  3. No LAN connection ESP8266 gateway
esp8266
21 Posts 4 Posters 3.9k Views 4 Watching
  • B Bramz
    @OldSurferDude Judging by the many different ways I tried to upload a functional gateway sketch I am beginning to suspect the same. Question is: where did things start to change from my earlier attempts two years ago?
    OldSurferDudeO
    OldSurferDudeO
    OldSurferDude
    @Bramz I'm fairly new to MySensors. As it is supported by volunteers, like you and me and @mfalkvidd, some code doesn't get updated when there's a version change, the code update often happens when someone notices that the code needs to be updated. I suspect that this is the case here.
    I'd be glad to help out, but not knowing the in's and out's of things, I can pretty much only verify code for which I have hardware.
    OSD
    B 1 Reply Last reply
    • B Bramz
      @Bramz see section #1:1 in https://forum.mysensors.org/topic/666/read-this-first-it-could-save-you-a-lot-of-time on how to enable debug logging. After that, please post the serial output here.
        B
        B
        Bramz
        @mfalkvidd Thanks for your suggestion. I was under the impression that the com port could only be used for one thing at a time: either flashing or monitoring, but apparently this combination is possible. Anyway, I followed the instruction but unfortunately the serial monitor remains completely blank.
        • electrikE
          electrikE
          electrik
          Did you try an earlier ESP 8266 framework version? Perhaps version 3 or even lower?
          • electrikE electrik
            @electrik version 3 will not work. 2.6.2 is required.
              B
              B
              Bramz
              @mfalkvidd I am not entirely sure what is meant by an ESP framework, but if it refers to the URL which is given in the <Preferences> section of the Arduino IDE under <More Board manager URL's> than this might be the problem.
              I am now using https://arduino.esp8266.com/stable/package_esp8266com_index.json which leads to a version 3.0.2.
              What URL should I use for a version 2.6.2 ? Than I will give that a try.
              • B Bramz
                @Bramz yes. Here:
                • B
                  B
                  Bramz
                  Blush, blush. Thanks.
                    @Bramz yes. Here:
                    B
                    B
                    Bramz
                    @mfalkvidd @electrik Yes! This did the trick for me. Thanks for your guidance.
                    Probably the instruction to use a version not higher than 2.6.2 has been given somewhere/sometime and I have overlooked it.
                    The serial monitor remained blank during upload, but when I select 9600 baud and press the reset-button it gives what I think is a healthy response:
                    ⸮⸮5R⸮⸮64 MCO:BGN:INIT GW,CP=RNNGE---,FQ=80,REL=255,VER=2.3.2
                    121 TSF:LRT:OK
                    137 TSM:INIT
                    151 TSF:WUR:MS=0
                    174 TSM:INIT:TSP OK
                    scandone
                    state: 0 -> 2 (b0)
                    state: 2 -> 3 (0)
                    state: 3 -> 5 (10)
                    add 0
                    aid 3
                    cnt
                    connected with XXX, channel 6
                    dhcp client start...
                    ip:192.168.178.46,mask:255.255.255.0,gw:192.168.178.1
                    403 TSM:INIT:GW MODE
                    426 TSM:READY:ID=0,PAR=0,DIS=0
                    458 MCO:REG:NOT NEEDED
                    ip:192.168.178.4,mask:255.255.255.0,gw:192.168.178.1
                    1544 GWT:TIN:CONNECTING...
                    2573 GWT:TIN:CONNECTING...
                    scandone
                    3601 GWT:TIN:CONNECTING...
                    3629 GWT:TIN:IP: 192.168.178.4
                    3662 MCO:BGN:STP
                    3680 MCO:BGN:INIT OK,TSP=1
                    3708 TSM:READY:NWD REQ
                    3735 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                    pm open,type:2 0
                    And sure enough, the LAN has detected an ESP device at 192.168.178.4 now.
                    Secretly, I was hoping that connection to Domoticz would now also work but unfortunately I keep on getting the persistent message:
                    2022-11-25 11:54:58.598 Error: MySensorsGateway: Can not connect to: 192.168.178.4:5003
                    However, that probably needs to be adressed in a different topic.
                      OSD
                      B
                      B
                      Bramz
                      @OldSurferDude Hope this worked for you too.
                      • OldSurferDudeO
                        OldSurferDudeO
                        OldSurferDude
                        @mfalkvidd @Bramz @electrik
                        When I saw 2.6.2 I was thinking the MySensors Library (2.3.2)! It never occurred to me it was the board manager.
                        So, yes! it works for me. :)
                        I just checked to see if Domoticz has an MQTT interface and it appears that it does. @Bramz, look into that. Once you have that, then it may be easy to connect other devices, like Tasmota devices, to Domoticz. MQTT requires an always-on computer connected to your network.
                        I have a headless (needs dummy monitor plug or 3x 75Ω resistors to boot), refurbished computer on which I run Linux OS, then both MQTT and Home Assistant running in Virtual Box.
                        Thanks everyone!
                        OSD
                          Thanks everyone!
                          OSD
                          B
                          B
                          Bramz
                          Still, there seems to be 'someting rotten in the state of Network' where my LAN is concerned. Although the Arduino serial monitor says:
                          13:03:55.821 -> connected with XXX, channel 6
                          13:03:55.868 -> ip:192.168.178.4,mask:255.255.255.0,gw:192.168.178.1
                          13:03:55.915 -> ip:192.168.178.4,mask:255.255.255.0,gw:192.168.178.1
                          13:04:04.826 -> pm open,type:2 0
                          when I ping the IP-address I get:
                          Pinging 192.168.178.4 with 32 bytes of data:
                          Request timed out.
                          Request timed out.
                          Request timed out.
                          Request timed out.
                          Ping statistics for 192.168.178.4:
                              Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
                          When I use the tool 'Wireless Network Watcher' I do see that a device is connected at 192.168.178.4 with the correct MAC address.
                          However, when I look at the management page of my FritzBox 7490 modem/router no device is mentioned at 192.168.178.4.
                          I remain at a loss here.
