  3. Issues when upgrading EnergyMeterPulseSensor from 1.5.x to 2.3.2
15 Posts 5 Posters 1.9k Views 4 Watching
  • jocke4uJ jocke4u
    I have upgraded a few sensors and MySensors GW to 2.3.2 but when it comes to my EnergyMeterPulseSensor (which has a light sensor on top of the diod since >3 years) I face issues
    The original 1.5.x sketch looks like
    // Use this sensor to measure KWH and Watt of your house meeter
    // You need to set the correct pulsefactor of your meeter (blinks per KWH).
    // The sensor starts by fetching current KWH value from gateway.
    // Reports both KWH and Watt back to gateway.
    // Unfortunately millis() won't increment when the Arduino is in
    // sleepmode. So we cannot make this sensor sleep if we also want
    // to calculate/report watt-number.
    #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
    #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
    unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
    double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
    boolean pcReceived = false;
    unsigned long oldPulseCount = 0;
    unsigned long oldWatt = 0;
    double oldKwh;
    unsigned long lastSend;
    MyMessage wattMsg(CHILD_ID,V_WATT);
    MyMessage kwhMsg(CHILD_ID,V_KWH);
    MyMessage pcMsg(CHILD_ID,V_VAR1);
      gw.begin(incomingMessage);
      gw.sendSketchInfo("Energy Meter", "1.1");
      gw.present(CHILD_ID, S_POWER);
      gw.request(CHILD_ID, V_VAR1);
    //  attachInterrupt(INTERRUPT, onPulse, RISING);
      attachInterrupt(INTERRUPT, onPulse, FALLING); // JOCKE
      lastSend=millis();
      unsigned long now = millis();
      if (pcReceived && (SLEEP_MODE || sendTime)) {
    //    if (!SLEEP_MODE && watt != oldWatt) { //JOCKE: Always send
          if (watt<((unsigned long)MAX_WATT)) {
            gw.send(wattMsg.set(watt));  // Send watt value to gw
          Serial.print("Watt:");
          Serial.println(watt);
          oldWatt = watt;
        // Pulse cout has changed
    //    if (pulseCount != oldPulseCount) { // JOCKE: Always send
          gw.send(pcMsg.set(pulseCount));  // Send pulse count value to gw
          double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
          oldPulseCount = pulseCount;
          if (kwh != oldKwh) {
            gw.send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
            oldKwh = kwh;
        lastSend = now;
      } else if (sendTime && !pcReceived) {
        // No count received. Try requesting it again
        lastSend=now;
      if (SLEEP_MODE) {
        gw.sleep(SEND_FREQUENCY);
      if (message.type==V_VAR1) {
        pulseCount = oldPulseCount = message.getLong();
        Serial.print("Received last pulse count from gw:");
        Serial.println(pulseCount);
        pcReceived = true;
    void onPulse()
      if (!SLEEP_MODE) {
        unsigned long interval = newBlink-lastBlink;
        if (interval<10000L) { // Sometimes we get interrupt on RISING
          return;
        watt = (3600000000.0 /interval) / ppwh;
        lastBlink = newBlink;
      pulseCount++;
    The 2.3.2 upgraded sketch looks like:
    // Enable debug prints
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define PULSE_FACTOR 1000       // Number of blinks per kWh of your meter. Normally 1000.
    #define SLEEP_MODE false        // Watt value can only be reported when sleep mode is false.
    #define MAX_WATT 10000          // Max watt value to report. This filters outliers.
    // OLD  - #define INTERRUPT DIGITAL_INPUT_SENSOR-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
    uint32_t SEND_FREQUENCY =
        20000; // Minimum time between send (in milliseconds). We don't want to spam the gateway.
