  3. CAN bus transport implementation
54 Posts 5 Posters 8.5k Views 8 Watching
  • Adam SlowikA
    Adam SlowikA
    Adam Slowik
    I'm not sure if We understood each other. This line #define CAN_CLOCK MCP_16MHZ should be in Your sketch. You should not modify MyConfig.h.
    Libraries (in general not only MySensors) should not be modified. MyConfig.h is part of library.
    Let's take a look at this code from MyConfig.h
    #ifndef CAN_CLOCK
    #define CAN_CLOCK MCP_8MHZ
    #endif.
    This is if statement. If user didn't defined CAN_CLOCK define it as CAN_CLOCK MCP_8MHZ
    If user defined (in sketch) CAN_CLOCK then do nothing.
    So You can treat MyConfig.h as a set of defaults which can be overridden from sketch.
    I have put all relevant (in My opinion) properties from MCP_CAN_lib into MyConfig.h, so You can override them. If I have missed some relevant property please let Me know.
    • J
      J
      JeeLet
      wrote on last edited by JeeLet
      #39
      Thank you for this clarification.
      (yes translator and my neuron it gives crooked dialog)
      "If I have missed a relevant property, please let me know."
      The list of #define go up for the MySensors sketch .
      ( if I'm not mistaken ?)
      ***for MCP_CAN_lib **************** MyConfig.h line 280 to 315
      CAN_INT // Pin for interrupting an incoming message.
      CAN_CS // Chip selection pin.
      CAN_SPEED // Transmission speed. The allowed values can be found in mcp_can_dfs.h
      CAN_CLOCK // Can clock. Allowed values can be found in mcp_can_dfs.h.
      CAN_BUF_SIZE // Assembly buffer size. As long messages can be split and arrive mixed with other messages, an assembly buffer is needed.
      **** for MyS **************** MyConfig.h line 2492 to 2494
        MY_CAN // Set this to use the CAN wire transport for sensor network communication.
      MY_DEBUG_VERBOSE_CAN // Set this for verbose debugging printouts related to the %CAN driver.
      can be added, for testing and controlling the CAN bus
      #define CAN_MSGAVAIL
      #define CAN_OK
      #define CAN_CTRLERROR
      return of the last 24 hours .
      CAN bus no error, good dialogue, no hole in the measurements and commands.
      the hardware base on the bus is :
      gateway + node 55 + node 56 .
      I will add another node 57.
      I think to go until 6 nodes
      • Adam SlowikA
        Adam SlowikA
        Adam Slowik
        @JeeLet said in CAN bus transport implementation:
        You are right.
        #define CAN_OK
        I'm afraid i do not understand what You want to achieve.
        To clarify things lets look at CAN_CLOCK
        CAN_CLOCK can take values: 0 or 1 or 2 those values are defined in mcp_can_dfs.h:
        #define MCP_20MHZ    0
        #define MCP_16MHZ    1
        #define MCP_8MHZ     2
        If You want to use 8MHz You can
        #define CAN_CLOCK 2
        or
        Both lines will do the same. However #define CAN_CLOCK MCP_8MHZ is recommended approach.
        So CAN_CLOCK can take one of values values (0,1,2), and user (based on used hardware) should pick one of them.
        Next example could be CAN_INT. User should be able to pick which interrupt pin should be used.
        Now when it comes to:
        #define CAN_OK
        in mcp_can_dfs.h We can find a section:
        #define CAN_OK             (0)
        #define CAN_FAILINIT       (1)
        #define CAN_FAILTX         (2)
        #define CAN_MSGAVAIL       (3)
        #define CAN_NOMSG          (4)
        #define CAN_CTRLERROR      (5)
        #define CAN_GETTXBFTIMEOUT (6)
        #define CAN_SENDMSGTIMEOUT (7)
        #define CAN_FAIL       (0xff)
        This We can treat as return code dictionary.
        For example when I initialize CAN in MyTransportCAN.cpp:
        	if (CAN0.begin(MCP_STDEXT, CAN_SPEED, CAN_CLOCK) != CAN_OK) {
        		canInitialized = false;
        		return false;
        	canInitialized = true;
        I could write if (CAN0.begin(MCP_STDEXT, CAN_SPEED, CAN_CLOCK) != 0 but recommended approach is to use dictionary key (CAN_OK) instead of dictionary value (0)
        Now overriding CAN_OK to 777 instead of 0 is possible, but it won't cause nothing but chaos. If We do that the function CAN0.begin(MCP_STDEXT, CAN_SPEED, CAN_CLOCK) would return 777 instead of 0. I don't think user should do that.
