  3. ECHO problems when sending with no payload
20 Posts 3 Posters 2.6k Views 3 Watching
  • karlheinz2000K
    karlheinz2000K
    karlheinz2000
    @frits, can you please check, if MySController reads correct ECHO from a no payload message? I have some ECHO problems, when sending with no payload. But maybe FHEM related...
    • fritsF
      fritsF
      frits
      sending an empty V_TEXT with "ACK" = "YES":
      MySensors Ethernet Gateway
      1896935 GWT:RFC:MSG=123;1;1;1;47;
      1896941 TSF:MSG:SEND,0-0-123-123,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
      1897074 TSF:MSG:READ,123-123-0,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
      1897195 TSF:MSG:SEND,0-0-123-123,s=1,c=1,t=47,pt=1,l=1,sg=1,ft=0,st=OK:0
      1897365 TSF:MSG:READ,123-123-0,s=1,c=1,t=47,pt=1,l=1,sg=0:0
      1897371 TSF:MSG:ECHO
      MySensors Node
      812210 TSF:MSG:READ,0-0-123,s=1,c=3,t=16,pt=0,l=0,sg=1:
      812216 SGN:SKP:MSG CMD=3,TYPE=16
      812292 SGN:SKP:MSG CMD=3,TYPE=17
      812300 TSF:MSG:SEND,123-123-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
      812308 SGN:NCE:XMT,TO=123
      812445 TSF:MSG:READ,0-0-123,s=1,c=1,t=47,pt=1,l=1,sg=1:0
      812451 SGN:BND:NONCE=xxxxxx
      812566 SGN:BND:HMAC=xxxxx
      812574 SGN:VER:OK
      812576 TSF:MSG:ECHO REQ
      812580 SGN:SKP:ECHO CMD=1,TYPE=47
      812584 TSF:MSG:SEND,123-123-0-0,s=1,c=1,t=47,pt=1,l=1,sg=0,ft=0,st=OK:0
      • karlheinz2000K
        karlheinz2000K
        karlheinz2000
        Is 2.3.2 running on your GW?
        I see different behaviour between 2.3.2 and old 2.2.0.
        With 2.3.2 on GW I see ECHO problems, with 2.0.0 everything is fine.
        First running a 2.3.2 GW, then switch to a 2.2.0 GW.
        The 2.3.2 version is adding a "0", which causes problems.
        12.11.2020 22:24:11	TX	70;0;1;1;47;
        12.11.2020 22:24:11	RX	0;255;3;0;9;41152 TSF:MSG:SEND,0-0-70-70,s=0,c=1,t=47,pt=1,l=1,sg=0,ft=0,st=OK:0
        12.11.2020 22:24:11	RX	0;255;3;0;9;41174 TSF:MSG:READ,70-70-0,s=0,c=1,t=47,pt=1,l=1,sg=0:0
        12.11.2020 22:24:11	RX	0;255;3;0;9;41192 TSF:MSG:ECHO
        12.11.2020 22:24:11	RX	70;0;1;1;47;0
        12.11.2020 22:25:10	INFO	Disconnected
        12.11.2020 22:25:24	INFO	Flushing FIFO
        12.11.2020 22:25:24	INFO	Connected to COM4
        12.11.2020 22:25:29	TX	70;0;1;1;47;
        12.11.2020 22:25:29	RX	0;255;3;0;9;192065 TSF:MSG:SEND,0-0-70-70,s=0,c=1,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
        12.11.2020 22:25:29	RX	0;255;3;0;9;192088 TSF:MSG:READ,70-70-0,s=0,c=1,t=47,pt=0,l=0,sg=0:
        12.11.2020 22:25:29	RX	0;255;3;0;9;192106 TSF:MSG:ACK
        12.11.2020 22:25:29	RX	70;0;1;1;47;
        • fritsF
          fritsF
          frits
          yes, it's 2.3.2:
          0 MCO:BGN:INIT GW,CP=RNNGAA--,FQ=8,REL=255,VER=2.3.2
          38 TSM:INIT
          40 TSF:WUR:MS=0
          47 TSM:INIT:TSP OK
          49 TSM:INIT:GW MODE
          51 TSM:READY:ID=0,PAR=0,DIS=0
          55 MCO:REG:NOT NEEDED
          618 GWT:TIN:IP=192.168.99.13
          1622 MCO:BGN:STP
          Version 0.1
          own mac address: DE:AD:BA:BE:99:13
          own network address: 192.168.99.13
          Gateway type: MysGW
          network port: 5003
          Radio type: NRF24
          signing: yes
          2140 MCO:BGN:INIT OK,TSP=1
          2148 TSM:READY:NWD REQ
          2154 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
          • fritsF
            fritsF
            frits
            here's the requests with 2.2.0.
