  3. Home Assistant
  4. This entity does not have a unique ID, therefore its settings cannot be managed from the UI.
14 Posts 5 Posters 2.6k Views 5 Watching
  • A
    ar91
    @BearWithBeard Thank you. I think thats what I am doing in my code. Anyway I have attached the full sketch below.
    MySprinkler for MySensors
    Arduino Multi-Zone Sprinkler Control
    May 31, 2015
    *** Version 2.0
    * LED status indicator
    PARTS LIST:
    * Relays (8 channel)
    * NRF24L01 Radio
    * Arduino (I used a Pro Mini)
    * Capacitors (10uf and .1uf)
    * 3.3v voltage regulator
    * Resistors (270, 1K & 10K)
    * Female Dupont Cables
    * LED
    * Push button
    * Shift Register (SN74HC595)
    * 18 gauge wire (for relay)
    INSTRUCTIONS:
      on the serial monitor.
    // Enable debug prints
    #define MY_RADIO_RF24
    //#define MY_NODE_ID 1  // Set this to fix your Radio ID or use Auto
    #include <TimeLib.h>
    #include <LiquidCrystal.h>
    #define NUMBER_OF_VALVES 8  // Change this to set your valve count up to 16.
    #define VALVE_TIMES_RELOAD 300000UL  // Change this (in milliseconds) for how often to update all valves data from the controller (Loops at value/number valves)
                                         // ie: 300000 for 8 valves produces requests 37.5seconds with all valves updated every 5mins
    #define SKETCH_VERSION "2.2"
    #define CHILD_ID_SPRINKLER 0
    #define ACTIVE_LOW // comment out this line if your relays are active high
    #ifdef ACTIVE_LOW
    #define ALL_VALVES_OFF 0xFFFF
    #define ALL_VALVES_OFF 0U
    #ifdef DEBUG_ON
    #define SERIAL_START(x)
    typedef enum {
    SprinklerStates;
    SprinklerStates lastState;
    byte menuState = 0;
    unsigned long menuTimer;
    byte countDownTime = 10;
    int allZoneTime [NUMBER_OF_VALVES + 1];
    int valveSoloTime [NUMBER_OF_VALVES + 1];
    int valveNumber;
    int lastValve;
    unsigned long startMillis;
    const int ledPin = 5;
    const int waterButtonPin = 3;
    bool buttonPushed = false;
    bool showTime = true;
    bool clockUpdating = false;
    bool recentUpdate = true;
    int allVars[] = {V_VAR1, V_VAR2, V_VAR3};
    const char *dayOfWeek[] = {
    String valveNickName[17] = {
    time_t lastTimeRun = 0;
    //Setup Shift Register...
    const int latchPin = 8;
    const int clockPin = 4;
    const int dataPin  = 7;
    const int outputEnablePin = 6;
    LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
    bool receivedInitialValue = false;
    bool inSetup = true;
      pinMode(latchPin, OUTPUT);
      pinMode(clockPin, OUTPUT);
      pinMode(dataPin, OUTPUT);
      pinMode(ledPin, OUTPUT);
      pinMode(outputEnablePin, OUTPUT);
      digitalWrite (outputEnablePin, LOW);
      attachInterrupt(digitalPinToInterrupt(waterButtonPin), PushButton, RISING); //May need to change for your Arduino model
      digitalWrite (ledPin, HIGH);
      updateRelays(ALL_VALVES_OFF);
      //delay(5000);
      lcd.clear();
      lcd.backlight();
      lcd.createChar(0, clock);
      lcd.createChar(1, raindrop);
      delay(500);
      if (loadState(0) == 0xFF) // EEPROM flag
        for (int i = 0; i < 4 ; i++)
          lastTimeRun = lastTimeRun | loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
      digitalWrite (ledPin, LOW);
      DEBUG_PRINTLN(F("Ready..."));
      lcd.setCursor(0, 0);
      lcd.setCursor(15, 0);
      lcd.write(byte(0));
      lcd.setCursor(0, 1);
      int clockCounter = 0;
        requestTime();
        wait(1000);
        lcd.print(".");
        clockCounter++;
        if (clockCounter > 16)
          lcd.clear();
          wait(2000);
      for (byte i = 1; i <= NUMBER_OF_VALVES; i++)
        lcd.clear();
        //goGetValveTimes();
        goInitiateValveTime();
      lcd.clear();
      inSetup = false;
        present(i, S_BINARY);
        wait(500);
      updateClock();
      updateDisplay();
      goGetValveTimes();
      if (buttonPushed)
        menuTimer = millis();
          state = ZONE_SELECT_MENU;
          menuState = 0;
          menuState++;
            menuState = 0;
        slowToggleLED ();
        if (state != lastState)
            wait(50);
            send(msg1valve.setSensor(i).set(false), false);
          lcd.clear();
          lcd.setCursor(0,0);
          lcd.setCursor(0,1);
          wait(2000);
          lastValve = -1;
        if (lastValve != valveNumber)
              send(msg1valve.setSensor(i).set(true), false);
            wait(50);
        lastValve = valveNumber;
        fastToggleLed();
          valveNumber = 1;
          startMillis = millis();
          valveNumber++;
            state = CYCLE_COMPLETE;
            lastValve = -1;
            lastTimeRun = now();
              wait(50);
            DEBUG_PRINT(F("State = "));
            DEBUG_PRINTLN(state);
        fastToggleLed();
            wait(50);
          DEBUG_PRINT(F("Zone: "));
          DEBUG_PRINTLN(valveNumber);
          fastToggleLed();
        displayMenu();
        lastState = state;
    void displayMenu(void)
      static int lastSecond;
        lcd.clear();
        lcd.print(F("Starting"));
