  3. NodeManager
  4. Nodemanage + EasyPCB Sleep
18 Posts 6 Posters 3.0k Views 5 Watching
  • U user2684
    @ElCheekytico from the NodeManager's side, yes preferred option is to use PowerManager and connect vcc and gnd pins of the sensors to the configured two pins so that NodeManager can turn them on and off all sensors in between sleeping cycles. For these situations I usually solder a MCP1702 or similar on the prototyping area of the EasyPCB and connect sensors from there so to keep it small and self-contained.
    E
    E
    ElCheekytico
    wrote on last edited by ElCheekytico
    @user2684 The MCP1702 appears to be a voltage regulator. Are you running a higher input voltage? I am running a pro mini on the easyPCB powered by 2xAA. All the DHT22, PIR, and SSD1306 are all powered at 3.3v. My idea was to use a 2n2222a with base to D6 and E to ground and C negative of sensors. Based on a forum post or issue on your github I saw that we can pass in -1 for the ground pin of the PowerManager constructor and of course 6 would be the power pin. Does this sound like it will work?
    MatiasVM U 2 Replies Last reply
    • E ElCheekytico
      MatiasVM
      MatiasVM
      MatiasV
      @ElCheekytico, I was asking myself the same question about @user2684 approach.
      For my power hungry sensors I'm experimenting using an 2n2222A Transistor with mixed success. (following this and that instructions ).
      All works OK with sensors as DHT22 and similar digital devices, but I can't make it work with Analog sensors as an soil moisture sensor. I need to test, but I believe is because the voltage drop disturbing the AREF.
      HomeAssistant
      MyController.org
      MQTT GW WIFI
      FOTA/MYSBootloader
      Phil WhitmarshP 1 Reply Last reply
      • MatiasVM MatiasV
        Phil WhitmarshP
        Phil WhitmarshP
        Phil Whitmarsh
        @MatiasV to switch on/off power to sensors and oled displays it is best to use a logic level P-channel Fet, something like an Si2305, it is not good practice to switch power to sensors/displays by switching the ground, it's OK for a relay though.
        See this link
        https://www.avrfreaks.net/forum/hi-side-fet-switch-low-voltage
        • E ElCheekytico
          U
          U
          user2684
          @ElCheekytico my bad sorry I was referring to a PNP2222a or similar and for some reason I wrote down MCP1702. Yes, this is the approach I'm using as well, just pass the vcc pin which is activating the transistor hence powering on the sensor. You should use also some resistors, for sure to drive the base, potentially on the collector/emitter depending on the transistor you are using
          E MatiasVM 2 Replies Last reply
          • U user2684
            E
            E
            ElCheekytico
            @user2684 Thanks for the confirmation. Now I'm just not sure if I have enough IO pins without wiring directly from pro mini.
            @sundberg84 how many IO pins are actually available on easypcb rev10 without wiring directly from pro mini? I'm using D3 for PIR, A4/A5 for oled i2c, and D5 for DHT22. I think A0 is for battery voltage and D2 for RFM69. Maybe D6 and A1?
            • E ElCheekytico
              sundberg84S
              sundberg84S
              @ElCheekytico correct, every pin you have on the mysx connector.
              • U user2684
                MatiasVM
                MatiasVM
                MatiasV
                @user2684 Did you experience any problems reading analog sensors that are powered via a transistor? I can not get reliable measurements from Capacitive Soil moisture Sensors when they are switched by a transistor.
                HomeAssistant
                MyController.org
                MQTT GW WIFI
                FOTA/MYSBootloader
                Phil WhitmarshP U 2 Replies Last reply
                • MatiasVM MatiasV
                  Phil WhitmarshP
                  Phil WhitmarshP
                  Phil Whitmarsh
                  @MatiasV said in Nodemanage + EasyPCB Sleep:
                  @MatiasV - How are you wiring up your transistor?
                  Can you see the Voltage to the Sensor switching?
                  • B bikerMark
                    @sundberg84 said in Nodemanage + EasyPCB Sleep:
                    @ElCheekytico - even better with transistor if you know how, atleast for the higher current things
                    This is exactly what I'm trying to achieve these days with an Attiny. Found a way to toggle on/off with one button: http://www.technoblogy.com/show?VOO (scroll down). When OFF; ATtiny is is a 0.5uA (!) sleep.
                    Now I want to swicth the full 10Amps on 40V with that aw..Tiny signal.
                    @sundberg84 do you know how to boost the signal to a (couple of) transistor(s)?
                    Any advice would be highly appreciated!
                    Phil WhitmarshP
                    Phil WhitmarshP
                    Phil Whitmarsh
                    @bikerMark said in Nodemanage + EasyPCB Sleep:
                    I would not take too much notice of that Web Page schematics, he has drawn the Fets the wrong way around - this is on all his examples (He has mixed up the drawing of the P & N Mosfets)
                    • MatiasVM MatiasV
                      U
                      U
                      user2684
                      @MatiasV Probably you would also need to wait a bit before reading after powering on the sensor. You can try adding a delay (in millis) as third argument to setPowerPins() of PowerManager so before the reading would take place, the Power Manager will wait a bit after power on and before giving control back to the sensor.
                      • sundberg84S sundberg84
                        @bikerMark, not sure - 10A is quite the current, i think you need some sort of relay for this. Not sure - be sure to be careful and check the datasheets .
                        B
                        B
                        bikerMark
                        @sundberg84 thanks, prudence is needed indeed. I abandoned this scenario and now only switch the lower energetic part of the bike.
