  3. Node to Node Communication via Gatreway
19 Posts 5 Posters 6.0k Views 3 Watching
  • F
    F
    FullMetal
    Sorry to resort to an old topic ...
    I am currently using mysensors RS485, and I would like to extend my installation with this protocol.
    and I would like to make the nodes communicate with each other through the gateway.
    But I can't do what I want ... help!
    on my node 4, I have an input and 1 output, the input activates and deactivates the output. (here no worries).
    On my node 5, I have an input to activate the output of node 4, so I can turn it off but not turn it on, and I don't see any frames towards the gateway
    here is the code for my node 5:
    // MySensors
    #define MY_PARENT_NODE_ID 0                   // define if fixed parent
    #undef MY_REGISTRATION_FEATURE                  // sketch moves on if no registration
    #define MY_NODE_ID 5                     // fixed node number
    // Enable RS485 transport layer
    #define MY_RS485
    // Define this to enables DE-pin management on defined pin
    #define MY_RS485_DE_PIN 2
    // Set RS485 baud rate to use
    // Set blinking period
    // Flash leds on rx/tx/err
    //#define MY_DEFAULT_RX_LED_PIN  5  // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN  6  // the PCB, on board LED
    // Enable this if RS485 is connected to a hardware serial port
    //#define MY_RS485_HWSERIAL Serial1
    //#include <MqttClient.h>
    #define CHILD_ID 4
    #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    Bounce debouncer = Bounce();
    int oldValue=0;
    bool state;
      // Setup the button
      pinMode(BUTTON_PIN,INPUT_PULLUP);
      // Activate internal pull-up
      //digitalWrite(BUTTON_PIN,HIGH);
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      sendSketchInfo("Button", "1.1");
      present(CHILD_ID, S_LIGHT);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue && value==0) {
          msg.setDestination(4);
          send(msg.set(state?false:true), false);// Send new state and request ack back
      oldValue = value;
    rejoe2R 1 Reply Last reply
    • F FullMetal
      // MySensors
      #define MY_RS485
      #define CHILD_ID 4
      int oldValue=0;
      bool state;
        // Setup the button
        debouncer.update();
        oldValue = value;
      rejoe2R
      rejoe2R
      rejoe2
      @FullMetal Imo, you have to specify all send-settings in one line, e.g. like this:
      send(buttonMsg.setDestination(MY_SISTER_NODE_ID).setSensor(CHILD_ID_RESET).set( button[i] ? "1" : "0"));
      F 1 Reply Last reply
      • rejoe2R rejoe2
        F
        F
        FullMetal
        @rejoe2
        thank you for your return,
        but I have the same problem, I manage to activate the relay of node 4 from node 5, but I cannot deactivate it. and when I act on node 5 the gateway does not receive frames since it calls node 4.
        I think that node 4 should send the relay status to node 5 so that it knows whether it is activated or not.
        tekkaT rejoe2R 2 Replies Last reply
        • F FullMetal
          @rejoe2
          tekkaT
          tekkaT
          tekka
          @FullMetal Please post a full debug log of both nodes showing the observed behaviour.
          • F FullMetal
            @rejoe2
            rejoe2R
            rejoe2R
            rejoe2
            @FullMetal Pls add also code from node 4.
            In general:
            • if you want also info from node 5 to be sent to your controller/gateway, you have to add a second (normal) send command.
            • wrt. to how node 4 reacts on the messages, you may better use sth. like a toggle logic.
            • tekkaT tekka
              F
              F
              FullMetal
              @tekka @rejoe2
              Désolé de revenir si tard ..
              J'ai modifié mon code sur mes nœuds, mais le résultat n'est toujours pas là!
              Voici mes codes:
              node 4:
              // MySensors
              #define MY_NODE_ID 4                    // fixed node number
              #define MY_RS485
              #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
              #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
              #define SYSTER_ID 5
              #define RELAY_ON 1
              #define RELAY_OFF 0
              int oldValue=0;
              bool state;
              //MyMessage msgconf(CHILD_ID,V_VAR1);
                // Setup the button
                pinMode(RELAY_PIN, OUTPUT);
                state = loadState(CHILD_ID);
              *  Example on how to asynchronously check for new messages from gw
                debouncer.update();
                    send(msg.setDestination(MY_PARENT_NODE_ID).setSensor(CHILD_ID).set(state?false:true), true); // Send new state and request ack back
                    wait(100);
                    send(msg.setDestination(SYSTER_ID).setSensor(CHILD_ID).set(state?false:true), true);
                oldValue = value;
                if (message.isAck()) {
                   // Change relay state
                   state = message.getBool();
                   // Store state in eeprom
                   saveState(CHILD_ID, state);
              node 5:
              // MySensors
              #define MY_RS485
              #define CHILD_ID 1
              #define SYSTER_ID 4
              int oldValue=0;
              bool state;
                // Setup the button
                debouncer.update();
                    send(msg.setDestination(MY_PARENT_NODE_ID).setSensor(CHILD_ID).set(state?false:true), false);// Send new state and request ack back
                    Serial.println("wait 1/10sec");
                    wait(100);
                    send(msg.setDestination(SYSTER_ID).setSensor(CHILD_ID).set(state?false:true), false);
                oldValue = value;
                   //digitalWrite(RELAY_PIN, state?RELAY_ON:RELAY_OFF);
                   saveState(SYSTER_ID, state);
              From node 4, my output is activated and deactivated immediately, due to double sending
              from node 5, I can activate or deactivate if I launch the command from node 4 before otherwise.
