  3. Did you buy a Fibaro keyfob has it fallen to pieces? well this might interest you. A eight keys keyfob ip68 rated
4 Posts 1 Posters 2.2k Views 1 Watching
  • clivecC
    clivecC
    clivec
    Hi fellow mysensors people :)
    I have been working on a project , might need a bit of guidance to finish this off (with the sketch)
    Ok lets start with what I have been doing , plus some researching
    Right who of you purchased Fibaro_keyfob ??? that very reliable and ruggedized key fob
    well yes I did too , it was approx. 45 pounds how long did it last ?? hmm 12 months or so
    you also need a Aeotec_z-stick_gen5 to link it to domoticz .
    It might look nice,, but really in my option was not fit for purpose poor design
    at high price !!!.
    The Fibaro you have to use a large coin to open and replace the battery ,,,,the connectors inside well weak!! not long and its buggered .. oh I’ll go and buy another at 45 ponds naaaaa!!!!
    rinse and repeat every 12 months or so naaaa!!!!
    you also needed a Aeotec_z-stick_gen5 to connect to domoitcz. As said.
    Why would I do this since nowhere days we have voice control etc..
    well for me it’s a universal way of switching off quite few things at once etc,,
    So what was the alternative’s ???? ok
    Well firstly most key fobs I have found are only 4 keys I wanted few more than that
    in the end I came up with the key fob in first picture a ( rf solutions) key fob ip68 rated helpful might last past 12 months ,ok , now at this point I thought oh err use rflink to pick up signals job done But naaa it does not sense them , so if you want try this then rflick is not ganna cut it unfortunately .
    So then you need its receiver module ie ..>>>
    Telemetry module that in my case at 443mz frequency . be sure to get a receiver module that matches the key fobs transmitting frequency ( I did not need to tell you that did I :) )
    Ok so the second picture is of the receiver module really not that hard really!!! .
    My soldering will just about passes put quite a few caps in to stabilise the power as best as possible .
    As you can see the telemetry modules are on the left and the mysensors (2) on the right .
    I picked up a program from another project and modified it so that hopefully it would pick up four inputs on each unit
    mini pro The sketch presented here is the modified sketch with 4 inputs
    but one input works and the other inputs are temperamental
    any suggestions or guidance for interfacing this with modules would be nice .
    ** Oh these receiver units like 3.6 volts so keep the voltage down
    roughly 33 quid for key fob
    11 pounds for each receiver unit ,,,you will need 2 for the eight key fob unit
    ![alt text](![image url](screenshot.121.png image url))
    screenshot.124.png screenshot.123.png screenshot.122.png IMG_20211123_172604.jpg IMG_20211123_172559.jpg IMG_20211123_172548.jpg
    clivecC 1 Reply Last reply
    • clivecC clivec
      at high price !!!.
      clivecC
      clivecC
      clivec
      @mutantx
      I am seeming to have problems with the sketch ,heres is the modified sketch any guidance appreciated .
         DESCRIPTION
         Simple binary switch example updated  for 2 switches
         Connect button or door/window reed switch between
         digitial I/O pin 3 (BUTTON_PIN below) and GND.
         http://www.mysensors.org/build/binary
      #define CHILD_ID1 3
      #define BUTTON_PIN1  3  // Arduino Digital I/O pin for button/reed switch
      #define CHILD_ID2 4
      #define BUTTON_PIN2  4  // Arduino Digital I/O pin for button/reed switch
      #define CHILD_ID3 5
      #define BUTTON_PIN3  5  // Arduino Digital I/O pin for button/reed switch
      #define CHILD_ID4 6
      #define BUTTON_PIN4  6  // Arduino Digital I/O pin for button/reed switch
      Bounce debouncer1 = Bounce();
      Bounce debouncer2 = Bounce(); // debouncer for the second switch
      Bounce debouncer3 = Bounce(); // debouncer for the third switch
      Bounce debouncer4 = Bounce(); // debouncer for the forth switch
      int oldValue1= -1;
      int oldValue2= -1; // second switch needs to have it's own old state
      int oldValue3= -1; // second switch needs to have it's own old state
      int oldValue4= -1; // second switch needs to have it's own old state
      MyMessage msg1(CHILD_ID1,V_TRIPPED),msg2(CHILD_ID2,V_TRIPPED),msg3(CHILD_ID3,V_TRIPPED),msg4(CHILD_ID4,V_TRIPPED);
       // Setup the button
        pinMode(BUTTON_PIN1,INPUT_PULLUP ); // You can assign pinmode and use pullup in one statement.
