  3. NodeManager
  4. NodeManager: plugin for a rapid development of battery-powered sensors
223 Posts 23 Posters 125.8k Views 26 Watching
  • U user2684
    Hi, being a newbie in this wonderful MySensors world, I found myself excited about the flexibility of the overall platform but also somehow implementing the same common functionalities across my sensors over and over again. I decided then to spend some reasonable amount of time to expand the idea behind MyExtention (https://forum.mysensors.org/topic/6062/myextension) into something I have called NodeManager (I know, I'm bad with names!).
    NodeManager is intended to take care on your behalf of all those common tasks a MySensors node has to accomplish, speeding up the development cycle of your projects. It should help who is new to MySensors to get up to speed quicker and for those already into the matter to delegate to NodeManager common and boring tasks so to focus on more interesting scenarios.
    NodeManager main features are:
    • Manage all the aspects of a sleeping cycle by leveraging smart sleep
    • Allow configuring the sleep mode and the sleep duration remotely
    • Allow waking up a sleeping node remotely at the end of a sleeping cycle
    • Allow powering on each connected sensor only while the node is awake to save battery
    • Report battery level periodically and automatically
    • Calculate battery level without requiring an additional pin and the resistors
    • Report battery voltage through a built-in sensor
    • Can report battery level on demand
    • Allow rebooting the board remotely
    • Provide out-of-the-box sensors personalities and automatically execute their main task at each cycle
    Specifically on this last point, the idea behind providing built-in the functionalities of most common sensors is to simplify the development especially for somebody new to it.
    E.g. if I connect a thermistor to one of the pin, I just need a single line to have it working, as it was leveraging some sort of embedded firmware:
    nodeManager.registerSensor(SENSOR_THERMISTOR,A2);
    The following built-in sensors are available:
    • SENSOR_ANALOG_INPUT Generic analog sensor, return a pin's analog value or its percentage
    • SENSOR_LDR LDR sensor, return the light level of an attached light resistor in percentage
    • SENSOR_THERMISTOR Thermistor sensor, return the temperature based on the attached thermistor
    • SENSOR_DIGITAL_INPUT Generic digital sensor, return a pin's digital value
    • SENSOR_DIGITAL_OUTPUT Generic digital output sensor, allows setting the digital output of a pin to the requested value
    • SENSOR_RELAY Relay sensor, allows activating the relay
    • SENSOR_LATCHING_RELAY Latching Relay sensor, allows activating the relay with a pulse
    • SENSOR_DHT11 DHT11 sensor, return temperature/humidity based on the attached DHT sensor
    • SENSOR_DHT22 DHT22 sensor, return temperature/humidity based on the attached DHT sensor
    • SENSOR_SHT21 SHT21 sensor, return temperature/humidity based on the attached SHT21 sensor
    • SENSOR_SWITCH Generic switch, wake up the board when a pin changes status
    • SENSOR_DOOR Door sensor, wake up the board and report when an attached magnetic sensor has been opened/closed
    • SENSOR_MOTION Motion sensor, wake up the board and report when an attached PIR has triggered
    • SENSOR_DS18B20 DS18B20 sensor, return the temperature based on the attached sensor
    I put the package on Sourceforce so to avoid leaving here piece of code which may become obsolete in a short time.
    The project is here: https://sourceforge.net/projects/mynodemanager
    I've also tried to document everything the best as I could on https://sourceforge.net/p/mynodemanager/wiki
    RPunktR
    RPunktR
    RPunkt
    @user2684 Hello all of You,
    this topic is quite old, but hopefully someone is reading this.
    I could not figure out, what to do if the NRF24 is wired to different pins.
    I have a board with nrf24 on board, but this are connected like:
    #define MY_RF24_CE_PIN 7
    #define MY_RF24_CS_PIN 10
    #define MY_SOFT_SPI_SCK_PIN 11
    #define MY_SOFT_SPI_MOSI_PIN 12
    #define MY_SOFT_SPI_MISO_PIN 13
    How can this be inplemented in the nodemanager?
