  3. No LAN connection ESP8266 gateway
esp8266
21 Posts 4 Posters 3.9k Views 4 Watching
    @Bramz I am not an expert, but I can verify your findings. This looks like a serious bug in the MySensors code.
    OSD
    B
    B
    Bramz
    @OldSurferDude Judging by the many different ways I tried to upload a functional gateway sketch I am beginning to suspect the same. Question is: where did things start to change from my earlier attempts two years ago?
    OldSurferDudeO mfalkviddM 2 Replies Last reply
    • B Bramz
      OldSurferDudeO
      OldSurferDudeO
      OldSurferDude
      @Bramz I'm fairly new to MySensors. As it is supported by volunteers, like you and me and @mfalkvidd, some code doesn't get updated when there's a version change, the code update often happens when someone notices that the code needs to be updated. I suspect that this is the case here.
      I'd be glad to help out, but not knowing the in's and out's of things, I can pretty much only verify code for which I have hardware.
      OSD
      B 1 Reply Last reply
      • B Bramz
        @Bramz see section #1:1 in https://forum.mysensors.org/topic/666/read-this-first-it-could-save-you-a-lot-of-time on how to enable debug logging. After that, please post the serial output here.
          B
          B
          Bramz
          @mfalkvidd Thanks for your suggestion. I was under the impression that the com port could only be used for one thing at a time: either flashing or monitoring, but apparently this combination is possible. Anyway, I followed the instruction but unfortunately the serial monitor remains completely blank.
          • electrikE
            electrikE
            electrik
            Did you try an earlier ESP 8266 framework version? Perhaps version 3 or even lower?
            • electrikE electrik
              @electrik version 3 will not work. 2.6.2 is required.
                B
                B
                Bramz
                @mfalkvidd I am not entirely sure what is meant by an ESP framework, but if it refers to the URL which is given in the <Preferences> section of the Arduino IDE under <More Board manager URL's> than this might be the problem.
                I am now using https://arduino.esp8266.com/stable/package_esp8266com_index.json which leads to a version 3.0.2.
                What URL should I use for a version 2.6.2 ? Than I will give that a try.
                • B Bramz
                  @Bramz yes. Here:
                  • B
                    B
                    Bramz
                    Blush, blush. Thanks.
                      @Bramz yes. Here:
                      B
                      B
                      Bramz
                      @mfalkvidd @electrik Yes! This did the trick for me. Thanks for your guidance.
                      Probably the instruction to use a version not higher than 2.6.2 has been given somewhere/sometime and I have overlooked it.
                      The serial monitor remained blank during upload, but when I select 9600 baud and press the reset-button it gives what I think is a healthy response:
                      ⸮⸮5R⸮⸮64 MCO:BGN:INIT GW,CP=RNNGE---,FQ=80,REL=255,VER=2.3.2
                      121 TSF:LRT:OK
                      137 TSM:INIT
                      151 TSF:WUR:MS=0
                      174 TSM:INIT:TSP OK
                      scandone
                      state: 0 -> 2 (b0)
                      state: 2 -> 3 (0)
                      state: 3 -> 5 (10)
                      add 0
                      aid 3
                      cnt
                      connected with XXX, channel 6
                      dhcp client start...
                      ip:192.168.178.46,mask:255.255.255.0,gw:192.168.178.1
                      403 TSM:INIT:GW MODE
                      426 TSM:READY:ID=0,PAR=0,DIS=0
                      458 MCO:REG:NOT NEEDED
                      ip:192.168.178.4,mask:255.255.255.0,gw:192.168.178.1
                      1544 GWT:TIN:CONNECTING...
                      2573 GWT:TIN:CONNECTING...
                      scandone
                      3601 GWT:TIN:CONNECTING...
                      3629 GWT:TIN:IP: 192.168.178.4
                      3662 MCO:BGN:STP
                      3680 MCO:BGN:INIT OK,TSP=1
                      3708 TSM:READY:NWD REQ
                      3735 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                      pm open,type:2 0
                      And sure enough, the LAN has detected an ESP device at 192.168.178.4 now.
                      Secretly, I was hoping that connection to Domoticz would now also work but unfortunately I keep on getting the persistent message:
                      2022-11-25 11:54:58.598 Error: MySensorsGateway: Can not connect to: 192.168.178.4:5003
                      However, that probably needs to be adressed in a different topic.
                        OSD
                        B
                        B
                        Bramz
                        @OldSurferDude Hope this worked for you too.
                        • OldSurferDudeO
                          OldSurferDudeO
                          OldSurferDude
                          @mfalkvidd @Bramz @electrik
                          When I saw 2.6.2 I was thinking the MySensors Library (2.3.2)! It never occurred to me it was the board manager.
                          So, yes! it works for me. :)
                          I just checked to see if Domoticz has an MQTT interface and it appears that it does. @Bramz, look into that. Once you have that, then it may be easy to connect other devices, like Tasmota devices, to Domoticz. MQTT requires an always-on computer connected to your network.
                          I have a headless (needs dummy monitor plug or 3x 75Ω resistors to boot), refurbished computer on which I run Linux OS, then both MQTT and Home Assistant running in Virtual Box.
                          Thanks everyone!
                          OSD
                            Thanks everyone!
                            OSD
                            B
                            B
                            Bramz
                            Still, there seems to be 'someting rotten in the state of Network' where my LAN is concerned. Although the Arduino serial monitor says:
                            13:03:55.821 -> connected with XXX, channel 6
                            13:03:55.868 -> ip:192.168.178.4,mask:255.255.255.0,gw:192.168.178.1
                            13:03:55.915 -> ip:192.168.178.4,mask:255.255.255.0,gw:192.168.178.1
                            13:04:04.826 -> pm open,type:2 0
                            when I ping the IP-address I get:
                            Pinging 192.168.178.4 with 32 bytes of data:
                            Request timed out.
                            Request timed out.
                            Request timed out.
                            Request timed out.
                            Ping statistics for 192.168.178.4:
                                Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
                            When I use the tool 'Wireless Network Watcher' I do see that a device is connected at 192.168.178.4 with the correct MAC address.
                            However, when I look at the management page of my FritzBox 7490 modem/router no device is mentioned at 192.168.178.4.
                            I remain at a loss here.
