  3. RF Nano = Nano + NRF24, for just $3,50 on Aliexpress
80 Posts 30 Posters 26.0k Views 32 Watching
  • Mark SwiftM
    Mark SwiftM
    Mark Swift
    Just got 4 of these, happy to say they're all '+' models and connect without issues, bingo!
    fruijsF 1 Reply Last reply
    • Mark SwiftM Mark Swift
      fruijsF
      fruijsF
      fruijs
      @mark-swift Do you have a link of your supplier?
      Mark SwiftM 1 Reply Last reply
      • fruijsF fruijs
        Mark SwiftM
        Mark SwiftM
        Mark Swift
        @fruijs I bought them here: https://www.aliexpress.com/item/32980796969.html?spm=a2g0s.9042311.0.0.61584c4dSzvgS3
        • D
          Dustin Thurston
          I previously purchased from the exact product link listed by @Mark-Swift and confirmed they are not + models.
          • D Dustin Thurston
            Mark SwiftM
            Mark SwiftM
            Mark Swift
            @dustin-thurston Mine are certainly plus models, as they connect at 250kbps without issue (nor do they need debug turned on).
            D 1 Reply Last reply
              Dustin Thurston
              Can others report their luck? I hate to purchase again and get same result. Especially when seller was non-responsive.
              • T
                torfinn
                Hi ! Got a couple of these. Hard to say if its + chip ( but I guess not ). Anyway I am not able to get them running a simple test sketch. Only get RBR:REG=23, VAL=17
                Z 1 Reply Last reply
                • T torfinn
                  Z
                  Z
                  zen85
                  @torfinn
                  i had to set
                  #define MY_RF24_CE_PIN 10
                  #define MY_RF24_CS_PIN 9
                  on mine (definetly not + btw) a while back....
                  • fruijsF
                    fruijsF
                    fruijs
                    I just got my order of 3, this time I got the nRF24L01+ version.
                    • alowhumA
                      alowhumA
                      alowhum
                      #57
                      :-D Now I wish I hadn't bought 70 of the old version already.
                      They're working well though, very happy with them. Great for workshops.
                      • Z zen85
                        @torfinn
                        i had to set
                        torfinn
                        @zen85 Thanks I got it to work but if I add #define MY_DEBUG_VERBOSE_RF24 i still get RBR:REG=23, VAL=17 filling the console....
                        • P
                          P
                          pichaty
                          Banned
                          wrote on last edited by pichaty
                          #59
                          • alowhumA
                            alowhumA
                            alowhum
                            @torfinn These settings should make it work, regardless of which version you buy:
                            // If you are using an RF-Nano, you have to switch CE and CS pins.
                            #define MY_RF24_CS_PIN 9                            // Used by the MySensors library.
                            #define MY_RF24_CE_PIN 10                           // Used by the MySensors library.
                            #define MY_RADIO_RF24
                            // Mysensors advanced settings
                            #define MY_RF24_DATARATE RF24_1MBPS                 // This datarate is supported by pretty much all NRF24 radios, including the RF-Nano.
                              Sherco49
                              Hi guys
                              just a newbie in MySensors, i am buikding my home net with RF24 radio.
                              Just received 4 of this rf-nano (+ chip) and set one into relay device
                              With my Wemos D1mini pro + NRF24L01 +PA+LA gateway, it works in my whole (relatively large) house (approx 30m through a lot of walls and armed floor).
                              Really handy for small boxes projects, the missing functionality is the interrupt pin not (easily ?) accessible for battery powering
                                Sherco49
                                I continue my test with this chip, and solved an issue in declaring children of a node
                                I tried the relay actuator with 2 relays, the second one never wanted to get an ACK message for the presentation message
                                I tried with 3 children relays , first is ACK, second still NACK and 3rd .... ACK again !
                                Even if it was not my first thought, i finally insert a wait(1000) between each present line which solved the problem
                                hope it can help
                                • E
                                  E
                                  echi
                                  You might be interested by the board I've designed. Not "RF Nano" but "RF Pro Mini". Of course you need a "USB to serial" programmer but it directly runs on batteries.
                                  See here and here.
                                  • E echi
                                    See here and here.
                                    martim
                                    @echi Where could you order this board?
                                    TheoLT N 2 Replies Last reply
                                    • M martim
                                      TheoLT
                                      TheoLT
                                      TheoL
                                      @martim Just search for RF Nano on Aliexpress. Haven't looked for the cheapest one, just the first that says LRF24L01+. Although not certain if it is really a + version of the NRF24L01.
                                      This is one on Aliexpress
                                      • M martim
                                        N
                                        N
                                        ncollins
                                        @martim I think this is a better alternative: https://www.electrodragon.com/product/nrf24duino-arduino-mini-plus-nrf24l01-board/
                                        TheoLT M 2 Replies Last reply
                                        • N ncollins
                                          TheoLT
                                          TheoLT
                                          TheoL
                                          wrote on last edited by TheoL
                                          #67
                                          @ncollins That is a nice board indeed. I haven't checked because I will order some things after dinner. For me it is a must to keep the arduino Nano footprint. So I can replace the nano and nrf in some of the projects I already built.