            Gateway:
            0 MCO:BGN:INIT GW,CP=RNNGA---,VER=2.2.0
            4 TSM:INIT
            4 TSF:WUR:MS=0
            12 TSM:INIT:TSP OK
            14 TSM:INIT:GW MODE
            16 TSM:READY:ID=0,PAR=0,DIS=0
            18 MCO:REG:NOT NEEDED
            583 GWT:TIN:IP=192.168.99.13
            1587 MCO:BGN:STP
            Version 0.1
            Gateway type: MysGW
            network port: 5003
            Radio type: NRF24
            signing: no
            2105 MCO:BGN:INIT OK,TSP=1
            36448 TSF:MSG:READ,123-123-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            36454 TSF:MSG:BC
            36456 TSF:MSG:FPAR REQ,ID=123
            36460 TSF:PNG:SEND,TO=0
            36462 TSF:CKU:OK
            36464 TSF:MSG:GWL OK
            37095 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
            38502 TSF:MSG:READ,123-123-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            38510 TSF:MSG:PINGED,ID=123,HP=1
            38514 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
            38531 TSF:MSG:READ,123-123-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            38539 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
            38549 TSF:MSG:READ,123-123-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.2.0
            38557 TSF:MSG:READ,123-123-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
            38567 GWT:TSA:ETH OK
            38576 GWT:RFC:MSG=123;255;3;0;6;M
            38582 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=OK:M
            38590 TSF:MSG:READ,123-123-0,s=255,c=3,t=11,pt=0,l=20,sg=0:Hello MySensors 328P
            38602 TSF:MSG:READ,123-123-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.3
            38612 TSF:MSG:READ,123-123-0,s=0,c=0,t=36,pt=0,l=6,sg=0:system
            38623 TSF:MSG:READ,123-123-0,s=1,c=0,t=36,pt=0,l=9,sg=0:timestamp
            38633 TSF:MSG:READ,123-123-0,s=2,c=0,t=3,pt=0,l=3,sg=0:led
            38645 TSF:MSG:READ,123-123-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
            38653 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
            85934 GWT:RFC:MSG=123;1;1;1;47;hello
            85940 TSF:MSG:SEND,0-0-123-123,s=1,c=1,t=47,pt=0,l=5,sg=0,ft=0,st=OK:hello
            85950 TSF:MSG:READ,123-123-0,s=1,c=1,t=47,pt=0,l=5,sg=0:hello
            85958 TSF:MSG:ACK
            93378 GWT:RFC:MSG=123;1;1;1;47;next message empty
            93386 TSF:MSG:SEND,0-0-123-123,s=1,c=1,t=47,pt=0,l=18,sg=0,ft=0,st=OK:next messa
            ge empty
            93399 TSF:MSG:READ,123-123-0,s=1,c=1,t=47,pt=0,l=18,sg=0:next message empty
            93407 TSF:MSG:ACK
            96987 GWT:RFC:MSG=123;1;1;1;47;
            96993 TSF:MSG:SEND,0-0-123-123,s=1,c=1,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
            97001 TSF:MSG:READ,123-123-0,s=1,c=1,t=47,pt=0,l=0,sg=0:
            97007 TSF:MSG:ACK
            Node:
            4 TSM:INIT
            4 TSF:WUR:MS=0
            12 TSM:INIT:TSP OK
            14 TSM:INIT:GW MODE
            1587 MCO:BGN:STP
            Version 0.1
            Gateway type: MysGW
            network port: 5003
            Radio type: NRF24
            signing: no
            36454 TSF:MSG:BC
            36462 TSF:CKU:OK
            85958 TSF:MSG:ACK
            ge empty
            93407 TSF:MSG:ACK
            97007 TSF:MSG:ACK
            • fritsF
              fritsF
              frits
              sorry, ctr-c didn't work
              Node:
               __  __       ____
                      |___/                      2.2.0
              26 MCO:BGN:BFR
              Version 1.3
              Radio type: NRF24
              signing: no
              32 TSM:INIT
              40 TSF:WUR:MS=0
              47 TSM:INIT:TSP OK
              49 TSM:INIT:STATID=123
              51 TSF:SID:OK,ID=123
              53 TSM:FPAR
              90 TSF:MSG:SEND,123-123-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              700 TSF:MSG:READ,0-0-123,s=255,c=3,t=8,pt=1,l=1,sg=0:0
              706 TSF:MSG:FPAR OK,ID=0,D=1
              2099 TSM:FPAR:OK
              2099 TSM:ID
              2101 TSM:ID:OK
              2103 TSM:UPL
              2107 TSF:MSG:SEND,123-123-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              2117 TSF:MSG:READ,0-0-123,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              2123 TSF:MSG:PONG RECV,HP=1
              2127 TSM:UPL:OK
              2129 TSM:READY:ID=123,PAR=0,DIS=1
              2134 TSF:MSG:SEND,123-123-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              2142 TSF:MSG:READ,0-0-123,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              2152 TSF:MSG:SEND,123-123-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.2.0
              2160 TSF:MSG:SEND,123-123-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
              2185 TSF:MSG:READ,0-0-123,s=255,c=3,t=6,pt=0,l=1,sg=0:M
              2193 TSF:MSG:SEND,123-123-0-0,s=255,c=3,t=11,pt=0,l=20,sg=0,ft=0,st=OK:Hello MySensors 328P
              2205 TSF:MSG:SEND,123-123-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.3
              2215 TSF:MSG:SEND,123-123-0-0,s=0,c=0,t=36,pt=0,l=6,sg=0,ft=0,st=OK:system
              2226 TSF:MSG:SEND,123-123-0-0,s=1,c=0,t=36,pt=0,l=9,sg=0,ft=0,st=OK:timestamp
              2236 TSF:MSG:SEND,123-123-0-0,s=2,c=0,t=3,pt=0,l=3,sg=0,ft=0,st=OK:led
              2244 MCO:REG:REQ
              2248 TSF:MSG:SEND,123-123-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              2256 TSF:MSG:READ,0-0-123,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              2263 MCO:PIM:NODE REG=1
              2265 MCO:BGN:STP
              2267 MCO:BGN:INIT OK,TSP=1
              49412 TSF:MSG:READ,0-0-123,s=1,c=1,t=47,pt=0,l=5,sg=0:hello
              49420 TSF:MSG:ACK REQ
              49424 TSF:MSG:SEND,123-123-0-0,s=1,c=1,t=47,pt=0,l=5,sg=0,ft=0,st=OK:hello
              h
              received message for sensor 1, type 47, value hello
              56838 TSF:MSG:READ,0-0-123,s=1,c=1,t=47,pt=0,l=18,sg=0:next message empty
              56846 TSF:MSG:ACK REQ
              56850 TSF:MSG:SEND,123-123-0-0,s=1,c=1,t=47,pt=0,l=18,sg=0,ft=0,st=OK:next message empty
              n
              received message for sensor 1, type 47, value next message empty
              60434 TSF:MSG:READ,0-0-123,s=1,c=1,t=47,pt=0,l=0,sg=0:
              60440 TSF:MSG:ACK REQ
              60444 TSF:MSG:SEND,123-123-0-0,s=1,c=1,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
              • karlheinz2000K
                karlheinz2000K
                karlheinz2000
                I again checked with latest 2.3.2 development lib. Same, ECHO does not work.
                You use ethernet gateway, my is serial. This might be the difference...
                13.11.2020 09:17:20	TX	70;0;1;1;47;
                13.11.2020 09:17:20	RX	0;255;3;0;9;10969 TSF:MSG:SEND,0-0-70-70,s=0,c=1,t=47,pt=1,l=1,sg=0,ft=0,st=OK:0
                13.11.2020 09:17:20	RX	0;255;3;0;9;10989 TSF:MSG:READ,70-70-0,s=0,c=1,t=47,pt=1,l=1,sg=0:0
                13.11.2020 09:17:20	RX	0;255;3;0;9;11008 TSF:MSG:ECHO
                13.11.2020 09:17:20	RX	70;0;1;1;47;0
                I now try to setup an ethernet gateway just for test.
                • karlheinz2000K
                  karlheinz2000K
                  karlheinz2000
                  Same with ethernet gateway (UNO, W5100)
                  gateway 2.2.0
                  10:25:06.047 -> 73634 GWT:RFC:MSG=70;0;1;1;47;
                  10:25:06.047 -> 73639 TSF:MSG:SEND,0-0-70-70,s=0,c=1,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
                  10:25:06.088 -> 73652 TSF:MSG:READ,70-70-0,s=0,c=1,t=47,pt=0,l=0,sg=0:
                  10:25:06.088 -> 73657 TSF:MSG:ACK
                  MYSController
                  13.11.2020 10:25:06	TX	70;0;1;1;47;
                  13.11.2020 10:25:06	RX	70;0;1;1;47;
                  gateway 2.3.2
                  10:30:45.718 -> 22546 GWT:RFC:MSG=70;0;1;1;47;
                  10:30:45.718 -> 22550 TSF:MSG:SEND,0-0-70-70,s=0,c=1,t=47,pt=1,l=1,sg=0,ft=0,st=OK:0
                  10:30:45.718 -> 22561 TSF:MSG:READ,70-70-0,s=0,c=1,t=47,pt=1,l=1,sg=0:0
                  10:30:45.718 -> 22566 TSF:MSG:ECHO
                  MYSController
                  13.11.2020 10:30:45	TX	70;0;1;1;47;
                  13.11.2020 10:30:45	RX	70;0;1;1;47;0
                  Now I have to look for some ESP board...
                  rejoe2R 1 Reply Last reply
                  • karlheinz2000K karlheinz2000
                    gateway 2.2.0
                    MYSController
                    gateway 2.3.2
                    MYSController
                    rejoe2R
                    rejoe2R
                    rejoe2
                    @karlheinz2000
                    Which type of radio you are using? There might be a difference between nRF24 and other (RFM-based?) transceivers. So if possible, also make a test with 2.3.2 and nRF24.
                    Problem may be related to the change from soft ACK to ECHO (https://github.com/mysensors/MySensors/releases).
                    • karlheinz2000K
                      karlheinz2000K
                      karlheinz2000
                      All tests are done with nRF24 radio only.
                      • rejoe2R
                        rejoe2R
                        rejoe2
                        Thx, so this seems not to be the reason behind that.
                        Sth. else: If possible, it could be a good idea to add some more content to the thread title (ECHO in 2.3.2 changes message content)?
                        • fritsF
                          fritsF
                          frits
                          the library differs the way it sends empty V_TEXT messages between 2.2.0 and 2.3.2.
                          2.2.0
                          note: length = 0, payload type = 0
                          2.3.2
                          note: length = 1, payload type = 1
                          • fritsF
                            fritsF
                            frits
                            I think the issue found it's way into the library here:
                            https://github.com/mysensors/MySensors/commit/74e566f5602261ba58e9a7fb06357810ae793b0b#diff-75e571c3ad1b2847e816b36b077fb7306d69ac8386b59d600a265f12bee1f8ba
                            old code:
                            	// payload
                            	if (command == C_STREAM) {
                            		uint8_t bvalue[MAX_PAYLOAD_SIZE];
                            		uint8_t blen = 0;
                            new code:
                            	// payload
                            	if (str == NULL) {
                            		// no payload, set default value
                            		message.set((uint8_t)0);
                            	} else if (command == C_STREAM) {
                            		// stream payload
                            if there's no payload, the library assumes uint8_t with value 0
                            • rejoe2R
                              rejoe2R
                              rejoe2
                              @frits: Thx for analyzing this issue. Atm I honestly don't have no clue how to deal with this change in the FHEM module code. When analyzing ECHO, there's a check weather send info is identical to what's been sent.
                              So the only way out seems to be less exact and also let be 0 the same as "nothing" (Perl doesn't use NULL).
                              @karlheinz2000 Perhaps, we could ad a small if statement at the end of line 760 to treat 0 as "nothing" or undef?
                              or $_->{payload} ne $msg->{payload} if $msg->{payload}
                              Deleting the entire line might cause problems...
                              • karlheinz2000K
                                karlheinz2000K
                                karlheinz2000
                                I've opened an issue for that.
                                https://github.com/mysensors/MySensors/issues/1452
                                According to API payload is same on ECHO message.
                                I feel this should be handled/fixed in lib, but I have no idea how to do...
                                If it is not possible to fix in lib, it shall not be allowed to send message with no payload anymore, which controller has to make sure then.
                                @rejoe2
                                Regarding FHEM, at the moment we should keep it as it is. No payload is not the normal use case.
                                I flashed gateway with 2.2.0 and this fixed the problem for me.
