  3. OpenHAB
  4. OH3 - MySensors Binding
135 Posts 34 Posters 36.0k Views 40 Watching
  • syntacrscS syntacrsc
    @Chacha
    Same here, I use MySensors to control rollershutters, pool pump, HVAC and solar panels.
    Maybe we should collect some volunteers for a bounty to give to @TimO to enhance his beautiful mySensors binding to work with the recent OH 3.1.0 version??
    @Peter-Loeffler
    I used to use plain MQTT before I found the mySensors binding and don't really want go back to it.
    I'd be willing to throw 100 USD into the bounty pot to enhance MySensors to work with the recent version of OH3...
    (I'd do it myself if I'd know how to ;-) )
    gundark2G
    gundark2G
    gundark2
    @syntacrsc @TimO My system just upgraded and killed all of mySensors, which is probably half of my system... so I would be in for $50 at least
    • V
      V
      vores8
      i've managed to build new version from the sources found here https://github.com/nikolac/openhab-addons/tree/mysensors-oh3-migration
      So far, so good - working with the latest OH 3.1.0
      please download from https://disk.yandex.ru/d/Yq3gn8N7tXSQxA
      DbagioniD T ChachaC 3 Replies Last reply
      • V vores8
        DbagioniD
        DbagioniD
        Dbagioni
        @vores8 just down loaded it and installed. Showing up online with my serial gateway. Gonna let it run but looks like it’s working now. Nice work, and thank you.
        • T TimO
          I've solved the dependency error and the package compiles fine, but I had no time for testing yet.
          If you're willing to test: Download
          H
          H
          haasje30
          @TimO After my system upgrade yesterday the mysensor binding stopt working. after I replaced the binding with your new download, it started working again. Thanks, you are a real hero (at least for me).
          • YoshuY
            YoshuY
            Yoshu
            Hi
            Just tested out the mysensors openhab binding (org.openhab.binding.mysensors-3.2.0-SNAPSHOT) in the link provided by vores8 a few messages above.
            Testing with the serial gateway, openhab 3.2 latest snapshot running pi 4.
            Another detail for new users setting up by following the instruction, in the openhab install wiki (https://github.com/tobof/openhab-addons/wiki/Installation) here. This line does not work
            feature:install openhab-transport-serial and feature:install openhab-core-io-transport-mqtt.
            From other comments I found it is overcome by installing the openhab serial and mqtt bindings .
            • N ncollins
              One thing I had to do was explicitly set secure="false" into /opt/openhab/userdata/config/org/openhab/mqttbroker.config.
              Please try that, then restart.
              dsbibby
              @ncollins said in OH3 - MySensors Binding:
              Just had a whole load of trouble getting the binding working using MQTT - this was the solution in case anyone else hits this!
              • V vores8
                ThkUF
                @vores8 said in OH3 - MySensors Binding:
                For anyone interested, I just installed the latest version of OpenHabian on a raspberry pi and it is running OH 3.1.0. The Openhab 3.1 MySensors binding from the Mysensors website was not working (same error as @Chacha).
                I have now installed the version that @vores8 has provided and MySensors is up and running properly.
                Thanks for the help.
                • F
                  F
                  forexsieno
                  just tested OH3 (3.1.0) on PI3 with mysensors openhab binding (org.openhab.binding.mysensors-3.2.0-SNAPSHOT) in the link provided by vores8.
                  feature:install openhab-transport-serial and feature:install openhab-core-io-transport-mqtt. done. It's all up and running . bundle:list shows all active.
                  But the "MySensors Serial Gateway" which I intend to use in OH3 will not keep ONLINE.
                  It always goes back to offline...
                  11:48:29.035 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge mysensors:bridge-ser:6e5dca16a9 DONE!
                  11:48:29.035 [DEBUG] [ocol.serial.MySensorsSerialConnection] - Connecting to /dev/ttyUSB1 [baudRate:115200]
                  11:48:29.045 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-ser:6e5dca16a9' changed from OFFLINE to ONLINE
                  11:48:29.062 [ERROR] [ocol.serial.MySensorsSerialConnection] - Exception found
                  java.lang.IllegalStateException: Serial Port Identifier not found
                          at org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialConnection.establishConnection(MySensorsSerialConnection.java:59) [bundleFile:?]
                          at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection.connect(MySensorsAbstractConnection.java:145) [bundleFile:?]
                          at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection.run(MySensorsAbstractConnection.java:124) [bundleFile:?]
                          at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) [?:?]
                          at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
                          at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
                          at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) [?:?]
                          at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) [?:?]
                          at java.lang.Thread.run(Thread.java:829) [?:?]
