  3. Wemos d1 mini : gateway error .
13 Posts 2 Posters 1.2k Views 2 Watching
  • David MarlingeD David Marlinge
    this is the first time I'm trying to work with mysensors.
    So I have a wemos d1 mini and a nrf24L01.
    I upload gateway8266 sketch on the wemos card.
    I setup an ip adress (192.168.1.111) gateway 192.168.1.1 and submask : 255.255.255.0.
    But it does work, I can't reach the adress.
    If I plug the wemos on my computer, and launch the serial monitor in arduino IDE, I get this .
    09:15:10.888 -> f`f⸮⸮ff⸮⸮⸮20389 TSM:FAIL:RE-INIT
    09:15:10.888 -> 20413 TSM:INIT
    09:15:10.935 -> 20433 !TSM:INIT:TSP FAIL
    09:15:10.935 -> 20459 TSM:FAIL:CNT=3
    09:15:10.983 -> 20481 TSM:FAIL:DIS
    09:15:10.983 -> 20501 TSF:TDI:TSL
    What do I have to do ?
    Thank you
    PS : i tried with another wemos and same issue.
    Welcome to the forum @David-Marlinge
    !TSM:INIT:TSP FAIL
    This means that the wemos was unable to initialize the nrf24 radio. Double-check the wiring. If you can't find anything wrong, post multiple photos of the wiring and we'll help check. Plase also post the entire sketch (with wifi namn/password removed).
    If you haven't already, see https://forum.mysensors.org/topic/666/read-this-first-it-could-save-you-a-lot-of-time/ for how to efficiently troubleshoot.
    • David MarlingeD
      David MarlingeD
      David Marlinge
      Oh, I will check the wiring ...
      I taught It means that it can't connect to wifi ...
      So it's normal that I can't ping the wemos ...
      For the sketch I just upload the example sketch for esp8266gateway..
       * Copyright (C) 2013-2019 Sensnology AB
       * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
       * Version 1.0 - Henrik Ekblad
       * Contribution by Ivo Pullens (ESP8266 support)
       * The EthernetGateway sends data received from sensors to the WiFi link.
       * VERA CONFIGURATION:
       * E.g. If you want to use the default values in this sketch enter: 192.168.178.66:5003
       * LED purposes:
       * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
       * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
       * - ERR (red) - fast blink on error during transmission error or receive crc error
       * See https://www.mysensors.org/build/connect_radio for wiring instructions.
       * If you are using a "barebone" ESP8266, see
       * https://www.mysensors.org/build/esp8266_gateway#wiring-for-barebone-esp8266
       * Inclusion mode button:
       * - Connect GPIO5 (=D1) via switch to GND ('inclusion switch')
      #define MY_BAUD_RATE 9600
      #define MY_RADIO_RF24
      //#define MY_RADIO_RFM95
      #define MY_GATEWAY_ESP8266
      #define MY_WIFI_SSID "xxxx"
      #define MY_WIFI_PASSWORD "xxxxxx"
      // Enable UDP communication
      //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
      #define MY_HOSTNAME "ESP8266_GW"
      #define MY_IP_ADDRESS 192,168,1,112
      #define MY_PORT 5003
      //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
      // Enable inclusion mode
      //#define MY_INCLUSION_MODE_BUTTON_PIN D1
      // Set blinking period
      // Flash leds on rx/tx/err
         * LED purposes:
        @David-Marlinge test it is normal, if there is a problem with the nrf24. A gateway is (usually) not useful if it can’t talk to any nodes, so it will block if initialization fails.
        • David MarlingeD
          David MarlingeD
          David Marlinge
          Now the wiring check.
          I have a nrf24l01 with antenna, and nothing is written on the board ...
          Does someone have a wiring diagram for that nrf module ?
          Thank you.
            Thank you.
            @David-Marlinge could you expand on what you mean by "nothing is written on the board". Which board?
            The wiring is available at https://www.mysensors.org/build/connect_radio#nrf24l01+-&-esp8266
            • David MarlingeD
              David MarlingeD
              David Marlinge
              nothing is written on the nrf24L01 board ...
              I send a picture ...
                @David-Marlinge the nrf24 chip is not a board in the Arduino board meaning. Nothing can be written to it. It must be connected to a microcontroller to be useful.
                • David MarlingeD
                  David MarlingeD
                  David Marlinge
                  If it's the same wiring, I connect like your link, but it does not work.
                  Now I can ping the wifi adress even if the nrf24l01 is not plugin ... In fact It doesn't take the adress I give in the sketch ....
                  • David MarlingeD
                    David MarlingeD
                    David Marlinge
                    What I want to say, is that nothing is written on the pin ... So How can I be sure where the gnd, vcc and so on are ???
                      @David-Marlinge I see. Sorry for misunderstanding.
                      The pinout is probably compatible with the smaller nrf24 (without PA). If you can, check with the vendor/store where you bought the nrf24.
                      • David MarlingeD
                        David MarlingeD
                        David Marlinge
                        I have already check, nothing is written on the store where i bought them ...
                        Is tha capacitor needed ? and Must the whole thing works connected on a PC usb ?
                        • David MarlingeD
                          David MarlingeD
                          David Marlinge
                          So I check the wiring. I think a wire was not well plugged.
                          Now it works.
                          I have such "sentences" :
                          11:52:22.169 -> 12496 GWT:TIN:CONNECTING...
                          11:52:22.499 -> scandone
                          11:52:23.204 -> 13525 GWT:TIN:CONNECTING...
                          11:52:23.204 -> 13555 GWT:TIN:IP: 192.168.1.111
                          11:52:23.251 -> 13588 MCO:BGN:STP
                          11:52:23.251 -> 13607 MCO:BGN:INIT OK,TSP=1
                          11:52:23.298 -> 13637 TSM:READY:NWD REQ
                          11:52:23.346 -> 13665 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                          11:52:23.535 -> pm open,type:2 0
                          12.5k
