  3. Sensebender. Still same problems with NEW board and radio
7 Posts 3 Posters 873 Views 3 Watching
  • N Offline
    N Offline
    Nigel31
    Re: Trouble with Sensebender gateway initialisation
    Hi.
    I'm having the same issues with a NEW Sensebender gateway board, fitted with a diffrent RFM69 radio.
    Diagnostics STILL fail at the eeprom reading.
    See log
    What can I possibly be doing wrong, given that the first one of these I built, worked fine?
    Regards Nigel
    Sensebender GateWay test routine
    Mysensors core version : 2.2.0
    GateWay sketch version : 0.2
    - > SHA204 Ok (serial : 01234DB597196D83EE)
    - > SD CARD SD CARD did not initialize!
     -> EEPROM 0;255;hu;0;hu;3 MCO:BGN:INIT GW,CP=RRNGS---,VER=2.2.0
    0;255;hu;0;hu;3 TSF:LRT:OK
    0;255;hu;0;hu;3 TSM:INIT
    0;255;hu;0;hu;3 TSF:WUR:MS=0
    0;255;hu;0;hu;3 !TSM:INIT:TSP FAIL
    0;255;hu;0;hu;3 TSM:FAIL:CNT=hu
    0;255;hu;0;hu;3 TSM:FAIL:DIS
    0;255;hu;0;hu;3 TSF:TDI:TSL
    0;255;hu;0;hu;3 TSM:FAIL:RE-INIT
    • rejoe2R Offline
      rejoe2R Offline
      rejoe2
      Is there any specific reason for using 2.2 and not either 2.3 or even 2.4 (development tree)?
      Afaik, there's been especially some changes around the RFM drivers, so giving newer versions a try might be a good idea :wink: .
      N 1 Reply Last reply
      • rejoe2R rejoe2
        N Offline
        N Offline
        Nigel31
        @rejoe2
        The reason for 2.2.0 is that when I (when 2.3.0) came out, I upgraded, and quite simply nothing worked, even though in theory, no significant "breaking" changes had been made.
        I could try upgrading, and building the gateway under 2.3.x, just to see if it works, but I am loth to change things, unless I can run some offline trials. I have about 20 nodes, including the whole central heating system. given it's now summer, I can give it a go, time depending.
        The NEW rfm69 driver, is it wirelessly compatible with the OLD driver? i.e. can old talk to new?
        the first Sensebender gateway, which I inadvertantly killed, by upping the max power, was built under 2.2.0.
        regards Nigel
        Y 1 Reply Last reply
        • N Nigel31
          @rejoe2
          regards Nigel
          Y Offline
          Y Offline
          @Njwyborn said in Sensebender. Still same problems with NEW board and radio:
          No, the on - air payload is different. All nodes in a network must use the same rfm driver.
          • Y Yveaux
            N Offline
            N Offline
            Nigel31
            wrote on last edited by Nigel31
            @Yveaux Thank you for the clarification, big job to upgrade!
            Question. Anyone know if I can run two mysensors serial gateways on Domoticz? Different network ID's? That would enable me to move nodes over to the latest release / drivers, and only have the node I was working on at the time offline! Assuming I can ever get my sensebender working!
            • N Nigel31
              Y Offline
              Y Offline
              big job to upgrade
              Or stick with the old driver
              • N Offline
                N Offline
                Nigel31
                Question.
                Would using the "ClearEepromConfig" sketch, do anything nasty to the sencebender gateway eeprom?
                12.1k
