,t=33,pt=2,l=2,sg=0:0 {second message to workaround another issue, ignored by the automation}
    2020-04-18 22:52:07 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 3 child 3
    2020-04-18 22:52:07 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: mysensors_wohnzimmer_main 3 3: value_type 33, value = 0
    2020-04-18 22:52:16 DEBUG (SyncWorker_8) [mysensors.persistence] Saving sensors to persistence file /config/mysensors1.pickle
    After this the integration doesn't answer to any more messages, though HA is running fine and I can toggle the lamp from lovelace.
    This doesn't happen with other services, it's just the switch that has this issue. It also happens when I use switch.turn_on and switch.turn_off.
    The switch is a tasmota-flashed plug, controlled by MQTT.
    Does anybody have an idea what I am doing wrong or how I can debug this further?
    • K Offline
      K Offline
      kiesel
      I decided to wait for some time after a freeze and I noticed that the gateway comes back after max 15 minutes:
      2020-04-19 21:51:06 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:48615 TSF:MSG:READ,3-3-0,s=3,c=1,t=33,pt=5,l=4,sg=0:34469099
      2020-04-19 21:51:06 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 3 child 3
      2020-04-19 21:51:07 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: mysensors_wohnzimmer_main 3 3: value_type 33, value = 34469099
      2020-04-19 21:51:07 WARNING (MainThread) [homeassistant.components.system_log.external] "Automation IR Debug: 34469099"
      2020-04-19 21:51:07 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:48775 TSF:MSG:READ,3-3-0,s=3,c=1,t=33,pt=2,l=2,sg=0:0
      2020-04-19 21:51:07 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 3 child 3
      2020-04-19 21:51:07 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: mysensors_wohnzimmer_main 3 3: value_type 33, value = 0
      2020-04-19 21:51:14 WARNING (MainThread) [homeassistant.components.light.reproduce_state] Unable to find entity light.grosse_lampe
      2020-04-19 21:51:16 DEBUG (SyncWorker_5) [mysensors.persistence] Saving sensors to persistence file /config/mysensors1.pickle
      2020-04-19 22:00:47 WARNING (MainThread) [homeassistant.components.light.reproduce_state] Unable to find entity light.grosse_lampe
      2020-04-19 22:05:20 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:900026 !TSF:SAN:FAIL
      2020-04-19 22:05:20 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:900034 TSM:FAIL:CNT=1
      2020-04-19 22:05:20 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:900044 TSM:FAIL:DIS
      2020-04-19 22:05:20 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:900052 TSF:TDI:TSL
      2020-04-19 22:05:30 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:910063 TSM:FAIL:RE-INIT
      2020-04-19 22:05:30 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:910071 TSM:INIT
      2020-04-19 22:05:30 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:910082 TSM:INIT:TSP OK
      2020-04-19 22:05:30 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:910090 TSM:INIT:GW MODE
      2020-04-19 22:05:30 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:910100 TSM:READY:ID=0,PAR=0,DIS=0
      2020-04-19 22:05:30 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:910112 TSM:READY:NWD REQ
      2020-04-19 22:05:30 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:910127 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
      2020-04-19 22:06:22 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:962252 TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      2020-04-19 22:06:22 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:962269 TSF:MSG:BC
      2020-04-19 22:06:22 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:962277 TSF:MSG:FPAR REQ,ID=2
      2020-04-19 22:06:22 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:962289 TSF:PNG:SEND,TO=0
      2020-04-19 22:06:22 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:962299 TSF:CKU:OK
      2020-04-19 22:06:22 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:962308 TSF:MSG:GWL OK
      2020-04-19 22:06:23 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:963104 TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
      2020-04-19 22:06:24 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:964259 TSF:MSG:READ,2-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
      2020-04-19 22:06:24 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:964278 TSF:MSG:PINGED,ID=2,HP=1
      2020-04-19 22:06:24 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:964501 TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
      2020-04-19 22:06:24 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:964528 TSF:MSG:READ,2-2-0,s=255,c=3,t=32,pt=5,l=4,sg=0:500
      Am I reading this right that the connection to the chip failed? Any ideas how this could happens and what triggers a restart?
      • K Offline
        K Offline
        kiesel
        wrote on last edited by kiesel
        Even more weirdness: I tried to workaround this by creating an input_boolean, to decouple the switch.toggle from the mysensors integration.
        I am using this automation to toggle the input_boolean:
        trigger:
          platform: state
        condition:
          condition: or
          conditions:
            - condition: template
              value_template: "{{ trigger.to_state.state == '551505585' }}"
              value_template: "{{ trigger.to_state.state == '34469099' }}"
        action:
            data_template:
              message: >
              level: warning
          - service: input_boolean.toggle
            entity_id: input_boolean.wa_kleine_lampe_infrared_switch
        And this automation to toggle the switch when a change of the input_boolean is detected:
        trigger:
          platform: state
        action:
        Still, the integration freezes for some time. If I omit the second automation (don't toggle the switch) then I can press the remote button for all eternity (untested) and the integration doesn't crash/freeze.
        There must be some sort of feedback that's too much for the mysensors integration. I noticed the switch is somewhat slow, could the slowness of the switch be the issue here? It's a plug running the newest tasmota firmware (updated it because of this issue).
        • monteM Offline
          monteM Offline
          monte
          wrote on last edited by monte
          @kiesel what type of transport do you use? Serial, MQTT, Ethernet? Have you read this paragraph from the manual:
          "The MySensors switch platform exposes a service to change an IR code attribute for an IR switch device and turn the switch on. The IR switch will automatically be turned off after being turned on, if optimistic is set to true in the configuration for the MySensors component. This will simulate a push button on a remote. If optimistic is false, the MySensors device will have to report its updated state to reset the switch"?
          Maybe this is the problem?
          K 1 Reply Last reply
          • monteM monte
            K Offline
            K Offline
            kiesel
            @monte
            If I get that correctly then that manual is about sending an IR-code to a node, but I am receiving an IR-code from a node. Based on that code I then want to do certain things, like turning a lamp on.
            I am using a serial gateway, here is the corresponding config:
            mysensors:
              gateways:
                    - device: '/dev/ttyUSB0'
                      baud_rate: 38400
              version: '2.3'
            And here is the sketch of the node with the IR-receiver:
            // Enable debug prints
            #define MY_OWN_DEBUG
            #ifndef MY_OWN_DEBUG //disable serial in production compile, potentially saves few uA in sleep mode
                 #define MY_DISABLED_SERIAL
            #define MY_RADIO_RFM69
            #define MY_IS_RFM69HW
            #define MY_RFM69_NEW_DRIVER
            #define MY_NODE_ID 3
            // IR specific setup
            #include <IRremote.h>
            int RECV_PIN     = 3;
            IRrecv            irrecv(RECV_PIN);
            decode_results    ircode;
            unsigned long last_value;
            // IR specific setup end
            #define CHILD_ID_HUM  0
            #define CHILD_ID_TEMP 1
            #define CHILD_ID_LUX  2
            #define CHILD_ID_IR 3
            #define SKETCH_NAME "mysensors_wohnzimmer_main"
            #define SKETCH_MAJOR_VER "1"
            #define SKETCH_MINOR_VER "0"
            static bool metric = true;
            int oldBatteryPcnt = 0;
            float lastHum = 0;
            float lastTemp = 0;
            int lastLux = 0;
            static const unsigned long UPDATE_INTERVAL = 90000;
            #include <SI7021.h>
            #include <BH1750.h>
            static SI7021 tempsensor;
            BH1750 lightmeter;
            MyMessage msgLux(CHILD_ID_LUX, V_LEVEL);
            MyMessage msgIrRecord(CHILD_ID_IR, V_IR_RECEIVE);
              present(CHILD_ID_HUM, S_HUM);
              present(CHILD_ID_LUX, S_LIGHT_LEVEL);
              present(CHILD_ID_IR, S_IR);
              //Serial.begin(9600);
              //Serial.print("Starting: ");
              while (not tempsensor.begin())
                Serial.println(F("Temperaturesensor not detected!"));
                delay(5000);
                #ifdef MY_OWN_DEBUG
                Serial.println("Tempsensor started");
              lightmeter.begin();
              #ifdef MY_OWN_DEBUG
                Serial.print("UPDATE_INTERVAL:");Serial.println(UPDATE_INTERVAL);
              irrecv.enableIRIn();
            void loop(){
              int8_t wake_reason;
              //send(msgIrRecord.set(0));
              sleep_bod_disable();//disable BOD  - saves~ 15uA
              wake_reason = sleep(RECV_PIN-2, FALLING, UPDATE_INTERVAL);
              #ifdef MY_OWN_DEBUG
              Serial.print("wake_reason=");Serial.println(wake_reason);
              if (wake_reason == 1){
                //woken up by interrupt on d3
                ir_received();
              else{
                //woken by update_interval
                update_interval();
              //send battery value
              //battery(); //TODO
            void ir_received(){
              delay(100);
              detachInterrupt(RECV_PIN-2);
                if (irrecv.decode(&ircode)) {
                  //#ifdef MY_OWN_DEBUG
                  //dump(&ircode);
                  //#endif
                  unsigned long ir_value = ircode.value;
                  if (ir_value == REPEAT) //if repeat-code: send last code
                     ir_value = last_value;
                  else{ //if not: save new value as last value
                    last_value = ir_value;
                  #ifdef MY_OWN_DEBUG
                  Serial.println(ir_value,HEX);
                  Serial.println(ir_value);
                  send(msgIrRecord.set(ir_value));
                  delay(150); //without this appdaemon doesn't have enough time to react.