    double ppwh = ((double)PULSE_FACTOR) / 1000; // Pulses per watt hour
    bool pcReceived = false;
    volatile uint32_t pulseCount = 0;
    volatile uint32_t lastBlinkmicros = 0;
    volatile uint32_t lastBlinkmillis = 0;
    volatile uint32_t watt = 0;
    uint32_t oldPulseCount = 0;
    uint32_t oldWatt = 0;
    double oldkWh;
    uint32_t lastSend;
    MyMessage wattMsg(CHILD_ID, V_WATT);
    MyMessage kWhMsg(CHILD_ID, V_KWH);
    MyMessage pcMsg(CHILD_ID, V_VAR1);
    #if defined(ARDUINO_ARCH_ESP8266) || defined(ARDUINO_ARCH_ESP32)
    #define IRQ_HANDLER_ATTR ICACHE_RAM_ATTR
    // --------OLD To investigate ----------
    //volatile unsigned long lastBlink = 0;
    void IRQ_HANDLER_ATTR onPulse()
      if (!SLEEP_MODE) {
        uint32_t newBlinkmicros = micros();
        uint32_t newBlinkmillis = millis();
        uint32_t intervalmicros = newBlinkmicros - lastBlinkmicros;
        uint32_t intervalmillis = newBlinkmillis - lastBlinkmillis;
        if (intervalmicros < 10000L && intervalmillis < 10L) { // Sometimes we get interrupt on RISING
          return;
        if (intervalmillis < 360000) { // Less than an hour since last pulse, use microseconds
          watt = (3600000000.0 / intervalmicros) / ppwh;
          watt = (3600000.0 / intervalmillis) /
                 ppwh; // more thAn an hour since last pulse, use milliseconds as micros will overflow after 70min
        lastBlinkmicros = newBlinkmicros;
        lastBlinkmillis = newBlinkmillis;
      pulseCount++;
      pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);
      attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, FALLING);
      // OLD one
      ////  attachInterrupt(INTERRUPT, onPulse, RISING);
      //attachInterrupt(INTERRUPT, onPulse, FALLING); // JOCKE
      lastSend = millis();
      sendSketchInfo(F("Energy Meter"), F("2.3.2"));
      uint32_t now = millis();
          // Check that we don't get unreasonable large watt value, which
          // could happen when long wraps or false interrupt triggered
          if (watt < ((uint32_t)MAX_WATT)) {
          oldWatt = watt;
        // Pulse count value has changed
          double kWh = ((double)pulseCount / ((double)PULSE_FACTOR));
          if (kWh != oldkWh) {
            send(kWhMsg.set(kWh, 4));  // Send kWh value to gw
            oldkWh = kWh;
        lastSend = now;
        // No pulse count value received from controller. Try requesting it again.
        lastSend = now;
      if (SLEEP_MODE) {
        sleep(SEND_FREQUENCY, false);
      if (message.getType()==V_VAR1) {
        Serial.print("Received last pulse count value from gw:");
        pcReceived = true;
    It seems it get stuck on requesting V_VAR1
    From the serial monitor I get:
     __  __       ____
            |___/                      2.3.2
    16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=16,REL=255,VER=2.3.2
    26 TSM:INIT
    28 TSF:WUR:MS=0
    34 TSM:INIT:TSP OK
    36 TSF:SID:OK,ID=6
    37 TSM:FPAR
    41 ?TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2050 !TSM:FPAR:NO REPLY
    2052 TSM:FPAR
    2056 ?TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4063 !TSM:FPAR:NO REPLY
    4065 TSM:FPAR
    4069 ?TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6076 !TSM:FPAR:NO REPLY
    6078 TSM:FPAR
    6082 ?TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8089 !TSM:FPAR:FAIL
    8090 TSM:FAIL:CNT=1
    8092 TSM:FAIL:DIS
    8094 TSF:TDI:TSL
    18096 TSM:FAIL:RE-INIT
    18098 TSM:INIT
    18104 TSM:INIT:TSP OK
    18106 TSF:SID:OK,ID=6
    18108 TSM:FPAR
    18113 ?TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20120 !TSM:FPAR:NO REPLY
    20122 TSM:FPAR
    20126 ?TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    22134 !TSM:FPAR:NO REPLY
    22136 TSM:FPAR
    22140 ?TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    24148 !TSM:FPAR:NO REPLY
    24151 TSM:FPAR
    24155 ?TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    26162 !TSM:FPAR:FAIL
    26163 TSM:FAIL:CNT=2
    26165 TSM:FAIL:DIS
    26167 TSF:TDI:TSL
    36170 TSM:FAIL:RE-INIT
    36172 TSM:INIT
    36178 TSM:INIT:TSP OK
    36180 TSF:SID:OK,ID=6
    36183 TSM:FPAR
    36188 ?TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    38195 !TSM:FPAR:NO REPLY
    38197 TSM:FPAR
    38201 ?TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    38636 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    38641 TSF:MSG:FPAR OK,ID=0,D=1
    40208 TSM:FPAR:OK
    I also tried to ClearEepromConfig, only gave it a new node ID.
    Do you have any tips and tricks to get it working.
    @jocke4u you changed a lot to your sketch when going from 1.5.x to 2.3.2, including e.g. the interrupt handler.
    I would advise to first convert your sketch to 2.3.2 only (following e.g. https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x) and then, if that works correctly, start changing other parts of the sketch (e.g. the interrupt handling).
