  3. 💬 backup power auto-switch circuit
powermodule
7 Posts 3 Posters 1.8k Views 2 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/32979/backup-power-auto-switch-circuit
      Sounds interesting. Please post the schematic as well.
      Abd AlHaleemA 2 Replies Last reply
        Abd AlHaleemA
        Abd AlHaleemA
        Abd AlHaleem
        @NeverDie of course, I'll add it now
          Abd AlHaleemA
          Abd AlHaleemA
          Abd AlHaleem
          @NeverDie I tried to add it, but it seems "kicad_sch" extension isn't supported now
          • Abd AlHaleemA Abd AlHaleem
            @Abd-AlHaleem You have three options:
            1. Print it as a .pdf file. You can upload those; or,
            2. Compress the kicad file as a .rar file, but not a .zip file. That will also upload.
            3. Best option: Archive the kicad project (as a .zip file by default), and then compress that as a .rar file. That way you can upload the entire kicad project without it being rejected.
              Thanks for posting the schematic. Just an observation, not a criticism: it looks as though the output voltage will sag down to the level of the logic-LOW threshold of your NOR gate before the battery voltage takes over. Depending on what the load is, maybe that's a non-issue. If, on the other hand, it turns out to be an issue, you could perhaps use a voltage divider to trigger the switch-over with less of a voltage drop seen at the load. In either case, I like the simplicity of the circuit. :+1:
              Abd AlHaleemA 1 Reply Last reply
                Abd AlHaleemA
                Abd AlHaleemA
                Abd AlHaleem
                Based on my simulation and testing it's not a problem, yet I can look at it and check it's transient response.
                12.5k
