  3. OpenHAB
  4. OH3 - MySensors Binding
135 Posts 34 Posters 36.0k Views 40 Watching
  • K
    K
    Klabbe
    Sad to hear that. I really liked the binding. I used MQTT before the binding and it worked but the binding was easier to use with auto ID and so on. Looking forward on following your progress. I guess I have to do the same, when I find the time.
    • K
      K
      Klabbe
      I'm thinking about running a separate instance of OpenHAB 2 under docker, just to get the mysensors binding functionality. Or can I get all the functionality of the binding, via MQTT? Like auto ID and that the sensor (like a watermeter) can request its previous value from the controller.
      • K
        K
        Klabbe
        Running OpenHAB 3 as my main system and OpenHAB 2 with the MySensors binding, under docker, works great. I use the remote binding in OpenHAB 3 to connect to OpenHAB 2. Just make sure to run them on different ports if they run on the same server.
        G 1 Reply Last reply
        • K Klabbe
          G
          G
          Guillermo Schimmel
          @Klabbe great to know. Thanks
          • H
            H
            haasje30
            Is smartsleep option of mysensors is implemented in de mqtt gateway? I have some battery powered units to control blinds which I put a lot in (smart)sleep to preserve batteries. This functions well with OH2 and mysensors binding....I'd rather not keep and OH2 instance running next to my OH3 instance if not necessary.
            regards,
            W 1 Reply Last reply
            • G
              G
              Guillermo Schimmel
              I think so. I have a lot of battery powered nodes heavily using smartsleep and they work just fine with MQTT.
              • H
                H
                haasje30
                Thanks Guillermo, are you using qos 1 for this, or are messages kept on the gateway automatically to deliver to a sensor which is asleep. Think I have to rebuild my gateway to mqtt then....
                • T
                  TimO
                  I'll look into the changes needed to migrate the binding to OH3 and let you know.
                  Maybe it's no big deal and I'll provide a version 3 binding.
                  K 1 Reply Last reply
                  • T TimO
                    K
                    K
                    Klabbe
                    @TimO That would be very appreciated! I really like your binding and it would be great to continue to use it without an extra instance of OpenHAB 2. I tried to compile it and got like 10 errors. Since I have zero java skills, I was unable to fix them.
                    • H
                      H
                      haasje30
                      @TimO, a binding for openhab 3.0 would be very much appreciated!
                      I have tried the MQTT gateway, and with standard setup, messages are lost wich are sent to the node when asleep. Does anyone know how to solve this. I didnt find anything in de mqtt-gateway config. I see mqtt messages which could be read by the controller (openhab), when the node goes to sleep and wakes up, but at this moment I don't see how to implement this in openhab MQTT generic things.
                      Thanks...
                      • T
                        TimO
                        For those of you willing to help testing the OH3 integration here is a link:
                        Jar Download
                        Please don't forget to fulfill the requirements for mqtt und serial. Installation of bindings will do.
                        What's working after a quick test:
                        • binding loads in OH3
                        • serial gateway receives messages (ethernet gateway should work too)
                        • discovery is working
                        What's not working:
                        • MQTT gateway: it's broken some time and needs some tinkering
                        Please let me know if you found some time to test the binding.
                        DbagioniD K G kerberosK Dustin HagstromD 5 Replies Last reply
                        • H haasje30
                          regards,
                          W
                          W
                          waspie
                          wrote on last edited by waspie
                          @haasje30
                          smartsleep is easy with MQTT
                          Initially a few years ago i tried the binding and it gave me nothing but trouble.
                          While it was configured I'd watch MQTT to see what it would do.
                          2020-12-31 22:58:22 unoout/202/255/3/0/33 180000 (THIS IS THE SLEEP DURATION)
                          2020-12-31 22:58:22 unoout/202/255/3/0/32 500 (AT THIS MOMENT YOU HAVE 500MS to GET A COMMAND SENT)
                          So define a thing to the channel ending in 32.
                          Bind an item to that channel with an expire timer for like 10 seconds state = 0
                          then for your rule you'd have
                          rule "whatever"
                          when
                          Item whateverSleepItem changed from 0 to 500
                          then
                          whateverOtherItemThatIsSendingOutACommand.sendCommand(ON/OFF/WHATEVER)
                          end
                          • H
                            H
                            haasje30
                            Thanks TimO and waspie. At this moment I have one mysensors hardware gateway, which is connected to my openhab2 instance. I have an OH3 test instance, and no hardware controller for this (yet). I did an short test with my current controller, but this is not the best way for me. So I orderded an wemos D1 mini to create a new mysensors gateway. As soon as this is in I will be testing. Thanks again...
                            • T TimO
                              Jar Download
                              What's not working:
                              DbagioniD
                              DbagioniD
                              Dbagioni
                              • H haasje30
                                W
                                W
                                waspie
                                @haasje30 if it's mqtt both can subscribe at the same time
                                • T TimO
                                  Jar Download
                                  What's not working:
                                  K
                                  K
                                  Klabbe
                                  @TimO Thank you! It works for me with my Ethernet Gateway. I don't have that many nodes but the ones that I have, works as good as they did with OpenHAB2. I have a watermeter, an actuator and a door sensor. Great work!
                                  T G 2 Replies Last reply
                                  • K Klabbe
                                    TimO
                                    @Klabbe thank you for your feedback!
                                    • K Klabbe
                                      G
                                      G
                                      Guillermo Schimmel
                                      @Klabbe great! perhaps I'll go back to ethernet gateway. Do you think is better option over mqtt gateway?
                                      • H
                                        H
                                        haasje30
                                        I did some testing with 2 openhab versions to one ethernet gateway. At first it did not discover any devices, thats because they were allready discovered in the old (2.5) version of openhab, I Think, because when I created a new mysensor device,it was immediattely discovered by the new openhab. I noticed a minor problem, there is an ability to scan (and because auto discovery did not seem to work I tried this), but after a scan the ethernet gateways failes. When you try to add a device(manually), it goes back to the first page when you select the gateway. I had to restart de openhab service to get it running again.
                                        I tested with a new blinds sensor (with smartsleep), and smartsleep seem to work OK. So I prefer this binding over de generic mqtt binding, because stuf like request() and smartsleep() work 'out of the box'. These are my fisrt tests, I will be doing more (other sensor types) later on when I have an additional gateway available.
                                        Regards...
                                        • T TimO
                                          Jar Download
                                          What's not working:
                                          G
                                          G
                                          Guillermo Schimmel
