  3. Home Assistant
  4. Where to change settings?
5 Posts 2 Posters 974 Views 2 Watching
  • E
    E
    eiten
    Hi there!
    Where can I change settings like the IP address or the protocol version in current HA release?
    Thanks, Edi
    OldSurferDudeO 1 Reply Last reply
    • E eiten
      Hi there!
      Thanks, Edi
      OldSurferDudeO
      OldSurferDudeO
      OldSurferDude
      Hi @eiten
      If you just want to find the IP address of HA you can use the command line (in windows)
      ping -4 homeassistant.local
      Find the version of HA is found by: settings-->about
      I use my router to set the IP address of HA.
      At the router you should be able to determine the MAC (media access control) address of HA. This address is six, two digit hex numbers eg E5:16:A7:92:87:BB. If your HA is online, you'll find the MAC associated with the current IP of HA.
      Your router should have a section for DHCP (dynamic host control protocol) When a device requests and IP address from the router, the DHCP routine provides it. The nomenclature seems to be different for every router, but somewhere in the DHCP configuration settings you'll be able to manually associate the MAC to the desired IP address. Save and exit.
      Next time you restart HA it should have the address you specified.
      Note on HA running in virtual machines: The MAC is a random number selected when the virtual machine is created. I believe it may be able to be set when the virtual machine is created. It's very bad to have two devices on the same network with the same MAC.
      I'm not sure one can change the version number. I would not advise doing that.
      • E
        E
        eiten
        Hey @OldSurferDude
        thanks for the info. But I want to know where I can change the IP of the MySensors-TCP-Gateway.
        Regards, Edi
        • E eiten
          Hey @OldSurferDude
          Regards, Edi
          OldSurferDudeO
          OldSurferDudeO
          OldSurferDude
          @eiten I believe the IP of the gateway is the same as the computer on which the gateway is running. In my case, I am running the gateway on an RPi.
          As a side note, that very same program is also a sensor (an array of relays to control my garden irrigation).
          When I think about it, I don't know of any other hardware that can usefully run the TCP gateway. Orange Pi?
          -osd
          • E
            E
            eiten
            Hey @OldSurferDude
            I think we have a missunderstanding here. I have my gateways running on ESP32. When I add the integration I can enter the IP in this dialog:
            2024-07-25 21_05_25-Einstellungen – Home Assistant – Mozilla Firefox.png If you want to change the IP number of the gateway (or the MQTT topic or the serial port), there is no way to do this:
