  3. RF Nano = Nano + NRF24, for just $3,50 on Aliexpress
80 Posts 30 Posters 26.0k Views 32 Watching
  • D Dustin Thurston
    I previously purchased from the exact product link listed by @Mark-Swift and confirmed they are not + models.
    Mark SwiftM
    Mark SwiftM
    Mark Swift
    @dustin-thurston Mine are certainly plus models, as they connect at 250kbps without issue (nor do they need debug turned on).
    D 1 Reply Last reply
    • Mark SwiftM Mark Swift
      Dustin Thurston
      Can others report their luck? I hate to purchase again and get same result. Especially when seller was non-responsive.
      • T
        torfinn
        Hi ! Got a couple of these. Hard to say if its + chip ( but I guess not ). Anyway I am not able to get them running a simple test sketch. Only get RBR:REG=23, VAL=17
        Z 1 Reply Last reply
        • T torfinn
          Z
          Z
          zen85
          @torfinn
          i had to set
          #define MY_RF24_CE_PIN 10
          #define MY_RF24_CS_PIN 9
          on mine (definetly not + btw) a while back....
          • fruijsF
            fruijsF
            fruijs
            I just got my order of 3, this time I got the nRF24L01+ version.
            • alowhumA
              alowhumA
              alowhum
              #57
              :-D Now I wish I hadn't bought 70 of the old version already.
              They're working well though, very happy with them. Great for workshops.
              • Z zen85
                @torfinn
                i had to set
                torfinn
                @zen85 Thanks I got it to work but if I add #define MY_DEBUG_VERBOSE_RF24 i still get RBR:REG=23, VAL=17 filling the console....
                • P
                  P
                  pichaty
                  Banned
                  wrote on last edited by pichaty
                  #59
                  • alowhumA
                    alowhumA
                    alowhum
                    @torfinn These settings should make it work, regardless of which version you buy:
                    // If you are using an RF-Nano, you have to switch CE and CS pins.
                    #define MY_RF24_CS_PIN 9                            // Used by the MySensors library.
                    #define MY_RF24_CE_PIN 10                           // Used by the MySensors library.
                    #define MY_RADIO_RF24
                    // Mysensors advanced settings
                    #define MY_RF24_DATARATE RF24_1MBPS                 // This datarate is supported by pretty much all NRF24 radios, including the RF-Nano.
                      Sherco49
                      Hi guys
                      just a newbie in MySensors, i am buikding my home net with RF24 radio.
                      Just received 4 of this rf-nano (+ chip) and set one into relay device
                      With my Wemos D1mini pro + NRF24L01 +PA+LA gateway, it works in my whole (relatively large) house (approx 30m through a lot of walls and armed floor).
                      Really handy for small boxes projects, the missing functionality is the interrupt pin not (easily ?) accessible for battery powering
                        Sherco49
                        I continue my test with this chip, and solved an issue in declaring children of a node
                        I tried the relay actuator with 2 relays, the second one never wanted to get an ACK message for the presentation message
                        I tried with 3 children relays , first is ACK, second still NACK and 3rd .... ACK again !
                        Even if it was not my first thought, i finally insert a wait(1000) between each present line which solved the problem
                        hope it can help
                        • E
                          E
                          echi
                          You might be interested by the board I've designed. Not "RF Nano" but "RF Pro Mini". Of course you need a "USB to serial" programmer but it directly runs on batteries.
                          See here and here.
                          • E echi
                            See here and here.
                            martim
                            @echi Where could you order this board?
                            TheoLT N 2 Replies Last reply
                            • M martim
                              TheoLT
                              TheoLT
                              TheoL
                              @martim Just search for RF Nano on Aliexpress. Haven't looked for the cheapest one, just the first that says LRF24L01+. Although not certain if it is really a + version of the NRF24L01.
                              This is one on Aliexpress
                              • M martim
                                N
                                N
                                ncollins
                                @martim I think this is a better alternative: https://www.electrodragon.com/product/nrf24duino-arduino-mini-plus-nrf24l01-board/
                                TheoLT M 2 Replies Last reply
                                • N ncollins
                                  TheoLT
                                  TheoLT
                                  TheoL
                                  wrote on last edited by TheoL
                                  #67
                                  @ncollins That is a nice board indeed. I haven't checked because I will order some things after dinner. For me it is a must to keep the arduino Nano footprint. So I can replace the nano and nrf in some of the projects I already built.
                                  • TheoLT TheoL
                                    martim
                                    @TheoL I meant the board of @echi here as I need battery power board and this seems to be working well.
                                    • N ncollins
                                      martim
                                      @ncollins If this board is suitable for battery use? I don't see how much current it uses.
                                      N 1 Reply Last reply
                                      • M martim
                                        N
                                        N
                                        ncollins
                                        @martim Yep, you just need to make sure to turn off the EEPROM module after setup, then it's basically an Atmega328p and NRF24L01+. It has solderable jumpers to bypass the voltage regulator and status LED.
                                        Here is a claim of 12uA in sleep: https://forum.mysensors.org/post/96631
                                        • TheoLT
                                          TheoLT
                                          TheoL
                                          Why not go for a sensebender? https://www.itead.cc/mysensors-micro.html
                                          I have one in each room, measuring temp and humidity. It works great
