Rain Guage
@BulldogLowell I also busy building an rain gauge. How is your one performing? Now did you set this up in the arduino? How did you do the calculation?
Regards
Francois
yes is working still, I mentioned how I did the math above...
@BulldogLowell do you mind sharing the sketch I not seeing in this forum or on the Build pages of MySensor.org
Sure, but I have that running at my 'other' house and it is on older version of MySensors (haven't upgraded there yet ;)
I'll take a whack at updating if you like... it needs to get done anyway... here it is:
/* Arduino Tipping Bucket Rain Gauge June 15, 2014 Version 1.00b Arduino Tipping Bucket Rain Gauge Utilizing a tipping bucket sensor, your Vera home automation controller and the MySensors.org gateway you can measure and sense local rain. This sketch will create two devices on your Vera controller. One will display your total precipitation for the last 24, 48, 72, 96 and 120 hours. The other, a sensor that changes state if there is recent rain (up to last 120 hours) above a threshold. Both these settings are user definable. This sketch features the following: * Allows you to set the rain threshold in mm * Allows you to determine the interval window up to 120 hours. * Displays the last 24, 48, 72, 96 and 120 hours total rain in Variable1 through Variable5 of the Rain Sensor device * Configuration changes to Sensor device updated every 3 hours. * SHould run on any Arduino * Will retain Tripped/Not Tripped status and data in a power outage, saving small ammount of data to EEPROM (Circular Buffer to maximize life of EEBPROM * There is a unique setup requirement necessary in order to properly present the Vera device variables. The details are outlined in the sketch below. * LED status indicator by BulldogLowell@gmail.com for free public use */ #include <SPI.h> #include <EEPROM.h> #include <RF24.h> #include <Sensor.h> // #define STATE_LOCATION 513 // stay away from EEPROM used with Sensor.h #define EEPROM_BUFFER 514 // location of the EEPROM circular buffer #define BUFFER_LENGTH 121 // Sensor gw; boolean metric = false; // int eepromIndex; int tipSensorPin = 3; int ledPin = 5; //PWM capable required unsigned long dataMillis; unsigned long serialInterval = 10000UL; const unsigned long oneHour = 60000UL; unsigned long lastTipTime; unsigned long lastBucketInterval; unsigned long startMillis; int dayBuckets [5] [2] = { { V_VAR1, 24 }, { V_VAR2, 48 }, { V_VAR3, 72 }, { V_VAR4, 96 }, { V_VAR5, 120}, }; volatile byte rainBucket [120] ; // 5 days of data const unsigned long calibrateFactor = 1UL; //Calibration in milimeters of rain per single tip unsigned long rainRate = 0; float currentRain = 0; boolean wasTipped = false; boolean updateVera; int rainCount; volatile int tipBuffer = 0; byte rainWindow = 72;//default rain window in hours int rainSensorThreshold = 15;//default rain sensor sensitivity in mm byte hourCount = 24; byte state; byte oldState = -1; unsigned long ledPulseTime = 500UL; unsigned long pulseStart; // void setup() { Serial.begin(115200); gw.begin(); // pinMode(tipSensorPin, OUTPUT); attachInterrupt (1, sensorTipped, CHANGE); pinMode(ledPin, OUTPUT); digitalWrite(ledPin, HIGH); gw.sendSketchInfo("Rain Guage", "1.00b"); gw.sendSensorPresentation(1, S_RAIN); gw.sendSensorPresentation(2, S_MOTION); Serial.println(F("Sensor Presentation Complete")); pinMode(tipSensorPin, INPUT); // state = EEPROM.read(STATE_LOCATION); for (int i = 0; i < BUFFER_LENGTH; i++) { byte locator = EEPROM.read(EEPROM_BUFFER + i); if (locator == 0xFF) { eepromIndex = EEPROM_BUFFER + i; loadRainArray(eepromIndex); Serial.println(eepromIndex); break; } } // gw.sendVariable(2, V_TRIPPED, state); dataMillis = millis(); startMillis = millis(); lastTipTime = millis() - oneHour; // uncomment the following block the first time you include this device. The delays // are necessary in order to create the five Variable buckets in the correct order. // Once you create them, you can comment out these lines and re-upload to your arduino //------------------------------------------------------ /* for (int j = 0; j < 5; j++) { delay(2000); gw.sendVariable(1, dayBuckets[j] [0], 1); } delay(2000); gw.sendVariable(2,V_VAR1, 1); delay(2000); gw.sendVariable(2,V_VAR2, 1); */ //------------------------------------------------------ rainWindow = atoi(gw.getStatus(2, V_VAR1)); delay(2000); rainSensorThreshold = atoi(gw.getStatus(2, V_VAR2)); gw.sendVariable(1, V_RAINRATE, 0); Serial.print(F("Radio Done")); analogWrite(ledPin, 20); } // void loop() { unsigned long measure = 0; // Check to see if we need to show sensor tripped in this block for (int i = 0; i < rainWindow; i++) { measure = measure + rainBucket [i]; } measure >= rainSensorThreshold ? state = 1: state = 0; if (millis() - pulseStart < ledPulseTime) { analogWrite(ledPin, 255); } else { analogWrite(ledPin, 20); } if (state != oldState) { gw.sendVariable(2, V_TRIPPED, state); EEPROM.write(STATE_LOCATION, state); oldState = state; } // if (millis() - lastTipTime >= oneHour)// timeout for rain rate { if (rainRate != 0) { rainRate = 0; gw.sendVariable(1, V_RAINRATE, rainRate); } } if (updateVera) { gw.sendVariable(1, V_RAINRATE, rainRate); updateVera = false; } // if ( (millis() - dataMillis) >= serialInterval)//Comment back in this block to enable Serial prints { for (int i = 24; i <= 120; i=i+24) { updateSerialData(i); } dataMillis = millis(); } // if (tipBuffer > 0) { Serial.println(F("Sensor Tipped")); rainBucket [0] ++; pulseStart = millis(); if (rainBucket [0] > 253) rainBucket[0] = 253; // odd occurance but prevent overflow int dayTotal = 0; for (int i = 0; i < 24; i++) { dayTotal = dayTotal + rainBucket [i]; } gw.sendVariable(1, V_RAIN, dayTotal); unsigned long tipDelay = millis() - lastTipTime; if (tipDelay <= oneHour) { rainRate = ((oneHour) / tipDelay); gw.sendVariable(1, V_RAINRATE, rainRate); Serial.print(F("RainRate= ")); Serial.println(rainRate); } lastTipTime = millis(); updateVera = true; tipBuffer--; } if ( (millis()- startMillis) >= oneHour) { Serial.println("one hour elapsed"); //EEPROM write last value EEPROM.write(eepromIndex, rainBucket[0]); eepromIndex++; if (eepromIndex > EEPROM_BUFFER + BUFFER_LENGTH) eepromIndex = EEPROM_BUFFER; Serial.println(eepromIndex); EEPROM.write(eepromIndex, 0xFF); // for (int i = BUFFER_LENGTH - 1; i >= 0; i--)//cascade an hour of values { rainBucket [i + 1] = rainBucket [i]; } rainBucket[0] = 0; gw.sendVariable(1, V_RAIN, tipCounter(24));// send 24hr tips startMillis = millis(); for (int j = 0; j < 5; j++) { int total = 0; for (int i = 0; i < dayBuckets[j][1]; i++) { total = total + rainBucket [i]; } gw.sendVariable( 1, dayBuckets[j] [0], total); } hourCount++; if (hourCount >=3)//8 times daily update the Sensor variables { rainWindow = atoi(gw.getStatus(2, V_VAR1)); if (rainWindow < 6) { rainWindow = 6; gw.sendVariable( 2, V_VAR1, rainWindow); } if (rainWindow > 120) { rainWindow = 120; gw.sendVariable( 2, V_VAR2, rainWindow); } rainSensorThreshold = atoi(gw.getStatus(2, V_VAR2)); delay(2000); // if (rainSensorThreshold < 1) { rainSensorThreshold = 1; gw.sendVariable( 2, V_VAR2, rainSensorThreshold); } if (rainSensorThreshold > 1000) { rainSensorThreshold = 1000; gw.sendVariable( 2, V_VAR2, rainSensorThreshold); } // hourCount = 0; } } } // void sensorTipped() { static unsigned long last_interrupt_time = 0; unsigned long interrupt_time = millis(); if (interrupt_time - last_interrupt_time > 200) { tipBuffer++; } last_interrupt_time = interrupt_time; } // unsigned long tipCounter(int x) { int tipCount = 0; for ( int i = 0; i < x; i++) { tipCount = tipCount + rainBucket [i]; } return tipCount; } // void updateSerialData(int x) { Serial.print(F("Tips last ")); Serial.print(x); Serial.print(F("hours: ")); int tipCount = 0; for (int i = 0; i < x; i++) { tipCount = tipCount + rainBucket [i]; } Serial.println(tipCount); } void loadRainArray(int value) { for (int i = 0; i < BUFFER_LENGTH - 1; i++) { value--; Serial.println(value); if (value < EEPROM_BUFFER) { value = EEPROM_BUFFER + BUFFER_LENGTH; } byte rainValue = EEPROM.read(value); Serial.println(rainValue); if (rainValue < 255) { rainBucket[i] = rainValue; } else { rainBucket [i] = 0; } } } -
Hey Francois
Thanks for a nice projekt. I am thinking on building one myself. But is it possible to log the rain for everyday and writing the data to a csv file so I can use the data in Excel on Windows.
Hope that you can help my.
Tom
Tom,
Are you wishing to
- log to an SD card
- collect data controller side (e.g. Vera or other controller)
- transmit data directly to a server
- something else....?
@BulldogLowell said:
#define STATE_LOCATION 513 // stay away from EEPROM used with Sensor.h #define EEPROM_BUFFER 514 // location of the EEPROM circular buffer #define BUFFER_LENGTH 121are we still required to steer clear of MySensor's EEPROM in addresses 0-512?
Neodymium magnet in and works fine. I had to clean out the countersink hole with a drill to get it in and used E6000 glue to hold it.
Now onto the hall effect sensor, wiring it up and of course the sketch.
The 123D Design file is also attached if anyone wants to make one, play with the design, make fun of it, etc. The .stl file is 13Mb, I can email that if you want.
If you want a print, let me know. I also have a few magnets and sensors, so I can send what you need for the project.
I think I'm going to design a housing for the electronics too. I'm not sure I can find the right project box for this (I really just want to print more parts :)
Hi!!
I was searching for a long time in internet any place where someone offers a design of this mechanism of rain gauge. Finally I've found you!. I really interested in having one, but I don't have a 3D (not jet!). Could you provide me one print? Let me know how is the process to get one, please ! (I am in Spain!)
Thank you
Hi!!
Thank you
I actually used www.3dhubs.com which I believe is a Dutch company. I looked, they have service in Spain!
the service connects you with owners of 3D printers who make money using their personal machines.
@nostradamux I had one printed using @BulldogLowell design and thru 3Dhubs.com the build was good and I used abs also for material. My cost in USA was approx. $17 usd and took a day to print and receive, looks good.
However I have not gotten far with project due to other issues unrealated just with I had more time and experience.But this group is most helpful for newbies!
Good luck -
@BulldogLowell could you convert your 123D file to STL so that the 3DHub could be used please ?
this is how to do it:
http://sitesupport.123dapp.com/entries/20540436-How-to-export-an-STL-file-for-3D-printing-in-123Dthanks,
exceeds max file size, so here is a link:
https://drive.google.com/file/d/0B3KGTJHUgpw1MVpaYnUyUDUwN0E/view?usp=sharing
Sorry for the lag time, I've been on Easter vacation with the family!
Yes, I did update it, but I don't have my laptop with me here. I'll post it when I return home, early next week.
@BulldogLowell Any luck finding the sketch? Sorry to bug you, I was just hoping to get this project completed soon so I can work on the irrigation controller next. It's almost time to start watering the lawn/plants... Thanks!
