  3. OpenHAB
  4. OH3 - MySensors Binding
135 Posts 34 Posters 36.0k Views 40 Watching
  • fabyteF fabyte
    @ncollins Any chance this rebased work will be pushed upstream to the openhab/openhab-addons repo? Mainline support could help this binding with future framework changes and avoid reverse engineering of code changes and simplifies the binding installation.
    Also any ideas on the MQTT bridge problem? Somehow the broker name cannot be resolved as also discussed here:
    https://forum.mysensors.org/topic/10184/help-openhab-2-4-binding-mqtt
    N
    N
    ncollins
    @fabyte I'd love to see this get pulled into the main repo. Not sure if @TimO plans to continue support, but I have no problem helping or even picking up where he leaves off.
    I didn't contribute any MQTT specific fixes, and I don't recall manually migrating any MQTT fixes, but let me take a look.
    fabyteF 1 Reply Last reply
    • N ncollins
      fabyteF
      fabyteF
      fabyte
      wrote on last edited by fabyte
      #36
      @ncollins Thanks, really appreciate it :) Let me know if you need more info, here's the basic config I did:
      • created a mqtt broker (not system broker) This thing is ONLINE
      UID: mqtt:broker:mosquitto
      label: mosquitto
      thingTypeUID: mqtt:broker
      configuration:
        lwtQos: 0
        publickeypin: true
        keepAlive: 60
        clientid: 566e1af2-19c2-4596-904f-18b89c502e53
        qos: 0
        reconnectTime: 60000
        host: localhost
        secure: false
        certificatepin: true
        lwtRetain: true
        enableDiscovery: true
      • created a MySensors MQTT Bridge with default settings (brokername = mosquitto)
      UID: mysensors:bridge-mqtt:01d212b118
      label: MySensors MQTT Gateway
      thingTypeUID: mysensors:bridge-mqtt
      configuration:
        networkSanCheckSendHeartbeat: false
        topicPublish: mygateway1-in
        networkSanCheckInterval: 3
        networkSanCheckSendHeartbeatFailAttempts: 10
        topicSubscribe: mygateway1-out
        networkSanCheckEnabled: false
        networkSanCheckConnectionFailAttempts: 3
        startupCheckEnabled: false
        brokerName: mosquitto
        imperial: false
        sendDelay: 100
      Here's the logs:
      09:59:32.973 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-mqtt:01d212b118' changed from UNINITIALIZED to INITIALIZING
      09:59:32.980 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
      09:59:32.994 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached not exist.
      09:59:32.995 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached not exist. Default passed, creating it...
      09:59:32.997 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
      09:59:32.998 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache (given_ids) content: []
      09:59:33.011 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Enabling connection watchdog
      09:59:33.015 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
      09:59:33.016 [DEBUG] [s.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
      09:59:33.022 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - No connection to broker: mosquitto
      09:59:33.027 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-mqtt:01d212b118' changed from INITIALIZING to OFFLINE
      09:59:33.027 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
      09:59:33.029 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
      I tried different broker names (like mqtt:broker:mosquitto, the clientid, different uid names, but the log always says the broker cannot be found. It maps to the following lines: link
      I can provide more info if needed and try out debug versions of the binding if required.
      • fabyteF fabyte
        label: mosquitto
        configuration:
          lwtQos: 0
          publickeypin: true
          keepAlive: 60
          qos: 0
          host: localhost
          secure: false
          lwtRetain: true
        configuration:
          imperial: false
          sendDelay: 100
        Here's the logs:
        fabyteF
        fabyteF
        fabyte
        #37
        Okay, now i tried to configure the MQTT system broker connection and this seems to work.
        • I set up the system broker and named it 'mosquitto'.
        • in the MySensors MQTT bridge, as before, I used mosquitto as Broker Name. Now the Broker Name could be resolved and the Thing is online.
        10:12:55.086 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
        10:12:55.089 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached not exist.
        10:12:55.091 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached not exist. Default passed, creating it...
        10:12:55.094 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
        10:12:55.100 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache (given_ids) content: []
        10:12:55.103 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Enabling connection watchdog
        10:12:55.106 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
        10:12:55.108 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - Reason unknown
        10:12:55.113 [DEBUG] [s.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
        10:12:55.117 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Adding consumer for topic: mygateway1-out/+/+/+/+/+
        10:12:55.127 [WARN ] [protocol.mqtt.MySensorsMqttConnection] - Skipping I_VERSION connection test, not recommended...