                  irrecv.resume(); // Receive the next value
                //delay(100);
                Serial.println("IR Processing done--------------------");
            void update_interval()
              #ifdef MY_OWN_DEBUG
              Serial.println("In loop");
              // Read temperature & humidity from sensor.
              const float temperature = float( metric ? tempsensor.getCelsiusHundredths() : tempsensor.getFahrenheitHundredths() ) / 100.0;
              float roundedTemp = floorf(temperature * 10) / 10; //round temp down to 1 decimal
              const float humidity    = float( tempsensor.getHumidityBasisPoints() ) / 100.0;
              float roundedHum = floorf(humidity * 10) / 10; //round humidty down to 1 decimal
              lightmeter.configure(BH1750_ONE_TIME_HIGH_RES_MODE);
              //delay(500); // Allow some time
              const uint16_t lux = lightmeter.readLightLevel();
            #ifdef MY_OWN_DEBUG
              Serial.print(F("Temp "));
              Serial.print(temperature);
              Serial.print(metric ? 'C' : 'F');
              Serial.print(F("\tHum "));
              Serial.println(humidity);
              Serial.print("Light: ");
              Serial.print(lux);
              Serial.println(" lx");
              Serial.println("-------");
              if (lastHum != roundedHum){
                  #ifdef MY_OWN_DEBUG
                    Serial.print("roundedHum: ");Serial.println(roundedHum);
                send(msgHum.set(roundedHum, 1));
                lastHum = roundedHum;
              if (lastTemp != roundedTemp){
                lastTemp = roundedTemp;
              if (lastLux != lux){
                send(msgLux.set(lux, 1));
                lastLux = lux;
              battery();
              // Sleep until next update to save energy
              //sleep_bod_disable();//disable BOD  - saves~ 15uA
              //smartSleep(UPDATE_INTERVAL);
            void battery(){
                  // get the battery Voltage
            #ifdef MY_OWN_DEBUG
                Serial.println(sensorValue);
            #ifdef MY_OWN_DEBUG
                float batteryV  = sensorValue * 0.003363075;//3.44v
                //float batteryV  = sensorValue *   0.002541544; //2.6v
                Serial.print(batteryV);
                Serial.println(" V");
                Serial.print(batteryPcnt);
                Serial.println(" %");
                    // Power up radio after sleep
                    oldBatteryPcnt = batteryPcnt;
            The node is waken up by an interrupt when the ir-sensor reads a code. It also polls the other two sensors (temp/humid, lux) once every 90 seconds.
            • K Offline
              K Offline
              kiesel
              Ok, so I think I have been getting at this the wrong way around...
              Switching the switch on and off kills the integration/the gateway, it doesn't matter whether the node sent an ir-code to the gateway first. I verified this by opening lovelace and turning the switch on and off from there a few times. The result is that no new messages can be received from any nodes.
              The switch in question is a tasmota flashed Gosund SP1 switch that has auto-discovery for Home Assistant activated (SetOption19). It connects to Home Assistant via mqtt. Since the gateway is a serial gateway I can't see how mqtt messages could kill the gateway.
              • K kiesel
                K Offline
                K Offline
                kiesel
                I found the issue. Everything works as expected when I use put the plug into another outlet. So this must be a power issue. I will create another thread for how to fix this.
                monteM 1 Reply Last reply
                • K kiesel
                  monteM Offline
                  monteM Offline
                  monte
                  @kiesel interesting! But weird :)
                  But why the power issue with one of the devices connected to HA breaks integration with Mysensors particularly?
                  11.9k
                  113.3k