                  11:48:29.073 [DEBUG] [ors.internal.gateway.MySensorsGateway] - MySensorsGateway connection status update -connected: false
                  11:48:29.077 [DEBUG] [s.discovery.MySensorsDiscoveryService] - Stopping MySensors discovery scan
                  11:48:29.080 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-ser:6e5dca16a9' changed from ONLINE to OFFLINE
                  11:48:29.081 [DEBUG] [ysensors.internal.event.EventRegister] - Listener org.openhab.binding.mysensors.discovery.MySensorsDiscoveryService@b2d6b0 not present, cannot remove it
                  11:48:29.086 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Connection status mysensors:bridge-ser:6e5dca16a9 updated to false
                  11:48:29.090 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: [0,4]
                  11:48:29.095 [ERROR] [ocol.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
                  any ideas?
                  T Duncan PullenD 2 Replies Last reply
                  • F forexsieno
                    any ideas?
                    TimO
                    @forexsieno Is the device accessible by the user that Openhab is running with?
                    • F
                      F
                      forexsieno
                      @TimO said in OH3 - MySensors Binding:
                      @TimO Yes it is. This behaviour is not reproduceable for me. Sometimes after reboot Serial gateway keeps online. in other cases it switches to OFFLINE. I assume anything is wrong with serial driver.
                      • YoshuY
                        YoshuY
                        Yoshu
                        Openhab 3.2 now contains a community marketplace for bindings, perhaps the mysensors binding can be made available there?
                        • J
                          J
                          Jarosław Narbut
                          Someone have working mysensors binding in openhab 3.3 ?
                          C 1 Reply Last reply
                          • J Jarosław Narbut
                            C
                            C
                            CyborgAndy
                            @Jarosław-Narbut Yes, I have.
                            D 1 Reply Last reply
                            • C CyborgAndy
                              daanjjansen
                              @CyborgAndy could you please share?
                              • D
                                daanjjansen
                                Im receiving following error in openhab:
                                [protocol.mqtt.MySensorsMqttConnection] - Can't send message, connection writer is null
                                Did you have the same? What did you do to resolve this?
                                Using addon: org.openhab.binding.mysensors-3.2.0-SNAPSHOT.jar
                                • D daanjjansen
                                  C
                                  C
                                  CyborgAndy
                                  @daanjjansen I'm using OpenHAB 3.3.0
                                  Information from OpenHAB 3.3.0 release notes:
                                  Support for the MQTT System Broker has been removed. Replace 'mqtt:systemBroker' things with 'mqtt:broker' things.
                                  I fixed this error with MqttConnection. Your need remove MQTT System Broker and create new MQTT Broker.
                                  Download fixed org.openhab.binding.mysensors-3.3.0-SNAPSHOT.jar from my Google Disk
                                    mbedarff
                                    It seems that still some people are interested in this MySensors binding being updated further.
                                    I'm currently using in openHAB 3.2 the version that @vores8 kindly provided in post #109 on 21/07/2022, based on the source fork from @ncollins (https://github.com/nikolac/openhab2-addons/tree/mysensors-oh3-migration).
                                    Now I noticed that there seems to be a bug in the ethernet gateway with reconnecting after the TCP connection is lost. The loss of the connection is detected, but it is not disconnected and re-established afterwards.
                                    I would like to look at this in the " current" source code and if possible develop a fix and provide it.
                                    Therefore the question to the community and especially to @vores8 and @ncollins, if the source code adapted to OH 3.2 or now to OH 3.3 has been uploaded by you to GitHub. If so, under which repository and branch? If not, please catch up on it for us so that we can merge the adaption you have made to the source and possibly bundle and ensure further development.
                                    Thanks a lot in advance! :face_with_cowboy_hat:
                                    N C 2 Replies Last reply
                                    • M mbedarff
                                      N
                                      N
                                      ncollins
                                      @mbedarff good question. Seems @CyborgAndy is keeping the addon alive? If so, @CyborgAndy are you publishing your changes to a public branch/fork?
                                      • F forexsieno
                                        any ideas?
                                        Duncan PullenD
                                        Duncan PullenD
                                        Duncan Pullen
                                        @forexsieno Did you solve this one?
                                        I'm still getting the same error.
                                        Using 3.3.0-SNAPSHOT
                                        2022-08-08 02:21:23.200 [ERROR] [col.serial.MySensorsSerialConnection] - Exception found
                                        • M mbedarff
                                          C
                                          C
                                          CyborgAndy
                                          Hi.
                                          @mbedarff I fix gateway connection checking issue.
                                          You can download the fixed version from my Google Disk
                                          @mbedarff @ncollins I published all changes to GitHub, "mysensors-binding-addon" branch.
                                          @forexsieno I tested my 3.3.0-SNAPSHOT in different environments (Arduino Nano as serial gateway, OH 3.3 installed on Windows 10 and Ubuntu Server 20.04) and did not find such a problem.
                                          D od1O 2 Replies Last reply
