  3. Gate controller with Battery Checker
13 Posts 3 Posters 1.4k Views 3 Watching
  • markjgabbM
    markjgabbM
    markjgabb
    @Yveaux said in Gate controller with Battery Checker:
    wait(15601000ul)
    champion that works much better thanks
    only one bug left now
    • markjgabbM
      markjgabbM
      markjgabb
      final bug
      when i try to compile the following code
      i Get this error
      exit status 1
      call of overloaded 'set(double&)' is ambiguous googling tells me that my msg need to be defined better for the purpose but im not sure, as i can see in my void that i have declared it as double, but for some reason it doesnt understant that when i go to send my message
      void batM()
      int Pin; // 0-1023 I/P
      double Vin;
      Pin = analogRead(A0); // Probe Input
      Vin = Pin * (5.0*11 / 1023); // Pin to Vin (Reduction Factor 11)
      Serial.print(Vin);
      Serial.println(" VOLT DC ");\
      send(power.set(Vin));
      • markjgabbM markjgabb
        final bug
        i Get this error
        exit status 1
        void batM()
        double Vin;
        Serial.print(Vin);
        @markjgabb MySensors does not have support for double. Use float instead.
        • markjgabbM
          markjgabbM
          markjgabb
          @mfalkvidd cheers
          ive added that instead but still get the following
          call of overloaded 'set(float&)' is ambiguous
            @mfalkvidd cheers
            @markjgabb sorry. I forgot we need to set the number of decimals. Like this:
            send(power.set(Vin, 2));
            I think you can change it back to double if you like.
            markjgabbM 1 Reply Last reply
            • markjgabbM
              markjgabbM
              markjgabb
              now compiles beautifully...
              but am getting weird voltage readings... ive just connected a double set of AA batteires and am getting a reading of 11.8-11.9
              im using a 100k and a 10k resistor as per this guide.... obviously i stuffed up something in my math....
              this always seems to be my way :)
              source for voltage reader code
              https://www.codrey.com/arduino-projects/nano-digital-volt-meter/
                markjgabbM
                markjgabbM
                markjgabb
                @mfalkvidd you are correct you can do double and it works
                • markjgabbM
                  markjgabbM
                  markjgabb
                  think i have figured it out
                  adjusted the math based on another page
                  Vin = (Pin * 5.0) / 1023;
                  removed the factor of 11 stuff and i think it wasn't necessary?
                  • markjgabbM
                    markjgabbM
                    markjgabb
                    Is anyone able to confirm if the calculations in this image are correct? I would need to multiply the result by 6 to get accurate numbers
                    I'm just currently stuggling with acuracy on my current design and figure bringing the max reading down would help
                    It's a 24v battery with solar cut off of 28.4v so it will never go over 30 anyway
                      @markjgabb yes it is correct.
                      What Arduino are you using? Most Arduinos return 1023 for max voltage, but some (Zero, Due and more) return 4095 for max voltage.
                      Is the Arduino 5V or 3.3V?
                      Are you using 100k+10k or 50k+10k resistor? (One early post says 100k, your latest post says 50k.)
                      Edit: Zero, Due default to 1023 so they should be fine anyway. Reference: https://www.arduino.cc/reference/en/language/functions/zero-due-mkr-family/analogreadresolution/
                      • markjgabbM
                        markjgabbM
                        markjgabb
                        Yeah I'm changing up the circuit die to inaccuracy...
                        Is a arduino nano 5v powered from usb.....
