  3. Question about security signing, and when it is "applied"
1 Posts 1 Posters 498 Views 1 Watching
  • N
    N
    Nigel31
    wrote on last edited by Nigel31
    Background.
    I have a smart thermostat node, which is signed, and requires signed messages from the gateway.
    As a nice to have, as part of the initialisation, time is requested., this is used to post the boot time in a text field back in the controller.
    when developing this version of the thermostat, I didn't use signing, until deployment, and all proceeded more or less as expected. After deployment however, it became apparent that "booting" was taking a considerable period of time ( up to 3 mins on one occasion) I narrowed this down to the infinate loop of getting the time I had created (now limited to 5 tries) in the startup().
    Prior to enabling the signing, the booting would complete in circa 40 secs ( I have 10 or so child objects and use wait(250); between presentations).
    My question : Is signing applied to ALL communications, including presentations, or is it only applied after the initial preambles, and utilised only on "received" commands( requested or directed)?
    Looking at the log of the node, once connected back up, the signing " NONCE KEY"t ype packets didn't appear until after much time, and definitely not at the start of the logs.
    here is an example log
    3522 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4318 TSF:MSG:READ,0-0-10,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    4319 SGN:SKP:MSG CMD=3,TYPE=8
    4319 TSF:MSG:FPAR OK,ID=0,D=1
    5523 TSM:FPAR:OK
    5523 TSM:ID
    5523 TSM:ID:OK
    5523 TSM:UPL
    5523 SGN:SGN:NREQ=0
    5529 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    6866 TSF:MSG:READ,0-0-10,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    6867 SGN:SKP:MSG CMD=3,TYPE=25
    6867 TSF:MSG:PONG RECV,HP=1
    6867 TSM:UPL:OK
    6867 TSM:READY:ID=10,PAR=0,DIS=1
    6867 SGN:PRE:SGN REQ
    6867 SGN:PRE:WHI NREQ
    6867 SGN:SGN:NREQ=0
    8390 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
    8390 SGN:PRE:XMT,TO=0
    8390 SGN:PRE:WAIT GW
    9598 TSF:MSG:READ,0-0-10,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    9598 SGN:SKP:MSG CMD=3,TYPE=15
    9598 SGN:SGN:NREQ=0
    10604 TSF:MSG:SEND,10-10-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.2.0
    10605 SGN:SGN:NREQ=0
    12729 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    13753 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    13753 SGN:SKP:MSG CMD=3,TYPE=16
    13753 SGN:SGN:NREQ=0
    14762 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    14763 SGN:NCE:XMT,TO=10
    LivingRm Thermostat Present, 1.1.11
    14763 SGN:SGN:NREQ=0
    18109 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=0,st=OK:LivingRm Thermostat
    18109 SGN:SGN:NREQ=0
    19115 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=12,pt=0,l=6,sg=0,ft=0,st=OK:1.1.11
    19116 SGN:SGN:NREQ=0
    20124 TSF:MSG:SEND,10-10-0-0,s=0,c=0,t=6,pt=0,l=16,sg=0,ft=0,st=OK:Room Temperature
    20224 SGN:SGN:NREQ=0
    20232 TSF:MSG:SEND,10-10-0-0,s=5,c=0,t=33,pt=0,l=18,sg=0,ft=0,st=OK:Thermostat RX RSSI
    20333 SGN:SGN:NREQ=0
    21546 TSF:MSG:SEND,10-10-0-0,s=2,c=0,t=3,pt=0,l=16,sg=0,ft=0,st=OK:Thermostat Relay
    21646 SGN:SGN:NREQ=0
    23579 TSF:MSG:SEND,10-10-0-0,s=3,c=0,t=3,pt=0,l=13,sg=0,ft=0,st=OK:Heat Override
    23679 SGN:SGN:NREQ=0
    24909 !TSF:MSG:SEND,10-10-0-0,s=1,c=0,t=14,pt=0,l=13,sg=0,ft=0,st=NACK:Temp Setpoint