        lcd.print(F("."));
        Serial.print(".");
      lastSecond = thisSecond;
        if (menuState == 0)
          valveNumber = 1;
          state = RUN_ALL_ZONES;
          valveNumber = menuState;
          state = RUN_SINGLE_ZONE;
      lastMenuState = menuState;
    void updateRelays(int value)
      digitalWrite(latchPin, LOW);
      digitalWrite(latchPin, HIGH);
        buttonPushed = true;
    void fastToggleLed()
        fastLedTimer = millis ();
    void slowToggleLED ()
        slowLedTimer = millis ();
      bool zoneTimeUpdate = false;
      if (message.isAck())
        if (message.sensor == i)
          if (message.type == V_LIGHT)
            if (switchState == 0)
              if (i == 0)
                valveNumber = 1;
                valveNumber = i;
                DEBUG_PRINTLN(i);
            DEBUG_PRINT(i);
            DEBUG_PRINT(F(" = "));
            DEBUG_PRINTLN(variable1);
              allZoneTime[i] = variable1;
              zoneTimeUpdate = true;
            receivedInitialValue = true;
            DEBUG_PRINT(i);
            DEBUG_PRINTLN(variable2);
              valveSoloTime[i] = variable2;
            if (newMessage.length() == 0)
              DEBUG_PRINTLN(i);
            if (newMessage.length() > 16)
              newMessage.substring(0, 16);
            valveNickName[i] = "";
            DEBUG_PRINT(F("Recieved variable3 valve: "));
            DEBUG_PRINT(i);
      if (zoneTimeUpdate)
          if (i != 0)
            DEBUG_PRINT(F("Zone "));
            DEBUG_PRINT(i);
            DEBUG_PRINT(allZoneTime[i]);
            DEBUG_PRINT(F(" name: "));
        recentUpdate = false;
    void updateDisplay()
      static bool displayToggle = false;
        switch (state) {
          case STAND_BY_ALL_OFF:
            fastClear();
            if (displayToggle)
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.print(hourFormat12());
              lcd.print(minute());
              lcd.print(month());
              lcd.print(day());
              lcd.print(F("/"));
              lcd.print(year() % 100);
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.setCursor(11, 1);
              lcd.print(day(lastTimeRun));
          case RUN_SINGLE_ZONE:
            fastClear();
            if (displayToggle)
              lcd.print(F(" Zone:"));
              lcd.print(valveNumber);
              lcd.print(F(" Active"));
                lcd.print("min");
                lcd.print("sec  ");
          case RUN_ALL_ZONES:
            fastClear();
            if (displayToggle)
              lcd.print(F(" Active "));
              lcd.print("min");
              lcd.print("sec  ");
          case CYCLE_COMPLETE:
            if (displayToggle)
              int totalTimeRan = 0;
              lcd.print(totalTimeRan);
              lcd.print(" Minutes   ");
          default:
            // what of ZONE_SELECT_MENU?
        lastUpdateTime = millis();
      lastDisplayState = state;
      int lastSecond = second();
      int lastMinute = minute();
      int lastHour = hour();
      setTime(newTime);
        DEBUG_PRINT(hourFormat12());
        DEBUG_PRINT(minute());
        DEBUG_PRINT(month());
        DEBUG_PRINT(F("/"));
        DEBUG_PRINT(day());
        DEBUG_PRINTLN(year());
        showTime = false;
    void fastClear()
    void updateClock()
        lcd.write(byte(0));
        clockUpdating = true;
        requestTime();
        lastVeraGetTime = millis();
      if (loadState(0) != 0xFF)
        saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
      for (int i = 1; i < 5; i++)
        saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
    void goGetValveTimes()
      static byte valveIndex = 1;
      if (inSetup || millis() - valveUpdateTime >= VALVE_TIMES_RELOAD / NUMBER_OF_VALVES) // update each valve once every 5 mins (distributes the traffic)
        if (inSetup) {
          lcd.print(F(" Updating  "));
          lcd.print(valveIndex);
        bool flashIcon = false;
        DEBUG_PRINT(valveIndex);
        DEBUG_PRINTLN(F(" Data..."));
        for (int a = 0; a < (sizeof(allVars)/sizeof(int)); a++) {
          byte timeout = 10;
          while (!receivedInitialValue && timeout > 0)
            flashIcon = !flashIcon;
            request(valveIndex, allVars[a]);
            wait(50);
            timeout--;
        valveUpdateTime = millis();
        valveIndex++;
        if (valveIndex > NUMBER_OF_VALVES)
          valveIndex = 1;
    void goInitiateValveTime() {
      if (inSetup) {
        send(var1valve.setSensor(i).set(1));
        wait(50);
        send(var2valve.setSensor(i).set(5));
      wait(50);
      lastValve = -1;
      valveIndex++;
        valveIndex = 1;
    • BearWithBeardB
      BearWithBeardB
      BearWithBeard
      wrote on last edited by BearWithBeard
      Oh, I reread your post and I think we're dealing with two different "issues" here. First off: forget about my detour with the different V_Types, this isn't a problem. I uploaded the sketch on my test node and it is working as expected. The sensor childs for the valves appear as switches and I can toggle them via the UI.