        pinMode(BUTTON_PIN2,INPUT_PULLUP);
        pinMode(BUTTON_PIN3,INPUT_PULLUP);
        pinMode(BUTTON_PIN4,INPUT_PULLUP);
       // Activate internal pull-up
       // digitalWrite(BUTTON_PIN1,HIGH);
       // digitalWrite(BUTTON_PIN2,HIGH);
       // digitalWrite(BUTTON_PIN3,HIGH);
       // digitalWrite(BUTTON_PIN4,HIGH);
        // After setting up the button, setup debouncer1
        debouncer1.attach(BUTTON_PIN1);
        debouncer1.interval(5);
        debouncer2.attach(BUTTON_PIN2);
        debouncer2.interval(5);
        debouncer3.attach(BUTTON_PIN3);
        debouncer3.interval(5);
        debouncer4.attach(BUTTON_PIN4);
        debouncer4.interval(5);
        present(CHILD_ID1, S_DOOR);
        present(CHILD_ID2, S_DOOR);
        present(CHILD_ID3, S_DOOR);
        present(CHILD_ID4, S_DOOR);
        // Check if the first switch state has changed
        debouncer1.update();
        // Get the update value
        int value = debouncer1.read();
        if (value != oldValue1) {
           // Send in the new value
           send(msg1.set(value==HIGH ? 1 : 0));
      //     send(msg2.set(value==HIGH ? 1 : 0)); // this is where you turn the second switch in your controller
      //     send(msg3.set(value==HIGH ? 1 : 0));  // this is where you turn the third switch in your controller
           oldValue1 = value;
        // Check if the 2nd switch state has changed
        debouncer2.update();
        value = debouncer2.read(); // no need to redeclare it (I removed int)
        if (value != oldValue2) {
      //     send(msg1.set(value==HIGH ? 1 : 0));
           oldValue2 = value;
        // Check if the third switch state has changed
        debouncer3.update();
       value = debouncer3.read(); // no need to redeclare it (I removed int)
        if (value != oldValue3) {
           oldValue3 = value;
        // Check if the forth switch state has changed
        debouncer4.update();
       value = debouncer4.read(); // no need to redeclare it (I removed int)
        if (value != oldValue4) {
           send(msg4.set(value==HIGH ? 1 : 0));  // this is where you turn the forth switch in your controller
           oldValue4 = value;
      • clivecC
        clivecC
        clivec
        wrote on last edited by clivec
        Update !!!! all fixed and working with domoticz
        I used FOBBER-8T8 please google it approx. 20 quid compared to 45 pounds for fibaro keyfob
        A) updated the sketch to allow 4 inputs s all fine
        B) Symmetric really so from the top two pictures from the left the telemetry modules on the Vero board (total of 8 outputs ) passed across to two mysensors modules with 4 inputs on each unit I used 4016 cmos switches to pair outputs with inputs and It worked !!! .
        So the ip 68 keyfob transmits to the telemetry modules which then output to the inputs of the sensors that
        domoticz can pick up . add to blocky script can do what you want
        Any help with This would be much applicated
        https://forum.mysensors.org/topic/11886/and-for-my-next-trick-project-i-mean-m5stamp-pico-any-body-playing-with-these-yet-battery-operated-mp3-unit/2?_=1642356371902
        • clivecC
          clivecC
          clivec
          And here's the completed unit I have not really tested the range yet ,
          but should be good , the receiver units (telemetry units) can work in latching mode and in push button mode easy
          I am pretty sure this setup will last longer than fibrio key fob , easy to pair receiver with key fob
          I have 3 key fobs ,, yes why ??? well they will break and I rather purchase few ,for an investment for the future
          Maybe some can help me with other project the stamp m5 pico trying to program it is a standard switch node