    25009 SGN:SGN:NREQ=0
    25016 TSF:MSG:SEND,10-10-0-0,s=6,c=0,t=4,pt=0,l=11,sg=0,ft=1,st=OK:Oil Tank PC
    25117 SGN:SGN:NREQ=0
    27896 TSF:MSG:SEND,10-10-0-0,s=7,c=0,t=36,pt=0,l=16,sg=0,ft=0,st=OK:Text Who is Home
    27996 SGN:SGN:NREQ=0
    29315 TSF:MSG:SEND,10-10-0-0,s=8,c=0,t=3,pt=0,l=14,sg=0,ft=0,st=OK:SP Update Flag
    29415 SGN:SGN:NREQ=0
    30553 TSF:MSG:SEND,10-10-0-0,s=9,c=0,t=3,pt=0,l=13,sg=0,ft=0,st=OK:HotWater Flag
    30653 SGN:SGN:NREQ=0
    35314 !TSF:MSG:SEND,10-10-0-0,s=10,c=0,t=36,pt=0,l=20,sg=0,ft=0,st=NACK:Returned Who is Home
    35414 SGN:SGN:NREQ=0
    36635 TSF:MSG:SEND,10-10-0-0,s=11,c=0,t=36,pt=0,l=8,sg=0,ft=1,st=OK:BootTime
    LivingRm Thermostat END Present, 1.1.11
    36635 MCO:REG:REQ
    36635 SGN:SGN:NREQ=0
    37641 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    37855 !SGN:BND:TMR
    38857 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    38857 SGN:SKP:MSG CMD=3,TYPE=16
    38857 SGN:SGN:NREQ=0
    41278 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    41279 SGN:NCE:XMT,TO=10
    41279 SGN:SGN:NREQ=0
    43691 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    43905 !SGN:BND:TMR
    44906 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    44907 SGN:SKP:MSG CMD=3,TYPE=16
    44907 SGN:SGN:NREQ=0
    45916 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    45917 SGN:NCE:XMT,TO=10
    45917 SGN:SGN:NREQ=0
    48532 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    49746 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    49747 SGN:SKP:MSG CMD=3,TYPE=16
    49747 SGN:SGN:NREQ=0
    50756 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    50757 SGN:NCE:XMT,TO=10
    50757 SGN:SGN:NREQ=0
    52251 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    53465 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    53466 SGN:SKP:MSG CMD=3,TYPE=16
    53466 SGN:SGN:NREQ=0
    54475 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    54476 SGN:NCE:XMT,TO=10
    54476 MCO:BGN:STP
    Loaded values
     :Relay output : 1
    54522 SGN:SGN:NREQ=0
    56543 TSF:MSG:SEND,10-10-0-0,s=2,c=2,t=2,pt=0,l=0,sg=0,ft=0,st=OK:
    uplink available
    57561 TSF:MSG:READ,0-0-10,s=2,c=3,t=16,pt=0,l=0,sg=1:
    57561 SGN:SKP:MSG CMD=3,TYPE=16
    57561 SGN:SGN:NREQ=0
    60305 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    60306 SGN:NCE:XMT,TO=10
    60306 SGN:SGN:NREQ=0
    61312 TSF:MSG:SEND,10-10-0-0,s=2,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
    Req SP
    61312 SGN:SGN:NREQ=0
    63331 TSF:MSG:SEND,10-10-0-0,s=1,c=2,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
    Req PC
    63581 SGN:SGN:NREQ=0
    63587 TSF:MSG:SEND,10-10-0-0,s=6,c=2,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    display init
    WD Enabled
    63633 SGN:SGN:NREQ=0
    66044 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
    66065 !SGN:BND:TMR
    67067 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    67067 SGN:SKP:MSG CMD=3,TYPE=16
    67067 SGN:SGN:NREQ=0
    69282 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    69283 SGN:NCE:XMT,TO=10
    Time REQ 1
    69283 SGN:SGN:NREQ=0
    70288 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
    71317 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    71318 SGN:SKP:MSG CMD=3,TYPE=16
    71318 SGN:SGN:NREQ=0
    73739 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    73740 SGN:NCE:XMT,TO=10
    Time REQ 2
    73740 SGN:SGN:NREQ=0