      Let's start with the elephant in the room. The message "This entity does not have a unique ID, therefore its settings cannot be managed from the UI" appears when you click the cogwheel on the detail pane of the entity, doesn't it?
      This isn't an error, nor is it directly MySensors related. Home Assistant has an internal entity registy which requires a unique_id (which is not the entity ID, like Garden_2) to be added to it. Only if an entity is registered, it is editable via the UI. A registerd entity can be renamed or flagged as inactive / deleted. That's basically it. It doesn't mean you can set any of the VAR values via this menu. If an entity isn't registered, you can still adjust everything via yaml configurations (see Customizing entities). I'd have to look further into the registry process to tell how this is done and why the MySensors integration doesn't provide unique IDs.
      If you want to send commands to the irrigation node, e.g. to adjust the watering duration or whatever those VARn types are used for (didn't look into it in detail), you'd have to setup inputs like a number slider and use it as a trigger for sending a message to the node with an automation. See MySensors Nofity for how to do this, you may need to adjust the sketch to listen for V_TEXT instead of V_VARn for incoming messages.
      The irrigation controller is not appearing the dashboard and the only way I can access the device is through Developer Tools-->States tab.
      And this is the other issue. Can you elaborate what you mean with this? Because, looking at the second screenshot of your first post, it looks like it is showing up in the UI. If you click on the slider / settings icon in the upper right corner, you should see a modal window with a toggle switch, a bar with the state history and some meta data as shown in my screenshot below. Is this the case? If so, it's working as intended.
      • A
        ar91
        First thank you @BearWithBeard for your detailed reply. Really appreciate your help.
        Yes that is correct.
        Yes you are correct, if I click on the settings icon in the upper right corner I am getting a modal window with a toggle switch along with the meta-data.
        But my question was, do you know why is it not appearing on the lovelace dashboard like any other binary switch with a on/off slider. Yes I agree I can write automation code to turn the binary switch on/off but what if I want to quickly turn on/off from the dashboard like we do with any other switches?
        electrikE 1 Reply Last reply
        • A ar91
          electrikE
          electrikE
          electrik
          @ar91 can you share a screenshot what is appearing? It is nothing shown at all?
          Did you try adding it manually to a dashboard by the configure UI button?
          A 1 Reply Last reply
          • electrikE electrik
            ar91
            @electrik, Yes it not showing automatically but when go through the configure UI button I was able to add my switches. Thank you everyone for all your help. Mysensors has a great community.
            • A ar91
              I have a HA running on a RPI3 and I have connected a mysensors serial gateway(MYS 2.3.2) to it. I have built an irrigation controller and it is working as except one issue. The irrigation controller is not appearing the dashboard and the only way I can access the device is through Developer Tools-->States tab.
              Here is my config
              Here is my issue in HA:
              Could someone please share their experience?
              Multimax
              @ar91 hi, i have the same problem, it is a new install and my sensors Gateway-node, with 12 relays
              • breimannB
                breimannB
                breimann
                Multimax, I was using Domoticz, then moved over to HA, and I had a few mys sensors, nodes, switches to add. I found I needed to activate any relay nodes from the node (which hopefully has a local pushbutton switch) for it to present automatically in lovelace. From then on the persistence file took over.
                The issue i have with one node is a hacked 12 v LED pendant light, with no local physical switch... still haven't added that one to HA yet as it will require me to pull it apart again, and add a switch, I think.
                Anyway, not sure if that is helpful, i'm still newb to HA, haven't gotten any automations going, but hoping to soon.
                • electrikE
                  electrikE
                  electrik
                  After the presentation, you should send the status to HA in order to show up in Lovelace.
                  https://www.home-assistant.io/integrations/sensor.mysensors/
                  • breimannB breimann
                    Multimax
                    @breimann thx for reply. I will try to look into it😁
                      Multimax
                      @electrik thx for reply, i will look into it😁
