  3. MyController.org
  4. Cannot add Nodes trough RS 485
Scheduled Pinned Locked Moved MyController.org
9 Posts 2 Posters 1.1k Views 2 Watching
  • Q
    Q
    qobouky
    I would like to ask you for your help. I frozen on adding a Nodes to Mycontroller.
    I am using Serial RS485 gateway - This I managed to add to MyController
    ![0_1626943900630_Gateway.JPG](Uploading 100%)
    As a Nod I am using DHT sketch with RS485 enabled and NOD definition
    #define MY_NODE_ID 22
    #define MY_PARENT_NODE_ID 0
    If I try to add Node manually Node is in status down
    ![0_1626944062318_Node.JPG](Uploading 100%)
    Communication between GW and Node works well
    0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RSNGA---,FQ=16,REL=255,VER=2.3.2
    0;255;3;0;9;5 TSM:INIT
    0;255;3;0;9;7 TSF:WUR:MS=0
    0;255;3;0;9;10 TSM:INIT:TSP OK
    0;255;3;0;9;13 TSM:INIT:GW MODE
    0;255;3;0;9;15 TSM:READY:ID=0,PAR=0,DIS=0
    0;255;3;0;9;19 MCO:REG:NOT NEEDED
    0;255;0;0;18;2.3.2
    0;255;3;0;9;23 MCO:BGN:STP
    0;255;3;0;9;29 MCO:BGN:INIT OK,TSP=1
    0;255;3;0;9;33 TSM:READY:NWD REQ
    0;255;3;0;9;53 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    0;255;3;0;9;7954 TSF:MSG:READ,22-22-0,s=0,c=1,t=1,pt=7,l=5,sg=0:41.0
    22;0;1;0;1;41.0
    Thank you very much for any advice
    J 1 Reply Last reply
    • Q
      Q
      qobouky
      • Q qobouky
        0;255;0;0;18;2.3.2
        22;0;1;0;1;41.0
        J
        J
        jkandasa
        @qobouky your attachments are not available. can you please add it again?
        do not you get your node by running discover on MyController?
        • Q
          Q
          qobouky
          Gateway
          Node
          Unfortunately function discover does not add anything
          • Q qobouky
            Gateway
            Node
            J
            J
            jkandasa
            @qobouky seems you have problem with MyController and serial port communication. I do not see the node 0 too (gateway node).
            can you check the MyController log file, is there any error? Also check the baud rate and port number of your serial device.
            • Q
              Q
              qobouky
              Of course it was issue on my side. My understanding was that GW baud rate in mycontroller should be baud rate of RS485. When I changed baud rate to correct value everything works well. Nod is added automatically.
              But I would like to kindly ask you for next suggestion.
              I plan to use one Arduino to monitor Temp, Hum and CO2. Those sensors are presented in MyController as static now.
              Additionally script should control 3 relays. I added relay script from My sensors but I have no idea where I should see those relays in MyController and how to control them manually
              // Enable RS485 transport layer
              #define MY_RS485
              // Define this to enables DE-pin management on defined pin
              #define MY_RS485_DE_PIN 2
              // Set RS485 baud rate to use
              // Enable this if RS485 is connected to a hardware serial port
              //#define MY_RS485_HWSERIAL Serial1
              #define MY_NODE_ID 20
              static const uint64_t UPDATE_INTERVAL = 10000;
              #define CHILD_ID_HUM 0
              #define CHILD_ID_TEMP 1
              #define CHILD_ID_CO2 2
              #define RELAY_PIN 10  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
              #define NUMBER_OF_RELAYS 3 // Total number of attached relays
              MyMessage msgCo2(CHILD_ID_CO2, V_LEVEL);
              MyMessage msgCo2b(CHILD_ID_CO2, V_UNIT_PREFIX);
              void before()
                  for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
                      pinMode(pin, OUTPUT);
                sendSketchInfo("Lihen", "1.0");
                present(CHILD_ID_HUM, S_HUM);
                present(CHILD_ID_CO2, S_AIR_QUALITY);
                send(msgCo2b.set("ppm"));
                  present(sensor, S_BINARY);
                Serial.println( F("Arduino MySensors RS485 Node test") );    // Fonction F() permet de placer la chaine dans la mémoire eprogramme (Arduino IDE 1.0).
                analogReference(INTERNAL);
                delay(1000);
                  Serial.println( F("Loop ...") );
                  TempHum();
                  readCO2();
                  sleep(UPDATE_INTERVAL);
              void TempHum ()
                  int temperature = 30;
                  int humidity = 50;
                  Serial.print(F("Tmp: "));
                  Serial.print(F("Hum: "));
                  Serial.println(humidity);
              int readCO2()
                  int CO2value = 1550;
                  Serial.print(F("CO2: "));
                  Serial.println(CO2value);
                  send(msgCo2.set(CO2value));
                  if (message.getType()==V_STATUS) {
                      // Change relay state
                      digitalWrite(message.getSensor()-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
                      // Store state in eeprom
                      saveState(message.getSensor(), message.getBool());
                      Serial.print(message.getSensor());
              • Q qobouky
                #define MY_RS485
                void before()
                  delay(1000);
                    TempHum();
                    readCO2();
                void TempHum ()
                    int humidity = 50;
                int readCO2()
                J
                J
                jkandasa
                wrote on last edited by jkandasa
                @qobouky to get V_STATUS, you can do it two ways
                1. (added automatically in MyController) Send the current status of the relays on your presentation block in your MySensors sketch
                2. (add manually in MyController) - you can see S_BINARY sensors in MyController on this node. You can add a V_STATUS variable on each S_BINARY sensor in MyController
                You will get a control option for your relays.
                • Q
                  Q
                  qobouky
                  Sorry but do I understand correctly that relay should be visible as a Sensor in MyController?
                  • Q qobouky
                    J
                    J
                    jkandasa
                    @qobouky You are correct, the Binary type sensors should be visible here.
                    I just revisited your sketch and I found a conflict on the allocated sensors id
                    void presentation()  {
                    your relay sensor id should start from 3 or above.
                    I do not see the use of pin=RELAY_PIN.
                    You can present the status of your relay's, that can create V_STATUS on MyController
                    example:
                    #define RELAY_SENSOR 3 // Relay sensor starts at 3
                    MyMessage relayMsg(RELAY_SENSOR, V_STATUS);
                    for (int sensor=RELAY_SENSOR; sensor < (RELAY_SENSOR + NUMBER_OF_RELAYS); sensor++) {
                        relayMsg.sensor = sensor;
                        send(relayMsg.set(loadState(sensor))); // current status of the relay
                    NOTE: You have to update your relay code on setup and in receive too
