  3. OpenHAB
  4. OH3 - MySensors Binding
135 Posts 34 Posters 36.0k Views 40 Watching
  • N
    N
    ncollins
    @TimO Great work.
    I've had a merge request https://github.com/tobof/openhab2-addons/pull/141 floating around for months to add a wind direction channel to the my sensors binding.
    Is your code in a shared repo? I'd love help add in my enhancement into your OH3 mysensors build.
    • N
      N
      ncollins
      Well, after a rather painful experience of manually upgrading and cherrypicking SerialPort changes from the decompiled OH3 mysensors jar posted above, I managed to get it a build working of the MySensors binding 3.1-SNAPSHOT.
      This is the source: https://github.com/nikolac/openhab2-addons/tree/mysensors-oh3-migration/bundles/org.openhab.binding.mysensors
      This fork has my addition, a direction channel on wind variables.
      • fabyteF
        fabyteF
        fabyte
        @ncollins Any chance this rebased work will be pushed upstream to the openhab/openhab-addons repo? Mainline support could help this binding with future framework changes and avoid reverse engineering of code changes and simplifies the binding installation.
        Also any ideas on the MQTT bridge problem? Somehow the broker name cannot be resolved as also discussed here:
        https://forum.mysensors.org/topic/10184/help-openhab-2-4-binding-mqtt
        N 1 Reply Last reply
        • fabyteF fabyte
          N
          N
          ncollins
          @fabyte I'd love to see this get pulled into the main repo. Not sure if @TimO plans to continue support, but I have no problem helping or even picking up where he leaves off.
          I didn't contribute any MQTT specific fixes, and I don't recall manually migrating any MQTT fixes, but let me take a look.
          fabyteF 1 Reply Last reply
          • N ncollins
            fabyteF
            fabyteF
            fabyte
            wrote on last edited by fabyte
            #36
            @ncollins Thanks, really appreciate it :) Let me know if you need more info, here's the basic config I did:
            • created a mqtt broker (not system broker) This thing is ONLINE
            UID: mqtt:broker:mosquitto
            label: mosquitto
            thingTypeUID: mqtt:broker
            configuration:
              lwtQos: 0
              publickeypin: true
              keepAlive: 60
              clientid: 566e1af2-19c2-4596-904f-18b89c502e53
              qos: 0
              reconnectTime: 60000
              host: localhost
              secure: false
              certificatepin: true
              lwtRetain: true
              enableDiscovery: true
            • created a MySensors MQTT Bridge with default settings (brokername = mosquitto)
            UID: mysensors:bridge-mqtt:01d212b118
            label: MySensors MQTT Gateway
            thingTypeUID: mysensors:bridge-mqtt
            configuration:
              networkSanCheckSendHeartbeat: false
              topicPublish: mygateway1-in
              networkSanCheckInterval: 3
              networkSanCheckSendHeartbeatFailAttempts: 10
              topicSubscribe: mygateway1-out
              networkSanCheckEnabled: false
              networkSanCheckConnectionFailAttempts: 3
              startupCheckEnabled: false
              brokerName: mosquitto
              imperial: false
              sendDelay: 100
            Here's the logs:
            09:59:32.973 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-mqtt:01d212b118' changed from UNINITIALIZED to INITIALIZING
            09:59:32.980 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
            09:59:32.994 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached not exist.
            09:59:32.995 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached not exist. Default passed, creating it...
            09:59:32.997 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
            09:59:32.998 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache (given_ids) content: []
            09:59:33.011 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Enabling connection watchdog
            09:59:33.015 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
            09:59:33.016 [DEBUG] [s.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
            09:59:33.022 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - No connection to broker: mosquitto
            09:59:33.027 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-mqtt:01d212b118' changed from INITIALIZING to OFFLINE
            09:59:33.027 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
            09:59:33.029 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
            I tried different broker names (like mqtt:broker:mosquitto, the clientid, different uid names, but the log always says the broker cannot be found. It maps to the following lines: link
            I can provide more info if needed and try out debug versions of the binding if required.
            • fabyteF fabyte
              label: mosquitto
              configuration:
                lwtQos: 0
                publickeypin: true
                keepAlive: 60
                qos: 0
                host: localhost
                secure: false
                lwtRetain: true
              configuration:
                imperial: false
                sendDelay: 100
              Here's the logs:
              fabyteF
              fabyteF
              fabyte
              #37
              Okay, now i tried to configure the MQTT system broker connection and this seems to work.
              • I set up the system broker and named it 'mosquitto'.
              • in the MySensors MQTT bridge, as before, I used mosquitto as Broker Name. Now the Broker Name could be resolved and the Thing is online.
              10:12:55.086 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
              10:12:55.089 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached not exist.
              10:12:55.091 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached not exist. Default passed, creating it...
              10:12:55.094 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
              10:12:55.100 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache (given_ids) content: []
              10:12:55.103 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Enabling connection watchdog
              10:12:55.106 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
              10:12:55.108 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - Reason unknown
              10:12:55.113 [DEBUG] [s.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
              10:12:55.117 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Adding consumer for topic: mygateway1-out/+/+/+/+/+
              10:12:55.127 [WARN ] [protocol.mqtt.MySensorsMqttConnection] - Skipping I_VERSION connection test, not recommended...
              10:12:55.133 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-mqtt:84dd4a387f' changed from INITIALIZING to ONLINE
              10:12:55.133 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
              10:12:55.139 [INFO ] [protocol.mqtt.MySensorsMqttConnection] - Successfully connected to MySensors Bridge.
              But
              I'm having troubles with the MQTT system broker, it can't connect the broker instance.
              com.hivemq.client.mqtt.exceptions.ConnectionClosedException: java.io.IOException: Connection reset by peer
              Caused by: java.io.IOException: Connection reset by peer
                      at sun.nio.ch.FileDispatcherImpl.read0(Native Method) ~[?:?]
                      at sun.nio.ch.SocketDispatcher.read(SocketDispatcher.java:39) ~[?:?]
                      at sun.nio.ch.IOUtil.readIntoNativeBuffer(IOUtil.java:276) ~[?:?]
                      at sun.nio.ch.IOUtil.read(IOUtil.java:233) ~[?:?]
                      at sun.nio.ch.IOUtil.read(IOUtil.java:223) ~[?:?]
                      at sun.nio.ch.SocketChannelImpl.read(SocketChannelImpl.java:358) ~[?:?]
                      at io.netty.buffer.PooledByteBuf.setBytes(PooledByteBuf.java:247) ~[bundleFile:4.1.42.Final]
                      at io.netty.buffer.AbstractByteBuf.writeBytes(AbstractByteBuf.java:1147) ~[bundleFile:4.1.42.Final]
                      at io.netty.channel.socket.nio.NioSocketChannel.doReadBytes(NioSocketChannel.java:347) ~[bundleFile:4.1.42.Final]
                      at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:148) [bundleFile:4.1.42.Final]
                      at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:700) [bundleFile:4.1.42.Final]
                      at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:635) [bundleFile:4.1.42.Final]
                      at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:552) [bundleFile:4.1.42.Final]
                      at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:514) [bundleFile:4.1.42.Final]
                      at io.netty.util.concurrent.SingleThreadEventExecutor$6.run(SingleThreadEventExecutor.java:1044) [bundleFile:4.1.42.Final]
                      at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) [bundleFile:4.1.42.Final]
                      at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30) [bundleFile:4.1.42.Final]
                      at java.lang.Thread.run(Thread.java:834) [?:?]
              Since this seems more a OpenHAB/mosquitto issue I will dig into it myself.
              Edit
              The MQTT System Broker seems to be a concept from OH2, where a MQTT broker was shipped internally with OpenHAB and it seems to be broken in OH3 (OH Forum).
              This leaves me with the following conclusions:
              1. The MySensors binding configuration references the MQTT system broker connection
              2. With OH3, this MQTT System Broker is not working anymore.
              I suppose the correct way of handling this issue is to make the MySensors binding reference a normal MQTT Broker bridge, not a System Broker bridge.
              Anyone who knows what changes this would require? My guess is that it should be manageable -> Source Code
              • fabyteF fabyte
                But
                Edit
                N
                N
                ncollins
                @fabyte this is helpful.
                My intuition says the embedded mqtt broker and the generic mqtt binding create the same "mqtt" connection service behind the scenes. I'm guessing the generic mqtt binding isn't registering its service by name, or it's registering it by some other key.
                I'd like to get the mysensors addon to work with both mqtt brokers if possible.
                • fabyteF
                  fabyteF
                  fabyte
                  @ncollins Yes, it looks like some resources are blocked or not resolved correctly when using the system broker.
                  But the system broker functionality comes with the mqtt binding itself. Here is a screen of the settings when I deleted the mqtt binding:
                  Also I never got the system broker working, even without defining a generic mqtt broker thing.
                  • fabyteF
                    fabyteF
                    fabyte
                    After reinstalling the mqtt bindung the MQTT System Broker connection now could be established - strange, that a reinstall was required since I did several OpenHAB system restarts and those didn't fix it.
                    Well, now the MySensors binding is working with the system broker:
                    Here's a MySensors temperature item:
                    To sum up, here's what I did
                    1. (manually) installed MySensors binding
                    2. uninstalled mqtt binding
                    3. installed mqtt binding
                    4. set up the MQTT system broker connection
                      4.1 set Connection Name to systembroker
                      4.2 set Broker Host to localhost (it's running on the same device)
                      4.3 Show advanced -> set Broker Port to 1883 since it was always using 8883 but I don't use a secure connection
                      (4.4 I didn't set a clientid, no user and no password)
                    5. set up the MySensors MQTT Gateway thing
                      5.1 set Broker Name to systembroker
                    N H 2 Replies Last reply
                    • fabyteF fabyte
                      N
                      N
                      ncollins
                      @fabyte Nice work. I don't use mysensors-mqtt, but I do have a lot of tasmota devices using the generic mqtt binding.
                      I followed your directions to create system broker, then changed my existing mqtt broker connection to a "systemBroker" and referenced it by brokerid (Broker Name).
                      I had one other issue, the new system broker wouldn't start up. I had to manually add secure="false" to /opt/openhab/userdata/config/org/openhab/mqttbroker.config .
                      Maybe you can get away with toggling "Secure Connection?" a couple of times.
                      • T
                        TimO
                        Hey @fabyte and @ncollins!
                        I just want you to know, that I'm still there, but out of time at the moment. My third child was born just recently and I don't have any time for the binding at the moment.
                        I'm really sorry you had to reverse engineer the binding to add your code. That's awfully wrong.
                        We need to create a new common base to continue the work on the binding.
                        I was not able to add the binding to the official repo because of the formal requirements from the Openhab Team. I'm sure these requirements are needed, but I'm no professional in java. I struggled mainly at the nonnull annotations that are needed.
                        fabyteF N 2 Replies Last reply
                        • T TimO
                          fabyteF
                          fabyteF
                          fabyte
                          @TimO Congratulations on your child :clap:
                          I know it's an exciting time and definitely more important than developing a OH binding :grin:
                          Spending time with your family should always be number 1 priority and you can't blame anyone for taking time off from a internet community :)
                          • T TimO
                            N
                            N
                            ncollins
                            @TimO Congrats!
                            I've been looking some of the other addon-ons and your code actually looks a lot better than most. I think the base is pretty solid.
                            I'll take a look at the annotations, and maybe getting some more traditional unit tests in place.
                            If we get to a point where a merge is acceptable, maybe we can move the maintenance fork to the MySensors repo.
                            • N
                              N
                              ncollins
                              wrote on last edited by ncollins
                              #45
                              @TimO & @fabyte I took a stab at making all of the classes/interfaces @NonNullByDefault and adding/overriding null checks throughout. It builds fine, seems to be working well with my ethernet gateway.
                              I'm going to look at unit testing next.