        10:12:55.133 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-mqtt:84dd4a387f' changed from INITIALIZING to ONLINE
        10:12:55.133 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
        10:12:55.139 [INFO ] [protocol.mqtt.MySensorsMqttConnection] - Successfully connected to MySensors Bridge.
        But
        I'm having troubles with the MQTT system broker, it can't connect the broker instance.
        com.hivemq.client.mqtt.exceptions.ConnectionClosedException: java.io.IOException: Connection reset by peer
        Caused by: java.io.IOException: Connection reset by peer
                at sun.nio.ch.FileDispatcherImpl.read0(Native Method) ~[?:?]
                at sun.nio.ch.SocketDispatcher.read(SocketDispatcher.java:39) ~[?:?]
                at sun.nio.ch.IOUtil.readIntoNativeBuffer(IOUtil.java:276) ~[?:?]
                at sun.nio.ch.IOUtil.read(IOUtil.java:233) ~[?:?]
                at sun.nio.ch.IOUtil.read(IOUtil.java:223) ~[?:?]
                at sun.nio.ch.SocketChannelImpl.read(SocketChannelImpl.java:358) ~[?:?]
                at io.netty.buffer.PooledByteBuf.setBytes(PooledByteBuf.java:247) ~[bundleFile:4.1.42.Final]
                at io.netty.buffer.AbstractByteBuf.writeBytes(AbstractByteBuf.java:1147) ~[bundleFile:4.1.42.Final]
                at io.netty.channel.socket.nio.NioSocketChannel.doReadBytes(NioSocketChannel.java:347) ~[bundleFile:4.1.42.Final]
                at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:148) [bundleFile:4.1.42.Final]
                at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:700) [bundleFile:4.1.42.Final]
                at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:635) [bundleFile:4.1.42.Final]
                at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:552) [bundleFile:4.1.42.Final]
                at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:514) [bundleFile:4.1.42.Final]
                at io.netty.util.concurrent.SingleThreadEventExecutor$6.run(SingleThreadEventExecutor.java:1044) [bundleFile:4.1.42.Final]
                at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) [bundleFile:4.1.42.Final]
                at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30) [bundleFile:4.1.42.Final]
                at java.lang.Thread.run(Thread.java:834) [?:?]
        Since this seems more a OpenHAB/mosquitto issue I will dig into it myself.
        Edit
        The MQTT System Broker seems to be a concept from OH2, where a MQTT broker was shipped internally with OpenHAB and it seems to be broken in OH3 (OH Forum).
        This leaves me with the following conclusions:
        1. The MySensors binding configuration references the MQTT system broker connection
        2. With OH3, this MQTT System Broker is not working anymore.
        I suppose the correct way of handling this issue is to make the MySensors binding reference a normal MQTT Broker bridge, not a System Broker bridge.
        Anyone who knows what changes this would require? My guess is that it should be manageable -> Source Code
        N 1 Reply Last reply
        • fabyteF fabyte
          But
          Edit
          N
          N
          ncollins
          @fabyte this is helpful.
          My intuition says the embedded mqtt broker and the generic mqtt binding create the same "mqtt" connection service behind the scenes. I'm guessing the generic mqtt binding isn't registering its service by name, or it's registering it by some other key.
          I'd like to get the mysensors addon to work with both mqtt brokers if possible.
          • fabyteF
            fabyteF
            fabyte
            @ncollins Yes, it looks like some resources are blocked or not resolved correctly when using the system broker.
            But the system broker functionality comes with the mqtt binding itself. Here is a screen of the settings when I deleted the mqtt binding:
            Also I never got the system broker working, even without defining a generic mqtt broker thing.
            • fabyteF
              fabyteF
              fabyte
              After reinstalling the mqtt bindung the MQTT System Broker connection now could be established - strange, that a reinstall was required since I did several OpenHAB system restarts and those didn't fix it.
              Well, now the MySensors binding is working with the system broker:
              Here's a MySensors temperature item:
              To sum up, here's what I did
              1. (manually) installed MySensors binding
              2. uninstalled mqtt binding
              3. installed mqtt binding
              4. set up the MQTT system broker connection
                4.1 set Connection Name to systembroker
                4.2 set Broker Host to localhost (it's running on the same device)
                4.3 Show advanced -> set Broker Port to 1883 since it was always using 8883 but I don't use a secure connection
                (4.4 I didn't set a clientid, no user and no password)
              5. set up the MySensors MQTT Gateway thing
                5.1 set Broker Name to systembroker
              N H 2 Replies Last reply
              • fabyteF fabyte
                N
                N
                ncollins
                @fabyte Nice work. I don't use mysensors-mqtt, but I do have a lot of tasmota devices using the generic mqtt binding.