    U 1 Reply Last reply
    • RPunktR RPunkt
      U
      U
      user2684
      @rpunkt just use those directives in your sketch, no differences with NodeManager, those will be seen by the MySensors library and applied. Thanks
      RPunktR 1 Reply Last reply
      • U user2684
        RPunktR
        RPunktR
        RPunkt
        @user2684 Thanks a lot. I should have tried this, before to post a question, but sometimes the brain is sticky.
        • RPunktR
          RPunktR
          RPunkt
          Hello all of You,
          if have a flight time sensor VL53L0X, that is running so far.
          It should measure the water level in a rain tank.
          But now i want to customize my sensornode in that way, that two other values will be transmitted.
          It should be
          V_level, that represents the percentage of my water tank
          and
          V_volume, that represents the available volume of water
          V_level and V_volume could be calculated from the sensor value of the distance sensor (VL53L0X).
          But somehow I could not manage to to get this running. I don't know where to insert what.
          Cant someone point me to the right direction, help appreciated
          * Copyright (C) 2013-2017 Sensnology AB
          Template
          This sketch can be used as a template since containing the most relevant MySensors library configuration settings,
          NodeManager's settings, all its the supported sensors commented out and a sketch structure fully functional to operate with
          NodeManager. Just uncomment the settings you need and the sensors you want to add and configure the sensors in before()
           * MySensors node configuration
          // General settings
          #define SKETCH_NAME "NodeManager"
          #define SKETCH_VERSION "1.0"
          #define MY_NODE_ID 8
          // NRF24 radio settings
          // Advanced settings
          #define MY_BAUD_RATE 9600
           * MySensors gateway configuration
          // Common gateway settings
          //#define MY_REPEATER_FEATURE
           * NodeManager configuration
          #define NODEMANAGER_DEBUG ON
          #define NODEMANAGER_INTERRUPTS ON
          #define NODEMANAGER_SLEEP ON
          #define NODEMANAGER_RECEIVE OFF
          #define NODEMANAGER_DEBUG_VERBOSE OFF
          #define NODEMANAGER_POWER_MANAGER ON
          #define NODEMANAGER_CONDITIONAL_REPORT OFF
          #define NODEMANAGER_EEPROM OFF
          #define NODEMANAGER_TIME OFF
          #define NODEMANAGER_RTC OFF
          #define NODEMANAGER_SD OFF
          #define NODEMANAGER_HOOKING OFF
          #define NODEMANAGER_OTA_CONFIGURATION OFF
          #define NODEMANAGER_SERIAL_INPUT OFF
          // import NodeManager library (a nodeManager object will be then made available)
          #include <MySensors_NodeManager.h>
           * Add your sensors
          //PowerManager power(5,6);
          #include <sensors/SensorBattery.h>
          SensorBattery battery;
          //#include <sensors/SensorConfiguration.h>
          //SensorConfiguration configuration;
          #include <sensors/SensorSignal.h>
          SensorSignal signal;
          #include <sensors/SensorVL53L0X.h>
          SensorVL53L0X vl53l0x(9);
           * Main Sketch
          // before
          void before() {
             * Configure your sensors
            // EXAMPLES:
            // report measures of every attached sensors every 10 seconds
            nodeManager.setReportIntervalSeconds(10);
            void setADCOff();
            nodeManager.setSleepSeconds(10);
            // call NodeManager before routine
            nodeManager.before();
          // presentation
            nodeManager.presentation();
          // setup
            nodeManager.setup();
          // loop
            nodeManager.loop();
          #if NODEMANAGER_RECEIVE == ON
          // receive
            nodeManager.receive(message);
          #if NODEMANAGER_TIME == ON
          // receiveTime
            nodeManager.receiveTime(ts);
          #endif```
          • RPunktR RPunkt
            Hello all of You,
            It should be
            and
            Template
            // General settings
             * Add your sensors
             * Main Sketch
            // before
            void before() {
              // EXAMPLES:
              void setADCOff();
            // presentation
            // setup
            // loop
              nodeManager.loop();
            // receive
            // receiveTime
            #endif```
            U
            U
            user2684
            @rpunkt my recommendation would be to create a custom sensor in NodeManager which is implementing the logic you like. Feel free to copy from https://github.com/mysensors/NodeManager/blob/master/sensors/SensorVL53L0X.h and create your own or make your own class by inheriting directly from SensorVL53L0X.