                              H 1 Reply Last reply
                              • N ncollins
                                H
                                H
                                haloway13
                                @ncollins
                                I have been trying to get MySensors working with OH3 for a few days now and have just stumbled upon this thread. How opportune!!!
                                I am just trying to get a temp/hum arduino nano with a NRF24L01 hooked up to PI400 with OH3 using this link:
                                https://www.smarthomeblog.net/diy-home-automation-sensors-first-node/
                                Since I am starting from scratch with a simple proof of concept there might be some easy testing to be done with my setup.
                                Do you have any suggestions for me?
                                • H haloway13
                                  @ncollins
                                  N
                                  N
                                  ncollins
                                  @haloway13 Glad to see you're diving in.
                                  Have you set up your gateway yet? If not, try this https://www.mysensors.org/build/raspberry. I find it's easier to build and debug node with a working gateway.
                                  • N ncollins
                                    H
                                    H
                                    haloway13
                                    @ncollins
                                    I believe so.
                                    openhabian@openhabian:~/MySensors $ sudo ./bin/mysgw
                                    Feb 28 14:28:54 INFO  Starting gateway...
                                    Feb 28 14:28:54 INFO  Protocol version - 2.4.0-alpha
                                    Feb 28 14:28:54 DEBUG MCO:BGN:INIT GW,CP=RNNGL---,FQ=NA,REL=0,VER=2.4.0-alpha
                                    Feb 28 14:28:54 DEBUG TSF:LRT:OK
                                    Feb 28 14:28:54 DEBUG TSM:INIT
                                    Feb 28 14:28:54 DEBUG TSF:WUR:MS=0
                                    Feb 28 14:28:54 DEBUG TSM:INIT:TSP OK
                                    Feb 28 14:28:54 DEBUG TSM:INIT:GW MODE
                                    Feb 28 14:28:54 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
                                    Feb 28 14:28:54 DEBUG MCO:REG:NOT NEEDED
                                    Feb 28 14:28:54 DEBUG MCO:BGN:STP
                                    Feb 28 14:28:54 DEBUG MCO:BGN:INIT OK,TSP=1
                                    Feb 28 14:28:54 DEBUG GWT:RMQ:CONNECTING...
                                    Feb 28 14:28:54 DEBUG connected to 192.168.1.151
                                    Feb 28 14:28:54 DEBUG GWT:RMQ:OK
                                    Feb 28 14:28:54 DEBUG GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
                                    Feb 28 14:28:54 DEBUG TSM:READY:NWD REQ
                                    Feb 28 14:28:54 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                                    Feb 28 14:29:13 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:31.3
                                    Feb 28 14:29:13 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
                                    Feb 28 14:29:23 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:31.4
                                    Feb 28 14:29:23 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
                                    Feb 28 14:29:43 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:16.1
                                    Feb 28 14:29:43 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
                                    • H haloway13
                                      @ncollins
                                      I believe so.
                                      N
                                      N
                                      ncollins
                                      @haloway13 Looks good.
                                      Next, I would get openhab ready for adding the mysensors addon. https://github.com/tobof/openhab2-addons/wiki/Installation
                                      Via the openhab console run the following to install/activate the binding dependencies:
                                      feature:install openhab-transport-serial
                                      feature:install openhab-core-io-transport-mqtt
                                      I recommend also setting log:set DEBUG org.openhab.binding.mysensors
                                      Create a mqtt system connection in OpenHAB. Be sure to check advanced, and set the port.
                                      Then you can drop the org.openhab.binding.mysensors.jar into the addons folder and it should auto install. You can start with the binding linked above.
                                      Once all of that is done, you can configure your first thing, which would be a MySensors MQTT Bridge. (you should disable "Enables the startup check", I believe there is a bug)
                                      • N ncollins
                                        H
                                        H
                                        haloway13
                                        @ncollins I have had some issues getting this going. Am I running the development branch? Can you tell from the output?
                                        • H haloway13
                                          N
                                          N
                                          ncollins
                                          @haloway13 you have any logs or screenshots of errors you're seeing?