    74745 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
    75778 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    75778 SGN:SKP:MSG CMD=3,TYPE=16
    75778 SGN:SGN:NREQ=0
    76787 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    76788 SGN:NCE:XMT,TO=10
    Time REQ 3
    76788 SGN:SGN:NREQ=0
    79541 !TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=NACK:
    Time REQ 4
    80041 SGN:SGN:NREQ=0
    80047 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=1,st=OK:
    80676 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    80677 SGN:SKP:MSG CMD=3,TYPE=16
    80677 SGN:SGN:NREQ=0
    81310 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    81311 SGN:NCE:XMT,TO=10
    Time REQ 5
    81311 SGN:SGN:NREQ=0
    82316 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
    83334 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    83335 SGN:SKP:MSG CMD=3,TYPE=16
    83335 SGN:SGN:NREQ=0
    84344 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    84345 SGN:NCE:XMT,TO=10
    Time REQ 6
    84345 SGN:SGN:NREQ=0
    86553 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
    87115 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    87115 SGN:SKP:MSG CMD=3,TYPE=16
    87116 SGN:SGN:NREQ=0
    88745 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    88746 SGN:NCE:XMT,TO=10
    Time REQ 7
    88746 SGN:SGN:NREQ=0
    89751 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
    89980 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    89980 SGN:SKP:MSG CMD=3,TYPE=16
    89980 SGN:SGN:NREQ=0
    91195 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    91196 SGN:NCE:XMT,TO=10
    Time REQ 8
    91196 SGN:SGN:NREQ=0
    92201 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
    93231 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    93231 SGN:SKP:MSG CMD=3,TYPE=16
    93231 SGN:SGN:NREQ=0
    94240 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    94241 SGN:NCE:XMT,TO=10
    Time REQ 9
    94241 SGN:SGN:NREQ=0
    95653 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
    96680 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    96681 SGN:SKP:MSG CMD=3,TYPE=16
    96681 SGN:SGN:NREQ=0
    97690 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    97691 SGN:NCE:XMT,TO=10
    Time REQ 10
    97691 SGN:SGN:NREQ=0
    99804 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
    Timedout
    99805 MCO:BGN:INIT OK,TSP=1
    100831 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    100831 SGN:SKP:MSG CMD=3,TYPE=16
    100831 SGN:SGN:NREQ=0
    103964 !TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=NACK:<NONCE>
    103964 !SGN:NCE:XMT,TO=10 FAIL
    Interval Timed :TEMPERATURE :2.08
    104743 SGN:SGN:NREQ=0
    105749 TSF:MSG:SEND,10-10-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=1,st=OK:2.08
    105750 SGN:SGN:NREQ=0
    108040 !TSF:MSG:SEND,10-10-0-0,s=2,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=NACK:1
    TX Error 1
    108240 SGN:SGN:NREQ=0
    110077 TSF:MSG:SEND,10-10-0-0,s=2,c=1,t=2,pt=1,l=1,sg=0,ft=1,st=OK:1
    110277 SGN:SGN:NREQ=0
    111486 TSF:MSG:SEND,10-10-0-0,s=5,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:0
    111486 SGN:SGN:NREQ=0
    114512 !TSF:MSG:SEND,10-10-0-0,s=7,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=NACK:
    114512 SGN:SGN:NREQ=0
    114518 TSF:MSG:SEND,10-10-0-0,s=7,c=2,t=47,pt=0,l=0,sg=0,ft=1,st=OK:
    Who is Home Status requested :Manual ...
    Setpoint requested :
    114518 SGN:SGN:NREQ=0
    115930 TSF:MSG:SEND,10-10-0-0,s=1,c=2,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
    Tank Level requested :
    115930 SGN:SGN:NREQ=0
    116935 TSF:MSG:SEND,10-10-0-0,s=6,c=2,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    Who is Home Status requested :116936 SGN:SGN:NREQ=0
    118993 TSF:MSG:SEND,10-10-0-0,s=7,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
    118994 SGN:SGN:NREQ=0
    120406 TSF:MSG:SEND,10-10-0-0,s=8,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
    requesting time
    120406 SGN:SGN:NREQ=0
    122817 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
    122843 !SGN:BND:TMR
    123340 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    123341 SGN:SKP:MSG CMD=3,TYPE=16
    123341 SGN:SGN:NREQ=0
    124350 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    124351 SGN:NCE:XMT,TO=10
    125132 TSF:MSG:READ,0-0-10,s=255,c=3,t=1,pt=0,l=10,sg=1:1628438223
    125132 SGN:BND:NONCE=83AF3CB5A90DA3FE33E45D341D189DA4040C6960FC16D6AB88AAAAAAAAAAAAAA
    125133 SGN:BND:HMAC=8BEA40C87AB3848F8455AEB87414BC6AFFF9C5337BC0AD46CBA29CC66B7E5D3D
    125133 SGN:VER:OK
    Time value received: Time value valid: 1628438223
    15 57 3 8 8 2021
    Interval Timed :TEMPERATURE :20.93
    180614 SGN:SGN:NREQ=0
    181620 TSF:MSG:SEND,10-10-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.93
    181621 SGN:SGN:NREQ=0
    183839 !TSF:MSG:SEND,10-10-0-0,s=2,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=NACK:0
    TX Error 1
    184039 SGN:SGN:NREQ=0
    184451 TSF:MSG:SEND,10-10-0-0,s=2,c=1,t=2,pt=1,l=1,sg=0,ft=1,st=OK:0
    184651 SGN:SGN:NREQ=0
    186266 TSF:MSG:SEND,10-10-0-0,s=5,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:0
    186266 SGN:SGN:NREQ=0
    188475 TSF:MSG:SEND,10-10-0-0,s=7,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
    188475 SGN:SGN:NREQ=0
    189887 TSF:MSG:SEND,10-10-0-0,s=7,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
    191743 TSF:MSG:READ,0-0-10,s=7,c=3,t=16,pt=0,l=0,sg=1:
    191743 SGN:SKP:MSG CMD=3,TYPE=16
    191743 SGN:SGN:NREQ=0
    192752 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    192753 SGN:NCE:XMT,TO=10
    Interval Timed :TEMPERATURE :21.00
    249889 SGN:SGN:NREQ=0
    249896 TSF:MSG:SEND,10-10-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:21.00
    249896 SGN:SGN:NREQ=0
    251309 TSF:MSG:SEND,10-10-0-0,s=2,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
    251309 SGN:SGN:NREQ=0
    252721 TSF:MSG:SEND,10-10-0-0,s=5,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:-46
    252721 SGN:SGN:NREQ=0
    256544 TSF:MSG:SEND,10-10-0-0,s=7,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
    256545 SGN:SGN:NREQ=0
    260159 TSF:MSG:SEND,10-10-0-0,s=7,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
    261009 !SGN:BND:TMR
    262011 TSF:MSG:READ,0-0-10,s=7,c=3,t=16,pt=0,l=0,sg=1:
    262011 SGN:SKP:MSG CMD=3,TYPE=16
    262011 SGN:SGN:NREQ=0
    263020 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    263021 SGN:NCE:XMT,TO=10
    305253 !SGN:BND:TMR
    305618 TSF:MSG:READ,0-0-10,s=6,c=3,t=16,pt=0,l=0,sg=1:
    305618 SGN:SKP:MSG CMD=3,TYPE=16
