  3. Domoticz
  4. [SOLVED] MySensors Raspberry Pi Gateway + Domotics Controller
23 Posts 5 Posters 3.8k Views 5 Watching
  • E
    E
    eiten
    @Eme said in MySensors Raspberry Pi Gateway + Domotics Controller:
    TSF:CKU:OK,FCTRL
    Uplink OK, flood control prevents pinging GW in too short intervals
    EmeE 1 Reply Last reply
    • E eiten
      TSF:CKU:OK,FCTRL
      EmeE
      EmeE
      Eme
      @eiten Yes what does that mean in English: :blush:
      • EmeE Eme
        EmeE
        EmeE
        Eme
        @eiten Don't know if the Pi model matters. I used a Pi Model A with wifi.
        • E
          E
          eiten
          @Eme did'nt I write English :grinning:
          So, if you look at the source:
          bool transportCheckUplink(const bool force)
                  if (!force && (hwMillis() - _transportSM.lastUplinkCheck) < MY_TRANSPORT_CHKUPL_INTERVAL_MS) {
                          TRANSPORT_DEBUG(PSTR("TSF:CKU:OK,FCTRL\n"));    // flood control
                          return true;
          The transport prevented an uplink check, since the last was done less then MY_TRANSPORT_CHKUPL_INTERVAL_MS milliseconds ago (defaults to 10 seconds)
          • EmeE Eme
            E
            E
            eiten
            Sure? AFAIK A had no WiFi. Or do you use a USB dongle?
            • E eiten
              EmeE
              EmeE
              Eme
              wrote on last edited by Eme
              @eiten l think it's A+ it has Wifi and l run it "headless" with my old Nano Gateway connected to the 1 USB. But I'll looking forward to getting the Pi to work as both Gateway and Controller.
              I want to use a prototype board and drop the long lines. Plus I'll also bring the cap closer to the nrf24 to see if that helps.
              • EmeE Eme
                E
                E
                eiten
                @Eme i usually solder a tantalum directly to the pins on the top side of the board :blush:
                • EmeE
                  EmeE
                  Eme
                  I have good news. I used a small prototype board for everything. made sure no line was more than 6 inches long. I soldered (My soldering sucks!) the capacitator right next to the radio and Bahm! Domoticz picked up all powered devices. :grinning:
                  Lessons learnt, keep length of your wires short, nRf24 MUST have a decent capacitator to smoothen out power. Don't rely on GPIO pins to power it, use a regulator. Though help may come from all and sundry, its all up to you to check their suggestions... Thanks all for helping me.
                  I can finally retire my Nano-Serial Gateway! Wont be upgrading for a long time to come :sneezing_face:
                  mfalkviddM zookazimZ 2 Replies Last reply
                  • EmeE Eme
                    Great work @Eme! Thanks for reporting the result.
                      EmeE
                      EmeE
                      Eme
                      @mfalkvidd so how do I change the title to reflect "SOLVED"?
                      • EmeE Eme
                        @Eme I did it for you, but next time choose to edit the top post, and change the topic
                        • EmeE Eme
                          zookazimZ
                          zookazimZ
                          zookazim
                          @Eme Thanks for letting us know how you solved the problem - helps us all to learn. I've recently upgraded my Raspberry Pi 1b to 4 and just got it working as an ethernet gateway with standard NRF24 radio. I'm curious about a few things as I've been trying to also use a PA LNA radio but without success;
                          • Any reason you have set up your gateway as serial and not ethernet?
                          • What did you mean by "Don't rely on GPIO pins to power it, use a regulator". By regulator did you mean the capacitor, did you use another regulator component - I can't see from your image
                          • Did you change the power setting of you configuration file MyConfig.h -lowering the power to "RF24_PA_LOW'?
                          • zookazimZ zookazim
                            EmeE
                            EmeE
                            Eme
                            @zookazim so sorry I haven't been on here in years. I actually left the IoT nodes for a while. I was running into so many issues. To answer your question... not sure if it's still required or even relevant.
