[SOLVED] MySensors Raspberry Pi Gateway + Domotics Controller
The lines with
!TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
mean that the gateway is sending a response to the node, but the gateway does not receive an acknowledgement from the node.
Are you using the very same nrf24 as you did on your nano gateway, or a different one?
How is the nrf24 powered?
What capacitor(s) are you using? Where are they connected?
What antenna are you using?
Is there any conducting material near the antenna? This can block the signal.
Are the nodes in the same place as before or have you moved them?
Is the gateway in the same place as before or have you moved it?
What is the distance between the nodes and the gateway?
Posting a few photos of your setup would help us understand the environment you are working in.
Hello @mfalkvidd , l am a fan! I very honoured to have you look into my issue... to answer your questions...
No it's another Rf24 but from the same batch as the one on the nano Gateway and all my nodes. I still have a spare one lying around. I'll try it see if it makes any difference.
The Rf24 is powered directly from the Pi with a 220uf cap connected next to GPIO pins as described in the official Rasberry Pi Gateway guide. I'll post a picture of the setup.
Everything is still on the fly with Dupont cables and Leds on a bread board until everything works well.
Concerning proximity of nodes to Gateway and if I've moved them from their original place. Besides the Gateway now lying on my desk, all my nodes are still in their place around the hose. Node ID 2 is the Sprinkler from my kitchen downstairs (over 10 metres away between concrete walls) Node ID 7 is the Gate node outside the house (about 9 meters from my desk) and Node ID 5 which didn't show in the log (probably disconnected at the time) is right next to the PiGateway.
Hello @Eme,
Sending only works for an unacknowledge msg. Now the question is did the gateway not send the message or did the sensor not receive the message thus not sending an ACK. Yould you ckeck on the sensor side what the debug says?
Thanks @eiten I thought I already shared that. I just hooked Node 5 to the laptop to get its log...
__ __ ____ | \/ |_ _/ ___| ___ _ __ ___ ___ _ __ ___ | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __| | | | | |_| |___| | __/ | | \__ \ _ | | \__ \ |_| |_|\__, |____/ \___|_| |_|___/\___/|_| |___/ |___/ 2.3.2 16 MCO:BGN:INIT REPEATER,CP=RNNRA---,FQ=16,REL=255,VER=2.3.2 27 MCO:BGN:BFR 28 TSM:INIT 29 TSF:WUR:MS=0 36 TSM:INIT:TSP OK 38 TSM:INIT:STATID=5 40 TSF:SID:OK,ID=5 41 TSM:FPAR 46 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 764 TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 770 TSF:MSG:BC 1880 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 1884 TSF:MSG:BC 2053 !TSM:FPAR:NO REPLY 2055 TSM:FPAR 2059 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 2810 TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 2816 TSF:MSG:BC 3924 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 3930 TSF:MSG:BC 4066 !TSM:FPAR:NO REPLY 4068 TSM:FPAR 4072 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 4845 TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 4850 TSF:MSG:BC 5971 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 5977 TSF:MSG:BC 6079 !TSM:FPAR:NO REPLY 6081 TSM:FPAR 6085 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 6887 TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 6892 TSF:MSG:BC 8008 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 8013 TSF:MSG:BC 8092 !TSM:FPAR:FAIL 8093 TSM:FAIL:CNT=1 8095 TSM:FAIL:DIS 8097 TSF:TDI:TSL 18099 TSM:FAIL:RE-INIT 18101 TSM:INIT 18107 TSM:INIT:TSP OK 18109 TSM:INIT:STATID=5 18112 TSF:SID:OK,ID=5 18114 TSM:FPAR 18118 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 20059 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 20064 TSF:MSG:BC 20125 !TSM:FPAR:NO REPLY 20127 TSM:FPAR 20131 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 22094 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 22099 TSF:MSG:BC 22140 !TSM:FPAR:NO REPLY 22142 TSM:FPAR 22147 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 24135 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 24140 TSF:MSG:BC 24155 !TSM:FPAR:NO REPLY 24157 TSM:FPAR 24161 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 26169 !TSM:FPAR:FAIL 26170 TSM:FAIL:CNT=2 26172 TSM:FAIL:DIS 26174 TSF:TDI:TSL 36177 TSM:FAIL:RE-INIT 36179 TSM:INIT 36186 TSM:INIT:TSP OK 36188 TSM:INIT:STATID=5 36191 TSF:SID:OK,ID=5 36193 TSM:FPAR 36197 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 38204 !TSM:FPAR:NO REPLY 38206 TSM:FPAR 38210 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 38228 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 38234 TSF:MSG:BC 40218 !TSM:FPAR:NO REPLY 40220 TSM:FPAR 40224 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 40258 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 40263 TSF:MSG:BC 42232 !TSM:FPAR:NO REPLY 42234 TSM:FPAR 42238 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 42304 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 42309 TSF:MSG:BC 44247 !TSM:FPAR:FAIL 44249 TSM:FAIL:CNT=3 44250 TSM:FAIL:DIS 44252 TSF:TDI:TSL 54255 TSM:FAIL:RE-INIT 54257 TSM:INIT 54263 TSM:INIT:TSP OK 54265 TSM:INIT:STATID=5 54268 TSF:SID:OK,ID=5 54270 TSM:FPAR 54275 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 56282 !TSM:FPAR:NO REPLY 56284 TSM:FPAR 56288 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 56393 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 56398 TSF:MSG:BC 58296 !TSM:FPAR:NO REPLY 58298 TSM:FPAR 58302 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 58434 TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 58439 TSF:MSG:BC 59362 TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 59367 TSF:MSG:BCIt still cant find the Gateway, and I see it reads Node 7 and 2 request for registration too.
So the sensors do not receive Messages from the gateway, but not from other sensors. Is the nrf24 on the gateway a module with PA? Then maybe test different PA settings, this helped once on a setup here.
BTW: Your picture is not visible: access denied@eiten based on the suggestions "leaning towards" powering the rf24 from you and @mfalkvidd l fed the radio a regulated 3.3 with LD33V and l also brought the capacitator near the radio... yet I still cant register the nodes.
Pls what does "TSF:CKU:OK:FCTRL" mean?
@Eme did'nt I write English :grinning:
So, if you look at the source:bool transportCheckUplink(const bool force) { if (!force && (hwMillis() - _transportSM.lastUplinkCheck) < MY_TRANSPORT_CHKUPL_INTERVAL_MS) { TRANSPORT_DEBUG(PSTR("TSF:CKU:OK,FCTRL\n")); // flood control return true; }The transport prevented an uplink check, since the last was done less then
MY_TRANSPORT_CHKUPL_INTERVAL_MSmilliseconds ago (defaults to 10 seconds)
@Eme said in MySensors Raspberry Pi Gateway + Domotics Controller:
Pi Model A with wifi
Sure? AFAIK A had no WiFi. Or do you use a USB dongle?
@eiten l think it's A+ it has Wifi and l run it "headless" with my old Nano Gateway connected to the 1 USB. But I'll looking forward to getting the Pi to work as both Gateway and Controller.
I want to use a prototype board and drop the long lines. Plus I'll also bring the cap closer to the nrf24 to see if that helps.
I have good news. I used a small prototype board for everything. made sure no line was more than 6 inches long. I soldered (My soldering sucks!) the capacitator right next to the radio and Bahm! Domoticz picked up all powered devices. :grinning:
Lessons learnt, keep length of your wires short, nRf24 MUST have a decent capacitator to smoothen out power. Don't rely on GPIO pins to power it, use a regulator. Though help may come from all and sundry, its all up to you to check their suggestions... Thanks all for helping me.
I can finally retire my Nano-Serial Gateway! Wont be upgrading for a long time to come :sneezing_face:
@mfalkvidd so how do I change the title to reflect "SOLVED"?
@Eme Thanks for letting us know how you solved the problem - helps us all to learn. I've recently upgraded my Raspberry Pi 1b to 4 and just got it working as an ethernet gateway with standard NRF24 radio. I'm curious about a few things as I've been trying to also use a PA LNA radio but without success;
Any reason you have set up your gateway as serial and not ethernet?
What did you mean by "Don't rely on GPIO pins to power it, use a regulator". By regulator did you mean the capacitor, did you use another regulator component - I can't see from your image
Did you change the power setting of you configuration file MyConfig.h -lowering the power to "RF24_PA_LOW'?