    305618 SGN:SGN:NREQ=0
    307450 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    307451 SGN:NCE:XMT,TO=10
    Interval Timed :TEMPERATURE :21.03
    320699 SGN:SGN:NREQ=0
    321909 TSF:MSG:SEND,10-10-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:21.03
    321910 SGN:SGN:NREQ=0
    323322 TSF:MSG:SEND,10-10-0-0,s=2,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
    323322 SGN:SGN:NREQ=0
    324557 !TSF:MSG:SEND,10-10-0-0,s=5,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=NACK:-47
    TX Error 1
    324757 SGN:SGN:NREQ=0
    326060 TSF:MSG:SEND,10-10-0-0,s=5,c=1,t=37,pt=2,l=2,sg=0,ft=1,st=OK:-47
    326260 SGN:SGN:NREQ=0
    327469 TSF:MSG:SEND,10-10-0-0,s=7,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
    327469 SGN:SGN:NREQ=0
    328881 TSF:MSG:SEND,10-10-0-0,s=7,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
    329730 !SGN:BND:TMR
    329732 TSF:MSG:READ,0-0-10,s=7,c=3,t=16,pt=0,l=0,sg=1:
    329732 SGN:SKP:MSG CMD=3,TYPE=16
    329732 SGN:SGN:NREQ=0
    329743 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    329743 SGN:NCE:XMT,TO=10
    331573 TSF:MSG:READ,0-0-10,s=7,c=2,t=47,pt=0,l=13,sg=1:Nigel & Emma.
    331573 SGN:BND:NONCE=FF59DC85B6BA907ED7E4FD01AF31A6B5ABC510899FDDCF9435AAAAAAAAAAAAAA
    331574 SGN:BND:HMAC=559FD511A684ADEA51424D002F644A41D472903F21D014B718FAFED81ABC1CA8
    331574 SGN:VER:OK
    REQ_Msg :47 MsgCmd:2 childID:7 Data:S/Nigel & Emma. Data:I/ 0 Data:B/ 0
    Incomming message From REQUEST Who is Home Nigel & Emma.
    331574 SGN:SGN:NREQ=0
    332582 TSF:MSG:SEND,10-10-0-0,s=10,c=1,t=47,pt=0,l=13,sg=0,ft=0,st=OK:Nigel & Emma.
    Who is Home Status sent :Nigel & Emma.
    Interval Timed :TEMPERATURE :21.06
    388892 SGN:SGN:NREQ=0
    388899 TSF:MSG:SEND,10-10-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:21.06
    388899 SGN:SGN:NREQ=0
    390124 TSF:MSG:SEND,10-10-0-0,s=2,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
    390124 SGN:SGN:NREQ=0
    392536 TSF:MSG:SEND,10-10-0-0,s=5,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:-47
    392536 SGN:SGN:NREQ=0
    393948 TSF:MSG:SEND,10-10-0-0,s=7,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
    393948 SGN:SGN:NREQ=0
    396584 !TSF:MSG:SEND,10-10-0-0,s=7,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=NACK:
    Who is Home Status requested :Nigel & Emma.
    457058 SGN:SGN:NREQ=0
    457065 TSF:MSG:SEND,10-10-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=1,st=OK:21.06
    457065 SGN:SGN:NREQ=0
    458487 TSF:MSG:SEND,10-10-0-0,s=2,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
    458487 SGN:SGN:NREQ=0
    459712 TSF:MSG:SEND,10-10-0-0,s=5,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:-47
    459712 SGN:SGN:NREQ=0
    461075 TSF:MSG:SEND,10-10-0-0,s=7,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
    461075 SGN:SGN:NREQ=0
    462833 TSF:MSG:SEND,10-10-0-0,s=7,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
    463690 TSF:MSG:READ,0-0-10,s=7,c=3,t=16,pt=0,l=0,sg=1:
    463690 SGN:SKP:MSG CMD=3,TYPE=16
    463690 SGN:SGN:NREQ=0
    463701 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    463701 SGN:NCE:XMT,TO=10