@petewill
I am embarrassed to tell you that after updating my arduino software a while back, I cannot locate a compilable sketch!I have Time Machine, but still can't find it... and it is running on my rain guage!!!
Here is a version that I have (which is titled RainGuage_V1.4.1.ino in my directory) which i found but cannot compile, it looks like a first save without edit?
I need to completely update Arduino, the version and mySensors but please look at this:
/* Arduino Tipping Bucket Rain Gauge June 15, 2014 Version 1.00b Arduino Tipping Bucket Rain Gauge Utilizing a tipping bucket sensor, your Vera home automation controller and the MySensors.org gateway you can measure and sense local rain. This sketch will create two devices on your Vera controller. One will display your total precipitation for the last 24, 48, 72, 96 and 120 hours. The other, a sensor that changes state if there is recent rain (up to last 120 hours) above a threshold. Both these settings are user definable. This sketch features the following: * Allows you to set the rain threshold in mm * Allows you to determine the interval window up to 120 hours. * Displays the last 24, 48, 72, 96 and 120 hours total rain in Variable1 through Variable5 of the Rain Sensor device * Configuration changes to Sensor device updated every 3 hours. * SHould run on any Arduino * Will retain Tripped/Not Tripped status and data in a power outage, saving small ammount of data to EEPROM (Circular Buffer to maximize life of EEBPROM * There is a unique setup requirement necessary in order to properly present the Vera device variables. The details are outlined in the sketch below. * LED status indicator by BulldogLowell@gmail.com for free public use */ #include <SPI.h> #include <EEPROM.h> #include <RF24.h> #include <Sensor.h> // #define STATE_LOCATION 513 // stay away from EEPROM used with Sensor.h #define EEPROM_BUFFER 514 // location of the EEPROM circular buffer #define BUFFER_LENGTH 121 // Sensor gw; boolean metric = false; // int eepromIndex; int tipSensorPin = 3; int ledPin = 5; //PWM capable required unsigned long dataMillis; unsigned long serialInterval = 10000UL; const unsigned long oneHour = 60000UL; unsigned long lastTipTime; unsigned long lastBucketInterval; unsigned long startMillis; int dayBuckets [5] [2] = { { V_VAR1, 24 }, { V_VAR2, 48 }, { V_VAR3, 72 }, { V_VAR4, 96 }, { V_VAR5, 120}, }; volatile byte rainBucket [120] ; // 5 days of data const unsigned long calibrateFactor = 1UL; //Calibration in milimeters of rain per single tip unsigned long rainRate = 0; float currentRain = 0; boolean wasTipped = false; boolean updateVera; int rainCount; volatile int tipBuffer = 0; byte rainWindow = 72;//default rain window in hours int rainSensorThreshold = 15;//default rain sensor sensitivity in mm byte hourCount = 24; byte state; byte oldState = -1; unsigned long ledPulseTime = 500UL; unsigned long pulseStart; // void setup() { Serial.begin(115200); gw.begin(); // pinMode(tipSensorPin, OUTPUT); attachInterrupt (1, sensorTipped, CHANGE); pinMode(ledPin, OUTPUT); digitalWrite(ledPin, HIGH); gw.sendSketchInfo("Rain Guage", "1.00b"); gw.sendSensorPresentation(1, S_RAIN); gw.sendSensorPresentation(2, S_MOTION); Serial.println(F("Sensor Presentation Complete")); pinMode(tipSensorPin, INPUT); // state = EEPROM.read(STATE_LOCATION); for (int i = 0; i < BUFFER_LENGTH; i++) { byte locator = EEPROM.read(EEPROM_BUFFER + i); if (locator == 0xFF) { eepromIndex = EEPROM_BUFFER + i; loadRainArray(eepromIndex); Serial.println(eepromIndex); break; } } // gw.sendVariable(2, V_TRIPPED, state); dataMillis = millis(); startMillis = millis(); lastTipTime = millis() - oneHour; // uncomment the following block the first time you include this device. The delays // are necessary in order to create the five Variable buckets in the correct order. // Once you create them, you can comment out these lines and re-upload to your arduino //------------------------------------------------------ /* for (int j = 0; j < 5; j++) { delay(2000); gw.sendVariable(1, dayBuckets[j] [0], 1); } delay(2000); gw.sendVariable(2,V_VAR1, 1); delay(2000); gw.sendVariable(2,V_VAR2, 1); */ //------------------------------------------------------ rainWindow = atoi(gw.getStatus(2, V_VAR1)); delay(2000); rainSensorThreshold = atoi(gw.getStatus(2, V_VAR2)); gw.sendVariable(1, V_RAINRATE, 0); Serial.print(F("Radio Done")); analogWrite(ledPin, 20); } // void loop() { unsigned long measure = 0; // Check to see if we need to show sensor tripped in this block for (int i = 0; i < rainWindow; i++) { measure = measure + rainBucket [i]; } measure >= rainSensorThreshold ? state = 1: state = 0; if (millis() - pulseStart < ledPulseTime) { analogWrite(ledPin, 255); } else { analogWrite(ledPin, 20); } if (state != oldState) { gw.sendVariable(2, V_TRIPPED, state); EEPROM.write(STATE_LOCATION, state); oldState = state; } // if (millis() - lastTipTime >= oneHour)// timeout for rain rate { if (rainRate != 0) { rainRate = 0; gw.sendVariable(1, V_RAINRATE, rainRate); } } if (updateVera) { gw.sendVariable(1, V_RAINRATE, rainRate); updateVera = false; } // if ( (millis() - dataMillis) >= serialInterval)//Comment back in this block to enable Serial prints { for (int i = 24; i <= 120; i=i+24) { updateSerialData(i); } dataMillis = millis(); } // if (tipBuffer > 0) { Serial.println(F("Sensor Tipped")); rainBucket [0] ++; pulseStart = millis(); if (rainBucket [0] > 253) rainBucket[0] = 253; // odd occurance but prevent overflow int dayTotal = 0; for (int i = 0; i < 24; i++) { dayTotal = dayTotal + rainBucket [i]; } gw.sendVariable(1, V_RAIN, dayTotal); unsigned long tipDelay = millis() - lastTipTime; if (tipDelay <= oneHour) { rainRate = ((oneHour) / tipDelay); gw.sendVariable(1, V_RAINRATE, rainRate); Serial.print(F("RainRate= ")); Serial.println(rainRate); } lastTipTime = millis(); updateVera = true; tipBuffer--; } if ( (millis()- startMillis) >= oneHour) { Serial.println("one hour elapsed"); //EEPROM write last value EEPROM.write(eepromIndex, rainBucket[0]); eepromIndex++; if (eepromIndex > EEPROM_BUFFER + BUFFER_LENGTH) eepromIndex = EEPROM_BUFFER; Serial.println(eepromIndex); EEPROM.write(eepromIndex, 0xFF); // for (int i = BUFFER_LENGTH - 1; i >= 0; i--)//cascade an hour of values { rainBucket [i + 1] = rainBucket [i]; } rainBucket[0] = 0; gw.sendVariable(1, V_RAIN, tipCounter(24));// send 24hr tips startMillis = millis(); for (int j = 0; j < 5; j++) { int total = 0; for (int i = 0; i < dayBuckets[j][1]; i++) { total = total + rainBucket [i]; } gw.sendVariable( 1, dayBuckets[j] [0], total); } hourCount++; if (hourCount >=3)//8 times daily update the Sensor variables { rainWindow = atoi(gw.getStatus(2, V_VAR1)); if (rainWindow < 6) { rainWindow = 6; gw.sendVariable( 2, V_VAR1, rainWindow); } if (rainWindow > 120) { rainWindow = 120; gw.sendVariable( 2, V_VAR2, rainWindow); } rainSensorThreshold = atoi(gw.getStatus(2, V_VAR2)); delay(2000); // if (rainSensorThreshold < 1) { rainSensorThreshold = 1; gw.sendVariable( 2, V_VAR2, rainSensorThreshold); } if (rainSensorThreshold > 1000) { rainSensorThreshold = 1000; gw.sendVariable( 2, V_VAR2, rainSensorThreshold); } // hourCount = 0; } } } // void sensorTipped() { static unsigned long last_interrupt_time = 0; unsigned long interrupt_time = millis(); if (interrupt_time - last_interrupt_time > 200) { tipBuffer++; } last_interrupt_time = interrupt_time; } // unsigned long tipCounter(int x) { int tipCount = 0; for ( int i = 0; i < x; i++) { tipCount = tipCount + rainBucket [i]; } return tipCount; } // void updateSerialData(int x) { Serial.print(F("Tips last ")); Serial.print(x); Serial.print(F("hours: ")); int tipCount = 0; for (int i = 0; i < x; i++) { tipCount = tipCount + rainBucket [i]; } Serial.println(tipCount); } void loadRainArray(int value) { for (int i = 0; i < BUFFER_LENGTH - 1; i++) { value--; Serial.println(value); if (value < EEPROM_BUFFER) { value = EEPROM_BUFFER + BUFFER_LENGTH; } byte rainValue = EEPROM.read(value); Serial.println(rainValue); if (rainValue < 255) { rainBucket[i] = rainValue; } else { rainBucket [i] = 0; } } }I will convert this this weekend.
Her is an untested go at it, and a very down and dirty update... I will test it probably Wednesday night, when I am back home. Let me know if you can!
/* Arduino Tipping Bucket Rain Gauge April 26, 2015 Version 1.01b for MySensors version 1.4.1 Arduino Tipping Bucket Rain Gauge Utilizing a tipping bucket sensor, your Vera home automation controller and the MySensors.org gateway you can measure and sense local rain. This sketch will create two devices on your Vera controller. One will display your total precipitation for the last 24, 48, 72, 96 and 120 hours. The other, a sensor that changes state if there is recent rain (up to last 120 hours) above a threshold. Both these settings are user definable. This sketch features the following: * Allows you to set the rain threshold in mm * Allows you to determine the interval window up to 120 hours. * Displays the last 24, 48, 72, 96 and 120 hours total rain in Variable1 through Variable5 of the Rain Sensor device * Configuration changes to Sensor device updated every 3 hours. * SHould run on any Arduino * Will retain Tripped/Not Tripped status and data in a power outage, saving small ammount of data to EEPROM (Circular Buffer to maximize life of EEPROM) * There is a unique setup requirement necessary in order to properly present the Vera device variables. The details are outlined in the sketch below. * LED status indicator by BulldogLowell@gmail.com for free public use */ #include <SPI.h> #include <MySensor.h> #include <EEPROM.h> #define RADIO_ID 99 #define STATE_LOCATION 513 // stay away from EEPROM used with Sensor.h #define EEPROM_BUFFER 514 // location of the EEPROM circular buffer #define BUFFER_LENGTH 121 // buffer plus the current hour // MySensor gw; // MyMessage msgRainRate(1, V_RAINRATE); MyMessage msgRain(1, V_RAIN); MyMessage msgRainVAR1(1, V_VAR1); MyMessage msgRainVAR2(1, V_VAR2); MyMessage msgRainVAR3(1, V_VAR3); MyMessage msgRainVAR4(1, V_VAR4); MyMessage msgRainVAR5(1, V_VAR5); MyMessage msgTripped(2, S_MOTION); MyMessage msgTrippedVar1(2, V_VAR1); MyMessage msgTrippedVar2(2, V_VAR2); // boolean metric = false; // int eepromIndex; int tipSensorPin = 3; int ledPin = 5; //PWM capable required unsigned long dataMillis; unsigned long serialInterval = 10000UL; const unsigned long oneHour = 60000UL; unsigned long lastTipTime; unsigned long