        Code from mcp_can.cpp:
        INT8U MCP_CAN::checkReceive(void)
        	INT8U res;
        	res = mcp2515_readStatus();                                         /* RXnIF in Bit 1 and 0         */
        	if (res & MCP_STAT_RXIF_MASK) {
        		return CAN_MSGAVAIL;
        		return CAN_NOMSG;
        This function returns dictionary key CAN_MSGAVAIL or CAN_NOMSG but if We could stop in debug We would see 3 or 4
        Again overriding CAN_MSGAVAIL to let's say 42 won't give user nothing.
        I keep My fingers crossed. Great job.
        • J
          J
          JeeLet
          #41
          The original idea was: how to check the status of the CAN bus.
          . is there any dialogue ?
          . are there any messages?
          of course this can be done with MySensors.
          But to get as close as possible to the communication channel (the CAN bus) I thought it was easy to do.
          this is by reading the post of bricoleau here
          text french
          that the idea came to me.
          • on the arduino have a blinking led to say that the CAN bus is out of order (but we forget, it loads the program unnecessarily)
          and also because you suggested it to me
          yes we have to beat the iron when it is hot, and my time available for the computer will soon be reduced (purchase and work of a house)
          I appreciate very much your explanatory note, thank you
          I activated the 16Mhz in the sketch, and put it back in the library
            #define MY_NODE_ID 57          /*Node en ID static*/
            #define MY_CAN
          Adam SlowikA 1 Reply Last reply
          • J JeeLet
            text french
              #define MY_CAN
            Adam SlowikA
            Adam SlowikA
            Adam Slowik
            That is something I can work with. I will check if used library provides some function to check bus status.
            I totally understand.
            • Adam SlowikA
              Adam SlowikA
              Adam Slowik
              So library gives us 3 interesting functions:
              INT8U checkError(void);
              INT8U errorCountRX(void);
              INT8U errorCountTX(void);
              Full description can be found in library source code and in documentation chapter 6:
              https://ww1.microchip.com/downloads/en/DeviceDoc/MCP2515-Stand-Alone-CAN-Controller-with-SPI-20001801J.pdf
              long story short:
              1. INT8U checkError(void); returns:
                -CAN_CTRLERROR when things are bad or very bad
                -CAN_OK when things are ok or not so bad (error counters below 96)
                I would like to chage implementation of sanity check to something like this:
              bool transportSanityCheck(void)
              	return (CAN0.getError()==CAN_OK)
              It won't blink diodes in case of communication problems, but will provide some feedback about communication to MySensors library.
              2)INT8U errorCountRX(void); return error counter for received messages. AFAIK this counter is incremented when error occurs and decremented when message is received. I'm not a 'radio guy' but i think this could be returned as int16_t transportGetReceivingSNR(void) or int16_t transportGetReceivingRSSI(void). I know SNR and RSSI are radio related parameters, but perhaps We could bend the border here. Maybe some 'radio guy' could say something about this idea?
              3)INT8U errorCountTX(void); same situation as with #2. 'Radio guy' opinion would by great.
              Again ideas #2 and #3 are not solving problems, but providing feedback to MySensors.
              Are My ideas ok, or do they do not pass sanityCheck() :)
              • J
                J
                JeeLet
                #44
                "Are my ideas good" .. yes yes c'est tout bon
                "It will not flash the diodes in case of communication problems" ... it's not a problem, Christmas is still far :)
                But yes a counter that increments is a good thing.
                what do you want me to test ????
                The "radio guy" opinion would be great.
                ((I'll look for possible help ). )
                Re-Edit
                hal/transport/CAN/MyTransportCAN.cpp
                	// not implemented yet
                	return true;
                :stuck_out_tongue_winking_eye:
                Edit
                I searched the web, and using SNR RSSI with the CAN bus is a dead end.
                https://www.thethingsnetwork.org/docs/lorawan/rssi-and-snr/
                V 1 Reply Last reply
                • J
                  J
                  JeeLet
                  #45
                  .. bip bip
                  • Adam SlowikA
                    Adam SlowikA
                    Adam Slowik
                    Are You still have an issue when MY_DEBUG is deactivated? Have You tried to add delay as is was suggested in one of the threads You found?
                    • J
                      J
                      JeeLet
                      sorry for the alert.
                      it was an error in the gateway sketch
                      a ... #define MY_WITH_LEDS_BLINKING_INVERSE... duplicate, is misplaced
                      désolé
                      go to a fourth node
                      (Gw0 - Nodes 55 56 57 58 )
                      • J
                        J
                        JeeLet
                        #48
                        hello
                        did you find some time to add the CAN bus error feedback?
