  3. Multi Button Relay switch
43 Posts 13 Posters 30.3k Views 8 Watching
  • T Terence Faul
    @BulldogLowell
    This new one had the relays correct, but the buttons did not work. I compared the old with the new and below now works.
    Thanks again a million for all the help
    #define RELAY_ON 0
    #define RELAY_OFF 1
    const int relayPin[] = {7, 8, A0, A1};
    const int buttonPin[sizeof(relayPin) / sizeof(relayPin[0])] = {3, 4, 5, 6};
    byte oldValue[sizeof(relayPin) / sizeof(relayPin[0])];
    boolean relayState[sizeof(relayPin) / sizeof(relayPin[0])];
    Bounce debouncer[sizeof(relayPin) / sizeof(relayPin[0])];
    MyMessage msg[sizeof(relayPin) / sizeof(relayPin[0])];//(sensor,type);
      gw.begin(incomingMessage, AUTO, false);
      // or you can try:
      // gw.begin(incomingMessage, <Your_Node_ID>, false); // where Your_Node_ID is a number from 1 to 254
      delay(250);
      gw.sendSketchInfo("MultiRelayButton", "0.9b");// <<<<<<<<<<<<<<<<<<< I forgot this, here
      delay(250);
      for (int i = 0; i < sizeof(relayPin) / sizeof(relayPin[0]); i++)
        msg[i].sensor = i;
        msg[i].type = V_LIGHT;
        debouncer[i] = Bounce();
        debouncer[i].interval(5);
        pinMode(buttonPin[i], INPUT_PULLUP);
        digitalWrite(relayPin[i], LOW);
        pinMode(relayPin[i], OUTPUT);
        gw.present(i, S_LIGHT); // <<<<<<<<<<<<<<<<<<<<<<< I fixed this too...
        delay(250);
      //retreive from EEPROM last states
        relayState[i] = gw.loadState(i);
        digitalWrite(relayPin[i], relayState[i]? RELAY_ON : RELAY_OFF);
        gw.send(msg[i].set(relayState[i]? true : false), true);
        delay(250);
      for (byte i = 0; i < sizeof(relayPin) / sizeof(relayPin[0]); i++)
        debouncer[i].update();
        byte value = debouncer[i].read();
        if (value != oldValue[i] && value == 0)
          relayState[i] = !relayState[i];
          digitalWrite(relayPin[i], relayState[i]);
        oldValue[i] = value;
    void incomingMessage(const MyMessage &message)
      if (message.isAck())
      for (byte i = 0; i< sizeof(relayPin) / sizeof(relayPin[0]); i++)
        if (message.sensor == i)
          if (message.type == V_LIGHT)
            relayState[i] = message.getBool();
            gw.saveState(relayPin[i], relayState[i]);
    Terence Faul
    wrote on last edited by Terence Faul
    @Terence-Faul
    Only one other thing.
    I notice that when the sensor starts up, each of the relays turn on and then off.
    This ia all good and well, however i assume in practice this would mean what ever is connected to them will turn on and off as well in the initialisation phase.
    Also I assume that retrieve from EEPROM means that if the sensor loses power while a relay is on, when it powers up this relay will return to the on state?
    Can you point me to to code that controls this, if these are lights and the power goes out a better option may be to have the relays all start in the off position so that the lights do not come on in the middle of the night
    Is this correct?
    • T
      Terence Faul
      Bulldog
      So this is as far as I got.
      Managed to get the relays to start in the off position by Changing LOW for the defined RELAY_OFF.
      Commented out the EEPROM Section and now when the sensor reboots is starts with all relays in off position.
      I do not know how to change the EEPROM section I am sur I need to maybe include the RELAY_OFF somewhere in that line.