    465080 TSF:MSG:READ,0-0-10,s=7,c=2,t=47,pt=0,l=13,sg=1:Nigel & Emma.
    465080 SGN:BND:NONCE=35BA9FD8ED811D46C550E974D198A143AC4B7AFB7A7EF19583AAAAAAAAAAAAAA
    465081 SGN:BND:HMAC=EDAFEA584D649579693E418859559FBF30E8C2D66019EDB34705F4EE4D982201
    465081 SGN:VER:OK
    465082 SGN:SGN:NREQ=0
    465847 TSF:MSG:SEND,10-10-0-0,s=10,c=1,t=47,pt=0,l=13,sg=0,ft=0,st=OK:Nigel & Emma.
    466679 TSF:MSG:READ,0-0-10,s=10,c=1,t=47,pt=0,l=13,sg=0:Nigel & Emma.
    466679 SGN:SKP:ACK CMD=1,TYPE=47
    466679 TSF:MSG:ACK
    +Ack FMGW
    *InMsgty :47 MsgComd:1 childID:10 Data:S/Nigel & Emma. Data:I/ 0 Data:B/ 0
    480931 TSF:MSG:READ,0-0-10,s=1,c=3,t=16,pt=0,l=0,sg=1:
    480932 SGN:SKP:MSG CMD=3,TYPE=16
    480932 SGN:SGN:NREQ=0
    480948 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    480948 SGN:NCE:XMT,TO=10
    523178 SGN:SGN:NREQ=0
    523185 TSF:MSG:SEND,10-10-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:21.06
    523185 SGN:SGN:NREQ=0
    524598 TSF:MSG:SEND,10-10-0-0,s=2,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
    524598 SGN:SGN:NREQ=0
    527746 !TSF:MSG:SEND,10-10-0-0,s=5,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=NACK:-46
    TX Error 1
    527933 !SGN:BND:TMR
    528935 TSF:MSG:READ,0-0-10,s=5,c=1,t=37,pt=2,l=2,sg=0:-46
    528935 SGN:SKP:ACK CMD=1,TYPE=37
    528935 TSF:MSG:ACK
    +Ack FMGW
    *InMsgty :37 MsgComd:1 childID:5 Data:S/ Data:I/ -46 Data:B/ 0
    528935 SGN:SGN:NREQ=0
    529941 TSF:MSG:SEND,10-10-0-0,s=5,c=1,t=37,pt=2,l=2,sg=0,ft=1,st=OK:-46
    530141 SGN:SGN:NREQ=0
    533171 !TSF:MSG:SEND,10-10-0-0,s=7,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=NACK:
    533171 SGN:SGN:NREQ=0
    533177 TSF:MSG:SEND,10-10-0-0,s=7,c=2,t=47,pt=0,l=0,sg=0,ft=1,st=OK:
    534034 TSF:MSG:READ,0-0-10,s=7,c=3,t=16,pt=0,l=0,sg=1:
    534034 SGN:SKP:MSG CMD=3,TYPE=16
    534034 SGN:SGN:NREQ=0
    534045 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    534045 SGN:NCE:XMT,TO=10
    534875 TSF:MSG:READ,0-0-10,s=7,c=2,t=47,pt=0,l=13,sg=1:Nigel & Emma.
    534876 SGN:BND:NONCE=C998AAAA6856A8D375F6B5DC6AC0CCE8DF6482EA8EDF525B91AAAAAAAAAAAAAA
    534877 SGN:BND:HMAC=A3EF9AFD5F50A710D6D50A0ADA4F4391CA059E491050D972D996179144356451
    534877 SGN:VER:OK
    534877 SGN:SGN:NREQ=0
    534885 TSF:MSG:SEND,10-10-0-0,s=10,c=1,t=47,pt=0,l=13,sg=0,ft=0,st=OK:Nigel & Emma.
    536197 TSF:MSG:READ,0-0-10,s=10,c=1,t=47,pt=0,l=13,sg=0:Nigel & Emma.
    536197 SGN:SKP:ACK CMD=1,TYPE=47
    536197 TSF:MSG:ACK
    +Ack FMGW
    Kind Regards
    Nigel