                I followed your directions to create system broker, then changed my existing mqtt broker connection to a "systemBroker" and referenced it by brokerid (Broker Name).
                I had one other issue, the new system broker wouldn't start up. I had to manually add secure="false" to /opt/openhab/userdata/config/org/openhab/mqttbroker.config .
                Maybe you can get away with toggling "Secure Connection?" a couple of times.
                • T
                  TimO
                  Hey @fabyte and @ncollins!
                  I just want you to know, that I'm still there, but out of time at the moment. My third child was born just recently and I don't have any time for the binding at the moment.
                  I'm really sorry you had to reverse engineer the binding to add your code. That's awfully wrong.
                  We need to create a new common base to continue the work on the binding.
                  I was not able to add the binding to the official repo because of the formal requirements from the Openhab Team. I'm sure these requirements are needed, but I'm no professional in java. I struggled mainly at the nonnull annotations that are needed.
                  fabyteF N 2 Replies Last reply
                  • T TimO
                    fabyteF
                    fabyteF
                    fabyte
                    @TimO Congratulations on your child :clap:
                    I know it's an exciting time and definitely more important than developing a OH binding :grin:
                    Spending time with your family should always be number 1 priority and you can't blame anyone for taking time off from a internet community :)
                    • T TimO
                      N
                      N
                      ncollins
                      @TimO Congrats!
                      I've been looking some of the other addon-ons and your code actually looks a lot better than most. I think the base is pretty solid.
                      I'll take a look at the annotations, and maybe getting some more traditional unit tests in place.
                      If we get to a point where a merge is acceptable, maybe we can move the maintenance fork to the MySensors repo.
                      • N
                        N
                        ncollins
                        wrote on last edited by ncollins
                        #45
                        @TimO & @fabyte I took a stab at making all of the classes/interfaces @NonNullByDefault and adding/overriding null checks throughout. It builds fine, seems to be working well with my ethernet gateway.
                        I'm going to look at unit testing next.
                        https://github.com/nikolac/openhab2-addons/tree/mysensors-oh3-migration/bundles/org.openhab.binding.mysensors
                        H 1 Reply Last reply
                        • N ncollins
                          H
                          H
                          haloway13
                          @ncollins
                          I have been trying to get MySensors working with OH3 for a few days now and have just stumbled upon this thread. How opportune!!!
                          I am just trying to get a temp/hum arduino nano with a NRF24L01 hooked up to PI400 with OH3 using this link:
                          https://www.smarthomeblog.net/diy-home-automation-sensors-first-node/
                          Since I am starting from scratch with a simple proof of concept there might be some easy testing to be done with my setup.
                          Do you have any suggestions for me?
                          • H haloway13
                            @ncollins
                            N
                            N
                            ncollins
                            @haloway13 Glad to see you're diving in.
                            Have you set up your gateway yet? If not, try this https://www.mysensors.org/build/raspberry. I find it's easier to build and debug node with a working gateway.
                            • N ncollins
                              H
                              H
                              haloway13
                              @ncollins
                              I believe so.
                              openhabian@openhabian:~/MySensors $ sudo ./bin/mysgw
                              Feb 28 14:28:54 INFO  Starting gateway...
                              Feb 28 14:28:54 INFO  Protocol version - 2.4.0-alpha
                              Feb 28 14:28:54 DEBUG MCO:BGN:INIT GW,CP=RNNGL---,FQ=NA,REL=0,VER=2.4.0-alpha
                              Feb 28 14:28:54 DEBUG TSF:LRT:OK
                              Feb 28 14:28:54 DEBUG TSM:INIT
                              Feb 28 14:28:54 DEBUG TSF:WUR:MS=0
                              Feb 28 14:28:54 DEBUG TSM:INIT:TSP OK
                              Feb 28 14:28:54 DEBUG TSM:INIT:GW MODE
                              Feb 28 14:28:54 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
                              Feb 28 14:28:54 DEBUG MCO:REG:NOT NEEDED
                              Feb 28 14:28:54 DEBUG MCO:BGN:STP
                              Feb 28 14:28:54 DEBUG MCO:BGN:INIT OK,TSP=1
                              Feb 28 14:28:54 DEBUG GWT:RMQ:CONNECTING...
