  3. OpenHAB
  4. OH3 - MySensors Binding
135 Posts 34 Posters 36.0k Views 40 Watching
  • ChachaC Chacha
    Hi!
    I've upgraded to OH 3.1.0 from OH 3.0.x
    Installed openhab-transport-serial and openhab-core-io-transport-mqtt in Karaf console with:
    feature:install openhab-transport-serial
    feature:install openhab-core-io-transport-mqtt
    Tried to restart mysensors binding:
    openhab> bundle:restart org.openhab.binding.mysensors
    Error executing command: Error restarting bundles:
    	Unable to start bundle 29: Could not resolve module: org.openhab.binding.mysensors [29]
      Unresolved requirement: Import-Package: org.apache.commons.lang; version="[2.6.0,3.0.0)"
    Checked that only org.apache.commons.lang3 is installed:
    openhab> bundle:list org.apache.commons.lang3
    START LEVEL 100 , List Threshold: 50
    ID │ State  │ Lvl │ Version │ Name
    66 │ Active │  80 │ 3.12.0  │ Apache Commons Lang
    P
    P
    Peter Loeffler
    @Chacha the log says it all: in OH3 the required package org.apache.commons.lang is installed with version 3.12.0
    the (very depreciated) binding does only support up to version 3.0.0
    the bug has been known for several months now.
    there are 2 ways out of that situation:
    a) if possible recode your sensors without mysensors and use Homie instead
    b) get rid of the binding and use plain mqtt
    this also applys to @syntacrsc
    ChachaC P 2 Replies Last reply
    • P Peter Loeffler
      ChachaC
      ChachaC
      Chacha
      Thanks @Peter-Loeffler !
      I think I'll dive into mqtt than!
      As I can see Homie is only for sensors. I use mySensors to control my rollershutters.
      syntacrscS 1 Reply Last reply
      • ChachaC Chacha
        syntacrscS
        syntacrscS
        syntacrsc
        wrote on last edited by syntacrsc
        #105
        @Chacha
        Same here, I use MySensors to control rollershutters, pool pump, HVAC and solar panels.
        Maybe we should collect some volunteers for a bounty to give to @TimO to enhance his beautiful mySensors binding to work with the recent OH 3.1.0 version??
        @Peter-Loeffler
        I used to use plain MQTT before I found the mySensors binding and don't really want go back to it.
        I'd be willing to throw 100 USD into the bounty pot to enhance MySensors to work with the recent version of OH3...
        (I'd do it myself if I'd know how to ;-) )
        P gundark2G 2 Replies Last reply
        • P Peter Loeffler
          P
          P
          Peter Loeffler
          @Chacha you are wrong: Homie is NOT ONLY for sensors.
          • syntacrscS syntacrsc
            @Chacha
            @Peter-Loeffler
            P
            P
            Peter Loeffler
            @syntacrsc well, for me it's no solution to throw Dollars into a pot that a community-based software get's some updates. either the software is state of the art ro it is not. and MySensors turned out to be not :(
              @Chacha
              @Peter-Loeffler
              gundark2G
              gundark2G
              gundark2
              @syntacrsc @TimO My system just upgraded and killed all of mySensors, which is probably half of my system... so I would be in for $50 at least
              • V
                V
                vores8
                i've managed to build new version from the sources found here https://github.com/nikolac/openhab-addons/tree/mysensors-oh3-migration
                So far, so good - working with the latest OH 3.1.0
                please download from https://disk.yandex.ru/d/Yq3gn8N7tXSQxA
                DbagioniD T ChachaC 3 Replies Last reply
                • V vores8
                  DbagioniD
                  DbagioniD
                  Dbagioni
                  @vores8 just down loaded it and installed. Showing up online with my serial gateway. Gonna let it run but looks like it’s working now. Nice work, and thank you.
                  • T TimO
                    I've solved the dependency error and the package compiles fine, but I had no time for testing yet.
                    If you're willing to test: Download
                    H
                    H
                    haasje30
                    @TimO After my system upgrade yesterday the mysensor binding stopt working. after I replaced the binding with your new download, it started working again. Thanks, you are a real hero (at least for me).
                    • YoshuY
                      YoshuY
                      Yoshu
                      Hi
                      Just tested out the mysensors openhab binding (org.openhab.binding.mysensors-3.2.0-SNAPSHOT) in the link provided by vores8 a few messages above.
                      Testing with the serial gateway, openhab 3.2 latest snapshot running pi 4.
                      Another detail for new users setting up by following the instruction, in the openhab install wiki (https://github.com/tobof/openhab-addons/wiki/Installation) here. This line does not work
                      feature:install openhab-transport-serial and feature:install openhab-core-io-transport-mqtt.
