  3. Best PC platform for running Esxi/Docker at home?
75 Posts 6 Posters 12.5k Views 5 Watching
  • monteM monte
    @NeverDie to be honest, I don't rememver :) It was so long ago, I was just updating the system from then. But I guess there might be an option in the installer... I will try it in vm, you made me curious :)
    UPDATE: I've just ran the install and it plain and simple, no extra options. It automatically partitioned the disk. The only drawback is that you don't have ability to fine tune the sizes of partitions, but that can be done later with some LVM magic :)
    @monte said in Best PC platform for running Esxi/Docker at home?:
    That's what I started with too, but then when I went to upload ISO's or create VM's, ProxMox said there was no disk available for that.
    monteM 1 Reply Last reply
    • monteM
      monteM
      monte
      So to be precise, Proxmox installer creates LMV VG (volume group) called pve, in which it creates LV(logic volume) root, swap and andother volume, which in fact is a pool for another thin volumes that will be created for each VM and container, called data. So ISO's, backups and other stuff related to proxmox itself will be located at root volume.
        monteM
        monteM
        monte
        wrote on last edited by monte
        #33
        @NeverDie that's strange. What's the size of your disk? Also you can see LVM structure with lvdisplay command. As I've mentioned, you also can manage sizes of said LV's in the console.
        • monteM monte
          What the size of your disk?
          1 terabyte. It's a Samsung nvme SSD.
            #35
            I've tried googling up instructions on how to do it exactly. It seems that others besides just me have struggled with this as well. The only solution proposed which someone claimed worked, which I haven't yet tried, seems to be to start with a Debian install and then upgrade it to ProxMox. But there were no simple 123 instructions on how to do that either, so I just threw in the towel and decided to go with 3 disks, like in the beginner tutorial.
              monteM
              monteM
              monte
              #36
              @NeverDie this is completely doable within proxmox installation. Show me please the return of lvdisplay.
              Or if you already have set up your system, then let it be :)
              • monteM monte
                @monte Getting it now. It will look a little screwy because the present incarnation has proxmox on a USB (yeah, I know, heavily not recommended).
                  Better yet, I'll reinstall it to the one 1Tb disk and you the lvdisplay of that, which will make more sense in this context.
                    #39
                    OK, did that.
                    This is with proxmox installed to the single 1 Tb disk. No USB's involved.
                      OK, did that.
                      monteM
                      monteM
                      monte
                      @NeverDie seems to me that 96GB is plenty of space for ISO's :)
                      • monteM monte
                        #41
                        @monte Right. But then I get this:
                        which is where I get stuck. If I add more physical disks, then this doesn't happen.
                          monteM
                          monteM
                          monte
                          #42
                          @NeverDie expand host000 item in the list on the left. Choose storage local at the end of the list, choose ISO Images, hit Upload.
                          Then press create VM on the top right of the GUI.
                          • monteM monte
                            @monte Thank you! That worked:
                            I uploaded both debian and windows iso's.
                            So, after starting the VM I gather I just click "monitor" to see the VM's virtual display?
                              monteM
                              monteM
                              monte
                              #44
                              @NeverDie no, you use Console just below Summary button.
                              I must add, I never installed windows in proxmox, so I can't say how install process is managed with it, but I think someone on google knows :)
                              • monteM monte
                                @monte Right. Just tried it, but got this:
                                Well, I won't burden you with more questions. Thanks for your help!
                                  monteM
                                  monteM
                                  monte
                                  @NeverDie first video in search https://youtu.be/_uvVZYcYaJE
                                    #47
                                    Reporting back: After trying many things and much frustration :dizzy_face: , It turned out the reason for the noVnc console fail was, of all things, Google Chrome. :confounded:
                                    Who'd have guessed? Thank you Google. :angry: :angry: :angry: Too bad there's no emoji for sarcasm. :rolling_on_the_floor_laughing: Actually, I like Google Chrome a lot, so I hadn't even suspected it. Switching to Firefox fixed the issue:
                                    I'm also able to connect to it using VNC Viewer:
                                    by typing:
                                    change vnc 0.0.0.0:100
                                    into the VM's monitor window, as described here: https://pve.proxmox.com/wiki/VNC_Client_Access#Standard_Console_Access
                                    I even tried installing the noVNC google chrome extension, but still no joy. No idea as to why Chrome failed for this, but at least now the culprit is identified. :smile:
                                      by typing:
                                      monteM
                                      monteM
                                      monte
                                      @NeverDie I am happy, that you've made a progress! I couldn't help you with that, cause I am using Firefox by default :)
                                      Strange, I've just tried in Chromium with Lubuntu as guest OS and it works nice...don't have Chrome installed, so can't check the exact issue you have.
                                        To save searching time for anyone else who also wants to run a Windows VM on ProxMox, I found that this guy has the most concise yet complete setup instructions:
                                        https://www.youtube.com/watch?v=6c-6xBkD2J4
                                          #50
                                          A couple more gotcha's I ran across.
                                          1. To get balloon memory working properly, you still need to go through the procedure that starts at around timestamp 14:30 on the youtube video that @monte posted above, where you use Windows PowerShell to activate the memory Balloon service.
                                          2. Interacting directly with the Window's VM using just VNC is sluggish. Allegedly the way around this is to use Windows Remote Desktop, rather than VNC, to connect to the Windows VM. However, here's the gotcha if you opt to go that route: the windows VM needs to be running Windows Pro. It turns out that Windows Home doesn't support serving Windows Desktop from the VM. :confounded: Gotcha!