    You could also flash a basic sketch to test if the hardware performs correctly (I can only hope you didn't switch hardware when going to 2.3.2 :grimacing: )
    The log files you posted don't seem to match the screenshot -- there are no internal messages in the log, while the screenshot shows e.g. even the sketch name being transmitted.
    jocke4uJ 1 Reply Last reply
    • YveauxY Yveaux
      jocke4uJ
      jocke4uJ
      jocke4u
      @Yveaux Thanks for your input.
      The hardware is unchanged ;)
      The sketch is pretty "stock" from example at the time at 1.5.4 and with 2.3.2 I went for the example as well and just secured the pins were the same etc.
      I will give your suggestion a try, just modify the pieces needed to use 2.3.2 and then leave the rest as is.
      (I wasn't sure if anything were encapsulated in 2.3.2 MySensor so that's why)
      • jocke4uJ jocke4u
        @jocke4u how about the log files don't match the screenshot?
        • jocke4uJ
          jocke4uJ
          jocke4u
          So I followed @Yveaux good advice to port the MySensors sketch as plain as possible from 1.5.4 to 2.3.2.
          I think the logs are in synk now also @Yveaux
          The sketch now looks like:
          // Node 49 Energy Sensor
          // Measure Total Energy
          // Sending every 20 sec
          double oldKwh;
            sendSketchInfo("Energy Meter", "2.3.2");
            //begin(incomingMessage);
            lastSend=millis();
                oldWatt = watt;
                  oldKwh = kwh;
              lastSend = now;
              lastSend=now;
            if (SLEEP_MODE) {
          //void incomingMessage(const MyMessage &message) {
              pcReceived = true;
          void onPulse()
            if (!SLEEP_MODE) {
                return;
            pulseCount++;
          I cleared the Eeprom on the sensor first and when kicking the Serial Monitor in "Arduino Studio" I get the logs as follows
           __  __       ____
                  |___/                      2.3.2
          26 TSM:INIT
          28 TSF:WUR:MS=0
          34 TSM:INIT:TSP OK
          36 TSF:SID:OK,ID=7
          37 TSM:FPAR
          41 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          2052 TSM:FPAR
          2056 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          4065 TSM:FPAR
          4069 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          6078 TSM:FPAR
          6082 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          8089 !TSM:FPAR:FAIL
          8090 TSM:FAIL:CNT=1
          8092 TSM:FAIL:DIS
          8094 TSF:TDI:TSL
          18098 TSM:INIT
          18106 TSF:SID:OK,ID=7
          18108 TSM:FPAR
          18113 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          20122 TSM:FPAR
          20126 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          22136 TSM:FPAR
          22140 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          24151 TSM:FPAR
          24155 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          26165 TSM:FAIL:DIS
          26167 TSF:TDI:TSL
          36172 TSM:INIT
          36180 TSF:SID:OK,ID=7
          36183 TSM:FPAR
          36188 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          38197 TSM:FPAR
          38201 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          38844 TSF:MSG:READ,0-0-7,s=255,c=3,t=8,pt=1,l=1,sg=0:0
          38849 TSF:MSG:FPAR OK,ID=0,D=1
          40209 TSM:FPAR:OK
          40210 TSM:ID
          40212 TSM:ID:OK
          40213 TSM:UPL
          40250 !TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
          42258 TSM:UPL
          42295 !TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
          44302 TSM:UPL
          44339 !TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
          46346 TSM:UPL
          46383 !TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
          48390 !TSM:UPL:FAIL
          48391 TSM:FPAR
          48396 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=4,st=OK:
          50403 !TSM:FPAR:NO REPLY
          50405 TSM:FPAR
          50409 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          52416 !TSM:FPAR:NO REPLY
          52418 TSM:FPAR
          52422 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          54430 !TSM:FPAR:NO REPLY
          54432 TSM:FPAR
          54436 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          56444 !TSM:FPAR:FAIL
          56445 TSM:FAIL:CNT=3
          56448 TSM:FAIL:DIS
          56450 TSF:TDI:TSL
          66453 TSM:FAIL:RE-INIT
          66455 TSM:INIT
          66461 TSM:INIT:TSP OK
          66463 TSF:SID:OK,ID=7
          66465 TSM:FPAR
          66470 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          68478 !TSM:FPAR:NO REPLY
          68481 TSM:FPAR
          68485 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          70492 !TSM:FPAR:NO REPLY
          70494 TSM:FPAR
          70498 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          72506 !TSM:FPAR:NO REPLY
          72508 TSM:FPAR
          72512 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          74519 !TSM:FPAR:FAIL
          74520 TSM:FAIL:CNT=4
          74522 TSM:FAIL:DIS
          74524 TSF:TDI:TSL
          84527 TSM:FAIL:RE-INIT
          84529 TSM:INIT
          84535 TSM:INIT:TSP OK
          84537 TSF:SID:OK,ID=7
          84539 TSM:FPAR
          84544 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          86551 !TSM:FPAR:NO REPLY
          86553 TSM:FPAR
          86557 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          88564 !TSM:FPAR:NO REPLY
          88566 TSM:FPAR
          88570 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          90578 !TSM:FPAR:NO REPLY
          90580 TSM:FPAR
          90585 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          92592 !TSM:FPAR:FAIL
          92593 TSM:FAIL:CNT=5
          92595 TSM:FAIL:DIS
          92597 TSF:TDI:TSL
          102600 TSM:FAIL:RE-INIT
          102602 TSM:INIT
          102608 TSM:INIT:TSP OK
          102611 TSF:SID:OK,ID=7
          102614 TSM:FPAR
          102618 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          104626 !TSM:FPAR:NO REPLY
          104628 TSM:FPAR
          104632 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          106640 !TSM:FPAR:NO REPLY
          106642 TSM:FPAR
          106646 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          108654 !TSM:FPAR:NO REPLY
          108656 TSM:FPAR
          108660 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          110668 !TSM:FPAR:FAIL
          110670 TSM:FAIL:CNT=6
          110672 TSM:FAIL:DIS
          110674 TSF:TDI:TSL
          120676 TSM:FAIL:RE-INIT
          120678 TSM:INIT
          120684 TSM:INIT:TSP OK
          120687 TSF:SID:OK,ID=7
          120689 TSM:FPAR
          120693 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          122701 !TSM:FPAR:NO REPLY
          122703 TSM:FPAR
          122707 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          124716 !TSM:FPAR:NO REPLY
          124718 TSM:FPAR
          124722 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          126730 !TSM:FPAR:NO REPLY
          126732 TSM:FPAR
          126736 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          128744 !TSM:FPAR:FAIL
          128746 TSM:FAIL:CNT=7
          128748 TSM:FAIL:DIS
          128750 TSF:TDI:TSL
          188752 TSM:FAIL:RE-INIT
          188754 TSM:INIT
          188761 TSM:INIT:TSP OK
          188764 TSF:SID:OK,ID=7
          188766 TSM:FPAR
          188770 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          190778 !TSM:FPAR:NO REPLY
          190780 TSM:FPAR
          190784 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          192792 !TSM:FPAR:NO REPLY
          192794 TSM:FPAR
          192798 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          194806 !TSM:FPAR:NO REPLY
          194808 TSM:FPAR
          194812 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          196822 !TSM:FPAR:FAIL
          196824 TSM:FAIL:CNT=7
          196826 TSM:FAIL:DIS
          196828 TSF:TDI:TSL
          256830 TSM:FAIL:RE-INIT
          256832 TSM:INIT
          256838 TSM:INIT:TSP OK
          256841 TSF:SID:OK,ID=7
          256843 TSM:FPAR
          256847 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          258856 !TSM:FPAR:NO REPLY
          258859 TSM:FPAR
          258863 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          260871 !TSM:FPAR:NO REPLY
          260873 TSM:FPAR
          260877 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          262885 !TSM:FPAR:NO REPLY
          262887 TSM:FPAR
          262891 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          264899 !TSM:FPAR:FAIL
          264901 TSM:FAIL:CNT=7
          264903 TSM:FAIL:DIS
          264905 TSF:TDI:TSL
          324907 TSM:FAIL:RE-INIT
          324909 TSM:INIT
          324915 TSM:INIT:TSP OK
          324918 TSF:SID:OK,ID=7
          324920 TSM:FPAR
          324924 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          326932 !TSM:FPAR:NO REPLY
          326934 TSM:FPAR
          326938 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          328946 !TSM:FPAR:NO REPLY
          328948 TSM:FPAR
          328952 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          330961 !TSM:FPAR:NO REPLY
          330963 TSM:FPAR
          330968 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          332976 !TSM:FPAR:FAIL
          332978 TSM:FAIL:CNT=7
          332980 TSM:FAIL:DIS
          332982 TSF:TDI:TSL
          392984 TSM:FAIL:RE-INIT
          392986 TSM:INIT
          392992 TSM:INIT:TSP OK
          392995 TSF:SID:OK,ID=7
          392997 TSM:FPAR
          393001 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          395010 !TSM:FPAR:NO REPLY
          395012 TSM:FPAR
          395016 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          397024 !TSM:FPAR:NO REPLY
          397026 TSM:FPAR
          397030 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          399038 !TSM:FPAR:NO REPLY
          399040 TSM:FPAR
          399044 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          401052 !TSM:FPAR:FAIL
          401054 TSM:FAIL:CNT=7
          401056 TSM:FAIL:DIS
          401058 TSF:TDI:TSL
          461060 TSM:FAIL:RE-INIT
          461062 TSM:INIT
          461068 TSM:INIT:TSP OK
          461071 TSF:SID:OK,ID=7
          461073 TSM:FPAR
          461077 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          463085 !TSM:FPAR:NO REPLY
          463087 TSM:FPAR
          463091 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          465099 !TSM:FPAR:NO REPLY
          465101 TSM:FPAR
          465105 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          467115 !TSM:FPAR:NO REPLY
          467117 TSM:FPAR
          467121 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          469129 !TSM:FPAR:FAIL
          469131 TSM:FAIL:CNT=7
          469133 TSM:FAIL:DIS
          469135 TSF:TDI:TSL
          529137 TSM:FAIL:RE-INIT
          529139 TSM:INIT
          529145 TSM:INIT:TSP OK
          529148 TSF:SID:OK,ID=7
          529150 TSM:FPAR
          529155 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          531163 !TSM:FPAR:NO REPLY
          531165 TSM:FPAR
          531169 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          533177 !TSM:FPAR:NO REPLY
          533179 TSM:FPAR
          533183 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          535191 !TSM:FPAR:NO REPLY
          535193 TSM:FPAR
          535197 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          537205 !TSM:FPAR:FAIL
          537207 TSM:FAIL:CNT=7
          537209 TSM:FAIL:DIS
          537211 TSF:TDI:TSL
          597213 TSM:FAIL:RE-INIT
          597215 TSM:INIT
          597221 TSM:INIT:TSP OK
          597224 TSF:SID:OK,ID=7
          597226 TSM:FPAR
          597230 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          599238 !TSM:FPAR:NO REPLY
          599240 TSM:FPAR
          599244 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          601252 !TSM:FPAR:NO REPLY
          601254 TSM:FPAR
          601259 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          603267 !TSM:FPAR:NO REPLY
          603269 TSM:FPAR
          603273 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          605281 !TSM:FPAR:FAIL
          605283 TSM:FAIL:CNT=7
          605285 TSM:FAIL:DIS
          605287 TSF:TDI:TSL
          665289 TSM:FAIL:RE-INIT
          665291 TSM:INIT
          665297 TSM:INIT:TSP OK
          665300 TSF:SID:OK,ID=7
          665303 TSM:FPAR
          665307 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          667315 !TSM:FPAR:NO REPLY
          667317 TSM:FPAR
          667321 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          669329 !TSM:FPAR:NO REPLY
          669331 TSM:FPAR
          669335 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          671343 !TSM:FPAR:NO REPLY
          671345 TSM:FPAR
          671349 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          671833 TSF:MSG:READ,0-0-7,s=255,c=3,t=8,pt=1,l=1,sg=0:0
          671838 TSF:MSG:FPAR OK,ID=0,D=1
          673357 TSM:FPAR:OK
          673358 TSM:ID
          673360 TSM:ID:OK
          673361 TSM:UPL
          673399 !TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
          675406 TSM:UPL
          675443 !TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
          677450 TSM:UPL
          677487 !TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
          679494 TSM:UPL
          679531 !TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
          681538 !TSM:UPL:FAIL
          681540 TSM:FPAR
          681544 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=4,st=OK:
          683551 !TSM:FPAR:NO REPLY
          683553 TSM:FPAR
          683557 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          685566 !TSM:FPAR:NO REPLY
          685569 TSM:FPAR
          685573 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          687581 !TSM:FPAR:NO REPLY
          687583 TSM:FPAR
          687587 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          689595 !TSM:FPAR:FAIL
          689597 TSM:FAIL:CNT=7
          689599 TSM:FAIL:DIS
          689601 TSF:TDI:TSL
          749603 TSM:FAIL:RE-INIT
          749605 TSM:INIT
          749612 TSM:INIT:TSP OK
          749615 TSF:SID:OK,ID=7
          749617 TSM:FPAR
          749621 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          751629 !TSM:FPAR:NO REPLY
          751631 TSM:FPAR
          751635 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          753643 !TSM:FPAR:NO REPLY
          753645 TSM:FPAR
          753649 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          755657 !TSM:FPAR:NO REPLY
          755659 TSM:FPAR
          755663 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          757672 !TSM:FPAR:FAIL
          757675 TSM:FAIL:CNT=7
          757677 TSM:FAIL:DIS
          757679 TSF:TDI:TSL
          817681 TSM:FAIL:RE-INIT
          817683 TSM:INIT
          817689 TSM:INIT:TSP OK
          817692 TSF:SID:OK,ID=7
          817694 TSM:FPAR
          817698 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          819706 !TSM:FPAR:NO REPLY
          819708 TSM:FPAR
          819713 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          821721 !TSM:FPAR:NO REPLY
          821723 TSM:FPAR
          821727 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          823735 !TSM:FPAR:NO REPLY
          823737 TSM:FPAR
          823741 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          825749 !TSM:FPAR:FAIL
          825751 TSM:FAIL:CNT=7
          825753 TSM:FAIL:DIS
          825755 TSF:TDI:TSL
          And the corresponding logs in MYSController looks like:
          And I observe a number of C_REQ like:
          • jocke4uJ
            jocke4uJ
            jocke4u
            Ok, still trying to get this to work.
