  3. get a string out of a payload
getcustomstringstringgetstring
17 Posts 4 Posters 6.7k Views 1 Watching
    Mickey
    char strMsg[25];
    char *strMsgPtr = strMsg;
    void incomingMessage(const MyMessage &message)
    if (message.type==V_VAR1)
    // spit to serial
    Serial.print(", New payload: ");
    Serial.println(message.getCustomString(strMsgPtr));
    hekH 1 Reply Last reply
    • M Mickey
      char strMsg[25];
      // spit to serial
      @Mickey
      Are you getting compile error using:
      Serial.println(message.getString(strMsg));
        Mickey
        No
        with this method it compile ...
        thanks
          Mickey
          wrote on last edited by Mickey
          OK
          Now I having problems with the other way around(x,y,z are one byte numbers) I want to convert 3 values of x,y,z to one string that contain 3 hex numbers
          char *strTag[] = {String(x, HEX)+String(y, HEX)+String(z, HEX)};
          gw.send(msg.set(strTag));
          but I cant work it out...
          *EDIT:
          This workout for me:
          String temp="I";
          temp+=String(x, HEX);
          temp+=String(y, HEX);
          temp+=String(z, HEX);
          temp.toCharArray(strMsg,10);
          gw.send(msg.set(strMsgPtr));
          • M Mickey
            OK
            *EDIT:
            String temp="I";
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            @Mickey
            how do you parse this string back out?
            you will not get leading zeroes, so how will you know if where the first second and third digit start and end in your string?
            byte a = 255;
            byte b = 0;
            byte c = 15;
            unsigned long myHex = 0;
              Serial.begin(9600);
              String yourString;
              yourString += String(a, HEX);
              yourString += String(b, HEX);
              yourString += String(c, HEX);
              Serial.println("your string looks like this:");
              Serial.println(yourString);
              // try this?
              myHex |= a;
              myHex <<= 8;
              myHex |= b;
              myHex <<= 8;
              myHex |= c;
              String myString = String(myHex, HEX);
              Serial.println("my string looks like this:");
              Serial.println(myString);
              char buffer[6];
              sprintf(buffer,"%02x%02x%02x",a,b,c);
              Serial.println("or even better...");
              Serial.println(buffer);
            output:
            ff0f
            ff000f
            or even better...
            ff000f
            updated
              Mickey
              ok I saw what you did and its way better.
              this is my current code:
              char strMsg[]="";
              myHex |= x;
              myHex <<= 8;
              myHex |= y;
              myHex <<= 8;
              myHex |= z;
              myString .toCharArray(strMsg,7;
              right now its doing the job.
              also how do I embed code in the forum?
              ChaoticC BulldogLowellB 2 Replies Last reply
              • M Mickey
                char strMsg[]="";
                myHex |= x;
                myHex <<= 8;
                myHex |= y;
                myHex <<= 8;
                myHex |= z;
                ChaoticC
                ChaoticC
                Chaotic
                @Mickey
                If your talking about codebender code just paste the link
                Example modified cleareeprom sketch that reports when done.
                https://codebender.cc/sketch:89547
                  Mickey
                  no I meant like above with the black background(didn't know how but I just paste code from arduino IDE and it turn out like this...)
                  ChaoticC 1 Reply Last reply
                  • M Mickey
                    ChaoticC
                    ChaoticC
                    Chaotic
                    @Mickey oh thats easy start the line with 4 spaces and a blank line before it
                    like this
                    I had assumed you knew about that since you did it in your post before this.
                    If you click on the ? when replying it should bring you to a page on markup which tells you how to do that and other things.
                      Mickey
                      like this
                      I must say its turn out to be a great community this site...
                      • ChaoticC Chaotic
                        like this
                        BulldogLowellB
                        BulldogLowellB
                        BulldogLowell
                        or put the whole block of code between 3 backticks like this:
                        (backticks are the apostrophe looking thingy to the left of your 1 on the keyboard!)
                        code posts automagically:
                          for (int i=0;i<512;i++) {
                            EEPROM.write(i, 0xff);
                          Serial.println("Finished");
                        • M Mickey
                          char strMsg[]="";
                          myHex |= x;
                          myHex <<= 8;
                          myHex |= y;
                          myHex <<= 8;
                          myHex |= z;
                          BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          isn't it still dropping a leading zero on the first byte?
                          how about:
                          byte a = 13;
                          byte b = 255;
                          byte c = 16;
                            Serial.begin(9600);
                            char *buffer = "";
                           // gw.send(msg.set(buffer))//<<<<<<<<<<<<<<
                          that should work, and get you the leading zero and is a little simpler code...
                            Mickey
                            @BulldogLowell said:
                            char *buffer = "";
                            this is what I get with this suggested code:
                            acff53ffd2
                            I expected and needed a six char figure here like RGB color code:
                            ffffff
                            000000
                            and this is what I got with my previous code
                            but I getting 10 chars now...(or am I missing some fundamental understanding on hex numbers...?)
                            • M Mickey
                              char *buffer = "";
                              acff53ffd2
                              ffffff
                              000000
                              BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              @Mickey
                              are you using an Arduino to break up the message on the other end? In other words, to what are you sending this message? It may be easier to send it as an Unsigned Long, and use the bitshift method you used, as long as you can decode it on the receiving side.
                              Can you decode an UL where the message is going?
                                Mickey
                                I'm writing a sketch that use a MEMS sensor (ADXL345 in this case but it will be a start point for more sensors like this like MPU6050).
                                this chip can raise an interrupt when: inactivity sensed,activity sensed,tap,double tap,free fall.
                                so the reading of the XYZ values with a leading char that represent the event sensed (I for inactivity and etc ) are going to a serial MySensor GW and from there to the controller (right now I'm using MYSController).
                                *EDIT
                                I found out that values can be negative so I just sending the decimal numbers as is...