                        the 2 and 3 is good, enough :dancer:
                        and give me the procedure for the sketch :)
                        • V
                          V
                          virtualmkr
                          @Adam-Slowik, @JeeLet
                          Ok, I will give CAN-Bus a try. This is my test setup:
                          I will use the demo sketches from Adam's fork. Let you know how it works for me.
                          • J JeeLet
                            Re-Edit
                            	return true;
                            Edit
                            V
                            V
                            virtualmkr
                            @JeeLet
                            I'm not a "radio guy", but I think this code change looks fine. When sanity check fails then MySensors core calls transportInit() which would try to re-initialise the MCP2515 module.
                            In my setup with only 2 CAN modules I'm afraid this will always return CAN_OK. So no idea how to check this. May be unplug the both CAN wires?
                            • V
                              V
                              virtualmkr
                              @Adam-Slowik, @JeeLet Ok, with the both sketches it works with some limitations.
                              Nice work so far - thank you for contributing!
                              I have done some modifications in the CAN transport files.
                              @Adam-Slowik I would like to create a PR in your forked repo. Then we can discuss the code changes in GitHub. Would that be Ok for you - do you have time for this?
                              One limitation I found so far are long MyMessages. They can be up to 32 byte - which results in up to 4 CAN-Bus sub telegrams. When I send 32 byte message I observed the sub telegrams do not always arrive in send order in MyTransportCAN.cpp like this:
                              19916 CAN:RCV:CANH=2202010368,ID=3,TOTAL=4,CURR=0,TO=3,FROM=0
                              19921 CAN:RCV:LN=8,DTA0=0,DTA1=0,DTA2=3,DTA3=202,DTA4=9,DTA5=2,DTA6=0,DTA7=49
                              19929 CAN:RCV:SLOT=0,PART=1
                              19932 CAN:RCV:CANH=2202075904,ID=3,TOTAL=4,CURR=1,TO=3,FROM=0
                              19937 CAN:RCV:LN=8,DTA0=50,DTA1=51,DTA2=52,DTA3=53,DTA4=54,DTA5=55,DTA6=56,DTA7=57
                              19945 CAN:RCV:SLOT=0,PART=2
                              19947 CAN:RCV:CANH=2202206976,ID=3,TOTAL=4,CURR=3,TO=3,FROM=0
                              19953 CAN:RCV:LN=8,DTA0=56,DTA1=57,DTA2=48,DTA3=49,DTA4=50,DTA5=51,DTA6=52,DTA7=53
                              19960 !CAN:RCV:proper slot not found
                              19964 CAN:RCV:CANH=2202141440,ID=3,TOTAL=4,CURR=2,TO=3,FROM=0
                              19970 CAN:RCV:LN=8,DTA0=48,DTA1=49,DTA2=50,DTA3=51,DTA4=52,DTA5=53,DTA6=54,DTA7=55
                              19978 CAN:RCV:SLOT=0,PART=3
                              Sub telegram 3 arrives before 2.
                              I'm afraid the function _findCanPacketSlot() needs an update to handle this.
                              @Adam-Slowik Do you see a chance for you to update the logic next time?
                              Other limitation I see is the limited CAN telegram buffer of 3 packets in the MCP2515 module. I'm afraid for reliable operation with MySensors a change from polling to interrupt mode is required.
                              But this can be done later, after the fix for the PacketSlot logic.
                              • V
                                V
                                virtualmkr
                                In logic analyser it looks like this:
                                Upper 4 channels are from node, lower ones are from gateway.
                                Close up from gateway send (4 packets):
                                • Adam SlowikA
                                  Adam SlowikA
                                  Adam Slowik
                                  @virtualmkr said in CAN bus transport implementation:
                                  Ok. I'll update code.
                                  Sure. Make PR. I'll try to review it within 48h.
                                  I think this two issues are linked. Now packets are sent in correct order (could You verify it?). If packets are sent in short periods We should use interrupt to keep MCP2515 buffers empty. When We fail to keep buffers empty (due to polling mechanism) We receive sub telegrams in mixed order. This theory could be true if MCP2515 buffers are implemented as LIFO. I'll look into documentation to figure it out.
                                  Anyway both fixes are worth to implement. I'll try to do this over weekend.
                                  • J
                                    J
                                    JeeLet
                                    Hello
                                    CAN Bus is still functional, and no problem.
                                    a question : is it possible to implement the use of 2 CAN Module on the same Gateway.
                                    2 CAN bus or RS485 + CAN
                                    as for the RS485 in example for a Mega2560 board
                                    MyConfig.h
                                     * Example: @code #define MY_RS485_HWSERIAL Serial1 @endcode
                                    //#define MY_RS485_HWSERIAL (Serial1)