            Added som more print-outs and I don't understand why none of the prints gets into the Serial Monitor.
            Is it stuck into MySensors so the sketch isn't started correctly, or what happens?!
            The ugly Sketch
            // Node Total Energy Sensor
            double oldKwh;
              Serial.println("### Start Present");
              Serial.println("### End Present");
              Serial.println("### Start Setup");
              lastSend=millis();
              Serial.println("### End Setup");
              Serial.println("### Loop");
                  Serial.println("");
                  Serial.print("### Sending WATTS: ");
                oldWatt = watt;
                  Serial.println("");
                  Serial.print("### Sending kWh: ");
                  Serial.println(kwh);
                  oldKwh = kwh;
                lastSend = now;
                lastSend=now;
              if (SLEEP_MODE) {
                Serial.println("");
                Serial.print("### Received last pulse count from gw:");
                pcReceived = true;
            void onPulse()
              if (!SLEEP_MODE) {
                  return;
              Serial.print(" . ");
              pulseCount++;
            The output from Serial Monitor:
             __  __       ____
                    |___/                      2.3.2
            26 TSM:INIT
            28 TSF:WUR:MS=0
            34 TSM:INIT:TSP OK
            36 TSF:SID:OK,ID=7
            37 TSM:FPAR
            2052 TSM:FPAR
            4065 TSM:FPAR
            6078 TSM:FPAR
            8089 !TSM:FPAR:FAIL
            8090 TSM:FAIL:CNT=1
            8092 TSM:FAIL:DIS
            8094 TSF:TDI:TSL
            18098 TSM:INIT
            18108 TSM:FPAR
            20122 TSM:FPAR
            22136 TSM:FPAR
            24151 TSM:FPAR
            26165 TSM:FAIL:DIS
            26167 TSF:TDI:TSL
            36172 TSM:INIT
            36183 TSM:FPAR
            38197 TSM:FPAR
            40209 !TSM:FPAR:NO REPLY
            40211 TSM:FPAR
            40215 ?TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            • jocke4uJ jocke4u
              The ugly Sketch
              double oldKwh;
                lastSend=millis();
                    Serial.println("");
                  oldWatt = watt;
                    Serial.println("");
                    oldKwh = kwh;
                  lastSend = now;
                  lastSend=now;
                if (SLEEP_MODE) {
                  Serial.println("");
                  pcReceived = true;
              void onPulse()
                if (!SLEEP_MODE) {
                    return;
                pulseCount++;
               __  __       ____
                      |___/                      2.3.2
              26 TSM:INIT
              28 TSF:WUR:MS=0
              34 TSM:INIT:TSP OK
              36 TSF:SID:OK,ID=7
              37 TSM:FPAR
              2052 TSM:FPAR
              4065 TSM:FPAR
              6078 TSM:FPAR
              8089 !TSM:FPAR:FAIL
              8090 TSM:FAIL:CNT=1
              8092 TSM:FAIL:DIS
              8094 TSF:TDI:TSL
              18098 TSM:INIT
              18108 TSM:FPAR
              20122 TSM:FPAR
              22136 TSM:FPAR
              24151 TSM:FPAR
              26165 TSM:FAIL:DIS
              26167 TSF:TDI:TSL
              36172 TSM:INIT
              36183 TSM:FPAR
              38197 TSM:FPAR
              40211 TSM:FPAR
              @jocke4u the node is unable to find a path to your gateway, so it never reaches loop()
              Could you post the log from your gateway and the gateway sketch?
              Do you still have your 1.x gateway running? Is it using the same channel?
              • jocke4uJ
                jocke4uJ
                jocke4u
                Thanks Mikael (@mfalkvidd )
                The GW is running 2.3.2 and have not changed the channel ( I skipped the RPi approach as we discussed in another thread)
                I hooked up my gateway to Arduino Serial Monitor and during this time I also restarted this sensor.
                Please note that I have other sensors reporting correctly.
                Log log shows:
                0 MCO:BGN:INIT GW,CP=RNNGA---,FQ=16,REL=255,VER=2.3.2
                4 TSM:INIT
                5 TSF:WUR:MS=0
                12 TSM:INIT:TSP OK
                13 TSM:INIT:GW MODE
                15 TSM:READY:ID=0,PAR=0,DIS=0
                18 MCO:REG:NOT NEEDED
                580 GWT:TIN:IP=192.168.1.11
                1584 MCO:BGN:STP
                1586 MCO:BGN:INIT OK,TSP=1
                1588 TSM:READY:NWD REQ
                1593 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                2140 TSF:MSG:READ,7-7-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
                14924 TSF:MSG:READ,7-7-0,s=1,c=2,t=24,pt=0,l=0,sg=0:
                34877 TSF:MSG:READ,7-7-0,s=1,c=2,t=24,pt=0,l=0,sg=0:
                54829 TSF:MSG:READ,7-7-0,s=1,c=2,t=24,pt=0,l=0,sg=0:
                80115 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                80120 TSF:MSG:BC
                80122 TSF:MSG:FPAR REQ,ID=7
                80124 TSF:PNG:SEND,TO=0
                80128 TSF:CKU:OK
                80129 TSF:MSG:GWL OK
                80392 TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                82126 TSF:MSG:READ,7-7-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                82131 TSF:MSG:PINGED,ID=7,HP=1
                82136 TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                82149 TSF:MSG:READ,7-7-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                82156 TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                82163 TSF:MSG:READ,7-7-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.2
                82171 TSF:MSG:READ,7-7-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                82180 GWT:TSA:ETH OK
                82184 GWT:RFC:MSG=7;255;3;0;6;M
                82189 TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=OK:M
                82196 TSF:MSG:READ,7-7-0,s=255,c=3,t=11,pt=0,l=12,sg=0:Energy Meter
                82205 TSF:MSG:READ,7-7-0,s=255,c=3,t=12,pt=0,l=5,sg=0:2.3.2
                82213 TSF:MSG:READ,7-7-0,s=1,c=0,t=13,pt=0,l=0,sg=0:
                82224 TSF:MSG:READ,7-7-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                82233 TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                82241 TSF:MSG:READ,7-7-0,s=1,c=2,t=24,pt=0,l=0,sg=0:
                102202 TSF:MSG:READ,7-7-0,s=1,c=2,t=24,pt=0,l=0,sg=0:
                110822 TSF:MSG:READ,2-2-0,s=1,c=1,t=0,pt=7,l=5,sg=0:22.1
                122153 TSF:MSG:READ,7-7-0,s=1,c=2,t=24,pt=0,l=0,sg=0:
                The Sketch of GW looks like:
                 * Copyright (C) 2013-2019 Sensnology AB
                 * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
                 * Version 1.0 - Henrik Ekblad
                 * Contribution by a-lurker and Anticimex
                 * LED purposes:
                 * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
                 * - ERR (red) - fast blink on error during transmission error or receive crc error
                #define MY_GATEWAY_W5100
                //#define MY_W5100_SPI_EN 4
                // radio on the same spi bus.
                #define MY_SOFTSPI
                #ifndef MY_RF24_CE_PIN
                #define MY_RF24_CE_PIN 5
                #ifndef MY_RF24_CS_PIN
                #define MY_RF24_CS_PIN 6
                // Enable UDP communication
                //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
                #define MY_IP_ADDRESS 192,168,1,11
                #define MY_PORT 5003
                //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
                // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
                // Enable inclusion mode
                // Set blinking period
                // Flash leds on rx/tx/err
                #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
                #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
                #define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
                #if defined(MY_USE_UDP)
                #include <EthernetUdp.h>
                #include <Ethernet.h>
                • mfalkviddM
                  When looking in the log parser, I notice the following:
                  • At 14924, 34877, 54829, node 7 is requesting data from node 0:
                  	Received Message
                  Sender: 7
                  Last Node: 7
                  Destination: 0
                  Sensor Id: 1
                  Command: REQ
                  Message Type: V_VAR1
                  Payload Type: P_STRING
                  Payload Length: 0
                  Signing: 0
                  Payload:
                  This probably corresponds to this code in the node:
                  My guess is that the node expects this variable to be available at the controller. I don't have much experience with requesting variables so I don't have any good suggestions unfortunately.