            • U user2684
              RPunktR
              RPunktR
              RPunkt
              wrote on last edited by RPunkt
              #219
              @user2684 Seems to be to difficult for a rookie :sob:
              On the conventional MySensors library it is possible with my abilities, but then the power management is a issue.
              For me the NodeManager was the choice, because it saves so much battery energy.
              Other way of solution:
              A friend of mine, convinced me off doing all the calculations in the home- automation (in my case FHEM).
              Now I only use the node transmitting the distance and calculating the "volume of water" and "percentage of water" as a "user reading".
              • J
                J
                justfra
                Hello @user2684 et al,
                I'm trying to use this library on an ESP32 board. I'm trying this sketch out (https://raw.githubusercontent.com/mysensors/NodeManager/master/examples/AnalogLightAndTemperatureSensor/AnalogLightAndTemperatureSensor.ino)
                My problem is that if I just try to use the 1.8 version of NodeManager it will use as a dependency a version of MySensors which do not work with ESP32 and I get a known error regarding re-definition of app_main. Because of that I need to use the development version of MySensors but it seems not compatible with NodeManager 1.8 as I get the following error:
                In file included from .pio/libdeps/nodemcu-32s/MySensors/MySensors.h:43:0,
                                 from .pio/libdeps/nodemcu-32s/NodeManager/MySensors_NodeManager.h:43,
                                 from src\main.cpp:60:
                .pio/libdeps/nodemcu-32s/MySensors/MyConfig.h:288:2: warning: #warning MY_RADIO_NRF24 is deprecated, use MY_RADIO_RF24 instead. [-Wcpp]
                In file included from .pio/libdeps/nodemcu-32s/NodeManager/MySensors_NodeManager.h:87:0,
                .pio/libdeps/nodemcu-32s/NodeManager/nodemanager/Sensor.cpp: In member function 'void Sensor::presentation()':
                .pio/libdeps/nodemcu-32s/NodeManager/nodemanager/Sensor.cpp:135:54: error: invalid conversion from 'uint8_t {aka unsigned char}' to 'mysensors_sensor_t' [-fpermissive]
                   present(child->getChildId(), child->getPresentation(), child->getDescription(), nodeManager.getAck());
                In file included from .pio/libdeps/nodemcu-32s/MySensors/MySensors.h:433:0,
                .pio/libdeps/nodemcu-32s/MySensors/core/MySensorsCore.cpp:375:6: note:   initializing argument 2 of 'bool present(uint8_t, mysensors_sensor_t, const char*, bool)'
                 bool present(const uint8_t childSensorId, const mysensors_sensor_t sensorType,
                *** [.pio\build\nodemcu-32s\src\main.cpp.o] Error 1
                I have also tried using the development version of NodeManager with the development version of MySensors although I get the same result.
                I'm stuck and I would really appreciate any input.
                Thanks in advance!
                • U
                  U
                  user2684
                  @justfra thanks for reporting this issue, I believe there is some sort of library conflicts which is arising across MySensors/Nodemanager versions...something which has to be investigated carefully, I'll track this bug with https://github.com/mysensors/NodeManager/issues/491
                  • G
                    G
                    ghiglie
                    Oh, I hate saying I've noticed this great piece of software just now! :( It would have saved me countless hours of software tinkering, giving more eyecare for better soldering...!
                    atmega328p serial killer
                    HomeAssistant / gateway: ESP8266 & NRF24L01+ gateway
                    • U user2684
                      U
                      U
                      user2684
                      @justfra realizing only now the issue you reported was not ESP32 related but due to a compatibility issues between MySensors v2.3.2 and NodeManager just fixed in the development version with https://github.com/mysensors/NodeManager/pull/508. Either try the latest development version of NodeManager or use MySensors v2.3.1. Thanks