lastBucketInterval; unsigned long startMillis; int dayBuckets [5] [2] = { { V_VAR1, 24 }, { V_VAR2, 48 }, { V_VAR3, 72 }, { V_VAR4, 96 }, { V_VAR5, 120}, }; volatile byte rainBucket [120] ; // 5 days of data const unsigned long calibrateFactor = 1UL; //Calibration in milimeters of rain per single tip unsigned long rainRate = 0; float currentRain = 0; boolean wasTipped = false; boolean updateVera; int rainCount; volatile int tipBuffer = 0; byte rainWindow = 72; //default rain window in hours int rainSensorThreshold = 15; //default rain sensor sensitivity in mm byte hourCount = 24; byte state; byte oldState = -1; // void setup() { Serial.begin(115200); gw.begin(getVariables, RADIO_ID); // pinMode(tipSensorPin, OUTPUT); attachInterrupt (1, sensorTipped, CHANGE); pinMode(ledPin, OUTPUT); digitalWrite(ledPin, HIGH); gw.sendSketchInfo("Rain Guage", "1.01b"); gw.present(1, S_RAIN); gw.present(2, S_MOTION); Serial.println(F("Sensor Presentation Complete")); pinMode(tipSensorPin, INPUT); // state = EEPROM.read(STATE_LOCATION); //retreive prior state from EEPROM gw.send(msgTripped.set(state), false); //send state to Vera delay(250); // recharge the capacitor // boolean isDataOnEeprom = false; for (int i = 0; i < BUFFER_LENGTH; i++) { byte locator = EEPROM.read(EEPROM_BUFFER + i); if (locator == 0xFF) // found the EEPROM circular buffer index { eepromIndex = EEPROM_BUFFER + i; loadRainArray(eepromIndex); isDataOnEeprom = true; Serial.println(eepromIndex); break; } } // if (!isDataOnEeprom) { // load all zeroes to EEPROM? // I gotta check this out!!! } // // reset the timers dataMillis = millis(); startMillis = millis(); lastTipTime = millis() - oneHour; gw.request(2, V_VAR1); delay(250); gw.request(2, V_VAR2); delay(250); Serial.print(F("Radio Done")); analogWrite(ledPin, 20); } // void loop() { gw.process(); pulseLED(); // // let's constantly check to see if the rain in the past rainWindow hours is greater than rainSensorThreshold // int measure = 0; // Check to see if we need to show sensor tripped in this block for (int i = 0; i < rainWindow; i++) { measure += rainBucket [i]; } state = (measure >= rainSensorThreshold); if (state != oldState) { gw.send(msgTripped.set(state), false); delay(250); EEPROM.write(STATE_LOCATION, state); oldState = state; } // // Now lets reset the rainRate to zero if no tips in the last hour // if (millis() - lastTipTime >= oneHour)// timeout for rain rate { if (rainRate != 0) { rainRate = 0; gw.send(msgRainRate.set(0)); delay(250); } } // if tipped,send updates to VERA // if (updateVera) { gw.send(msgRainRate.set(rainRate)); delay(250); updateVera = false; } /* if ( (millis() - dataMillis) >= serialInterval)//Comment back in this block to enable Serial prints { for (int i = 24; i <= 120; i = i + 24) { updateSerialData(i); } dataMillis = millis(); } */ if (tipBuffer > 0) { Serial.println(F("Sensor Tipped")); rainBucket [0] ++; // if (rainBucket [0] > 253) rainBucket[0] = 253; // odd occurance but prevent overflow int dayTotal = 0; for (int i = 0; i < 24; i++) { dayTotal = dayTotal + rainBucket [i]; } gw.send(msgRain.set(dayTotal)); delay(250); unsigned long tipDelay = millis() - lastTipTime; if (tipDelay <= oneHour) { rainRate = ((oneHour) / tipDelay); gw.send(msgRainRate.set(rainRate)); Serial.print(F("RainRate= ")); Serial.println(rainRate); } lastTipTime = millis(); updateVera = true; tipBuffer--; } if (millis() - startMillis >= oneHour) { Serial.println("one hour elapsed"); //EEPROM write last value