  3. NodeManager
  4. Help needed with connecting MySensors node to Home Assistant
node
2 Posts 2 Posters 1.1k Views 2 Watching
  • V
    V
    vivek101
    Banned
    Hello everyone,
    I'm having some trouble getting a MySensors node to work with Home Assistant. Here are my accomplishments so far:
    • I've built the node using an Arduino Nano and a NRF24L01+ radio module.
    • I've uploaded the MySensors sketch to the Arduino Nano.
    • I've connected the NRF24L01+ module to my Home Assistant server using a USB adapter.
    However I don't see any devices when I try to add the node to Home Assistant. Although I've reset the node and looked through the logs, no issues are showing up. At this point, I'm not sure what else to attempt.
    Has anyone else had a similar issue? Any tips on troubleshooting this problem would be greatly appreciated.
    Thanks in advance!
    • E
      E
      eiten
      Hey vivek101
      how did you connect the NRF24L01 to your home assistant server? Normaly, you connect the nRF to an microcontroller and flash it with a gateway sketch. Then you connect the uC to your server...
      Regards, Edi