      #define RELAY_ON 0  //switch around for realy HIGH/LOW state
      #define RELAY_OFF 1
        // or you can try:
        delay(250);
        delay(250);
          msg[i].sensor = i;
          digitalWrite(relayPin[i], RELAY_OFF); //Start State of Relays
          delay(250);
      //  for (int i = 0; i < sizeof(relayPin) / sizeof(relayPin[0]); i++)//>>>>>>> I'm sure that this is causing all relays to turn on and off at startup
      //    relayState[i] = gw.loadState(i);
      //    digitalWrite(relayPin[i], relayState[i]? RELAY_ON:RELAY_OFF);
      //    gw.send(msg[i].set(relayState[i]? true : false), true);
      //    delay(250);
      • T Terence Faul
        Bulldog
        #define RELAY_OFF 1
          // or you can try:
          delay(250);
          delay(250);
            msg[i].sensor = i;
            delay(250);
        //    delay(250);
        BulldogLowellB
        BulldogLowellB
        BulldogLowell
        if you are not relying on settings saved to EEPROM to recover its state after a power cycle, you can also comment our or remove this line:
        it saves the state of the relay each time it gets changed.
        glad to see you are learning and have it working just the way you like.
        • T
          Terence Faul
          Thanks a stack, it is slow.
          If I did want to restore the relay state how would I change the code?
          At the moment if I leave that code in when the arduino boots it cycles each relay on and then off, instead of just restoring the previous state
          • A
            Anthony Straw
            go for SSR instead of hk mechical relay it will stop working after 10,000 clicked ... cheap brand
            • jeylitesJ
              jeylitesJ
              jeylites
              I got the same question as @Terence-Faul, How to change the code to have the Relay to restore its previous state. I tried a couple of things but can't seem to get it to work. Thanks @BulldogLowell for the script !
              • BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @jeylites ,
                so, try to look over the example just above the one that worked for @Terence-Faul
                It included saving states to EEPROM and retrieving them in setup( ).
                • C
                  C
                  C.r.a.z.y.
                  How do you seperate relay power?
                  What is your solution to drop 220v AC to 5v DC?
                  jeylitesJ 1 Reply Last reply
                  • C C.r.a.z.y.
                    jeylitesJ
                    jeylitesJ
                    jeylites
                    @C.r.a.z.y. You could get a USB power adapter... see Ebay link below. On my current setup, I'm using a 2.1A+1A Dual USB 2-Ports. I use the the 1A port for the Arduino and the 2.1A port for the relays. On the relay board, you have VCC, IN1 & GND. IN1 gets connected to the Arduino, VCC to the second power supply or power port. The GND is shared between both power ports. Hope that helps!
                    http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2141725.m570.l1313.TR12.TRC2.A0.H0.XUSB+Wall+Charger+.TRS0&_nkw=USB+Wall+Charger+&ghostText=&_sacat=0
                    • jeylitesJ jeylites
                      jeylitesJ
                      jeylitesJ
                      jeylites
                      wrote on last edited by jeylites
                      @BulldogLowell
                      I have gone through the script like 8 times with no luck at all. Are you suggesting the mistake in in the EEPROM retrieval section ?
                      #define RELAY_ON 1 //switch around for realy HIGH/LOW state
                      #define RELAY_OFF 0
                      // or you can try:
                      delay(250);
                      delay(250);
                      msg[i].sensor = i;
                      delay(250);
                      //gw.send(msg[i].set(relayState[i]? true : false), true);
                      delay(250);
                      #define RELAY_OFF 0
                        // or you can try:
                        delay(250);
                        delay(250);
                          msg[i].sensor = i;
                          delay(250);
                          delay(250);
                      AWIA 1 Reply Last reply
                        @BulldogLowell
                        #define RELAY_OFF 0
                        // or you can try:
                        delay(250);
                        delay(250);
                        msg[i].sensor = i;
                        delay(250);
                        delay(250);
                        #define RELAY_OFF 0
                          // or you can try:
                          delay(250);
                          delay(250);
                            msg[i].sensor = i;
                            delay(250);
                            delay(250);
                        AWIA
                        AWIA
                        AWI
                        @jeylites You are initializing the relays with the "Start State of Relays" and afterwards with the state from EEPROM. That could cause the on/off switching at startup.
                        • ChaoticC
                          ChaoticC
                          Chaotic
                          You have both of those lines in your Setup() The first one is setting the relay to off the second one is checking the EEPROM value
                          Remove the first one and the problems should be fixed (assuming the EEPROM data is correct.
                          • ChaoticC Chaotic
                            jeylitesJ
                            jeylitesJ
                            jeylites
                            @Chaotic , @AWI
                            //digitalWrite(relayPin[i], RELAY_OFF); //Start State of Relays
                            I did as you say and removed the above line but still no luck. The relay turns on/off on every start up. And it doesn't hold the last state. I compared My Sensor's script with Bulldogs's and found lots of similarities but can't seem to find the fault.
                              @Chaotic , @AWI
                              AWIA
                              AWIA
                              AWI
                              wrote on last edited by AWI
                              #24
                              @jeylites I took a deeper look at your sketch and think I found the cause. You are writing and reading from different EEPROM locations. The "standard" way is to use the "Sensor number" as location reference. Whereas the sketch also used "relayPin[i]" to store values. I took the liberty of adapting your sketch as I found it hard to read. Also added storing the value in EEPROM after pushing a button.
                              I have not build the circuit so were not able to test it in real life :) Have fun and let me know if it worked for you.
                              https://codebender.cc/sketch:92964
                              • AWIA AWI
                                jeylitesJ
                                jeylitesJ
                                jeylites
                                #25
                                @AWI Thank you so much. This is awesome! I bet so many people is going to benefit from this script.
                                I had some time off today and ran the script. It didn't work the fist time, but I made some minor changes to "Relay_ON & Relay_OFF and also activated " Start State of Relays" and it worked. I'm guessing it didn't the first time because my relays are Active Low.
                                Also, while toying around with it, I realize that it doesn't send back the status of the relay & actuator to the Controller (Homeseer). On Homeseer, suppose you have it at “ON” there is a maker that indicates its state and vice versa. I noticed that worked on Binary Switch & Motion Sensor but not on Relay & Relay Button Actuator sketch. Don't know if it's a script or Homeseer issue though.
                                Again, thanks, everyone who helped pointing out the problem. I'm new to My Sensor and I'm glad to be here and making progress.
                                #define RELAY_ON 0 //switch around for relay HIGH/LOW state
                                #define RELAY_OFF 1
                                  #define RELAY_OFF 1
                                  jeylitesJ
                                  jeylitesJ
                                  jeylites
                                  #26
                                  @AWI I just realize another thing. The is a long delay for the sensor to sends its presentation during inclusion mode. Is there something to do with the number of sensors in one node or sketch? Essentially, I would have to reset the sensor several times to get it discovered.
                                  It's pretty quick on a single or double sensor node.
                                    AWIA
                                    AWIA
                                    AWI
                                    @jeylites I don't have experience with Homeseer as controller.and don't fully understand your questions, so just give it a shot..
                                    The multi relay sketch is firing a large amount of messages to the gateway/ controller during presentation. If you have transmission problems and/or a slow controller it could get into trouble. I suggest you monitor on the serial port of the sensor if there are "fail" messages. (need to turn on DEBUG = default) If there are it could be a power problem or...
                                    The real fun (and headache) is in the debugging :) The serial monitor can give you lost of clues
                                    Depending on how long is "long". there are also 250 ms delays between the individual presentations of the relays. ..'
                                    have fun ;)
                                    • AWIA AWI
                                      have fun ;)
                                      jeylitesJ
                                      jeylitesJ
                                      jeylites
                                      @AWI
                                      I think you're right on the controller. I've been getting some glitch running HS3 on Mac. I don't know if its a plugin or software issue, but I will like to get to the bottom of it. In addition, a buddy of mine is loaning his Vera edge so I might run some test on that too.
                                      Meanwhile, will take your advice on serial monitor and will let you know the outcome. Cheers!
                                      • Q
                                        Q
                                        quocanhcgd
                                        Thanks for sharing.
                                        I have a problem with this scripts. My relay auto start then off every gateway check node. How can i fix it?
                                        • jeylitesJ
                                          jeylitesJ
                                          jeylites
                                          @quocanhcgd
                                          You will need to activate this line pinMode(Relays[i].relayPin, OUTPUT);
                                          It should work right after.
                                          Q 1 Reply Last reply