              tekkaT 1 Reply Last reply
              • F FullMetal
                @tekka @rejoe2
                Voici mes codes:
                node 4:
                // MySensors
                #define MY_RS485
                #define SYSTER_ID 5
                #define RELAY_ON 1
                #define RELAY_OFF 0
                int oldValue=0;
                bool state;
                  // Setup the button
                  debouncer.update();
                      wait(100);
                  oldValue = value;
                node 5:
                // MySensors
                #define MY_RS485
                #define CHILD_ID 1
                #define SYSTER_ID 4
                int oldValue=0;
                bool state;
                  // Setup the button
                  debouncer.update();
                      wait(100);
                  oldValue = value;
                tekkaT
                tekkaT
                tekka
                @FullMetal said in Node to Node Communication via Gatreway: Please upload the debug logs for further troubleshooting.
                F 2 Replies Last reply
                • tekkaT tekka
                  F
                  F
                  FullMetal
                  @tekka said in Node to Node Communication via Gatreway:
                  Sorry
                  Debug logs node 4
                  Press button node 4
                  08:16:01.668 -> 13555 TSF:MSG:SEND,4-4-0-0,s=1,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
                  08:16:01.701 -> 13582 TSF:MSG:READ,0-0-4,s=1,c=1,t=2,pt=1,l=1,sg=0:0
                  08:16:01.701 -> 13586 TSF:MSG:ECHO
                  08:16:01.701 -> This is an ack from gateway
                  08:16:01.701 -> Incoming change for sensor:1, New status: 0
                  08:16:01.800 -> 13678 TSF:MSG:SEND,4-4-5-5,s=1,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:1
                  08:16:01.800 -> 13684 TSF:RTE:N2N OK
                  08:16:01.800 -> 13703 TSF:MSG:READ,5-5-4,s=1,c=1,t=2,pt=1,l=1,sg=0:1
                  08:16:01.833 -> 13708 TSF:MSG:ECHO
                  08:16:01.833 -> This is an ack from gateway
                  08:16:01.833 -> Incoming change for sensor:1, New status: 1
                  Press button node 5
                  08:21:01.371 -> 313012 TSF:MSG:READ,5-5-4,s=1,c=1,t=2,pt=1,l=1,sg=0:0
                  08:21:01.371 -> Incoming change for sensor:1, New status: 0
                  second press node 5
                  08:21:06.238 -> 317865 TSF:MSG:READ,5-5-4,s=1,c=1,t=2,pt=1,l=1,sg=0:0
                  08:21:06.238 -> Incoming change for sensor:1, New status: 0
                  Debug logs node 5
                  Press button node 4
                  08:23:59.955 -> 51752 TSF:MSG:READ,4-4-5,s=1,c=1,t=2,pt=1,l=1,sg=0:1
                  08:23:59.955 -> 51757 TSF:MSG:ECHO REQ
                  08:23:59.988 -> 51777 TSF:MSG:SEND,5-5-4-4,s=1,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:1
                  08:23:59.988 -> 51783 TSF:RTE:N2N OK
                  08:23:59.988 -> Incoming change for sensor:1, New status: 1
                  Press button node 5
                  08:24:36.929 -> 88704 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
                  08:24:36.929 -> wait 1/10sec
                  08:24:37.062 -> 88827 TSF:MSG:SEND,5-5-4-4,s=1,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
                  08:24:37.062 -> 88834 TSF:RTE:N2N OK
                  Debug logs gateway
                  Press button node 4 and node 5
                  08:26:19.261 -> 0;255;3;0;9;79078 TSF:MSG:READ,4-4-0,s=1,c=1,t=2,pt=1,l=1,sg=0:0
                  08:26:19.261 -> 0;255;3;0;9;79084 TSF:MSG:ACK REQ
                  08:26:19.294 -> 0;255;3;0;9;79105 TSF:MSG:SEND,0-0-4-4,s=1,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
                  08:26:19.294 -> 4;1;1;0;2;0
                  08:26:20.321 -> 0;255;3;0;9;80116 TSF:MSG:READ,5-5-0,s=1,c=1,t=2,pt=1,l=1,sg=0:0
                  08:26:20.321 -> 5;1;1;0;2;0
                  • tekkaT tekka
                    F
                    F
                    FullMetal
                    wrote on last edited by FullMetal
                    @tekka @rejoe2
                    I just found!
                    ask the gateway not to send back acq
                    send(msg.setDestination(MY_PARENT_NODE_ID).setSensor(CHILD_ID).set(state?false:true), false); // Send new state and request ack back
                    wait(100);
                    • rejoe2R
                      rejoe2R
                      rejoe2
                      Good to her you found that point :smile:.
                      Imo you'd better change also your receive functions to not react on "ack" messages (via "else" prior to message.type-comparison).
