  3. mysensor gateway with ENC28J60 Ethernet doubts!
10 Posts 3 Posters 752 Views 3 Watching
  • pw44P Offline
    pw44P Offline
    pw44
    TRS-80T 1 Reply Last reply
    • pw44P pw44
      TRS-80T Offline
      TRS-80T Offline
      TRS-80
      @pw44 said in mysensor gateway with ENC28J60 Ethernet doubts!:
      seams there is no interaction
      This is what it looks like to me, too.
      I base that on:
      • 13182 GWT:TSA:ETH OK which I am guessing means Ethernet is working?
      • Then it just keeps sending GWT:RFC:MSG=0;255;3;0;2; which, according to log parser and serial protocol API documentation command internal (3) value of 2 is "I_VERSION" described as "Used to request gateway version from controller." And because it just keeps sending it over and over, I agree with you, and also think that is where the problem lie.
      Any progress on your end in the meantime?
      pw44P 1 Reply Last reply
      • TRS-80T TRS-80
        I base that on:
        pw44P Offline
        pw44P Offline
        pw44
        @TRS-80 said in mysensor gateway with ENC28J60 Ethernet doubts!:
        I base that on:
        No no progress yet. Does not speaks with mycontroller or home assistant.
        • pw44P pw44
          I base that on:
          pw44P Offline
          pw44P Offline
          pw44
          @pw44
          Hi All,
          when i disconnect the usb cable (power is on and ethernet cable connected), the gateway stops responding to ping.
          Any hint?
          BR
          • mfalkviddM Offline
            • pw44P Offline
              pw44P Offline
              pw44
              i really can't figure what is going on. with usb connected, i can ping to gateway, with usb disconnected, ping stops. yes, i have a 2 A power supply delivering 3,3 V to nano v3, rf42 and ens28j60 and ethernet cable on rj45.
              does anyone have a reliable gateway working able to share the knowledge with me?
              • TRS-80T Offline
                TRS-80T Offline
                TRS-80
                wrote on last edited by TRS-80
                Focus on the communication between controller and your gateway. It sounds to me like your gateway is working.
                I never used MYSController, but I would imagine you should be seeing something coming across in there. Double check all your settings. Make sure MYSController is running before you start the gateway. Because after initial announcement, I think the gateway will mostly just sit there unless it has some node(s) to talk to (I could be wrong about that).
                Let me dig up my working Ethernet gateway sketch. It is also on a Nano, so maybe it can help you figure it out. Mine is MQTT though (sounds like yours just straight Ethernet?). With MQTT you don't even need a controller really, you can just start a command line client and listen for messages. Although I would imagine MYSController should provide some similar functionality.
                 * Created by Henrik Ekblad <[email protected]>
                 * Copyright (C) 2013-2019 Sensnology AB
                 * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
                 * Version 1.0 - Henrik Ekblad
                 * Contribution by a-lurker and Anticimex
                 * Contribution by Norbert Truchsess <[email protected]>
                 * Contribution by Tomas Hozza <[email protected]>
                 * LED purposes:
                 * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
                 * - ERR (red) - fast blink on error during transmission error or receive crc error
                #define MY_RADIO_RF24
                //#define MY_RADIO_NRF5_ESB
                //#define MY_RADIO_RFM95
                #define MY_GATEWAY_W5100
                // Following were missing from https://www.mysensors.org/build/mqtt_gateway, had to get from
                // https://github.com/mysensors/MySensors/blob/master/examples/GatewayW5100MQTTClient/GatewayW5100MQTTClient.ino
                #define MY_MQTT_PUBLISH_TOPIC_PREFIX "home/gateways/mysensors0-out"
                #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "home/gateways/mysensors0-in"
                // Set MQTT client id
                #define MY_MQTT_CLIENT_ID "mysensors-0"
                //down to here
                //#define MY_W5100_SPI_EN 4
                // radio on the same spi bus.
                #define MY_SOFTSPI
                // Note: When using analog functions, these pins are numbered (A)0-5. but these same pins are
                // numbered 14-19 when used with digital functions.
                #define MY_SOFT_SPI_SCK_PIN 14  // A0
                #define MY_SOFT_SPI_MISO_PIN 16  // A2
                #define MY_SOFT_SPI_MOSI_PIN 15  // A1
                #ifndef MY_RF24_CE_PIN
                #define MY_RF24_CE_PIN 5
                #ifndef MY_RF24_CS_PIN
                #define MY_RF24_CS_PIN 6
                // Enable UDP communication
                //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
                #define MY_PORT 1883  // was 5003 (?) but 1883 is default for MQTT
                    #define MY_CONTROLLER_IP_ADDRESS 192, 168, x, y  // this is my MQTT broker address
                //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
                // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
                #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0x00, 0x00
                // Enable inclusion mode
                // Set blinking period
                // Flash leds on rx/tx/err
                #if defined(MY_USE_UDP)
                #include <EthernetUdp.h>
                #include <Ethernet.h>
                I will mention that I am using W5500, which my understanding is maybe more reliable / better than the ENC module (I could be wrong about that, in fact the ENC module is listed as supported, so...?)? One thing I did read is that the ENC module apparently needs a lot more memory, because it does not implement as much of the IP stack in hardware as the W5x00 modules do. May or may not be relevant. But from what I can tell, it looks like your Ethernet is working?
                Also, please try and hang in there and be patient, instead of spamming topics everywhere. Sooner or later you should get some help. But we are all volunteers here, helping out in our free time. And there are not a lot of us.
                • TRS-80T TRS-80
                   * LED purposes:
                  //down to here
                  #define MY_SOFTSPI
                  pw44P Offline
                  pw44P Offline
                  pw44
                  @TRS-80 Thank you for your kind answer. WIll wait.
                  • TRS-80T Offline
                    TRS-80T Offline
                    TRS-80
                    In the meantime, check some of the things I mentioned. And/or, keep reading and searching Internet. You might make some progress. Keep reporting back how you are coming along, steps you tried, etc...
                    Just be methodical. Take notes, etc... You can do it!
                    • TRS-80T Offline
                      TRS-80T Offline
                      TRS-80
                      How are you troubleshooting? Monitoring serial? Network?
                      12.1k
