  3. Node to Node Communication via Gatreway
19 Posts 5 Posters 6.0k Views 3 Watching
  • J
    J
    jkandasa
    How to print routing table in serial console?
      You have to read it from eeprom.
      It starts at position: EEPROM_ROUTES_ADDRESS (defined in MySensors.h)
      http://www.arduino.cc/en/Tutorial/EEPROMRead
      • J
        J
        jkandasa
        @hek you are right! There was an entry for Node-2 in Node-1 routing table, As it has direct access to Node-2, was trying to send directly. I removed the entry and now it's going throw gateway. All node works well. Perfect!
        I thing we have to add code to remove routing table entry dynamically if it face some N number of failures. It will make life easier for those who is shifting node from one location to another location often.
        • F
          F
          FullMetal
          Sorry to resort to an old topic ...
          I am currently using mysensors RS485, and I would like to extend my installation with this protocol.
          and I would like to make the nodes communicate with each other through the gateway.
          But I can't do what I want ... help!
          on my node 4, I have an input and 1 output, the input activates and deactivates the output. (here no worries).
          On my node 5, I have an input to activate the output of node 4, so I can turn it off but not turn it on, and I don't see any frames towards the gateway
          here is the code for my node 5:
          // MySensors
          #define MY_PARENT_NODE_ID 0                   // define if fixed parent
          #undef MY_REGISTRATION_FEATURE                  // sketch moves on if no registration
          #define MY_NODE_ID 5                     // fixed node number
          // Enable RS485 transport layer
          #define MY_RS485
          // Define this to enables DE-pin management on defined pin
          #define MY_RS485_DE_PIN 2
          // Set RS485 baud rate to use
          // Set blinking period
          // Flash leds on rx/tx/err
          //#define MY_DEFAULT_RX_LED_PIN  5  // Receive led pin
          //#define MY_DEFAULT_TX_LED_PIN  6  // the PCB, on board LED
          // Enable this if RS485 is connected to a hardware serial port
          //#define MY_RS485_HWSERIAL Serial1
          //#include <MqttClient.h>
          #define CHILD_ID 4
          #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
          Bounce debouncer = Bounce();
          int oldValue=0;
          bool state;
            // Setup the button
            pinMode(BUTTON_PIN,INPUT_PULLUP);
            // Activate internal pull-up
            //digitalWrite(BUTTON_PIN,HIGH);
            debouncer.attach(BUTTON_PIN);
            debouncer.interval(5);
            sendSketchInfo("Button", "1.1");
            present(CHILD_ID, S_LIGHT);
            debouncer.update();
            // Get the update value
            int value = debouncer.read();
            if (value != oldValue && value==0) {
                msg.setDestination(4);
                send(msg.set(state?false:true), false);// Send new state and request ack back
            oldValue = value;
          rejoe2R 1 Reply Last reply
          • F FullMetal
            // MySensors
            #define MY_RS485
            #define CHILD_ID 4
            int oldValue=0;
            bool state;
              // Setup the button
              debouncer.update();
              oldValue = value;
            rejoe2R
            rejoe2R
            rejoe2
            @FullMetal Imo, you have to specify all send-settings in one line, e.g. like this:
            send(buttonMsg.setDestination(MY_SISTER_NODE_ID).setSensor(CHILD_ID_RESET).set( button[i] ? "1" : "0"));
            F 1 Reply Last reply
            • rejoe2R rejoe2
              F
              F
              FullMetal
              @rejoe2
              thank you for your return,
              but I have the same problem, I manage to activate the relay of node 4 from node 5, but I cannot deactivate it. and when I act on node 5 the gateway does not receive frames since it calls node 4.
              I think that node 4 should send the relay status to node 5 so that it knows whether it is activated or not.
              tekkaT rejoe2R 2 Replies Last reply
              • F FullMetal
                @rejoe2
                tekkaT
                tekkaT
                tekka
                @FullMetal Please post a full debug log of both nodes showing the observed behaviour.
                • F FullMetal
                  @rejoe2
                  rejoe2R
                  rejoe2R
                  rejoe2
                  @FullMetal Pls add also code from node 4.
                  In general:
                  • if you want also info from node 5 to be sent to your controller/gateway, you have to add a second (normal) send command.
                  • wrt. to how node 4 reacts on the messages, you may better use sth. like a toggle logic.
                  • tekkaT tekka
                    F
                    F
                    FullMetal
                    @tekka @rejoe2
                    Désolé de revenir si tard ..
                    J'ai modifié mon code sur mes nœuds, mais le résultat n'est toujours pas là!
                    Voici mes codes:
                    node 4:
                    // MySensors
                    #define MY_NODE_ID 4                    // fixed node number
                    #define MY_RS485
                    #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
                    #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
                    #define SYSTER_ID 5
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    int oldValue=0;
                    bool state;
                    //MyMessage msgconf(CHILD_ID,V_VAR1);
                      // Setup the button
                      pinMode(RELAY_PIN, OUTPUT);
                      state = loadState(CHILD_ID);
                    *  Example on how to asynchronously check for new messages from gw
                      debouncer.update();
                          send(msg.setDestination(MY_PARENT_NODE_ID).setSensor(CHILD_ID).set(state?false:true), true); // Send new state and request ack back
                          wait(100);
                          send(msg.setDestination(SYSTER_ID).setSensor(CHILD_ID).set(state?false:true), true);
                      oldValue = value;
                      if (message.isAck()) {
                         // Change relay state
                         state = message.getBool();
                         // Store state in eeprom
                         saveState(CHILD_ID, state);
                    node 5:
                    // MySensors
                    #define MY_RS485
                    #define CHILD_ID 1
                    #define SYSTER_ID 4
                    int oldValue=0;
                    bool state;
                      // Setup the button
                      debouncer.update();
                          send(msg.setDestination(MY_PARENT_NODE_ID).setSensor(CHILD_ID).set(state?false:true), false);// Send new state and request ack back
                          Serial.println("wait 1/10sec");
                          wait(100);
                          send(msg.setDestination(SYSTER_ID).setSensor(CHILD_ID).set(state?false:true), false);
                      oldValue = value;
                         //digitalWrite(RELAY_PIN, state?RELAY_ON:RELAY_OFF);
                         saveState(SYSTER_ID, state);
                    From node 4, my output is activated and deactivated immediately, due to double sending
                    from node 5, I can activate or deactivate if I launch the command from node 4 before otherwise.
                    tekkaT 1 Reply Last reply
                    • F FullMetal
                      @tekka @rejoe2
                      Voici mes codes:
                      node 4:
                      // MySensors
                      #define MY_RS485
                      #define SYSTER_ID 5
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                      int oldValue=0;
                      bool state;
                        // Setup the button
                        debouncer.update();
                            wait(100);
                        oldValue = value;
                      node 5:
                      // MySensors
                      #define MY_RS485
                      #define CHILD_ID 1
                      #define SYSTER_ID 4
                      int oldValue=0;
                      bool state;
                        // Setup the button
                        debouncer.update();
                            wait(100);
                        oldValue = value;
                      tekkaT
                      tekkaT
                      tekka
                      @FullMetal said in Node to Node Communication via Gatreway: Please upload the debug logs for further troubleshooting.
                      F 2 Replies Last reply
                      • tekkaT tekka
                        F
                        F
                        FullMetal
                        @tekka said in Node to Node Communication via Gatreway:
                        Sorry
                        Debug logs node 4
                        Press button node 4
                        08:16:01.668 -> 13555 TSF:MSG:SEND,4-4-0-0,s=1,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
                        08:16:01.701 -> 13582 TSF:MSG:READ,0-0-4,s=1,c=1,t=2,pt=1,l=1,sg=0:0
                        08:16:01.701 -> 13586 TSF:MSG:ECHO
                        08:16:01.701 -> This is an ack from gateway
                        08:16:01.701 -> Incoming change for sensor:1, New status: 0
                        08:16:01.800 -> 13678 TSF:MSG:SEND,4-4-5-5,s=1,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:1
                        08:16:01.800 -> 13684 TSF:RTE:N2N OK
                        08:16:01.800 -> 13703 TSF:MSG:READ,5-5-4,s=1,c=1,t=2,pt=1,l=1,sg=0:1
                        08:16:01.833 -> 13708 TSF:MSG:ECHO
                        08:16:01.833 -> This is an ack from gateway
                        08:16:01.833 -> Incoming change for sensor:1, New status: 1
                        Press button node 5
                        08:21:01.371 -> 313012 TSF:MSG:READ,5-5-4,s=1,c=1,t=2,pt=1,l=1,sg=0:0
                        08:21:01.371 -> Incoming change for sensor:1, New status: 0
                        second press node 5
                        08:21:06.238 -> 317865 TSF:MSG:READ,5-5-4,s=1,c=1,t=2,pt=1,l=1,sg=0:0
                        08:21:06.238 -> Incoming change for sensor:1, New status: 0
                        Debug logs node 5
                        Press button node 4
                        08:23:59.955 -> 51752 TSF:MSG:READ,4-4-5,s=1,c=1,t=2,pt=1,l=1,sg=0:1
                        08:23:59.955 -> 51757 TSF:MSG:ECHO REQ
                        08:23:59.988 -> 51777 TSF:MSG:SEND,5-5-4-4,s=1,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:1
                        08:23:59.988 -> 51783 TSF:RTE:N2N OK
                        08:23:59.988 -> Incoming change for sensor:1, New status: 1
                        Press button node 5
                        08:24:36.929 -> 88704 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
                        08:24:36.929 -> wait 1/10sec
                        08:24:37.062 -> 88827 TSF:MSG:SEND,5-5-4-4,s=1,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
                        08:24:37.062 -> 88834 TSF:RTE:N2N OK
                        Debug logs gateway
                        Press button node 4 and node 5
                        08:26:19.261 -> 0;255;3;0;9;79078 TSF:MSG:READ,4-4-0,s=1,c=1,t=2,pt=1,l=1,sg=0:0
                        08:26:19.261 -> 0;255;3;0;9;79084 TSF:MSG:ACK REQ
                        08:26:19.294 -> 0;255;3;0;9;79105 TSF:MSG:SEND,0-0-4-4,s=1,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
                        08:26:19.294 -> 4;1;1;0;2;0
                        08:26:20.321 -> 0;255;3;0;9;80116 TSF:MSG:READ,5-5-0,s=1,c=1,t=2,pt=1,l=1,sg=0:0
                        08:26:20.321 -> 5;1;1;0;2;0
                        • tekkaT tekka
                          F
                          F
                          FullMetal
                          wrote on last edited by FullMetal
                          @tekka @rejoe2
                          I just found!
                          ask the gateway not to send back acq
                          send(msg.setDestination(MY_PARENT_NODE_ID).setSensor(CHILD_ID).set(state?false:true), false); // Send new state and request ack back
                          wait(100);
                          • rejoe2R
                            rejoe2R
                            rejoe2
                            Good to her you found that point :smile:.
                            Imo you'd better change also your receive functions to not react on "ack" messages (via "else" prior to message.type-comparison).
