  3. HowTo MY_CORE_ONLY
HowTo MY_CORE_ONLY
3 Posts 2 Posters 1.1k Views 2 Watching
  • F
    F
    Frog
    For a project, i need to separate the initialisation, so i figure out i could use the MY_CORE_ONLY option. I didn't find any documentation about that option, so i use sketch example from the forum but that dont work. Actually i have that :
    #define MY_NODE_ID 123
    #define sensorid 2
    #define MY_RADIO_RFM69
    #define MY_RFM69_NEW_DRIVER
    #define MY_RFM69_FREQUENCY RFM69_433MHZ // Set your frequency here
    #define MY_IS_RFM69HW // Omit if your RFM is not "H"
    #define MY_RFM69_TX_POWER_DBM 5
    #define MY_RFM69_MAX_POWER_LEVEL_DBM 10
    #define MY_RFM69_SPI_SPEED (4*10*1000ul)  // datasheet says 10Mhz max.
    #define MY_RFM69_NETWORKID (38)
    #define MY_PASSIVE_NODE //+248 B
    #define MY_CORE_ONLY
    #define MY_DEBUG_VERBOSE_RFM69
    #define MY_RFM69_IRQ_PIN 2 //DI0#define MY_RFM69_CS_PIN 10 //D8 // NSS. Use MY_RFM69_SPI_CS for older versions (before 2.2.0)
    #include <MySensors-Attiny.h>
    MyMessage msg(sensorid, V_TRIPPED);
      transportInit();
      transportSetAddress(MY_NODE_ID);
    //Pour le premier démarrage, on attend d'avoir un bon voltage avant de continuer
      present(sensorid, S_DOOR, "test", false);
    send(msg.set(hwCPUVoltage()));
    wait(10000);
    And i get that message from serial :
    0 RFM69:INIT
    1 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
    8 RFM69:PTX:LEVEL=5 dBm
    80 !TSF:SND:TNR
    10150 !TSF:SND:TNR
    Someone could give some information about the my_core_only option ? Seems i miss some part.
    Thx in advance :)
    • J
      J
      JeeLet
      no info, nothing found :(
      https://github.com/mysensors/MySensors/search?q=MY_CORE_ONLY
      • F
        F
        Frog
        That's the point, i don't see important part which change with or without my_core_only.
        I think i miss something