EEPROM.write(eepromIndex, rainBucket[0]); eepromIndex++; if (eepromIndex > EEPROM_BUFFER + BUFFER_LENGTH) eepromIndex = EEPROM_BUFFER; Serial.println(eepromIndex); EEPROM.write(eepromIndex, 0xFF); // for (int i = BUFFER_LENGTH - 1; i >= 0; i--)//cascade an hour of values { rainBucket [i + 1] = rainBucket [i]; } rainBucket[0] = 0; gw.send(msgRain.set(tipCounter(24)));// send 24hr tips delay(250); transmitRainData(); // send all of the 5 buckets of data to controller startMillis = millis(); } } // void sensorTipped() { static unsigned long last_interrupt_time = 0; unsigned long interrupt_time = millis(); if (interrupt_time - last_interrupt_time > 200) { tipBuffer++; } last_interrupt_time = interrupt_time; } // int tipCounter(int hours) { int tipCount = 0; for ( int i = 0; i < hours; i++) { tipCount = tipCount + rainBucket [i]; } return tipCount; } // void updateSerialData(int x) { Serial.print(F("Tips last ")); Serial.print(x); Serial.print(F("hours: ")); int tipCount = 0; for (int i = 0; i < x; i++) { tipCount = tipCount + rainBucket [i]; } Serial.println(tipCount); } void loadRainArray(int value) { for (int i = 0; i < BUFFER_LENGTH - 1; i++) { value--; Serial.println(value); if (value < EEPROM_BUFFER) { value = EEPROM_BUFFER + BUFFER_LENGTH; } byte rainValue = EEPROM.read(value); Serial.println(rainValue); if (rainValue < 255) { rainBucket[i] = rainValue; } else { rainBucket [i] = 0; } } } void transmitRainData(void) { int rainUpdateTotal = 0; for (int i = 0; i < 24; i++) { rainUpdateTotal += rainBucket[i]; } gw.send(msgRainVAR1.set(rainUpdateTotal)); delay(250); for (int i = 24; i < 48; i++) { rainUpdateTotal += rainBucket[i]; } gw.send(msgRainVAR2.set(rainUpdateTotal)); delay(250); for (int i = 48; i < 72; i++) { rainUpdateTotal += rainBucket[i]; } gw.send(msgRainVAR3.set(rainUpdateTotal)); delay(250); for (int i = 72; i < 96; i++) { rainUpdateTotal += rainBucket[i]; } gw.send(msgRainVAR4.set(rainUpdateTotal)); delay(250); for (int i = 96; i < 120; i++) { rainUpdateTotal += rainBucket[i]; } gw.send(msgRainVAR5.set(rainUpdateTotal)); delay(250); } void getVariables(const MyMessage &message) { if (message.sensor == 1) { // nothing to do here } else if (message.sensor == 2) { if (message.type == V_VAR1) { rainWindow = atoi(message.data); if (rainWindow > 120) { rainWindow = 120; } else if (rainWindow < 6) { rainWindow = 6; } if (rainWindow != atoi(message.data)) // if I changed the value back inside the boundries, push that number back to Vera { gw.send(msgTrippedVar1.set(rainWindow)); } } else if (message.type == V_VAR2) { rainSensorThreshold = atoi(message.data); if (rainSensorThreshold > 1000) { rainSensorThreshold = 1000; } else if (rainSensorThreshold < 1) { rainSensorThreshold = 1; } if (rainSensorThreshold != atoi(message.data)) // if I changed the value back inside the boundries, push that number back to Vera { gw.send(msgTrippedVar2.set(rainSensorThreshold)); } } } } void pulseLED(void) { static boolean ledState = true; static unsigned long pulseStart = millis(); if (millis() - pulseStart < 500UL) { digitalWrite(ledPin, !ledState); pulseStart = millis(); } } -
@BulldogLowell Awesome, thank you very much! I know what it's like to lose code that way. I have done the same thing myself...
Yes, I will test this. I'll do my best to get it tested tonight. I'm combining it with some other sensors (light and temp/humidity) so once I get everything merged I'll be able to upload it.
I'll let you know what I find.
Thanks again!
Pete
