  3. get a string out of a payload
getcustomstringstringgetstring
17 Posts 4 Posters 6.7k Views 1 Watching
    Mickey
    wrote on last edited by Mickey
    OK
    Now I having problems with the other way around(x,y,z are one byte numbers) I want to convert 3 values of x,y,z to one string that contain 3 hex numbers
    char *strTag[] = {String(x, HEX)+String(y, HEX)+String(z, HEX)};
    gw.send(msg.set(strTag));
    but I cant work it out...
    *EDIT:
    This workout for me:
    String temp="I";
    temp+=String(x, HEX);
    temp+=String(y, HEX);
    temp+=String(z, HEX);
    temp.toCharArray(strMsg,10);
    gw.send(msg.set(strMsgPtr));
    • M Mickey
      OK
      *EDIT:
      String temp="I";
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @Mickey
      how do you parse this string back out?
      you will not get leading zeroes, so how will you know if where the first second and third digit start and end in your string?
      byte a = 255;
      byte b = 0;
      byte c = 15;
      unsigned long myHex = 0;
        Serial.begin(9600);
        String yourString;
        yourString += String(a, HEX);
        yourString += String(b, HEX);
        yourString += String(c, HEX);
        Serial.println("your string looks like this:");
        Serial.println(yourString);
        // try this?
        myHex |= a;
        myHex <<= 8;
        myHex |= b;
        myHex <<= 8;
        myHex |= c;
        String myString = String(myHex, HEX);
        Serial.println("my string looks like this:");
        Serial.println(myString);
        char buffer[6];
        sprintf(buffer,"%02x%02x%02x",a,b,c);
        Serial.println("or even better...");
        Serial.println(buffer);
      output:
      ff0f
      ff000f
      or even better...
      ff000f
      updated
        Mickey
        ok I saw what you did and its way better.
        this is my current code:
        char strMsg[]="";
        char *strMsgPtr = strMsg;
        myHex |= x;
        myHex <<= 8;
        myHex |= y;
        myHex <<= 8;
        myHex |= z;
        myString .toCharArray(strMsg,7;
        right now its doing the job.
        also how do I embed code in the forum?
        ChaoticC BulldogLowellB 2 Replies Last reply
        • M Mickey
          char strMsg[]="";
          myHex |= x;
          myHex <<= 8;
          myHex |= y;
          myHex <<= 8;
          myHex |= z;
          ChaoticC
          ChaoticC
          Chaotic
          @Mickey
          If your talking about codebender code just paste the link
          Example modified cleareeprom sketch that reports when done.
          https://codebender.cc/sketch:89547
            Mickey
            no I meant like above with the black background(didn't know how but I just paste code from arduino IDE and it turn out like this...)
            ChaoticC 1 Reply Last reply
            • M Mickey
              ChaoticC
              ChaoticC
              Chaotic
              @Mickey oh thats easy start the line with 4 spaces and a blank line before it
              like this
              I had assumed you knew about that since you did it in your post before this.
              If you click on the ? when replying it should bring you to a page on markup which tells you how to do that and other things.
                Mickey
                like this
                I must say its turn out to be a great community this site...
                • ChaoticC Chaotic
                  like this
                  BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  or put the whole block of code between 3 backticks like this:
                  (backticks are the apostrophe looking thingy to the left of your 1 on the keyboard!)
                  code posts automagically:
                    for (int i=0;i<512;i++) {
                      EEPROM.write(i, 0xff);
                    Serial.println("Finished");
                  • M Mickey
                    char strMsg[]="";
                    myHex |= x;
                    myHex <<= 8;
                    myHex |= y;
                    myHex <<= 8;
                    myHex |= z;
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    isn't it still dropping a leading zero on the first byte?
                    how about:
                    byte a = 13;
                    byte b = 255;
                    byte c = 16;
                      Serial.begin(9600);
                      char *buffer = "";
                     // gw.send(msg.set(buffer))//<<<<<<<<<<<<<<
                    that should work, and get you the leading zero and is a little simpler code...
                      Mickey
                      @BulldogLowell said:
                      char *buffer = "";
                      this is what I get with this suggested code:
                      acff53ffd2
                      I expected and needed a six char figure here like RGB color code:
                      ffffff
                      000000
                      and this is what I got with my previous code
                      but I getting 10 chars now...(or am I missing some fundamental understanding on hex numbers...?)
                      • M Mickey
                        char *buffer = "";
                        acff53ffd2
                        ffffff
                        000000
                        BulldogLowellB
                        BulldogLowellB
                        BulldogLowell
                        @Mickey
                        are you using an Arduino to break up the message on the other end? In other words, to what are you sending this message? It may be easier to send it as an Unsigned Long, and use the bitshift method you used, as long as you can decode it on the receiving side.
                        Can you decode an UL where the message is going?
                          Mickey
                          I'm writing a sketch that use a MEMS sensor (ADXL345 in this case but it will be a start point for more sensors like this like MPU6050).
                          this chip can raise an interrupt when: inactivity sensed,activity sensed,tap,double tap,free fall.
                          so the reading of the XYZ values with a leading char that represent the event sensed (I for inactivity and etc ) are going to a serial MySensor GW and from there to the controller (right now I'm using MYSController).
                          *EDIT
                          I found out that values can be negative so I just sending the decimal numbers as is...
