  2. Enclosures / 3D Printing
  3. Is there a 3D printable enclosure for RPi 4 w/ serial gateway?
8 Posts 4 Posters 1.6k Views 5 Watching
  • KikakeeK
    KikakeeK
    Kikakee
    I'm just getting started w/ my setup (components are in the mail), so sorry if I've missed something - I swear I've been looking.
    I can't find a 3D printable enclosure to house both my Raspberry Pi 4 and my serial gateway (Arduino Nano and NRF24L01+PA+LNA). Is there one out there, or am I going to get to design one myself?
    I had thought this would be a common setup, but maybe I'm over complicating things? I'm planning to run Domoticz and I read it's easiest w/ a separate serial gateway, vs integrating the radio into the GPIO pins.
    A 1 Reply Last reply
    • KikakeeK Kikakee
      Avamander
      wrote on last edited by Avamander
      @Kikakee
      I couldn't find one, so I designed my own.
      (My model is not suitable for anyone else because I made it fit very snugly around my board)
      Wanting a smaller, neater solution than that, I bought a nRF52840 USB stick, hoping I could use that because it's very nice, but unfortunately there are some compatibility issues I have to yet resolve.
      S 1 Reply Last reply
      • KikakeeK
        KikakeeK
        Kikakee
        I'm slowly working out a case design in Tinkercad.
        Does anyone know if it's OK to put the NRF module close and parallel as the RPi?
        Tinkercad link if anyone's interested.
        • KikakeeK
          KikakeeK
          Kikakee
          Still on the journey...
          Finished a v0.2 notes:
          • Now have a printed case! See pics below.
          • The Radio and the Arduino needed to have the header pins soldered upside down.
          • The NRF24L01+PA+LNA doesn't come that way, so I had to de/re solder the pins. Not the simplest.
          • The fan screws get in the way of the serial gateway assembly.
          Ideas for gen v0.3:
          • Turn Arduino and Radio 90 degrees , basically make a sandwich. I think there is enough room if I use a double sided perf board.
          • I'd need smaller 3mm LEDs instead of the 5mm one's I've got... I've got some on order.
          • Also want a fresh radio module, if I don't have to flip the pins it would be easier for anyone else to do it.
          • Alignment pins - the Magnets do a good job, but little gaps are not ideal.
          Again for anyone interested here's the updated tinker cad link: https://www.tinkercad.com/things/3NuVSR723k2
          TRS-80T S 2 Replies Last reply
          • KikakeeK Kikakee
            Steven
            Banned
            @Kikakee :+1: :+1: :+1:
            • KikakeeK Kikakee
              Ideas for gen v0.3:
              TRS-80T
              TRS-80T
              TRS-80
              @Kikakee,
              Looks very nice and professional!
              Couldn't help but wonder however if there is a way to connect the Arduino to the RPi through internal GPIO pins, in order to eliminate the external USB cable? I think that would be the finishing touch on such an otherwise nice looking project.
              Version 0.3 perhaps? If not I (and perhaps others coming by later) suppose I was wondering if there was some technical reason why not to do this?
              Or maybe you simply didn't get around to it yet (perfectly acceptable reason as well :smiley: ).
              • A Avamander
                @Kikakee
                Steven
                Banned
                @Avamander
                Designed by your own?
                Genius!:+1:
                Pintuu
                • KikakeeK Kikakee
                  Ideas for gen v0.3:
                  Steven
                  Banned
                  @Kikakee :+1:
