  3. OpenHAB
  4. OH3 - MySensors Binding
135 Posts 34 Posters 32.9k Views 40 Watching
  • P
    P
    Peter Loeffler
    has anyone of you guys already a bibdign version for OH3?
    • G
      G
      gieemek
      wrote on last edited by gieemek
      I don't use MySensors binding so I have not tested it in OH3. But I know, that there are not binding special for OH3. All binding 2x should work with OH3. Difference is with binding 1x - these are not working with OH3.
      • K
        K
        Klabbe
        The 2.5 binding does not work out of the box in OpenHAB 3 for me.
        2020-12-22 22:53:34.555 [WARN ] [org.apache.felix.fileinstall        ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.mysensors-2.5.0-SNAPSHOT.jar
        org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.mysensors [272]
          Unresolved requirement: Import-Package: org.eclipse.smarthome.config.core
                at org.eclipse.osgi.container.Module.start(Module.java:444) ~[org.eclipse.osgi-3.12.100.jar:?]
                at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[org.eclipse.osgi-3.12.100.jar:?]
                at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.6.4]
                at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.6.4]
                at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [bundleFile:3.6.4]
                at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.6.4]
                at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.6.4]
        I guess it has somehing to do with this?
        https://community.openhab.org/t/guide-binding-development-changes-for-openhab-3-from-2-5-x/104134
        Namespace change of openHAB core classes
        With the migration of Eclipse Smart Home to openHAB the namespace of all classes in openHAB core needed to be changed. This means all imports done by bindings that refer to org.eclipse.smarthome have been changed to org.openhab.core. With your binding code you can simply do a file level replace of this text string in the java source files to migrate the binding. On linux you can use the following commands in you src/main/java directory:
        find . -name *.java -exec sed -i "s/org.eclipse.smarthome.core/org.openhab.core/g" {} ;
        find . -name *.java -exec sed -i "s/org.eclipse.smarthome/org.openhab.core/g" {} ;
        • G
          G
          Guillermo Schimmel
          Well it seems that there isn't and ther won't be a mysensors binding anymore. It was abandoned by the developer.
          So as of december 2020, with OpenHAB 3, the way to go is plain MQTT.
          I can't say I disagree really. MQTT is simple and works.
          I'm going to start from scratch and try to document my experience here.
          • K
            K
            Klabbe
            Sad to hear that. I really liked the binding. I used MQTT before the binding and it worked but the binding was easier to use with auto ID and so on. Looking forward on following your progress. I guess I have to do the same, when I find the time.
            • K
              K
              Klabbe
              I'm thinking about running a separate instance of OpenHAB 2 under docker, just to get the mysensors binding functionality. Or can I get all the functionality of the binding, via MQTT? Like auto ID and that the sensor (like a watermeter) can request its previous value from the controller.
              • K
                K
                Klabbe
                Running OpenHAB 3 as my main system and OpenHAB 2 with the MySensors binding, under docker, works great. I use the remote binding in OpenHAB 3 to connect to OpenHAB 2. Just make sure to run them on different ports if they run on the same server.
                G 1 Reply Last reply
                • K Klabbe
                  G
                  G
                  Guillermo Schimmel
                  @Klabbe great to know. Thanks
                  • H
                    H
                    haasje30
                    Is smartsleep option of mysensors is implemented in de mqtt gateway? I have some battery powered units to control blinds which I put a lot in (smart)sleep to preserve batteries. This functions well with OH2 and mysensors binding....I'd rather not keep and OH2 instance running next to my OH3 instance if not necessary.
                    regards,
                    W 1 Reply Last reply
                    • G
                      G
                      Guillermo Schimmel
                      I think so. I have a lot of battery powered nodes heavily using smartsleep and they work just fine with MQTT.
                      • H
                        H
                        haasje30
                        Thanks Guillermo, are you using qos 1 for this, or are messages kept on the gateway automatically to deliver to a sensor which is asleep. Think I have to rebuild my gateway to mqtt then....
                        • T
                          TimO
                          I'll look into the changes needed to migrate the binding to OH3 and let you know.
                          Maybe it's no big deal and I'll provide a version 3 binding.
                          K 1 Reply Last reply
                          • T TimO
                            K
                            K
                            Klabbe
                            @TimO That would be very appreciated! I really like your binding and it would be great to continue to use it without an extra instance of OpenHAB 2. I tried to compile it and got like 10 errors. Since I have zero java skills, I was unable to fix them.
                            • H
                              H
                              haasje30
                              @TimO, a binding for openhab 3.0 would be very much appreciated!
                              I have tried the MQTT gateway, and with standard setup, messages are lost wich are sent to the node when asleep. Does anyone know how to solve this. I didnt find anything in de mqtt-gateway config. I see mqtt messages which could be read by the controller (openhab), when the node goes to sleep and wakes up, but at this moment I don't see how to implement this in openhab MQTT generic things.
                              Thanks...
                              • T
                                TimO
                                For those of you willing to help testing the OH3 integration here is a link:
                                Jar Download
                                Please don't forget to fulfill the requirements for mqtt und serial. Installation of bindings will do.
                                What's working after a quick test:
                                • binding loads in OH3
                                • serial gateway receives messages (ethernet gateway should work too)
                                • discovery is working
                                What's not working:
                                • MQTT gateway: it's broken some time and needs some tinkering
                                Please let me know if you found some time to test the binding.
                                DbagioniD K G kerberosK Dustin HagstromD 5 Replies Last reply
                                • H haasje30
                                  regards,
                                  W
                                  W
                                  waspie
                                  wrote on last edited by waspie
                                  @haasje30
                                  smartsleep is easy with MQTT
                                  Initially a few years ago i tried the binding and it gave me nothing but trouble.
                                  While it was configured I'd watch MQTT to see what it would do.
                                  2020-12-31 22:58:22 unoout/202/255/3/0/33 180000 (THIS IS THE SLEEP DURATION)
                                  2020-12-31 22:58:22 unoout/202/255/3/0/32 500 (AT THIS MOMENT YOU HAVE 500MS to GET A COMMAND SENT)
                                  So define a thing to the channel ending in 32.
                                  Bind an item to that channel with an expire timer for like 10 seconds state = 0
                                  then for your rule you'd have
                                  rule "whatever"
                                  when
                                  Item whateverSleepItem changed from 0 to 500
                                  then
                                  whateverOtherItemThatIsSendingOutACommand.sendCommand(ON/OFF/WHATEVER)
                                  end
                                  • H
                                    H
                                    haasje30
                                    Thanks TimO and waspie. At this moment I have one mysensors hardware gateway, which is connected to my openhab2 instance. I have an OH3 test instance, and no hardware controller for this (yet). I did an short test with my current controller, but this is not the best way for me. So I orderded an wemos D1 mini to create a new mysensors gateway. As soon as this is in I will be testing. Thanks again...
                                    • T TimO
                                      Jar Download
                                      What's not working:
                                      DbagioniD
                                      DbagioniD
                                      Dbagioni
                                      • H haasje30
                                        W
                                        W
                                        waspie
                                        @haasje30 if it's mqtt both can subscribe at the same time
                                        • T TimO
                                          Jar Download
                                          What's not working:
                                          K
                                          K
                                          Klabbe
                                          @TimO Thank you! It works for me with my Ethernet Gateway. I don't have that many nodes but the ones that I have, works as good as they did with OpenHAB2. I have a watermeter, an actuator and a door sensor. Great work!
                                          T G 2 Replies Last reply