                              Feb 28 14:28:54 DEBUG connected to 192.168.1.151
                              Feb 28 14:28:54 DEBUG GWT:RMQ:OK
                              Feb 28 14:28:54 DEBUG GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
                              Feb 28 14:28:54 DEBUG TSM:READY:NWD REQ
                              Feb 28 14:28:54 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                              Feb 28 14:29:13 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:31.3
                              Feb 28 14:29:13 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
                              Feb 28 14:29:23 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:31.4
                              Feb 28 14:29:23 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
                              Feb 28 14:29:43 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:16.1
                              Feb 28 14:29:43 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
                              • H haloway13
                                @ncollins
                                I believe so.
                                N
                                N
                                ncollins
                                @haloway13 Looks good.
                                Next, I would get openhab ready for adding the mysensors addon. https://github.com/tobof/openhab2-addons/wiki/Installation
                                Via the openhab console run the following to install/activate the binding dependencies:
                                feature:install openhab-transport-serial
                                feature:install openhab-core-io-transport-mqtt
                                I recommend also setting log:set DEBUG org.openhab.binding.mysensors
                                Create a mqtt system connection in OpenHAB. Be sure to check advanced, and set the port.
                                Then you can drop the org.openhab.binding.mysensors.jar into the addons folder and it should auto install. You can start with the binding linked above.
                                Once all of that is done, you can configure your first thing, which would be a MySensors MQTT Bridge. (you should disable "Enables the startup check", I believe there is a bug)
                                • N ncollins
                                  H
                                  H
                                  haloway13
                                  @ncollins I have had some issues getting this going. Am I running the development branch? Can you tell from the output?
                                  • H haloway13
                                    N
                                    N
                                    ncollins
                                    @haloway13 you have any logs or screenshots of errors you're seeing?
                                    • N ncollins
                                      H
                                      H
                                      haloway13
                                      @ncollins best I can do is say that it was a java io exception of some sort associated with the bridge or broker. I have since started from scratch several times and have not taken any screenshots.
                                      I have faithfully followed directions from: https://github.com/tobof/openhab2-addons/wiki/Installation
                                      Then it is a bit of a mystery to me how to finish up the configuration through the web pages.
                                      Any help would be greatly appreciated!
                                      • N
                                        N
                                        ncollins
                                        Hmm, I don't use openhabian, but it looks like there is a log viewer built in: http://openhabian:9001 (maybe change openhabian to the IP of your pi).
                                        Without logs or screenshots, it'll be impossible to help.
                                        • N ncollins
                                          H
                                          H
                                          haloway13
                                          @ncollins
                                          openhab log:tail output
                                          openhab> log:tail
                                          20:17:49.861 [INFO ] [b.core.internal.i18n.I18nProviderImpl] - Time zone set to 'America/Denver'.
                                          20:17:49.924 [INFO ] [b.core.internal.i18n.I18nProviderImpl] - Location set to '39.82834020908714,-105.06875216960907'.
                                          20:17:49.929 [INFO ] [b.core.internal.i18n.I18nProviderImpl] - Locale set to 'en_US'.
                                          20:18:27.583 [INFO ] [b.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
                                          20:18:33.947 [INFO ] [org.openhab.ui.internal.UIService    ] - Started UI on port 8080
                                          20:18:35.072 [INFO ] [re.automation.internal.RuleEngineImpl] - Rule engine started.
                                          20:18:36.112 [INFO ] [hab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
                                          20:25:15.958 [INFO ] [ig.discovery.internal.PersistentInbox] - Added new thing 'mqtt:systemBroker:mosquitto' to inbox.
                                          20:25:15.959 [INFO ] [openhab.event.InboxAddedEvent        ] - Discovery Result with UID 'mqtt:systemBroker:mosquitto' has been added.
                                          20:25:17.970 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid 86f6e016-3847-404f-80dc-a5abb81f6b2d
                                          20:25:28.579 [INFO ] [t.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.151'. Next attempt in 60000ms
                                          20:25:28.673 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid 86f6e016-3847-404f-80dc-a5abb81f6b2d
                                          20:26:28.685 [INFO ] [t.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.151'. Next attempt in 60000ms
                                          20:26:28.694 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid 86f6e016-3847-404f-80dc-a5abb81f6b2d
                                          Broker config screen:
                                          Addition to the Inbox:
                                          Clicking the inbox. This is where I have no clue as to how to proceed...