                      From other comments I found it is overcome by installing the openhab serial and mqtt bindings .
                      • N ncollins
                        One thing I had to do was explicitly set secure="false" into /opt/openhab/userdata/config/org/openhab/mqttbroker.config.
                        Please try that, then restart.
                        dsbibby
                        @ncollins said in OH3 - MySensors Binding:
                        Just had a whole load of trouble getting the binding working using MQTT - this was the solution in case anyone else hits this!
                        • V vores8
                          ThkUF
                          @vores8 said in OH3 - MySensors Binding:
                          For anyone interested, I just installed the latest version of OpenHabian on a raspberry pi and it is running OH 3.1.0. The Openhab 3.1 MySensors binding from the Mysensors website was not working (same error as @Chacha).
                          I have now installed the version that @vores8 has provided and MySensors is up and running properly.
                          Thanks for the help.
                          • F
                            F
                            forexsieno
                            just tested OH3 (3.1.0) on PI3 with mysensors openhab binding (org.openhab.binding.mysensors-3.2.0-SNAPSHOT) in the link provided by vores8.
                            feature:install openhab-transport-serial and feature:install openhab-core-io-transport-mqtt. done. It's all up and running . bundle:list shows all active.
                            But the "MySensors Serial Gateway" which I intend to use in OH3 will not keep ONLINE.
                            It always goes back to offline...
                            11:48:29.035 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge mysensors:bridge-ser:6e5dca16a9 DONE!
                            11:48:29.035 [DEBUG] [ocol.serial.MySensorsSerialConnection] - Connecting to /dev/ttyUSB1 [baudRate:115200]
                            11:48:29.045 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-ser:6e5dca16a9' changed from OFFLINE to ONLINE
                            11:48:29.062 [ERROR] [ocol.serial.MySensorsSerialConnection] - Exception found
                            java.lang.IllegalStateException: Serial Port Identifier not found
                                    at org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialConnection.establishConnection(MySensorsSerialConnection.java:59) [bundleFile:?]
                                    at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection.connect(MySensorsAbstractConnection.java:145) [bundleFile:?]
                                    at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection.run(MySensorsAbstractConnection.java:124) [bundleFile:?]
                                    at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) [?:?]
                                    at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
                                    at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
                                    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) [?:?]
                                    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) [?:?]
                                    at java.lang.Thread.run(Thread.java:829) [?:?]
                            11:48:29.073 [DEBUG] [ors.internal.gateway.MySensorsGateway] - MySensorsGateway connection status update -connected: false
                            11:48:29.077 [DEBUG] [s.discovery.MySensorsDiscoveryService] - Stopping MySensors discovery scan
                            11:48:29.080 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-ser:6e5dca16a9' changed from ONLINE to OFFLINE
                            11:48:29.081 [DEBUG] [ysensors.internal.event.EventRegister] - Listener org.openhab.binding.mysensors.discovery.MySensorsDiscoveryService@b2d6b0 not present, cannot remove it
                            11:48:29.086 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Connection status mysensors:bridge-ser:6e5dca16a9 updated to false
                            11:48:29.090 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: [0,4]
                            11:48:29.095 [ERROR] [ocol.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
                            any ideas?
                            T Duncan PullenD 2 Replies Last reply
                            • F forexsieno
                              any ideas?
                              TimO
                              @forexsieno Is the device accessible by the user that Openhab is running with?
                              • F
                                F
                                forexsieno
                                @TimO said in OH3 - MySensors Binding:
                                @TimO Yes it is. This behaviour is not reproduceable for me. Sometimes after reboot Serial gateway keeps online. in other cases it switches to OFFLINE. I assume anything is wrong with serial driver.
                                • YoshuY
                                  YoshuY
                                  Yoshu
                                  Openhab 3.2 now contains a community marketplace for bindings, perhaps the mysensors binding can be made available there?
                                  • J
                                    J
                                    Jarosław Narbut
                                    Someone have working mysensors binding in openhab 3.3 ?
                                    C 1 Reply Last reply
                                    • J Jarosław Narbut
                                      C
                                      C
                                      CyborgAndy
                                      @Jarosław-Narbut Yes, I have.
                                      D 1 Reply Last reply
                                      • C CyborgAndy
                                        daanjjansen
                                        @CyborgAndy could you please share?
                                        • D
                                          daanjjansen
                                          Im receiving following error in openhab:
                                          [protocol.mqtt.MySensorsMqttConnection] - Can't send message, connection writer is null
                                          Did you have the same? What did you do to resolve this?
                                          Using addon: org.openhab.binding.mysensors-3.2.0-SNAPSHOT.jar