                  • The log also shows that the FPAR requests that failed earlier work fine now:
                  Sent Message
                  Sender: 0
                  Last Node: 0
                  Next Node: 7
                  Destination: 7
                  Sensor Id: 255
                  Command: INTERNAL
                  Message Type:I_FIND_PARENT_RESPONSE
                  Payload Type: P_BYTE
                  Payload Length: 1
                  Signing: 0
                  Failed uplink counter: 0
                  Status: OK (OK=success, NACK=no radio ACK received)
                  Payload: 0
                  • jocke4uJ
                    jocke4uJ
                    jocke4u
                    First day of vacation and it is raining = MySensors time :)
                    I brought this power sensor with TSL237 to the office since I suspected some issues with HW. And yes it seems the TSL237 is broken so tested with a new one. The sensor seems to work fine (using a flashlight).
                    But I can't get the reply of the V_VAR1 from the GW.
                    Any idea why?
                    The Sketch:
                    double oldkWh;
                    uint32_t lastSend;
                    	if (!SLEEP_MODE) {
                    			return;
                      Serial.println("### Pulse");
                    	pulseCount++;
                    	attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
                    	if (/*pcReceived &&*/ (SLEEP_MODE || sendTime)) {
                    			Serial.print("### Watt:");
                    			oldWatt = watt;
                    				oldkWh = kWh;
                    		lastSend = now;
                    		lastSend = now;
                    	if (SLEEP_MODE) {
                      Serial.println("### NEW Received message of type: ");
                      Serial.println(message.getType());
                      Serial.println("### Expected: ");
                      Serial.println(V_VAR1);
                    		Serial.println("");
                    		Serial.print("### Received last pulse count value from gw:");
                    		pcReceived = true;
                    Log from serial monitor:
                     __  __       ____
                            |___/                      2.3.2
                    26 TSM:INIT
                    28 TSF:WUR:MS=0
                    34 TSM:INIT:TSP OK
                    36 TSF:SID:OK,ID=7
                    37 TSM:FPAR
                    962 TSF:MSG:READ,0-0-7,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    967 TSF:MSG:FPAR OK,ID=0,D=1
                    2050 TSM:FPAR:OK
                    2051 TSM:ID
                    2052 TSM:ID:OK
                    2054 TSM:UPL
                    2057 TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                    2068 TSF:MSG:READ,0-0-7,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                    2073 TSF:MSG:PONG RECV,HP=1
                    2076 TSM:UPL:OK
                    2077 TSM:READY:ID=7,PAR=0,DIS=1
                    2086 TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                    2094 TSF:MSG:READ,0-0-7,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    2106 TSF:MSG:SEND,7-7-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.2
                    2116 TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                    2137 TSF:MSG:READ,0-0-7,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                    ### Start Present
                    2166 TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=OK:Energy Meter
                    2183 TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=12,pt=0,l=5,sg=0,ft=0,st=OK:2.3.2
                    2193 TSF:MSG:SEND,7-7-0-0,s=1,c=0,t=13,pt=0,l=0,sg=0,ft=0,st=OK:
                    ### End Present
                    2199 MCO:REG:REQ
                    2238 !TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2
                    2244 TSF:MSG:READ,0-0-7,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                    2249 MCO:PIM:NODE REG=1
                    2252 MCO:BGN:STP
                    ### Start Setup
                    2255 TSF:MSG:SEND,7-7-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=1,st=OK:
                    ### End Setup
                    2262 MCO:BGN:INIT OK,TSP=1
                    ### Pulse
                    ### Pulse
                    ### Pulse
                    ### Pulse
                    ### Pulse
                    ### Pulse
                    ### Pulse
                    42265 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=17,pt=5,l=4,sg=0,ft=0,st=OK:2263
                    ### Watt:2263
                    42276 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:7
                    42290 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:0.0070
                    ### Pulse
                    ### Pulse
                    ### Pulse
                    ### Pulse
                    ### Pulse
                    ### Pulse
                    ### Pulse
                    ### Pulse
                    ### Pulse
                    ### Pulse
                    ### Pulse
                    ### Pulse
                    62271 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=17,pt=5,l=4,sg=0,ft=0,st=OK:2103
                    ### Watt:2103
                    62279 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:19
                    62290 TSF:MSG:SEND,7-7-0-0,s=1,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:0.0190
                    Screenshot from MYSController
                      Sasquatch
                      wrote on last edited by Sasquatch
                      V_Var1 is variable(your total pulses) stored in the controller - HomeAssistant, Domoticz etc....
                      Assuming you have controller shut down you have to send that value from MYSController.
                      This request will be fulfilled by controller after you configure it to use node's 7 child 1
                      • S Sasquatch
                        jocke4uJ
                        jocke4uJ
                        jocke4u
                        @Sasquatch Thanks, it was a connection issue with HomeAssistant to MySensors GW.
                        Now it is time to clean up the sketch and put it to operation again.
                        Also thanks you other guys that have been helpful @mfalkvidd @Yveaux @niclas
